View Full Version : Parts Classifieds
- ***LS1 Throttle Body $45 shipped**
- Dry Ls1 Nitrous Kit $550 shipped(bottle;noid;purge;heaters;microedge;lines)
- 415 CI Forged rotating assembly
- nib ls1 edit
- FS: FAST 90mm intake/ billet rails. Nice!
- FS: 2005 Pontiac GTO Wheels & Tires
- L92/LS3/LS6 Springs, retainers, keepers, seals (lowered price)
- FS: crashed z28 roller,ecu,harness,ttops,walboro 255 more!!!
- Cam Motion Cam
- complete ls2 long block cammed 447/398
- ~ls1 parts~NEED RID OF!!!
- magnaflow exhaust system
- Weld Draglite skinnies with tires - 15x3.5
- D585 Coil Packs and Brackets (very clean)
- FS: (2) Nitto NT555 285/40/18
- F/s Aluminum Fidanza Flywheel LS1 LS6 – Part #198571
- Hankook Snow Tires on 4th Gen Salad Shooters 225/55/R16 Good tread left.
- LS Solid motor mounts
- TTop BAR TRIM PIECES, PAIRS. DISCONTINUED PART.
- QA1's, bmr K member upper and lower A arms, torque arms, lowered prices
- G5X4 Cam SOLD
- Ls1 SLP Black Wing Air Lid (Rare)
- OEM LS6 Intake
- Shaner S3 Ported and Epoxied Throttle Body Ls1
- Radar Detector Passport 8500
- Hooker catback
- 98 firebird FEELER
- Ported Direct port Fast 92 intake
- Rear prokit, lid, crank pulley, turn signals
- LS6 intake with EGR
- KUP RHS block/All Pro LSW-1 LS7/Callies/custom Diamond(boost)/Bullet/Morel/Procharger
- Sold!!!
- headers
- PART OUT! 2001 Pontiac Trans Am 68k Miles
- Fast 92mm with Black Widow
- LS3 valve springs/ trade for MAF
- complete ls2 intake,injectors
- FS- LS1 Shaner S3 T/B
- FAST OEM fuel rail kit for LSXR intake
- LS3 intake, injectors, rails, gaskets..basically new
- 408 hke boost engine complete and 1000up fuel system
- 42lb Flow Matched Injectors for LS1/LS6
- F/s sold!!!!
- ls1 accesories and bolt ons
- Racetronix/Delphi 42# injectors
- Fs - new gen 4 6l iron block
- LS1 block and other parts
- FS: RARE C5 Corvette Magnesium Wheels with Tires
- Stock LS 7.400 pushrods
- SOLD ---Ported throttle body
- F/S 98-02 honeycome tailights and center piece!!!!!!!!!
- LSX454 Valve covers BRAND NEW!!!
- Sold
- Recaro Seats
- Used C6 Z51 Sway Bars
- trade oem SS hood for vfn 3" SS hood
- fs je pistons part #221176 408 stroker low compression
- 98-02 Stock Aluminum Driveshaft
- 2001 ws-6 oem hood!!!!!!!
- SLP LS6 Intake W/EGR
- Weld Magnum 2.0 Rear Wheels
- WS6 bumpers and side skirts
- QA1's PSI springs RAM release bearing 2010/2011 camaro
- FS: Hurst Quarter Stick/Pistol grip shifter
- LT1 stuff (wideband, pcm, opti, etc)
- 98-02 F-Body aluminum driveshaft
- Slp 85mm maf new
- Clarion VZ409 7" Flip Screen
- Complete set of c6 Z06 brake calipers, pads, and rotors
- Precision Vigilante 4,000 rpm stall converter for LS engines
- Mildly ported LT1 cylinder heads w/ new GM hotcam springs
- Brand new Cooks Powerglide w/ Ultra Bell
- spohn tunnel mounted tq arm
- 2002 Trans am "ebony" sun visors
- LS2 HD timing set + install kit
- AFR 205 milled .014s ready to go
- 24" Chrome U2 RIMS ONLY
- Pacesetter LT headers w/ v-bands +
- set of vette tires, 285/35/19 and 245/40/18 Goodyear eagle f1's
- 97-04 corvette oil pan
- SLP Loudmouth, ORY, rear valence
- LS2 pistons and rods...FS
- 60lb injectors fs
- wtt/wts 60lb injectors
- Patriot Stage 3 Heads For Sale
- nos plate kit
- LT1 PARTS, PERFORMANCE-STOCK everything has to go!!
