View Full Version : Parts Classifieds
- ATI/Lingenfelter C5/C6 10% Under Drive Balancer with Stock Size A/C Pulley SOLD
- Lingenfelter C6 LS3 CNC Bare Cylinder Heads SOLD
- FS 105mm LS3 Holley Hi-Ram intake Price Drop!
- Donaldson/Slp Corvette Blackwing intake. 1 Broken corner
- Pontiac 7-band EQ CD radio
- V-Band Truck Manifolds
- Mammo 408 for sale or trade
- Gen lll 6.0 short block
- Price drop!*Complete oil relocation/cooler system!*
- PRC 225 as cast heads, Cammotion 226/230 114+3 cam
- 98-02 camaro tail light (DS)
- FOR SALE-WALBRO F90000262 Racing In Tank Fuel Pump 400LPH
- 108191 Siemens Deka 60lb High Impedance fuel injectors Chevy LS
- Delete
- GM LSx Hydraulic Roller Lifters, Set of 16
- 243 Heads & LS6 Intake w/ Throttle Body & Lunati Voodoo Spring Kit
- FS LS2 Silver BLade Throttle Body (SOLD)
- Built 4l60e with yank ss4000 and TCI flexplate
- Suspension parts/ IR racing baffle/ SLP SS hood
- SOLD SOLD BNIB Ls Arp rod bolts 134-6006
- Stock 75k mile aluminum driveshaft *SOLD*
- Used LS6 clutch kit
- NEW Scat I beam rods
- WTB: gauge carrier/housing for '68 camaro
- Haltech fully terminated ev1 harness with Platnum Sport 2000 w/wide band o2 upgrade
- Inland Empire 3" Aluminum Driveshaft - UPDATE SOLD!
- viking coilovers
- Super Victor 4150 EFI Intake/Accufab TB/IS Sledgehammer 4150 Plate/ETC
- NIB Nitrous Outlet Fuel Nitrous and purge solenoids and -6 line
- HPI Bosch 120lb injectors
- 04 GTO Engine Harness SOLD!!!!
- Truck Intake COMPLETE
- Incomplete CTS-V twin turbo kit parts w intercooler assembly
- Built 4l80e and parts
- Sold
- Circle D 4200-4600 Stall Multi Disk Converter - 4l80e wth 4l60e front
- 98-02 Trans Am Ram Air Hood
- Lq4 4l80e harness and pcm
- Brand new F-body oil pan
- Shot in thr dark. Sport/light bar for TA vert
- AEM UEGO Wide band O2 kit 30-4110
- Engine for sale
- 98-02 Fbody aluminum driveshaft (Illinois)
- Huron Speed Alt relocation
- BADASS 416 Cube LS shortblock
- GEN 4 408 Shortblock; wiseco, molnar, ARP, Clevite
- 19" Strasse Forged S5 Wheels- C6Z/GS/Wide body
- Corvette Balancer
- 3 channel backing plates
- Koni Shocks/ Strano Springs
- Wiseco Tool Steel piston wrist pins
- Wiseco 4.030 flat top pistons and rings for 6.0
- GTO Procharger F-1A Kit - MANY EXTRAS
- Autometer Cobalt mechanical boost gauge - #6108
- BMR suspension, FTI Converter
- 2010+ Camaro Brembo front brake kit
- Fuidampr harmonic balancer
- Vig 9.5 4l80 converter
- Sold
- T56 - Level 2 600ft lbs, clutch, speed bleeder, etc
- LS7 Engine - Fresh rebuild with upgrades
- 93-02 fbody ebiach sportline lowering springs
- FIC 1100cc injectors, Magnafuel -8an fuel filter, HPTuners Pro
- All Forged LS9 Short Block/LS3 EFI
- Ford Green Top 42lb fuel injectors
- Edelbrock 90mm Throttle body
- COMP CAMS LSX Hydraulic Roller Camshafts [NEW]
- HP Tuners PRO
- Built 6.0 Motor
- LS1/LS2 Lonnies Fuel Rails
- 2011 Camaro SS Engine
- Tsp MS4 cam
- Mafs, coils, gears
- ls9/lsA factory 52lb injectors (Short Ls3 style)
- 4L80 mechanical diode converter
- Fast fuel rails ls1/ls6
- Nitrous Outlet 102mm plate kit
- Truck intakes
- (2) ls1 coolant crossovers
- Squash fuel system for CTS-V
- BTRSLR Lifters NIB
- WTB fox body turbo hot side with front mount or passenger side turbo mount
- ***SOLD*** WS6 Ram Air Intake Bellow - LT1 Trans-Am/Formula
- FAST LSXRT and Rails
- Early TBSS intake and Gen 4 Floating Rods
- ***SOLD*** Arizona Speed & Marine LT1 Monoblade Throttle Body
- Zex 82121 Nitrous bottle fill station
- Stainless Vband clamps
- Silver 5th Gen Camaro Engine Cover Brand New
- Elbow, throttle bodies, and intake *FIXED PICS*
- FS- Vertical Doors
- 799 heads LOWER PRICE!
