View Full Version : Parts Classifieds
- SOLD---Comp Cam XER 224/228 .581/.588 114 for a LSx
- Stage III 4L60E
- sos ms 10pt 93-02 cage fs
- 241 Heads with 17,900 miles
- LS6 fuel injectors stock 28.8#
- Procharger Pulleys | Custom Fan Shroud
- Granatelli MAF
- LS3 head gaskets. BRAND NEW!!!
- 2002 Rear End for Sale with 3:90 gears
- Red MSD 8.5 Wires
- 2002 M6 Aluminum Driveshaft
- ABS Block
- Hotchkis STB - SOLD
- New Eibach Pro kit front springs
- 2001 OFI Turbo SS - going back to stock"ish" sale
- 15x12 double screwed draglites
- 5.3 / 6.0 Truck manifold flanges
- 28lb injectors, p&p maf, and much more
- Aluminum Driveshaft
- Strange Dana S60 Locker/Gear
- 2001 5.3 truck engine /w harness.
- Aem ecu 30-1220 and lm1 with xd-16 gauge
- lsa block and rods
- FS: Stand alone Nitrous fuel system
- GM Performance 25534401 - L76/L92 Carb Intake Manifold
- BNIB Fidanza 6.5 Twin plate clutch
- New Tick Master cylinder
- 08 5.3 H/C with 800 miles on it, complete with wiring
- FS: SBC 383 Stroker - Lots of $$ invested!
- pat. 59cc heads and stock diff
- LQ4 pistons/rods/oil pan
- 408 6.0 block
- NEW Monster Clutch Level 5 w/LWB Flywheel Only have 1, Lowest Price Ever!!!
- Comp 918 springs with retainers, locks and seats
- corvette wagon wheels MINT
- Gt47-80
- nos direct port no drilling intake cheap..
- 70-81 Camaro Tubular Upper Control Arms Global West
- L92 VVT Comp Cam, Stock F-body LS1 Cam
- 3.42 gears
- 42# Lucas Injectors
- BNIB: Magnaflow 3" in/out muffler
- F-body Poly Engine and Trany mount NIB Black
- NEW LS1 Injectors 12555894 set of 8
- Trickflow 225cc Heads
- Livernois Motorsports Stage 3R CNC 243 Heads
- LS6 Intake Manifold - ported
- Camaro or Firebird Convertible Boot
- ZL402/CNC patriot Heads
- RHS Billet Main Caps New
- TRICK FLOW hardened push rods
- BMR weld in LCA relo brackets, black GS stipes, black hockey stipes
- ls1 vic jr intake fuel rails
- Ram adjustable master cylinder
- a4 stuff, tranny, pedels, shifter, console, firehawk wheel
- yank 4000 ss and zo6 wheels
- ls1 k&n air filter for lid swap on lt1 or 98-02
- black zo6 wheels and tires!!!!!!!!
- 1LE Rear Lower Control Arms, 28lb LS6 Injectors, Stock Panhard Bar
- Kooks 1 3/4" stainless headers & off ride Y-pipe.(pics)
- Misc Tastefull Mods (StealthBox, BilGrille, Head Plate, +More)
- 4th gen T-top conversion set up
- Custom Comp 228/232 cam and 918 springs
- Mad Man alternator relocation bracket SOLD!! and aluminum lt1 valvecovers
- machine finish billitt caps oil-powersteering- radiator caps
- Whisper lid and smooth bellows
- FS: LS N/A 427 ci engine
- 2002 WS6 Trans AM & LS1 Engine Part Out & More!
- FS: Spoiler-Universal-Supra style
- SVO 42lb Green Top Injectors, LS2 Fuel Rail and more
- painted intake gaskets p&p tb and maf ends
- Strange front brake kit 20 passes like new complete assembly with strange hubs!!!!