- Innovate wide band o2 and data logger
- F-Body Parts Traction&Cruise, ABS, Air Bag Module, Exh Tips etc
- 1998 ls1/t56 pcm
- Edelbrock/Victors Stepped Ceramic Coated Long Tube Headers
- FS C5rims and tires
- prc 215 cnc heads from texas speed never used
- fast 102mm intake ported by vengeance racing nick williams 102mm tb
- bolt in LCA relocators 10 bolt fbody
- *NEW* SLP CME Exhaust Tips
- Fikse FM13 Wheels
- nitrous express intake
- F-Body ATI Serpentine UD Damper w/HTD 8mm belt drive
- 25% Underdrive Pulley w/Belt
- L92 heads.rocker arms $675 shipped OBO
- Cts-v b&m shifter
- WTT Borlamouth for Slp dual dual
- LT1 Clutch 600hp
- ls1 rods and pistons
- FS: LS1 steering shaft
- wtt/wts FTP 98mm lid
- FS: LS7 Intake takeoff, Almost new
- WTS:NW 90mm throttle body (almost new)
- FS: CompCam for Ls1/2/3 Mild
- 2001 ls1 long block for sell
- T/A Hatch
- Rpm Forged LS7 Boost Long Block!!!
- SLP 85mm MAF Sensor (98-00) and Casper's 3-To-5 Wire Harness *SOLD*
- MTI G1 cam ls1
- nitrous express intake and tb
- FS: New Vic Jr. L92 Setup w/ Rails and 47# Injectors
- ELM237 OBD2 Bluetooth Adaptor
- Set of fully hand ported LS1 heads FS - $550
- WTB: Stock hurst curved stick
- 2012 GM Navigation Disc
- TEA 243 Heads
- Complete LQ4 intake and motor mounts
- New Polly Motor mounts
- a few things.
- PAC SWI-Jack - Steering wheel control with aftermarket headunit!
- 93-02 F-body QA1s & SLP Eibach springs
- Bosch 160lb injectors
- FS- Fast 90 mm tb
- Factory Hurst leather "H" shift knob
- NEW SCT Performance Programmer #3416
- Bunch of Parts- monster clutch-nitrous-rearend-rollbar. . .
- 93-02 camaro k member assembly
- 2004-2005 gm truck programmer
- 498" Big Block Chevy
- modified ls1/t-56 complete ready for swap
- BN Spohn Weld In LCA Relocation Brackets
- Mamofied FAST 92/LS2 TB, Harness, & Ford Red top Injectors
- LS6 Valley Tray
- lq4/4l80e
- COMPLETE lq9/4l80 swap in FLORIDA
- NEW OEM LS6 Longblock (No intake)
- Patriot LQ9 72cc heads Stg3
- FS.C5Z06 Titanium catbacks 2003 (2 sets) in PA.
- D585 Truck Coils
- Vindactor,springs and oil pump
- Vortec 350ci T5 longtube xpipe combo for sale
- FTI Level 4 Powerglide with ATI case
- Stock LS1 K-Member,Upper&Lower A arms, Shocks and Lowerin Springs
- Harland Sharp 1.7 Ratio Rockers
- LQ9 ENGINE COMPLETE 70k miles
- WTB:LS2 Longblock (or short) w/58x reluctor
- DISCOUNTED BRAND NEW MWC Fab 9" Rear & BRAND NEW BOGART D10 RIMS... WITHOUT THE WAIT!
- '04-'06 GTO Billet Products Shifter ***SOLD***
- 741034 - KYB AGX Adjustable Gas Shocks
- 4L60E Goodfellows Transmission
- FS: 6.2L L92 rotating assembly
- big part out 2 complete doors, complete black dash, all accessories
- 99 PCM with holder and auto wiring harness
- 95 Firebird Top Console plate FS - Charcoal / Dk Gray
- Camaro Export Tails
- Complete 6.0 boosted motor
- Pro 5.0 Shifter and Short Stick *SOLD*
- 3" True Duals - Dynomax Bullets/Turndowns
- Polished 317 heads yellow springs never milled low miles
- Efi live v2
- Monsoon headunit and amp w/ pigtail
- WTB T-Top Sunshade (tan)
- moly piston rings, new water pump, rockers
- 241's,s-light,springs,valve cvr spacers,5pt, slp85mm,FTRA,28lb injectors
- Precision 46mm Wastegate
- Sheet metal intake elbow..
