View Full Version : Parts Classifieds
- tci reverse manual valve body
- Sold!
- WTT: 18 inch chrome C6 wheels with tires for drag setup with bigs/littles
- FS FAST 92 and TB
- Few Stock Things For Sale Take a Look
- Prc 215 heads and tsp trq3 cam 2000$$
- SLP High-Flow Mass Air Flow Sensor
- 2 K&N filters like new. $40 for 2
- FS Cartek Proto Headers
- FS Kenne Bell BAP 40 amp
- FS BNIB Textralia oz700
- FS: BNIB KOOKS 1 3/4 and x pipe
- QA1 275 Lb. Springs for sale
- NOS 5177 Dry Kit/HSW Interface/Bottle Heater/Purge
- Set of Bogart Bolted R/T's with tires
- BBK ported Ls6 ls1 Throttle body and spacer
- 35th ANNIVERSARY CAMARO SS LEATHER TROPHY MAT BRAND NEW!!
- 36lb accel injectors
- WTB a set of trunk lid hydrolics.
- LT1 Plastic PCM Bracket
- 4" Corsa Clones
- red top 30 lb injectors
- M6 Crossmember
- FAST with Traction controll
- Bs3
- FS: D585 Heatsink Truck Coils
- CCW 505a wheels for sale 18's and 19's!!
- stock cats
- Aluminum Driveshaft LS1
- C5 Z06 repro wheels. 17x9.5 18x10.5 550 shipped
- Camaro trans am 4 inch mufflex exhaust flowmaster race muffler ls1 lt1
- Dekka etx 16, 2 bar, Ta seats, walbro, ls1 alt, wires, 317 heads
- 1998 Z28 Part Out... Stock and Performance
- Sparco PRO 2000 seats
- 295 35 18 Eagle F1 supefrcars
- Fs: crane 99893 dual valve spring /ti retainers
- Never used, tan convertible top tonneau boot cover for '93-'02 Camaro
- Nitrous outlet switch panel
- FS 99 LS1 Harness/PCM--SOLD--
- LT1 Hooker LT headers, and Hooker ORY FS...
- FS:93-02 Camaro Rearview Mirror w/Maplights OEM
- BRAND NEW black face red digital trans temp gauge with sending unit
- Used LT1 MSD Blaster Coil FS...
- BW Turbo 75MM/T6 1.08ar
- TC76 Turbonetics Turbo, 3" V-band exhaust with .81 AR
- SLP Smooth Bellow & Two 6" x 4" Silicone Hoses F/S
- Stock 343 10 bolt=$150 driveshaft $100
- 2002 ZO6 Cam - Low miles, clean
- Moser 12 Bolt. 33 Spline Eaton, 3 Channel + Driveshaft.
- FS: center bolt valve covers (wrinkle black)
- T/A Hatch Brake Light
- LS1 Stroker K1 Technologies Connecting Rods
- 409 boost stroker
- Meziere Elec. Pump, Yella Tera 1.8 Rockers, GMPP Bowtie valve covers!!
- Kore3 355mm Hybrid adapters - LS1 Brake Conversion
- C5/C6 Brake Pad Abutment Brackets (PAB) - SOLD
- NEW MPT70 turbo, 60lb injectors, 85mm delphi MAF w/adaptor harness,Tial BOV/gate
- ctsv oil pan 150.00
- New 15x10 rallyes, 5" BS
- 2 sets of 241 heads
- FS- Engine Hoist, Stand, 2 Load Levelers- Austin area
- OEM '06 GTO Tail Lights
- Ls6 Corvette Intake Manifold
- Probe P2441F.040 forged pistons with plasma rings
- FS: LS6 Manifolds and 02 sensors
- Nitro Daves kit LOADED
- Brand New Flowmaster Merge for ypipe
- Two stock 16" camaro rims
- Zr1/ls9 injectors
- 98-02 F-Body Parts / Exterior and Interior
- 98 LS1 Engine Harness REPINED for 99-02 PCM
- exhaust sale! borla magnaflow slp dynomax
- 1000W Kenwood Excelon Amp & 3 Farad Power Acoustic Capacitor
- FS: ARE Dry Sump Setup
- LT1 Z28 150 mph cluster and air bags from 94Z
- LG motorsports powerdyne supercharger-lt1
- 2 Nitto 555r tires less than 1k on them
- FS:Fast EFI, data logger&wideband $850!