- C5 Z06 Z51 center caps
- Camaro Billet Grill
- **Sold** FS: O2 Simulators and 2nd gear override
- Ls1 Motorports Air Lid
- Set of 4 NEW Holeshot HoleStar Wheels
- LS2 #243 heads Comp Cams #26921-16 H/D spring kit with Titanium Retainers
- Stainless Steel Z-28 emblems
- Ported FAST 90 (only 2K on it)
- slp maf for a stock maf
- 241 Heads w/ PRC .650 lift springs
- Yella Terra 1.7 rockers / 7.500 pushrod combo
- 99 Firebird seats and Comp custom grind
- Lightly used SVO "Green Top" 42lb injectors
- Manley 11501-8 & 11500-8 - Manley Race Series Stainless Steel Valves
- Like New COMP Cams 943-16 - COMP Cams Solid Roller Valve Springs
- Lonnies twin intank pump setup, no miles
- Siemens Deka 30lb Injectors EV1 - Fresh 0 Miles *flow matched*
- Lakewood Drive Shaft Loop - Brand New In Box
- MTI black lid
- comp 7.350 pushrods
- Lot's of performance parts, LOOK!!!!!! Updated 11/14
- Underdrive pulley A/C gatorback belt
- L76 intake
- U7198 Predator
- Trans am Fenders & Headlight, Suspension Parts
- 25%UDP-Bmr STB Walbro255
- Z28 Full Part Out
- LG G2 adjustable phb
- 98-02 Factory OEM WS-6 Ram Air Hood
- ls1 bare block
- ultradyne LT1 custom ground cam
- LT1 parts 58mm twin TB and more parts added pic added
- **stock heads cam tranny some performance parts..
- Window motors for 98+ fbodies
- 4 chrome snowflakes off 2002 z28 and 2 aluminum snowflakes w/ blizzaks for sale
- L92/l99 heads (2010 camaro)
- 10bolt,4l60e,z28 rims/tires an camaro stuff
- LS1 02 sensors and extensions for LT's -Price Drop! $50..
- FS: z06 replicas
- Twin Turbo T/A Part-Out
- Ls1 s10 part out!
- LS7 long block from 2006 Corvette Z06
- Stage III 317 Heads/Cam Package
- F/S NEW-SLP CENTER Mount **** SOLD
- For Sale: Dorman Clutch Master Cylinders
- Ls race parts got to go
- LSA brand new crate engine $12,000
- 95 camaro part out
- FS: (2) LS2 Intake Manifolds
- 21"5th gen rims,speedlines,zex bottle,ls1 parts
- msd coil for lt1
- T56/4L60E slip yoke PRICE DROP
- Cranks, Rods, Pistons, and Various Parts
- SOLD FS -TSP stroker Cam 251/259 .660/.663 113 lsa
- 94 Camaro Z28 t56 partout
- jesel shaft mount. drysump valve covers. oil pan. headers poly mounts
- ls1 Mezier Electric Water Pump "Race Version"
- Nine inch rearend and 91/98 turbo all new
- Going ltcc, selling OTVC, MSD OPTI CHEAP! PICS!
- C5R lsx ls1 heads intake m&m tunnel ram
- ATR Pitbull mufflers
- stock parts(non ws6 hood)abs,6.0 manifolds
- Factory master cylinder from 2002 Camaro SS 78k
- Holley LT1 Billet 52mm TB
- Comp Cams LS1/LS6/LS2/LS3 Cam
- B&M Ripper Shifter & C6Z06 Shifter Knob
- ft/slp lm1 catback
- Modded C6Z exhaust
- fs 25534401 L76/L92 carb efi Intake Manifolds
- 18" C5 Z06 wheels
- Polished GMMG
- fs L92 heads assembled w/ yella terra rockers
- Pcm
- polished WS6 times with tires
- mac mid lengths 1998 camaro with egr
- 1999 camaro front end sale bolt in and go!! everything u need
- performance parts
- Granatelli mass airflow sensor
- a/c compressor 00 camaro ss 30 thousand miles
- Superchips LS 1/2/6 Flashpaq Tuner
- Trade 4 Chrome 18 by 9 rebels
- WTT spohn adjustable torque arm for Transmission mount torque arm
- Bogart slicks/skinnies, MAF, torque arm and more
- m/t dragradials and slicks for sale
- Lt1 pro charger and tons of race parts for 93-97
- GTO Fuel Rail Covers & AC Setup & Radiator
- LT1 Ported heads
- Ls6 intake ported tb
- Ls1 & ls2 parts
- new stock head bolts
- AP Racing 4 disc cabon clutch
- Slp headers, y-pipe, high flow cats
- Vengenance Racing Ported Fast 92 MM
- 4l60e fs
- slp ls1 cai
- F1-R procharger New Never Used
- ss spoilers
- ** Free Shipping ON HP Tuners Kits
- Adj PHB, Catch Can, Cam swap tools FS
- Precision 76mm FS!!!!!!
