View Full Version : Parts Classifieds
- Gm carb intake- SOLD!
- 5.3 long block
- Scorpion 1.7 ratio rocker arms---SOLD
- Bullet Solid Roller cam, spec'd by LE
- Probe forged pistons/Scat rods for LT1/SBC
- New LS1 engine harness and ecu
- TFS .660" valve springs, SLP oil pump, 7.4" pushrods
- 17x11 ZR1 rims polished
- LS1 Intake (non-EGR) and LS1 fuel rail
- 4.8 5.3 6.0 Engine Parts MN12 Parts
- *Sold* FTRA $85 shipped *mint condition*
- 160lbs bosch injectors
- 75mm t6-1.08 ar BW turbo.
- FS: GM LS7 Crankshaft NIB
- Masterpower T70 turbo (.96 A/R exhaust housing)
- Complete LS1/T56 - sold
- New 60# Injectors, SD Siemens Deka
- LS6 short block, LQ4 Rotating Assembly, STage 2 clutch and lots more
- WTT NX Plate kit and Mufflex Single 4 inch catback
- FS:american racing ory
- Nitrous outlet low profile elbow
- CTS-V 6 piston BBK and custom rotors
- crane turbo or nitrous cam NEW
- BNIB thunder racing 230/236 cam
- BMR Trak Pak Torque Arm **Pics Added**
- infinity reference series 5 1/4 components, 6.5 coax, 6x9 triax package deal
- cam and valve springs
- Victor jr, elbow, and rails
- Thunder Racing Cam
- stock exhaust & lid
- chrome z06 wheels
- 2006 GTO Black Leather Power Seats $325
- 228/232 Cam OBO
- WTB coil pack brackets with harness
- MSD 2-step and NBM WS6 hood
- ATTN Corvette-- WTT- SP16 CCW 19s C5Z
- Chrome C5 replicas F/S
- FS.... LS2 Block
- fs ls6 long block and t56
- Dynotune Nitrous Kit LT/LS ( Brand New )
- Suspension Tech Lowering Springs 93-02
- fs: t-56 and misc
- 7.2 hardened pushrods
- WTT smoked TA tail lights
- FS: NIB Manley 4.00" stroke 4340 crankshaft
- lt1 le2 heads
- LOWERED **LT1 Accel 300+ ignition**Controller/Coil/Icm/Opti/9000xt Ferro Wires
- CAM~Futral F14
- wanting to swap built a4 for m6
- 28.8 lb injectors
- sold
- Comp Cams 918 Beehive Springs, 0.600" Lift, 5K miles
- 93-97 A4 UMI tq arm reloc
- 2000 WS6 part out(pics added)3/15/11**comeplete motor/Camaro parts
- Comp Cam: 227/230 .613 .591 @113 SOLD!
- Engine Rebuild Parts from a '99 Camaro Z28 LS1
- LS Longblock, Body Parts, Misc Good Deals
- custom black tt2's great tires!!!
- 99 camaro,stock 4l60e with only 56xxx miles.
- protorque 4l60e tc 2400stall 12"
- ls1 performance parts
- 60lb injectors!!!!
- WTT Factory ss hood for vfn bolt on hood
- Double timing chain
- Dual Square Borla Tips For Sale
- bunch of good parts for sale(fuel pump,60's,turbo cam,CIrcle D)
- LED front license plate filler for firebirds
- 93-97 firebird/tran am 4 inch vfn ram air hood
- going back to stock sale, monster stage three clutch almost new speed inc si6 cam
- Truck Manifolds for turbo setup
- 1998-2002 OEM Tailights.. Mint condition
- LS1 Parts for sale
- Polished 92mm ptm t/b, SOLD
- Ls1 darton mid sleeved block by steve at red
- NEW DynaTech Mustang SWAP Headers LSX Ceramic Coated
- Used clutch kit and hydraulics
- 224/224 .581 .581 @114 Comp Cam (shipped price)
- LS1 non EGR Intake
- Victor Jr Carb intake for Carb
- High performance parts for sale...