- Comp Cams Magnum 1.75 roller rockers-sold
- Aem wideband failsafe 30-4900
- EPS custom grind cam
- 04-06 GTO Corsa Sport Catback
- Cleaned up 317s
- Black ZR1, Grand Sport wheels 17x9.5 17x11
- Rocker arms, stands and bolts
- 2000 Z28 A4 Engine Harness
- 5.3L P59 ECUs (L59, L33), DBW TAC/harness
- SOLD - LS7 8452 Head - Stock Takeoff
- LS2 Bare Block w/ Main Caps
- DBW tb/tac module/truck pedal for sale
- MSD 7AL-3 Ignition Box NIB
- Fbody T56 swap, RXT, PST
- 98-02 Fbody D1SC Kit with Aster Bracket & Meth Kit
- ***SOLD*** Headliner - Hardtop - 4th gen F-body
- 6LE Fiberglass Targa Top
- FS QA1-TS705 Stocker Star Single Adj. REAR Shocks C5/C6
- FS 279780 JE LS7 F.S.R. Dish Pistons 4.130 bore -22cc
- Destroke it setup- 6.300" Compstars and Gen4 4.8 crank
- REDUCED: 799 cylinder head *Slightly damaged.*. Sold
- 1998-2002 Camaro Firebird Borla Catback
- 4L80e FTI 3800-400 billet single disk lockup converter
- Brutespeed (EPP) Blower cam
- COMP CAM Custom LS grind 249/261@.050 ***NEW***
- Drag radials with wheels. NEED GONE!
- SOLD - LQ4 TURBO long block
- Borla Adjustable exhaust $500 shipped E-cutout $75
- 98-02 Tail Light Drivers Side OEM Used
- LS Swap Autokraft Oil Pan & Mounts
- LQ4 truck accesories for sale
- Front and rear covers, 862 heads, nitrous standalone
- Black 92mm throttle body - Nick Williams ---SOLD!!!----
- BNIB Pioneer 8200NEX nav and used LSA injectors price drop
- Parting 93z28
- Brand New Ls1 Bare Block
- 1 camaro monsoon door speaker
- 1997-2002 Camaro Chrome Factory Wheels
- 2007? Cadillac Escalade Rear Seats
- Twin MSD 6aln ignition panel setup
- Turbo kit part out - Pump/Wastegate/BOV/Injectors
- Used Precision 46mm Wastegate
- FJO 2 Channel Progressive Nitrous Mini-Controller
- MSD 8733 LS Two Step Used
- NIB Devils Own DDP 3800 Injection Pump
- FIC 80lb Flow Matched Injectors Barely Used $400
- Clean 317 heads
- TBSS intake
- Ontario guys I have a 6.0 iron block for sale
- OFI T6 Turbo Kit w/custom 4" exhaust
- Ice/water box 5gal
- 18" Forgestar F14 staggered deep concave wheels/Toyo 888
- Holley HP EFI system 550-607N
- 120lb ls3/7 high injectors for sale
- 2012 ZR1 LS9 dry sump kit. Complete take off, 12k miles on it.
- Tanks Inc. Fuel Pump Hanger
- Oil pump, timing chain, SLP LM1 resonator
- WTT: Tinted LT1 Tails for Stock LS1 Tails
- WTT: GTO oil pan setup for F-body setup
- New black seat belt guides
- 102mm Aluminum LS1 intake / throttlebody
- Holley Ultra XP 750cfm Carb Hardcore Grey
- Spohn #210 LCA Relocation Brackets
- REDUCED: 2004 6.0 DBW Truck Harness, Pcm, Coils, Tac module, Pedal, and Throttle Body
- Brand NEW Valve Springs - PAC 1218
- 98-02 F-Body LS1 Alternator with Modified Bracket for no PS
- 98-02 LS1 F-Body Power Steering Pump with Bracket and partial lines
- TR6060 6 Speed Manual Transmision
- ls1 f body oil pan, ls1 intake, ls6 intake, gto oil pan, PAINLESS harness
- Yank PT4000 510$ shipped
- FS: FIC1000 Injectors
- TBSS/NNBS Intake with injectors/rail/gaskets
- Strange Engineering 12 Bolt w/ Moly DS LCAs Tubular Torque Arm
- LS style t56 swap kit
- Autometer gauges
- LT1 Hooker long tubes FS
- Holley throttle bracket
- Pac 1218 springs new
- Precision 6266
- Fuel injector connection 95lb/1000cc
- Iso fast 102 fuel rail kit for ls1
- (2) LS6 intake, ported TB, Nitrous shift knob, ebony upper console
- D585 coils and brackets and 10296 Pump
- Stock struts and springs
- SBC 388ci Alcohol drag racing engine
- CCW Classics Fbody & C5
- Stock trailblazer SS cam lifters timing gear pushrods
- 438 sb2 engine for sale / trade
- Garage clean out...