- FS: 383 LS1 forged turbo/blower motor
- Morel/Lunati Linkbar Lifters, Brand New In Box!!!
- 98 & 00 WS6 Part Outs
- LS1 Corvette Acessories Bracket / LT1 Acc Bracket
- bluegoat10
- 4th Gen Fuel Pump Assembly
- 98-02 F-Body STS Turbo kit W/T76
- 2 Hurst Shift knobs, UMI drive shaft safety loop
- BMR TrakPack Torque Arm with 4130 CM Crossbrace mount or tunnel mount
- New March Fluid Sfi Underdrive pulley and LS7 Fuel Rail
- Yokohama Advan Neova 295/30R18
- Free Wipers & Blades to a good home
- Stock short block LS1 5.7 1999 C5
- LS2 90mm Throttle body with harness interface for C5 harness
- Texas Speed and Performance “TSP” Terminator 200cc heads
- LS3 L92 Harland Sharp upgraded rockers
- FS: SLP SS grill
- F/S Caddy 6.0L Coil Packs With Brackets and Harness
- FAST 92mm Throttle Body
- 3.23 gears
- 98 ls1 fbody pcm
- Maxxis Z1 Drifts 275/35R18
- GMMG catback
- FS... TFS 215cc heads
- ATI 8" Treemaster 3800 stall
- BNIB 5/16" Pushrod Guideplates
- Sold Rollmaster double adjustable timing chain
- ARP 3/8" Rocker Studs New
- BNIB BMR upper and lower A-arms (AA001 & AA002)
- 15x10 draglites 7.5 b/s
- LOWERED PRICES Billet Specialty street lites CHEAP. intercooler. ls6 pump, cams
- Black Ram Air Decals
- 06 Silverado L33 5.3L Engine and Parts, GTO Manifolds
- Rules for using the classifieds
- Meziere Electric Water Pump FS
- Stock Tq Arm Mount, gray 97-99 Switch panels, SLP jounce spacers.....
- Strano Springs, Brand New!!
- FS: Autometer Ultra lites
- Alpine HU, Pontiac CD Player, stock speaker
- ls1 oem 241 heads
- Fbody ls1 vortech v-9 G supercharger
- FS:Th350, T-brake, deep pan etc.. fresh.
- 1999 LS1 crate engine $1400 zero miles
- LS6 Intake Manifold - SOLD
- 98-02 oem red ss hood 'no chips'
- 875-16 roller lifters, $110 shipped
- Quicktime INC RM 6035 bellhousing
- A1000 fuel pump/Filter/ported TB
- Quicktime INC RM 8020 bellhousing
- F/S: P1SC Procharger for '05-'06 GTO
- MicroEdge Controller
- Monsoon System
- T-top, rubbers, trim and hardware
- th400 ls1 stall
- TNT nitrous kit with extras
- TR220, P.I. TBTC, Head Bolts and more
- lt1 starter
- GTO T56 M12 shifter assembly
- 98 Z28 Camaro Drag Car PART OUT
- WTB Heads - TEA 235'S
- 408 rotating assembly
- truck ac compressor
- 2001 truck exhaust manifolds
- LS1 1.7:1 Harland Sharp Roller Rockers 385$ shipped obo
- UMI Body Mount TQ Arm, 17x9.5 Silver ZR1 Wheels and Nitrous Outlet Bottle Heater
- CTS-V oil pan and corvette/cts balancer
- Spec 3 clutch and billet flywheel
- Edelbrock Pro Flo XT ls1 intake FL
- T-Top Sun Shades
- 93-02 Trans Am Sidemarker Lights
- Camaro Reverse Light LED's
- New UMI Upper A-Arms
- GTO Spare Wheel and Tire - Great for front runner - $115 Shipped Price Drop
- New VFN 3" SS Bolt on Hood!
- (4) Vredestein Ultrac Sessenta Tires
- 4000 rpm vigilante fs
- comp pro mags 1.6 rocker arms, comp hi energy hardened pushrods
- Bosch 044 brand new. Houston Texas.
- T56 Pull out!!!!
- Stock 5.3 crank and rods
- 5.3 ls truck motor
- lunati cam for ls
- edelbrock dual plane carb'd ls intake
- K&N LT1 CAI+ Trickflow elbow, LS1 Lid, Kenwood HU
- intercooler
- LQ4 Parts for sale. Pistons, Rods, Cam, and Misc. Parts
- 96 Black leather back seats (PERFECT)
- LQ9 parts for sale & Volant CAI ,Ls1 stuff
- F1R Head unit
- Polk Audio 6x9 DB series $75 shipped OBO
- RPM Transmissions 4l80e Level 5 and Triple disk converter
- Painless Harness/speedo kit/turn signals/ fan controller
- Random Audio stuff!!!