- FS: 4L80e TransGo HD2 Shift kit - TRG-4L80E-HD2
- Left Over LTx Parts
- Monsoon CD head unit for 98-02 Trans Am/Formula w/front door and rear speakers $60.00
- Brand New 99camaro/01 cadilac cam
- Stock k-member, upper & lower control arms for sale $$$$$
- Katech Billet Main Caps NEW
- Starter and 140-160 amp alternator for sale$$$
- 241 heads with springs, Torquer V3 Cam!!, pushrods, SLP MAF
- GTO oil pan , 6spd rear cross member , and random crap...CHEAP
- stainless brake hose set, fbody hub bearings, random LS1 bolts, cam plate w/ bolts
- Weld Alumastars Beadlocks, Black, lots of pics
- 2002 lq9 parts!
- Briggs LS 416 Complete top to bottom
- 15x10 prostars
- Brand new Seat foam!
- LS2 Vette/GTO Injectors
- solid roller cam and lifters for sale!!!
- eagle, 4" crank for sale
- tanks inc. pump setup for ls swaps
- truck parts, engine harness, body harness, tac module, compressor
- Ls1 fuel rail with 8- AN fitting
- Fbody water pump
- Michelin slicks
- Lt1 slp clutch and flywheel
- 6.0 truck intake complete!
- fs vfm bolt on ws6 hood i think its a 4 inch
- Corbeau CR1 reclining Seat, blue, MINT!!!!
- In tank Walbro 340 and Racetronix harness
- MTX Thunderform with built in amplifier!
- NOS progressive nitrous controller
- hps pads, rotors, line loc, strut tower brace
- FS: Ragin Racing blower cam 224/248 0.631"/0.601" 117+4
- Changing set up need these parts gone
- 1997 camaro ss starter lt1
- lt1 t56 bell housing and front tranny plate.
- 4.8 5.3 6.0 Truck intake Complete F/S --- SOLD
- 62-67 Nova TWIN turbo set up proven 1000hp to wheels
- LS1 LSx Engine Mount Plates- Street and Performance Billet Alum- NEW-
- Cleaning out the garage, part 1
- i need to know how much to ask for my LT1 engine
- Trans Am Lettering
- Stock truck coils
- WTT: GTO oil pan for Fbody pan
- LS1 LS6 throttle body TB
- firebird parts
- 01 TA parts manifolds, throttle body, gear, and more
- 78mm nitrous kit, and Zex NMU
- lc-1 wideband
- 3.42 gears for 10 bolt
- Patriot Stage II LS6 ported heads! (59cc) SOLD!
- O2 Simulators for Sale
- 92mm Fast throttle body
- Bosch Design III 42lb fuel injector
- a few things f/s
- LS6 valves, light weight. New in box
- FS: AEM UEGO Wideband 02 sensor 30-4100
- Complete Stage 2 Methanol kit
- LS1/L92/Turbo/Mustang Spring Cleaning!
- L92 Felpro intake gaskets
- LT1 fuel injection parts
- Futral Motorsports F13 Camshaft!
- Brand new 408 Boost Mahle Power Pack
- Garage clean up "Make Offer"
- 60# siemens injectors
- 98-02 black trans am OEM hood
- A set of 7.400 push rods .080 wall
- 30# SVO injectors, fat style.
- LS6 intake manifold and TB
- Ported Dart Heads, Valvetrain Parts, 2'' Kooks Headers, S95 Turbo, Random Parts
- Flowmaster 80 series
- 3 piece rs spoiler fs/ft
- Mcleod bellhousing
- QA1 Front Coil-Over Springs
- Black ZR1's with a chrome lip
- Ported Heads, 6.125 Rods, and more ls1 parts
- Newish L-92 823 Casting heads
- FS: Convertible Tonneau Cover
- Sheet Metal valve covers by Intake Elbows.com
- 2006 GTO Wheels/LS1 Valley Cover/Foose Wheels
- *** ET LS7 heads ported by Greg Good and much more***
- Hickock Five Shot Wheels 17x9 18x10
- Lt1 obd1 pcm
- LS1 "truck resistor" coils
- Alternator, PS pump, Water pump all NEW Camaro Brackets
- 93-02 Stock MAF NEW
- Stock Vette/truck balancer pullies
- LS1 Camaro AC compressor bracket for sale
- 76mm T4 turbo
- Borla 140039 Stainless Exhaust 1997-2004 Chevrolet Corvette price driopped to $500
- WTS/WTT 99-00 style LQ4
- 2004 Gto Kook headers
- *LOWER PRICE* 80lb EV6 injectors
- NEW LS2 6.0L Turn Key Crate Engine
- LS2 With LS3 Heads And Intake
- Suzuki GSXR Hotbodies Flush Mount LED kit
- Just did another partout. engine Acc's and parts stock/aftermarket
- kooks and RPM 4l70E
- 2002 Z28 stock parts for sale make offers!!!
