View Full Version : Parts Classifieds
- NEW LS2 timing chain AND adjustable cam gear
- ls2,ls6 injectors for sale
- NX heater and switch panel
- MSD 8.5mm Wires. Barley Used!
- Complete 10 bolt w/ 3.42 gears, traction control, ABS, LSD
- Stock Aluminum LS1 driveshaft
- 45 Degree Slash Cut Tips Polished
- used ls7 lifters, g8 lcas with polys
- Ms4 camshaft only
- WTB: LSX 376 or LSX 454 Valve Covers for a project!
- Patriot Extreme Dual Springs
- LS1 Centerforce Dual Friction Clutch
- gmpp efi single plane intake
- Darton MID sleaved LS1 block
- Trans Am window switches
- Ls9 Cam
- LT1 A4 engine wiring harness 1995
- Seimens Deka 60lb Mototron Injectors FS SOLD
- Comp Cam 230/242
- Freshly Rebuilt 2600 Torque Converter - 700R4, 4L60E, 4L65E
- edelbrock ignition box ls1/ls6
- Bmr lowering kit. Springs, relocation brackets, panhard bar
- 98 Camaro 4l60e trans
- LT1 performance and stock parts. CHEAP! PICS!
- handheld tuner
- FS/FT Adjustable Spohn Tunnel Mount Torque Arm
- Window Guides & Airbox Clips For 98-02 Cars
- SPEC Stage 3 Clutch
- Brand New Delphi Fuel Pressure Regulator For 98-02 LS1 Cars
- 98-99 M6 Ashtray Lid
- twin garrett gt3582r
- 335 30 18 KDW tires
- Diamond Forged Pistons 11521 New In Box
- Pred Z Custom Cam SOLD
- FS: Rossler th350, ATI, TCI
- 2002 35th Anniversary SS 10 spokes W/tires!
- Whisper lid & stock LS1 MAF sensor...
- GMMG exhaust
- C6 Z06 rear drivetrain transmission and differential Very Low Miles.
- 2000 Trans am body parts for sale
- AC System, Complete, '98-'02 Fbody
- New l92 water pump
- Lingenfelter 58x to 24x reluctor converter module
- ls garage clean out! make offers have a few items left
- New LT1 2800 Stall Billet Converter
- N2O parts, nitrous outlet
- circle D 4000 stall
- Stock HURST SHIFTER WITH STICK and dead alt(Needs Rebuilt)
- Turbo hot side plumbing for "truck manifold" setup
- 1999 Camaro z28 ground effects
- KBRacing PT88 Complete Kit
- new lq4 cam, fbody 160A powdercoated alternator, AC bracket, WP pulley, valvecovers
- New 98-02 Camaro/Firebird Specialized Stainless Polished Engine Bay Covers
- Delco opti ( vented) w/ msd cap & rotor
- Stock LS1 Injectors
- 90mm Nick Williams CNC Throttle Body
- 42lb racetronix/lucas fuel injectors
- Ed Curtis / FlowTech Induction Stroker Cam
- Demod Sale, lots of stuff, Nitrous, TA leather seats, QA1's,draglites
- delete
- FS: Black Camaro 5 spoke wheels
- Parts Wanted!
- lq4 6.0 for sale
- sold
- F/s jet hot long tubes
- LT1 parts, Lingenfeter heads, comp rockers, short block etc
- Falken Azenis 615 315/30-18
- Cam only LS1 Short Block
- New 98-02 SJM ABS Delete/Line Lock
- White gauges
- New Masterpower t70 .68 turbo
- 36lb Fuel Injectors $150 and SLP Shifter for T56 $70 Shipped
- t top black band for roof near hatch
- eibach sportlines...
- 97 camaro grey cloth seats...30th anni....
- eibach pro springs....
- Custom STS style T74BB turbo for Silverado and full size trucks
- Parts for sale
- ls3 tsp cam prc springs titanium retainers comp 7.4 ls3 intake
- FS Near new S400 chassis turbo, race cover
- Aluminum ram air, like FTRA.