- LT1 water pump
- LT1/SBC Black Centerbolt red bowtie valve covers
- 12 bolt spool and metco lca
- SLP Air Lid with K&N filter
- Lt1 starter
- lots of parts, engine harness, heads, visors, 1/4 panels, fender...
- FS LS6 moneymaker, with wet kit + corbeau fx1 pro seats + more!!
- MSD optispark vented #83811
- zo6 wheels and tires FS!!!
- FS: Chevy LS1 High Torque Starter
- LT1 Part for sale low miles alternator FS
- NOS plate kit (wet) 78mm
- Master Power T70 .96
- 16 inch chrome 4th gen Trans Am wheels, adj LCA
- FS:Direct ports system, NW 90mm tb, Aeromotive fuel rails, 90MM Plate
- C6 vette rims for sale!
- Edelbrock LT4 Intake 7107
- Gates Belt K080408 - Brand New
- Two 02 simms
- 1 oem zr1 rim
- LSX to TH-XXX Swap Flexplate
- Tial 50mm bov
- Big Stuff 3 BS3 for sale
- 5.3 longblock, CAM, LID, MAF, 706 Heads, Formula Front Bumper
- FS: Sparco Torino II Seats (Los Angeles Area)
- PRO 5.0 shifter- $100 plus shipping
- FS: CCW classics, C5 Corvette offset/backspacing 17/18 front/rear
- Ford 80 lb/hr injectors
- Fast 46LB injectors
- LS1 Covers, oil pan, 5.3l pistons/rods, PCM, rockers, lifters, valve covers
- camaro decklid panel(taillamp panel)
- Fast XFI new in unopened box
- dual electric fan setup
- TA driver's door and door panels
- Hotchkis STB
- GM 3.42 gear set
- 2.73 posi 10 bolt from '99 TA
- 4L60E from a '99 TA
- Complete Incon Twin-turbo kit, Spec 3, Foose wheels, BFG KDW tires
- Moser 12 bolt w all the goodies, cheap !
- Z06 Motorsport wheels ( Price Drop)
- 26" Hoosier drag radials(Qtp's)
- FEELER: drag racing Eaton Locker
- Bmr, slp, hotchkis
- BNIB Hurst Pistol-Grip Quarter Stick part#3162020
- Nitrous and fuel system and other parts
- Melling Performance LS1/LS2 Oil Pump
- ls1/ls2 oil pan TBss
- ls2 6.0 rotating assembly
- Various small parts and 1 large one.
- 17" zr1 wheels and tires
- patriot gold extreme valve springs LS1 good to 660 lift
- NIB: Elemental Designs 3.6 4ohm Trans Am sailpanel subs
- Trans Am Mirror, Stock MAF
- 6.0 lq4
- FS: LS2 heads
- 317 truck heads CHEAP
- Pedals, Shifter, Console, Rear Seat, A/C.....
- 2004 gto part out
- Custom 1 7/8" - 2" stepped headers/exhaust
- new eagle forged 4 inch crank
- T-56 tranney for sale... OFFERS! TRADES! OBO!
- appearence parts air filter, mat, chrome, strut tower brace
- brand new black corvette frc
- steering wheel airbag
- Racetronix Fuel Pump, HSW arming plate, Trans mount
- *NEW LS1 Billet Main Caps*
- Turbonetic TC78
- 342 gears
- 315 60 15 m/t dragradial 85 % left
- Chrome Firehawk Wheels FS
- Moser 12 bolt for sale
- APR head bolts
- Trailblazer SS Intake Bare 09-10
- Brand new Nitrious Dave N2o Outlet Wet Kit! - NEED GONE!
- BRAND NEW Chrome Center Caps FOR SALE !!
- K&N CAI FIPK2 93-97 LT1 Car $65.00 Shipped **PICS ADDED**
- RPM Level V Auto, Yank 3000 Converter, near new
