View Full Version : Parts Classifieds
- Lsx Parts For Sale
- Fmic 28x11x3 in/out
- 02 z06 borla x and stock mid pipes
- lc-1 wideband kit with guage
- fs: midwest converter 3600 for a 4l60e
- Damaged Z06 17" wheels (2)
- GM Performance Parts Flexplate/Crankshaft Adapter/Spacer
- G-Tech Pro RR : Performance Meter For Sale
- Hurst Shift knob (1632004)
- 17x9.5/17x11 Polished TT2s and (2) 315/35/17 GSD3 tires *both items are brand new*
- Beck Sheetmetal intake (upper)
- diabblosport tuner
- WTS/WTT NEW Richmond 3:73 Gears
- Prothane poly motor mounts 98-02/LS1 fbody
- Diamond Forged high compression flat top pistons
- T56 F-body 32-spline triple-cone hybrid - Fits LS blocks
- FS: CCW Drag Pack 17 fronts 16 rears Polished!
- LS4 Exhaust Manifolds, LS1 Intake
- O2 Simulators (SOLD!!!)
- Some LT1 parts
- 1998 camaro ss egr valve/tube
- 1998 camaro ss clutch master cylinder
- Aem injector driver
- FS - MS4 Cam - Magic Stick 4
- Procharger 6 rib 3.2 pulley
- BW S472 Turbo T6 1.10ar Brand new
- 243 ported heads, melling oil pump, bosch 48 lbs injectos
- For Sale: LS6 Intake
- 94 formula part out
- MSD optispark near new
- Moroso Oil pan, Windage tray, Pickup Tube... 425 shipped
- For Sale or Trade: 347" LM7 built for boost
- A&A C5 Vortech YSi kit COMPLETE and take off parts
- GMMG Exhaust, LS1 throttle body and injectors off 2000 TA
- Pacesetter, Hughes, SCT, TCI, 42lb injectors, and lots of good stock stuff.
- 05 GTO LS2-6Speed take out & LT1 6 Speed Swap
- F/S 1 (One) Used Kumho 285/45/17
- LM7 Swap Leftover Parts
- LS3 Beck Sheetmetal intake manifold with fuel rails
- Boxed Lcas and Interior parts 96 trans am
- stock exhaust manifolds and cats
- Prothane Poly Motor Mounts with Clamshells
- nitrous pars and wideband
- Nick Williams 102mm Drive By Wire *SOLD*
- FAST 102mm ported by cartekracing with fast rails/lines *SOLD*
- Nick Williams 90mm Throttle Body
- WTS TX speed true dual system, new slave, LS1-LS2 conversion wiring
- FAST 92 Intake Manifold
- Thunder Racing T-REX V2 cam
- LT4 Air-Gap Intake Manifold (NEW)
- 99/02 pcm for sale
- adjustable rocker arms
- LS1 Fuel Rail - SOLD
- LG G5XX w/ specs
- Ported MAF and Ported Ls6 Oil pump
- 6.0L LQ9 Parts, Intake, Oil Pan, Exhaust Manifolds, Water Pump, Balancer
- 82-92 F Body Chromoly Tubular A Arms
- LS2 Intake Manifold Assembly
- BMR Xtreme Duty Torque Arm chrome moly with drvieshaft loop
- 1999-2002 Camaro Hood, Spoiler and SHifter
- New TSP TV2 113lsa with .650 lift single springs
- Chrome ws6 wheels
- FS: Reconditioned Camaro Headlight Lenses
- Bilstein shocks and struts 98-02 Fbody
- Jesel 1.7 rockers and valve cover spacers
- New Kenne Bell 40 Amp. Boost A Pump BAP SOLD
- ccw classics (drag race wheels)
- PRC 650 springs brand new!
- 00 TA seat Leathers
- parts for sale, 6l80e, truck intake, 1.8 roller rockers ect...
- Lv. 6 RPM Transmssion F/S MUST GO
- C6 rims
- 1998 Camaro v6 partout
- Trick Flow 7.700 Pushrods
- svo 30lb redtops! 1.6 rr
- 2-275/40-17 Goodyear Eagle F1 GS tires
- 6al box and more stuff...
- Hypertech power programmer 3
- TNT F2 Complete Setup
- UMI adjustable lower control arms
- Dart pro1 225cc heads complete 2000 miles
- Sts meth pump,Borla,foglights,ram air box.....OBO
- Corvette Z06 Stock OEM Battery
- Wheels
- Tons of stuff - ls1, ls6, ls2 - Transmissions, heads, rearends...