- Quick Fuel 850 Pro Series carb with line
- Bilstein and eibach
- Autometer Fuel level gauge
- Ls7 Crankshaft
- 2004-2006 gto exhaust
- Like new oe wheels DD chrome ZR1s
- Siemens Deka 80lb injectors
- CDT Ultra High End w/ Upgrades
- WTB stock f body map, and air temp sensor
- B&M short throw shifter PRICE DROP
- For Sale 418ci LS3
- 241 heads / cam / valve train
- Supercharger manifold L92 Magnacharger
- 243 heads.
- LS7 Titanium Rods
- T56 Son of Tranzilla transmission
- Front and Rear SS Seats Leathher
- Vic jr intake, efi elbow, fuel rails
- LS6 intake and F-body oil pan
- Drive by wire xlink 2.1
- tsunami cam
- sold
- LS3 67cc heads, ls3 intake complete, injectors, rocker and pushrods.
- FS: Like New 72cc LS7-X 6 Bolt Ported Heads by TEA
- 1999 ls1 hypertech power programer
- 95' LT1 5.7L upper radiator hose FREE + the ride
- LS6 block, Wiseco 3.905" pistons, Repaired LS2 manifold
- C6 borla cat-back
- Stock & Aftermarket Parts Clean Up
- LS7 lifters
- LS6 rockers/bolts and .080 7.400 pushrods
- LS6 intake/Ported TB, 853 Heads, SLP Lid, Waterpump, BMR Strut Tower Brace
- Bogarts and hoosiers must sell
- FS: Optima Red Top Battery Like new.
- 2002 LS1 & T56 pullout
- Ls1 short block and parts
- Stock LT1 stuff (price drop)
- cleaning out shop.. underdrive pulley, slp grille, double roller timing chain
- FS - LS1 Parts - growing list
- Exhaust tips, ytips, brand new
- Stock ws.6 shifter
- Procharger P1SC kit
- Kirkey Seat Bolt in Brackets (like new)
- Milodon Oil Pan KIt (Like New) $325 Shippped
- Federal front tires for skinnies
- Moser axles for 10 bolt "Price drop"
- Wtb fbody tb sensors
- CME tips & bends by 6LE - Brand new in box
- Koni Yellow SA Sport Shock, Front Pair
- Cleaning Time W/ Pics (Hi-Res)
- Fast 102,injectors,yella terra rockers,spec clutch,tick master
- WTT: 17 x 9.5 chrome zr1s for chrome c5 z06
- LS1 intake for sale
- 99' F-Body LS1 Intake Manifold with Throttle body w/ sensors
- ls1 headers headman
- 435" Darton Sleeved LS1 w/ C5R heads
- Yella Terra ultralite rockers 1.7 non-adj $310 shipped or trade for cometic .040 + $$
- LS1 Intake bolts
- ls1 parts
- 2002 Z28 partout
- FS: Like New Comp Cam 7997 8.100" 5/16" Push Rods
- Harris speed works microedge controller FS need it gone
- KYTP GT88 header turbo kit (complete) also PTC powerglide and converter
- FS: New Comp Cams Short Travel Race Hydraulic Roller Lifters
- lq4 rods and pistons
- 2000 WS6 m6 part out
- Siemens 55# injectors
- heat sink truck coils
- FS: Complete 5.3 L33 Engine
- Comp 238/240 cam and stock LS2 cam
- Want to buy a lq4
- Clutch Fan and Shroud 2003 Chevy Truck
- Drivers Side Tail Light Lens
- 97 camaro compleat bumper 4 eyed headlights fenders all show condition+aftmrk cowlhod
- ARP Rod Bolts, NOS, Rear Mount Battery Box
- --Nitrous Plate Kit--Nitrous Parts--LS3 Parts--
- SRP Forged -16cc Pistons
- Stock LS1 flywheels
