View Full Version : Parts Classifieds
- ls1 edit software and cables
- For Sale: LS1 LS6 Auto Trans Engine Harness - SOLD
- 2003 Silverado 1500 part out
- stock g8 intake, injectors, rails
- T56 Swap kit and or parts FS indvidually too
- Solid roller camshaft
- Asp underdrive alt overdrive
- wts camaro trans am driver side t-top 93-02
- M/T drag radial 275/60/15
- hoosier qtp 26*11.5*15
- Katech black truck billet tensioner
- Sick Ls6 Intake Set up
- Mustang Saleen 18 wheels
- LS1 Performance parts
- TA Performance Products Rear End Cover
- Helmets and fire jacket
- 28x12.5 et street radials
- low mile 317 heads with patriot golds
- PTC 9" converter
- Z06 85MM Mass Air/New
- LS1 fuel injectors w/rail
- TCI 2400 Stall Nitrous Torque Converter for 4L60e/700R4
- LT1 Engine w/ Aluminum heads
- Stand Alone S&P harness and ECM
- 35TH LE Anniversary Wheels Price dropped! will ship
- SLP 85mm MAF
- Power Steering Cooler (Factory LS1 style) $40 SHIPPED - Pics
- 2 BRAND NIB Tial 38mm wastegates
- Soundstream 7" in-dash DVD player
- Alky Injection Systems Trunk mount kit
- (2) 275/50/17 M&H drag radials
- 2 chrome centercaps off ZR1's
- Stock LS1 injectors 28#
- Stock LS1 Intake
- FS: LS1 Water Pump
- 6LE Custom Gauge Overlay for Camaro Z28, 99-02
- 6.0L 80k miles
- Brand New ARP Head Bolts 04+ and ARP Rod botls
- (2) 275/50/17 M&H Drag radials
- (2) 275/40/17 Yokohama's
- Wolfe 4th gen parachute mount kit
- Wtt .040 454 For Complete LT1
- hvac delete panel, stock stuff
- 93-97 f body lt1 v8 swap
- Blingmaster Polish
- Nitrous Outlet 78mm plate
- FS: Shorty Antenna
- FS: C5 ZO6 Shifter & Billet Shift Knob
- FS: 01 ZO6 Camshaft
- (6) 18" Miglia Wheels, Stainless GTO Valve Stem Caps North NJ
- Misc. Parts for sale, Procharger bracket & pullies, McLeod Master
- LS9 bare valve cover 12602209
- low miles ls1 for sale
- Odds and Ends
- Etp ls7 heads new
- F-body stuff, mostly LS1
- F/S: UV dash gauge LED's (set)
- F/S: LCA's & Panhard Rod w/ Energy Suspension Poly Ends
- Monster stage 3 clutch kit BRAND NEW with lightened chromoly flywheel etc.
- UMI Shock Tower Brace f/s
- NX Nitrous Kit
- 6.0 LS forsale/trade
- FS: Brand New Chrome 18" Ruff 279's
- Vigilante 4400rpm Stall Torque Converter LSx/th400 trans
- Corsa Muffler and Tips
- Parting out LS1 turbo mustang *TH400, suspension, gauges, Prostars etc*
- EV1 pigtails
- FS: LIKE NEW LT1 Vented Optispark MSD Cap/Rotor
- ETP heads 215cc
- Th350 JW ultra bell
- LT-1 Parts
- FS~ Some used stock parts from my 2005 GTO
- OEM Camaro SS badges, new, silver/black
- LS6 Long Block assembly
- A few 93-02 F body parts
- Emblempros "Firebird" License Plate
- LS1 o2 simulators!
- Corvette and truck manifolds w/1 O2 sensor, stock dbw throttle body
- FS: Superchips 2950
- C5 Driveshaft (new in box)
- 3.42 ring and pinion
- Panhard
- Built LS1 FS..Cars Been 11.60s Frist Time Out
- NX kit, Nitrous outlet plate--lots of extra's!
- Pacesetters and TSP true duals
- Mufflex,big SX fuel pump, NOS controler LS7 lifters. NEW PRICING!
