View Full Version : Parts Classifieds
- Hotchkis Strut Tower Brace
- AFR 210cc heads for LT1/LT4 engine
- Trade: 3.90 Strange 12 bolt rear end for 10 bolt, & WS6 hood
- LS2/Truck 85mm MAF's
- 275/40/17 MT ET Street Radials on OEM c5z Wheels (Fits c6z06/GS/c6 + more)
- Comp cam $290 **SOLD**
- 2 Car stereo Amps
- F/S Meziere WP319U Water Pump
- guaging interest in a complete rear mount turbo system
- 4.10 gears and nitrous bottle
- Stock ls1 parts need to go!!!
- F/s ls3 frc's (pics are up)
- 98-02 Camaro/Firebird Air Intake Kit
- Magnaflow catback new in box!!
- FS...WS9 hood, complete 241 heads w/ Patriot Golds
- -6AN fuel filter and braided lines with ends
- FS: Katech Coil relocate, battery relocate, valve covers, stock k-member, misc
- Lingenfelter LS1, LS6 Heavy Duty Rocker Arm Stands
- BN .040 cometics
- OEM 93-95 Camaro wheels
- 3.42 10bolt 4 channel complete rear
- richmond 3.73's for 12 bolt
- FS: Darton Sleeves 388
- Garage Sale Lots of C5 parts but other things as well!
- LS6 cam, springs and pushrod combo
- 93 LT1 Auto Wire Harness
- AutoMeter Phantom II Digital Wideband Air Fuel Gauge
- Feeler: Full KOOKS True duals and headers
- 42lb Injectors LS3 $165 shipped! (LIKE NEW)
- Glasstek Extended Hood with Dzus fasteners
- Practically new G5x3 cam for sale!
- Slp smooth bellow #23065(SOLD)
- Edelbrock 3847 low profile elbow
- SOLD Ported, Polished and Powder coated Throttle Body
- Ls1/6 msd timing twister
- 10 bolt ta cover with arp stud kit,and 4.10 gears
- ZR1 Replica Wheels with Mickey Thompson ET Street Drag Radials 295/45/17
- 4.56 ring gear, Auborn Pro Series Diff. and a couple random LT1 parts.
- LT1 AC Delete Bracket $30
- Msd 8.5mm wire set ls1/ls6 car(SOLD)
- used eagle rods and srp pistons out of my lt1 383
- New full set gm 12498545 head bolts!!
- 370ci longblock boost setup
- slp lm1 exhaust kit with pacesetter y pipe
- ls1/6 head bolts
- Spohn LSx Solid Motor Mounts
- LT1 Engines and Accesories (PCM, SLP CAI, ETC.)
- TBSS LS2 ASP U/D Pulley
- FS: ls1 block, GMPP intake, stock ls1 rods and pistons, ect!!!!
- NIB Mahle 408" pistons.
- sheet metal elbow and scavenge oil pump
- Brand new OE timing chain and gears
- parting out running/driving 99 TA LS1 383 500+HP T56
- TransAm Fog Lights
- 100mm DBW Throttle Body (Sold)
- T56 from '02 Camaro SS
- Polished Vortech V9 Supercharger
- For Sale Excellent condition B&B stainless 3" Muffler.
- JBA shorty headers
- BNIB Professional Products PowerForce Plus Harmonic Dampner 6.1L HEMI
- 18" Black, Momo Strike Wheels (5x114.3)
- WTS 17" chrome SLP ZR1 wheels
- 6 lunati pro billet LTE9 rods
- NBM SS Rear Valance panel
- bosch 41lb injectors
- LS1 A/C Compressor w/bracket and tensioner. + other stock stuff
- HPTuner's PRO, New, Open box buy, save $75
- LS1 coils and brackets
- FS; LS3 Valvesprings + Retainers Brand New (0 miles)
- FS; LS2 Heads (243) Complete Take-Offs
- Lingenfelter CNC'd Heads (CHEAP!!!) GT2-3 Cam
- Rpm 4l65e
- Magnaflow catback sale - 93-97 and 98-02
- CTS-V DSS 1000HP Race Axles Eliminate Wheelhop
- Autometer procomp 2" boost/vac gauge
- ls6 intake, Fbody oil pan, ALL SOLD
- 98-02 Camaro License Plate Bracket
- Th350, Bmr cross member, 243s, cam
- Passenger side airbag 4th gen Fbody
- Fuse panel
- Fast 90mm intake
- PRC .675" springs w/ titanium retainers(SOLD)
- Polished Gen III Lq4 Crank
- F.S. Yank converter, tci pan , 90mm t-body...