- Complete FiTech fuel injection/induction/ignition setup
- ******SOLD****98-02 F body headers ceramic coated
- LS1 Long Block
- LS3 Straub bushing rockers with new stands(intake rockers brand new)
- 44lb fuel injectors
- 99ss Camaro PARTOUT
- 2000 year model 5.3L
- FS: LSx ARP flywheel and flex plate bolts "New"
- Camaro Monsoon CD Head Unit
- American racing Torque Thrust 2 wheels 17"
- SLP Lid, SLP Bellow, Delphi Maf/harness
- GMPP LS7 Single Plane Intake w/ EFI
- Proefi 128
- T&D Shaft mount
- tick performannce adjustable clutch master cylinder
- F1-a procharger
- F-Body Pro 5.0 Power Tower
- Various 6.0 Short Block Parts
- FOR SALE 66mm Precision wastegate
- 3 sets of ARH Headers, 1 7/8 to 2", Ceramic, High flow cats, turndowns, etc.
- holley 90 mm throttle body
- Built 2000 Camaro partout - LS1/T56/9"
- Painless Performance Wiring LS Swap Wiring harness
- 2 Convo Pro 15x8.5 5"bs 5x4.75 lug pattern For sale
- REDUCED: Diablosport InTune i2 i2030 Tuner for GM
- Siemens Deka 60lb EV1 Injectors
- LT1 3.5" MAF w/ Screen
- Corsa XO-Pipe 2.5" to 3" (C6)
- Stock exhaust manifolds and catalytic converters (C6 LS2)
- ISO looking for a 1999-07 LS1-LS9 4l60e stall converter 2500-3500 stall
- QA1/HAL front shocks (F-body)
- LT1 F-body turbo setup
- FS: MBA billet shift knob for automatic, Pontiac logo
- FS Tial 44mm wastegate
- F body pacesetter headers coated
- Wheels/Tires
- Weldon DB2025A pump with Aeromotive pre and post filters
- Turbonetics T7875 1.15 A/R
- GTO Tremec T56
- 2013 Z06 427 engine
- Wings West 1998-2002 Pontiac Trans Am W-Type 5Pc polyurethane Complete Body Kit
- Brembo GT1 Big Brake Kit (Front only)
- Racetronix fuel pump and hot wire kit
- Csr th400 flexplate over shield
- Strano 35mm swaybar, poly bushings, aluminum DS, etc..
- Sold!!!!! Arp 234-6301 Pro series Arp 2000 Rod bolts. 0 miles
- Camaro Headlights
- Nice 93-97 LT1 Camaro/Firebird parts
- LS2 Intake + FAST 92MM DBC + Billet Fuel Rails + DBC cable Bracket.
- Diamond Forged Pistons 4.030
- Nitrous Express stand alone new
- ARP rod bolts PN 134-6006 ~1000 miles
- P1SC Procharger*SOLD*
- C6 Z06 seats
- Square G6 18x9.5 +15 5x114.3 5x4.5
- Ls6 intake manifold
- Cts 18" spares for skinnies
- FS - FAST 102 LS3 intake manifold
- Standalone Engine Harness And Ecu With Labels
- LS6 camshaft 5308
- Stock springs for 4th gen fbody
- Solid 1" rear swaybar for 4th gen fbody
- 1997-2004 C5 OEM Exhaust Midpipe and Mufflers
- Competition grey c6 Chevy corvette wheels
- CNC ported LSA heads
- Factory 10 bolt 3.23 gear
- HP Tuners Pro
- 2005 Corvette LS2 with Speartech harness/computer/pedal VATS delete
- 365 c.i. Shortblock for Boost.