- Tilton Carbon/Carbon Setup
- New Pankl Rods
- FS/FT; factory ss catback dual/dual model
- FS: Auto Meter 4378 Wideband Air/Fuel Gauge
- Strut Tower Brace
- NGK AFX meter F/S
- T/A parts for sale
- Comp Cams 918 springs
- lt1 cnc heads and other parts FS
- FS:heads, cam, headgaskets and some oem
- 4.0 eagle stroker crank and scat h beam rods not for sale
- MSD Pro Billet HEI and 6AL-2 box
- 8 Rib crank pulley for superchargers BRAND NEW! Including Shipping - PRICE LOWERED!
- (2) 85mm MAF's
- brand new 317 heads
- CME with Valance - Gauging Interest
- Leather Seats, Y2k Rims, And Draglites
- t 56 swap low miles
- Tci ez tcu brand new never used $750 obo
- Overhauled LS2 shortblock
- svo green top 42lb injectors 135 shipped
- SOLD - Ls7 Factory GM carb intake with power coating
- built t56 with pro 5.0 and monster stage 3 clutch
- GTO/LSx Parts
- Gauging interest in selling my FireHawk Wheels
- 98-02 ls1 mid length mac headers an misc.
- Any Interest? Z28 Exhaust Tips
- FS Aftermarket Brakes
- TA 10 bolt stud girdle
- Kenne Bell 2.8l supercharger with 8 Rib Drive $4000!
- 17 gallon fuel cell with gm sending unit-new
- Brand new drivers side LS1 Fbody Exhaust Manifold
- Used LS1 F-Body Hooker Long Tube Headers and ORY
- GTO Energy Suspension Control Arm Bushings front & rear
- Firehawk Car Cover, RAPTOR Hood, Firehawk Owners manuel
- FS: stock LS1 TB, MAF, Fans/7.450 pushrods SOLD
- Parting 2000 Camaro SS
- Ebony T-Top shades
- Stock WS6 Cat Back Exhaust
- 275 40 R17 BRAND NEW MT DR's
- Parting Camaro 2000 SS
- Nitrous parts, Coil Brackets, misc. *PICS*
- Performabuilt Level III Invincible FOR SALE
- Nitrous bottle, oilpan, lifters
- Built 4L80E, T-Rex Cam, 104mm FTP lid, HSW nitrous, Greg Welds for sale
- Subthump deep subbox w/15" L5/L7 firebird, camamro 93-02
- ls motorsports airlid
- NX Nitrous wet GM kit complete, Loaded!
- ASP underdrive pulley (pics added)
- Fs Ls1 gto kooks long tubes Wtb first gen ls swap parts Wtb ls2 drop out
- LS1 4l60e
- C5 Z06 Chrome Staggered 17"-18" Wheels
- o-ring fittings,arp rod bolts,afr valve springs
- Lokar 36" Hi-Tech LS1 Throttle Cable Kit
- LS6 20k mile Rotating assembly new rings / bearings
- Callies Main Caps New Lower price
- LS6 New Block with calies caps
- 6.0 lq-4 fs
- SLP 1.85 Rockers with 20 miles on them
- vig 3600 stall
- Weld Draglites with slicks and skinnies! LIKE NEW 15x10 7.5bs and 15x3.5
- 8 - RC SL4-750cc injectors rated at 71lb/hr @43.5PSI
- 5.3 motor edelbrock dual plane carb'd intake and a lunati cam
- Comp 918's, Comp Cam, MSD, & HVAC Delete Panel
- UMI on-car adjustable panhard bar
- chrome lug nuts brand new with wheels locks and key
- F/S fluidampr UD pully p/n740102
- Mint Condition 99 camaro A/C Compressor
- Sold: FLP long tube header kit for LS1
- T/a rear bumper cover
- T/a side skirts
- Real GMMG Dick Harrell hood for sale!
- Brand new wilwood 6piston front 4 piston rear BBK
- ARP ls1 head bolt set
- LQ9 Coil set D585
- Patriot spring locators brand new
- blue green dbw 05 1500 auto wiring harness
- Hps garage sale!!!!
- WTB Billet/Chrome Rear Camaro Letters for 2000 SS