- BMR TQ Arm
- LS3 intake manifold
- 383 LS1 Shortblock, Built TH400 w/brake & Moser 12 Bolt Tru-Trac
- LSx 408 Stroker Shortblock w/Extra parts
- Corvette LS1 Drive Acessories Complete Setup
- FAST 102mm and Rails NIB
- Brand new 19" axis pentagon wheels $780 shipped!!
- Strano Lowering Springs
- SPEC SC75A Aluminum LS1 Flywheel NIB
- Fresh Gen VI BBC 502
- WTS: LS1 exhaust stuff; gaskets,egr,manifolds,?convertersetc..
- 39mm precision wastegate, intercooler
- Random Parts - Wheels and Suspension
- brake proportioning valve
- 1996 LT1 Motor w/ 70k miles
- Edelbrock Intake elbow for Vic. Jr.
- '93 z28 lt1/4l60 complete
- Ebony Dash Trim...pix added
- C6 Z06 18x9.5" & 18x10.5" w/TIRES 4thgen F-body
- 02 Camaro 28# injectors 40K miles
- z28 hood & spoiler $250 together
- Borla with CME
- LSX short block, K1 crank and rods
- 2002 F Body Steering Shaft
- LS1 Parts and Fox swap headers KOOKS
- FAST 102 / NW 102 Like new ls1/2/6
- Gauging Interest - New In Box - GMPP LSX-LS7 Cylinder Heads
- SOLD: GM Limited Slip Additive (1052358 ) - 2 bottles
- Camaro SS Sway Bar
- 98 ss vert part out...lots of good stuff/hi perf.
- LS1 LSx OEM Starter 52k miles ***SOLD***
- T-REX V2 cam for sale
- 6.0L and T56 For sale
- Stock and performance parts for sale!
- slp loudmouth exhaust and pace y-pipe
- Momo Steering wheel and adapter. Air Bag By-Pass Resistors.
- F/S: TREX V2 cam
- FS: NEW Meziere race pump WP119
- Nitrous Outlet LSX plate kit
- ls1/ls6 SLP underdrive pulley CORVETTE
- Parts For Sale
- 98 pcm, tuned for your needs!
- Thunder Racing Cheater Cam V1
- Gm Accesories 93-02 Camaro Cover (Brand New in Box)
- FS: brand x nitrous kit/HSW 78mm wet nitrous plate/Window RPM Activated Switch
- Custom grind cam brand new
- Like New GM OEM Camaro 16" wheels and tires (set of 4)
- Auto console, Flexplate, Stock Injectors
- LS6 Cam, Push Rods, Springs & Oil Pump
- FS: 1999 firebird LS1 engine and misc. items
- 90mm TB gasket / seal LS2 GM 12576549
- Tci ssf 3500
- LS1 exhaust manifolds.
- Ebony A4 Console In Mint Condition
- stainless ory
- Eibach Drag springs and stock shocks (front) eibach
- wtt: borla w/ ory for TSP axleback
- ARH 2010/2011 ARH headers
- 2010 Camaro Pace Setter Coated 1-3/4" LT's w/catless mids
- 408 Short Block W/parts sheet
- Factory water pump & 160* lingenfelter thermastat
- Monster Stage 3 clutch and PRC Stage 2.5 heads
- New Edelbrock LT4 Air-Gap Intake
- PAC 1218 valve springs and pushrods
- Hooker Maxflow muffler (PICS ADDED)
- Performabuilt 4000 stall
- LT1 T56 front bearing plate
- LT1 T56 bellhousing
- F/S Thunder Racing cam package w/ TR TRuTorq Level 3 cam
- Comp Cams Hi-Tech Rocker Arm Studs
- ARH 1 7/8" Headers NIB
- ls3 Intake Manifold and all Goodies Brand new
- Cam, 92mm plate kit,6L80 yank ss3600
- 93-02 bilstein Coilovers
- T 56 for sale
- Comp cams 26918-16. Still in plastic
- 17" STREET LITES 17x7 with tires 100 miles
- LS3 long block with FAST intake!!!