- darton sleeved ls1 block
- Autokraft LS Pan - Brand New
- LT1: Clear corners, PCM (pcmforless), OPTI tubes (CHEAP)
- F/S: Nick Williams 92MM Ported/Polished TB
- CHEAP hotside piping for 6.0L manifolds
- PRC Gold Springs w/Titanium Retainers
- custom cam, stock gto ls2 crank, tsp ported ls6 oil pump
- headlights and shifter
- MT Drag radials with 16" rims, SLP line lock NEW!!!
- NIB F.A.S.T fuel rail kit 54023
- -10an Billet fuel filters
- Brand new LT4 springs, Brand new LT1/SBC Howard springs
- Ls Parts for sale
- Corsa Clones Exhaust Tips
- SLP Smooth Bellow
- racestar wheels and tires
- For Sale: (2) Bridgestone Potenza S03 tires 215/40/17, $80 + Shipping
- ccw drag pack
- Brand new NX MAF kit F/S!
- FS: LS6 Rocker Arms with Rails and bolts
- new ls2 timing chain, stock crank pulley and water pump
- Corvette C5 twin turbo kit & methanol kit COMPLETE
- SLP Hood for 93-97 Firebird
- Comp Cams 7.450 pushrods and stock Ls1 cam, pushrods, and springs
- FS: UMI Pistol Grip shift knob for T-56
- stroker sbc rotating assembly
- NEW in BOX Pacesetter Y pipe F/S -PICS ADDED-
- For Sale Yank SS3600 4L60E
- 4l60e
- T56 out of an 02 ws6 $1800 in CA
- (VA)LS1-Intake
- F/s-eibach pro kit-lowering springs
- Chrome 16x8 Cragar wheels FS
- GM LS7 Lifters 1800 Miles 85.00 SHIPPED PICS
- BMR Xtreme Torque Arm w/Driveshaft Loop
- 93-97 shorty headers FS, cheap
- Sold
- 98-02 Camaro Grill Insert
- Dark gray door panels and cruise control module
- Wtb 4th gen v6 springs
- 98'-02' OEM SS HOODs & Trunks
- TransAm side skirts
- Air to air intercooler
- small block parts for sale
- TSP Chromemoly 7.4 pushrods
- C6 ZO6 Wheels and Tires
- Nitto Invo 315 25 zr19 Tires FOR SALE! (Almost new)
- new Cloyes 9-3145 dbl roller, csi electric h20 pumps, comp-r's 875, ported intakes
- nitrous kit. TNT power ring.
- 7.400 hardened pushrods
- 42lb Lucas injectors
- HP Tuners VCM Scanner MPVI Pro
- Kooks 1 7/8 inch headers
- SVO 42lb injectors
- {FS} Holsett HX-55
- Simmons wheels
- FS: Spohn solid motor mounts
- New stock 02 LS1 Valves for sale Full set
- spec stage 5 clutch forsale
- WTT: UMI Pistol Grip sihft knob/handle for chrome shift lever and 8 ball knob
- CLOYES adjustable timing chain sprocket,fram tg5 oil filters
- stock WS6 springs front/rear and BMR non adjustable panhard rod
- First gen f body goodies
- LS7 stainless exhaust valves
- Detroit Trutrac 9"
- 4an swivel gauge adaptor & 4an 90 swivel female to male, FREE SHIPPING
- Bunch of left over parts from 98-02 cars
- 1000cc high imp injectors w/ adapters
- Autometer C2 oil psi gauge
- pair of ZR1's 17 x 11 SOLD!!!