- FS Ford 42lbs injectors like new !
- FS ! Crane Gold adj 1.8 rocker kit
- 98-02 OEM SLP SS Hood - Will ship
- Ptc3200
- msd dis 2 and 4 boxes
- Red SS hood 98-02 $300
- Clearing out garage
- Stock springs, shift knob, tires
- 806 heads in great shape 140 shipped
- 6-rib Procharger Crank Pulley
- 243's w/New Comp 918s and Ti retainers
- 99+ engine harness and PCM
- Pewter SS Spoiler, GM 4.10 Gears, WS6 Springs
- FS: Stock Monsoon CD player and iSimple connector
- Trans am tape player & cd changer
- KYB AGX for FBody ********CHEAP
- Tan interior
- Nitrous Outlet 97-04 Corvette Vehicle Complete plate kit
- Lsx
- Lsx carb conversion with demon carb
- FS: C5 Chrome Billet Door Sill Plate
- Tubular A-Arms (upper and lower)
- Suspension, wheels and cage
- UMI driveshaft loop and LSX swap turbo headers
- 5.3 Oil pan setup.
- LS1 block and components for sale
- C5 DD w/KDW2's
- 2001 f body hub and spindles
- Cold Fusion Nitrous Controller
- FS: Vette LS3 821 Heads with rockers
- Harris Speed Works 90mm Wet Plate
- fbody oil pan, LS1 heads, and other parts
- P1SC Procharger Setup 98-02 F-body
- FS: external walbro 255
- 42lb Injectors LS3 LS7 ls1 ls2
- LS3 Intakes with Fuel rails & Injectors- $300
- Nitrous Bottle and Billet Bottle Bracket
- GI: Nano HSW Nitrous Outlet FJO ect ect
- Perfect stock MAF from 2001 Z28. $45 shipped in US
- Lt4 knock sensor, obd2 pcm and more
- LT1 Ported Heads!
- 243 heads $450
- LS2 Injectors (12569113)
- ws6 speedlines
- Stand alone harness
- Black FRC's trimmed for FAST/ C6 Shift knob
- Nitrous outlet 90mm Plate, SOLD
- FS: LS2 6.0L Aluminum Bare Block
- Strange DA Shocks!!!
- FIC 85# injectors
- mcleod master cylinder
- fast 102
- ws6 hood
- LT1 ported, polished, and powdercoated MAF PIC
- FS NEW C6 Belt Tensioner LS1,LS2,LS3,LS7
- tick performance 6 speed
- 2011 ctsv 6 speed auto trans NEW in crate
- used ECS paxton novi supercharger kit in NY for c5 corvettes
- aeroforce oil/fuel pressure sending unit kit and 5v regulator
- FS: Tick Adjustable Master Cylinder
- LS1 harness
- Eibach Sportlines
- slp long tubes for 98-02 f-body cheap!!!!
- TBSS GTO LS2 parts
- H/C LS1/6 Engine
- Brand New Rollmaster Double Roller Timing Chain (Heat Treated)
- New crate ls6 block
- LS2 Intake Manifold and Fuel Rails
- LS1 Deatschwerks 42lb fuel injectors NEW
- Melling high volume oil pump 10296 NEW
- LS1 Comp Cams trunion rocker arm upgrade kit
- RC Engineering 71# Injectors (80# @ LSX PSI) Fox Body DS Loop, 12mm Lug Locks
- LS1 Exedy hyper single clutch/flywheel NEW
- Custom single plane intake elbow
- LS1 ARP Pro series cracked rod bolts
- Tial 50mm bov {qr}
- (2) Magnaflow/Carsound high flow cats 3" 59929
- BBK/Prosport Underdrive crank pulley
- Hooker y-pipe with dual cut outs
- SLP Loudmouth 4sale
- 2001 camaro SS wheels and tires 4 sale
- Valvespring Shims - comp cam beehive shims
- Crane 7.350 pushrods
- MAC Mid Length Headers, Cats, and Y-Pipe, NEW
- Precision Industries 9.5" 3600, 4x4 4L60e
- Hoosier DOT Drag Radial 255/50/16 MD
- ARH F-body ORY
- for sale LS2 stock intake 4k miles
- Moser 12 bolt
- 2001 M6 camaro part out stuff. Interior/exterior. NICE body stuff too. CHEAP.