- 10 lb nitrous bottle w/ gauge and blowdown tube
- FS- LG Pros long tube headers
- FS: two 19" Tires
- Suomy Helmet Tattoo Edition
- Brand new Alpine V Power Amp - MRP-F250
- WTT: Magnaflow catback For?
- FS: Nitrous Outlet Plate
- FS: CNC ported LS7 TB, Haltech Intake
- Ford 30 lb injectors 100.00, SLP cai 65.00
- L92 Intake
- *Complete Ls6 intake*
- built 9"
- ALL SOLD * LS6 Intake, 78mm DBW, 85mm MAF * ALLSOLD
- Harris Speed Works 90mm nitrous plate for wet or dry
- LT1 stuff! MAF, ECU, AN adapters, LMA3
- Ls1 Ls2 Ls6 1.85 Roller Rockers...SOLD !!!
- SOLD Lt's Hpipe Hi-flow Cats Exhaust 97-04 c5 CHEAP !!!
- 250$$ Lunati Gift Certificate
- Ls1 853 Heads with NEW Z06 springs
- 93-02 camaro rear roof panel
- F/S: Professionally Ported and Polished TB
- 2004 LS1 parts
- Master Power T76 Q-trim 1.00 A/R T4 turbo
- ***76mm turbo kit***
- Garage sale (9in, fans, etc)
- P1SC procharger and big front mount kit
- SOLD...f-BODY 88MM COMPLETE TURBO KIT FOR SALE
- Stock C5 parts intake intake manifold exhaust ls6 coolant crossover
- New Never Mounted (2) Nitto DR's 245-50-16
- Kenne Bell Boost-a-pump
- Nitrous Parts (MSD Window Switch, Powershot Solenoid)
- Racetronix fuel pump kit lt1
- Cp turbo pistons, custom ls3 heads, l&r 6.0 block, 76mm bb turbo, NEW PRICES!!!!!!!!!
- External Walbro 255 pump
- 93 pontiac firebird formula parts lt1
- comp 7.35 pushrods
- Custom 9" 3.89 gears Moser axles less than 500 miles
- New GM Parts LS Oil Pan Gasket
- 2 Used Bosch 044
- FS: 1994 Camaro Hypertech Power programer.
- 4l80e built with transbrake, controller & converter
- Nitrous Kit 78mm plate, C5 Wheels, Stock wheels, Drag Radials
- aem injector driver
- LS7 CLUTCH SALE...Limited Time Only
- 1998 ls1
- '04 Truck DBW Intake - Complete!
- lq9 stuff
- SOLD! NEW TEA LS6 CNC Ported Stage 2.5 Heads
- AC Compressor
- BMR Adjustable Panhard par w/poly bushings $100 shipped
- TCI Street Fighter Converter
- FS: LS Tall Valve Covers Brand New!
- FS: ATI Procharger D1 Custom Kit. 12 rib 700rwhp++!!!
- Arp head studs
- TPIS Mini Ram II EFI
- Warhawk head studs
- wtb some good injectors 42lb
- 6.0 escalade engine
- LSX Sprint Car/Dyno Headers
- LS1 Motor for Sale
- Speedline's w/ BFG drags
- GTO Oil Pan
- Complete LM7 With Turbo Truck Manifolds & T56
- I have the misc. motor parts you need.
- "01 6.0 crank
- 99 F-Body Service Manuals
- Hotchkis Used Strut Bar
- Bolt In Tubular Steering Column Complete Kit
- Part out 94 T/A 58k miles. Red/Graphite interior
- TSP Ported LS6 Oil Pump ***NEW***
- SVO green top 42# injectors
- LS6 intake & ported TB+ other parts317
- 799 head valvesprings
- jet performance chip 110 shipped
- LS1 MAF, Fuel rails and LS1/LS2 Injectors. SOLD SOLD SOLD SOLD
- Bmr extreme trak pak kit chassis mounted chromoly
- Weld Prostars 15x10 (5x4.75)
- MSD 6AL-2 & Corbeau CR1
- brand New Engine coolant temp sensor LS1 3 pin connector
- BE COOL 6spd radiator stock fit unused in box
- OEM 3.42 gears
- used pacesetters for sale 175
- headers and y pipe
- SLP headers, cats and y-pipe
- LS6 Intake, FAST Rails, Filled/Ported T.B.