- OEM CME tip (NEEDS WORK)
- FS: Clutch, Driveshaft, 3.42's, 4.10's, Torque Arm, O2 sensors and Rotors
- Metco Valve Cover Breather
- FTP 98mm
- FS CCW race 17x11.5 and 17x12.5 for C5 corvette
- Y-pipe, wheels, flak vest - help me raise money for headers!
- Patriot .650 dual spring kit
- Stock 16 inch chrome snowflakes must sell
- Performance parts!!!!!!!!!!!
- Selling 30th camaro white powder coated wheels
- SFC's (brand new),cutout,LM1 resonator & tip!!
- Fast 90 tb (SOLD)
- NIB Callies Compstar 6.125 rods Pics added!!
- Phantom Guages for TA center vents!
- NEW LS1 TCI 4L60E Super Street Fighter 3600 Torque Converter
- Loudmouth resonator/muffler*SOLD
- blaster 5 wheels
- SOLD!!!! 85mm Delphi MAF w/ Adaptor
- ** For Sale LS2 05-06 GTO Engine Harness**
- FS: Greddy Profec B spec II boost controller
- LS6 intake 240.00
- D1SC blower pulley! 4.50" 8 rib **PICS ADDED**
- SBC 383 stroker and thirdgen headers and y pipe
- wtt/wts 1998 and up ss hood
- LQ4 w/ L92 heads LSX Parts - *Updated*
- LS1 Stock Balancer
- Rocker Arms
- tubular rear control arms
- M12 and 3.42 diff corvette
- WTB GTO spares
- Jakes 4l80e with TB and Yank PY3400
- PAC Springs LSX/LS7
- Sold
- McLeod RACING bell housing
- ls2 cam, valve springs, ls2 timing set, 700r4
- LS2 Cam + yellow valve springs
- 98-02 LS1 Camaro or Firebird/Trans Am ProCharger HO Intercooled Supercharger
- valve covers
- ls6 valley cover
- LS1 front brake lines w/ new caliper boot
- ls1 rails/inj,vette o2's, slp dual dual
- 4th Gen F-body T-Tops
- feeler complete ls1 carbed engine
- Kicker Comp VT 6.5" replacement sail panel subs
- WTT Complete Built A4 Setup for Complete 6spd Setup
- Parting Out 99 Z28
- OEM c6 Polished wheels CHEAP!
- pre-cut vette fuel rail covers
- 15x8 weld prostars and hoosiers
- Strut Tower Brace
- 92mm fast throttle body
- plug wires, rocker stands, and 6.0 manifolds
- PRC Ls6 heads
- 4.005" pistons, turbo cam, intake manifold, SS clutch line, MAF, fuel rails, balancer
- Camaro CME w/ valence
- FS: LS1 Aluminum Driveshaft, Camaro Tail Lights, 3.42 Rear End 4 Channel
- SAC 3 Piece Wheels 18x10 & 18x12
- Extra Shop Items For Sale
- 427 long block lsx mast heads or just short block!
- LT1 Camaro taillights
- Delphi 85mm MAf w/ 3pin pigtail
- Group purchase on LSX or Firebird logo shot glasses
- Lingenfelter 100MM MAF *SOLD*
- WTT 4L60E stage 2 for T56
- Mixed 3rd Gen and 4th Gen stuff 4SALE
- MBA shift knob
- Gauging interest ls1 engine
- injectors LS1-26,39,42 LS3
- 96 Trans Am LT1 Parts (stock)
- Stock LS1 parts from 01 WS6
- Misc. Stock ls1/lt1 parts
- big cam, PP polished intake manifold, 4l80 deep pan, fbody oil pan/covers, powerbond
- LS1 MAF sensor
- G-Tech Performance Meter
- (New) borg warner turbo s475 & God speed intercooler
- O2 Simulator $40.00 no more SES light
- LS1/LT1 MAF Translator
- WTT: True Dual Setup-Borla XR1's
- LT1 K&N FIPK, Crane Cams HI-6 Ignition, Crane Cams Coil
- PRICE DROPPED! Diablo Tuner
- SuperChips Cortex Programer 2950 All Gas & Diesel GM
- Garage Sale - Exhaust/Nitrous/Suspension/Wheels
- NEW O2 Sensors/Key FOBS/EGR Valve/MAP Sensor
- Billet Specialties street lite wheels
- LT1/Fuel Rail,Plugs,Dipstick,Condenser,Alt,MAF,TB,etc....!! !!
- M6 center console
- Moser 12 bolt