- Caspers Electronics 3 wire to 5 wire MAF harness
- 80lb High Impedance Injectors, Brand New
- FS - Solid Lifters / Direct Port Nitrous / Compstar Rods
- FS:9 in rear , wolfe rear suspension
- Hydraulic Roller Lifters
- Axles | Stubs | Diff |
- Nano 4500 PSI Competition Kit w/ Bottle
- Need top and TCS switch plate for TA Vert
- 243 heads + Misc
- ZR1 Wheels Silver Finshed 17x11 Rear 17x9.5 Front
- maf, pushrods and valve springs
- LT1 PCM 95 obd1
- Parting out 98 WS6
- SLP LID - 35th anny floor mats
- Garage Cleaning Lots of Parts
- Interior, wheels, fuel and more
- Pistons, Proflo edelbrock plumbed, nitrous stuff.. fjo controller..etc
- 18" black c5 z06 wheels w/new tires
- Auburn Racer's Diff - new
- NASTY PERFORMANCE LS1 Fabbed Valve Covers
- 9sec 382 combo!
- Pat G Spec'd Turbo Cam 222/226 .599"/.598" 116+4
- stock airlid/upper airbox & power steering pump
- Stock exhaust parts for sale
- FS: LS3 Heads Brand New In Box
- NEW LS3 PORTED Heads / Ls3 Intake complete with fuel rails and injectors
- 382 LS6 All Bore Motor with great parts (Everything Must Go!)
- Hurst Shifter CHEAP
- Stock Ls1 Parts
- LS1 S10 MID LENGTH HEADERS brp
- FS: stock 10 bolt with 3.23s
- 427 turbo pistons
- Patriot Stage 3 CNCd 317s 72cc 2.08/1.60 FS
- 19" HP Lightning EVO wheels and tires
- Nick williams 102mm tb {cable driven}
- 99 firebird parts
- Bogart D10
- HKE 0mile 383 shortblock,comp stroker cam,misc parts!!
- LS2 Fuel rails and injectors
- 2000 LS1 Long Block
- Stock 28lb injectors
- Dart Pro 1 CNC LS1/2/6 heads
- 6.0L LQ4 parts
- stock ls1 injectors f/s
- HSW 90MM nitrous plate F/S
- pro stars for trade 15x4 15x10,with tires
- 3" x-pipe
- LS6 intake
- Lsx nx camaro ls parts for sale
- Parts, parts parts and more parts
- Everything you possibly need nitrous kit!
- 6.0l stock crank rods pistons great shape! pics added
- 10" Alpine Type X - SWX-1043D
- Mallory Billet anodized black aluminum shift knob + short throw stick and filter
- Procharger 8 rib pulleys 4.0 and 4.5
- fs sjm abs delete/line lock
- 317 heads with stock springs 230 shipped 25k miles
- F.S. prostars
- stock 2001 ls1 short block with heads
- FS:NIB Harris Speed Works Nitrous Kit w/ Nano! SOLD
- Comp Cams Camshaft
- Part out
- Performance Parts-NOS,Lingerfelter,MSD,ZEX,MadMan,Blackwing
- Performabuilt 3000 Billet converter
- LS2 Intake $150
- Misc GM parts
- Fbody Performance suspension! PICS
- Final 01 TA partout list
- TDP Diamond Stage 3 Clutch kit w/flywheel
- Lq4 parts
- TNT 78mm power ring and MSD rpm switch FS
- LT1 solid roller camshaft
- FS: Complete Coil Packs
- Gen 3 PCM and stand alone harness
- Misc Parts!