- 3" Magnaflow Cut Out
- 98-02 F body Kooks headers 1 7/8-2"
- Truck Manifold with dbw tb and injectors
- Knock sensor harness, cam sprockets, berger panel, more
- [SOLD] HPTuners VCM Suite Unlimited 1999 F-body License (NOT MPVI) + Freebies
- FS: NOS brand plate and solenoids
- SOLD! Bassani Stainless catback for LS1 F body, will also work on LT1
- Brand New Boyd Air Vent Rings for Firebirds
- 243 Heads! fresh valve job, cleaned and ready to bolt on. MAYtrade for cam swap parts
- Gauging interest TEA ported L92's and FAST 102mm
- SLP lid
- 2000 Trans Am WS6 wheels for sale
- PI 3400 th400 conv,backseats
- 100% Complete D1sc Procharger kit
- LS7 Clutch kit CTS-V adaptor/speed bleeder
- 317 heads with patriot golds new
- LS1 engine parts plus other parts F/S
- F/S: hypertech 3 : 96 camaro/firebird
- FTI 8" full competion race converter NEW
- Forged 408 pistons
- Engine parts New&Used
- sheet metal body panels 99 SS camaro
- 10 bolt Rear
- FT/ Borla Muffler from the borla adj CBE
- Hughs LS1/TH400 4500 stall torque converter
- Pro Fogger direct port Kit,FS/FT for intake,TB,Turbo stuff,K memeber or??
- stock maf sensor
- 2000 stock trans am seats
- Power Steering Cooler from 2002 WS6
- For Sale Stalls Cams Lifters more
- 6.0 Truck intake.
- LS6 intake and springs, K&N FIPK Intake System, SLP LM, UMI torque arm and STB
- LT1 rail with AFPR
- LS6 Intake, TB, Camshafts, Catch Can, 3.70 gears, Cometic, Heads
- 99 Chrome Vette Rims Wagons w/Tires&Sensors
- SLP CME Tips & Bends
- 98 350 vortec shortblock
- Fs...Corvette pullies and lots more
- fs:235-60/18 goodyear tires
- HSW Wet Nitrous Kit - BRAND NEW
- 317 heads with ls6 springs
- LSX tall deck block brand new
- LS2 Portworks ported LS2 intake
- Nasty Polished Fuel Rails w/ Black lines/fittings & Fuel Pressure Regulator
- LT1 cold air intake
- *Couple items for sale* XPIPE, TSW 500, Manifolds
- Corvette Y2K wheels
- Sold
- BMR Shock Tower Brace
- 85mm 5 pin maf
- 98 camaro 6 speed ecu and wiring harness
- stock ls7 pushrods for sale
- BNIB comp cam N/A power
- 02 zo6 trans, torque tube, misc...
- sold
- Port&polished LT1 heads and cc306 cam SOLD!!!!!!!
- Gm replacement ls7 lifters
- chromemoly pushrods 7.4"
- stock ls2 crank 24tooth
- few things for sale..valve covers, tires,etc
- Rebuilt 4L60E FS, converting to six speed
- Headlights, Fenders, Mirros, Maneal Console, Etc...
- Pro 5.O Shifter(SOLD)
- Nib hp tuners pro kit with 12 credits!
- misc nitrous parts...lines, fittings, etc
- Lakewood Driveshaft Loop
- GM 3.42 Ring & Pinion
- Truck Idler pulley relocate bracket
- Intercooler.
- FS: FAST 90mm Intake bottom half Cracked, Easy Fix
- FS: LS6 inake/tb
- Long Tubes, Flexplate, 1.6rr and studs, ARP Headbolts, AC Delete
- WTB: (4) 17X11 +50mm offset
- LS1 Coils and DBW throttle body
- New STS turbo kit
- Electric cutout....$55 shipped
- sold
- sold!
- Lt1 52 mm tb
- Nitrous Outlet 90mm Plate
- 2000 LS1 Engine
- 2010 Camaro engine cover
- Truck manifold head pipes for custom build
- stock and aftermarket lt1 parts