- Moser axles, 4th Gen w/tc, pair or each
- '99 LS1 Shortblock w/ intake, wiring harness
- Trick performance duall window switch..details inside
- 1998-02 OEM WS6 Hood ***Excellent Condition***
- FS 6.0l block, Wiseco Pistons, Cam Motion Cam
- For Sale Goodyear Tires
- ~3600 vigilante stall
- Fbody aluminum LS1 T56 driveshaft
- FS: 17x9.5" & 17x11" TT2s with tires
- Garage Clean Out!! Zex Dry Brain Box!!
- LT1 Motor, 2 4l60e Trans, LTs
- BRAND NEW LS1 Centerforce Dual Friction clutch
- two ss wheels
- 275/40/18 firestone firehawk tires
- M6 Upper Console and Lower Shift Boot
- M6 Transmission Cross-member
- M6 LS1 Driveshaft
- Hurst Shift Knob
- Garage clean out
- SOLD - Futral LS cam and LS6 valvesprings
- *New* Cammotion 252/259 cam
- Mufflex Y-Pipe "Bump stop" Hanger
- Spohn Torque Arm - Transmission mounted, 10 bolt
- New LS6 Heads Cam Used LS6 heads intake
- Midwest Chassis 9" TH400 tons of options NEW! ACCEPTING OFFERS FOR QUICK SALE.
- 93 TA M6 Part Out (Updated)
- ONE NEW 315x30x18 tire
- Pro 5.0, Comp 7.425 P/R, T/A relocation cross member(M6), rod end PHR
- 160# e85 injectors
- 98-02 T56 throwout bearing
- FS/FT 7in Eonon Touch Screen DVD, TV, CD, Blue Tooth, MP3 + wiring harness and bezel
- FS: 7.350 pushrods
- F.s. Evolution hood and p90x
- SLP Loudmouth I 3.5" Slash Tips
- LS1 Parts..
- TSP true duals with tail pipes(magnaflow)
- zr1 and c5 wheels
- American Racing headers 1 7/8 with y-pipe!
- complete 6.0l parting out
- FS ls1 6spd engine harness ecu
- 3.73 Gears With Install Kit
- LT1 magnaflow exhaust
- NEW Corvette oil pan, pick-up, windage tray. (BATWING)
- Braided Turbo oil Feed Line (Complete)
- camaro gloss black berger panel with ss inserts ready to go!
- Passenger Side Longtube Header
- FS:4L60E+ wiring harness
- LT1 parts for sale$$$$$$$$ MOVING TO FLORIDA MAKE AN OFFER!!!!!!!!!!!
- FS: Trackbird Engineering Aluminum Rod End Panhard Bar, New In Box
- F/S Two B&M SuperCoolers #70265
- 42lb flow matched injectors
- FS-Lingenfelter LNC-002 2 step, Nitrous solenoids ,Edelbrock 4150 Nitrous Plate
- FS: FIKSE FM5's
- WTT - my 90mm power ring with dual nozzles for your NX MAF end
- CME Exhaust for Camaro
- YANK SST 3200 stall
- 305/25 R20 Continental Z Rated Tires (2)
- 275/30 R19 Continental Z Rated Tires (2)
- ARP Head Studs p#-234-4316
- STS elec dual stage boost controller,misc sts turbo piping,lt1 canton vc's,etc..
- LT1 Magnaflow and LS1 Cam For Sale
- VHT Nite Shade'd LS1 camaro tail lights
- Garage cleanout-Peformance and stock stuff
- 383 Stroker T56 6 Speed Package ~ 500hp
- LS1 front brakes, control arms, WS6 springs/shocks, MSD6A, K&N Filter, Driveshaft
- UMI LCA relo brackets, Yo Fab t-top shades
- polished Z28 style tips by SILVERLINE
- new torque arm, new oil pan, ati super damper
- ati super damper non ac 10% under
- Garage cleanout! Lots of random stuff for sale! Pics!! UPDATED!
- F/s HD Truck Wheel and Iroc Wheel
- MAF, Coils
- 93-97 firehawk hood and RamAir Box
- LS1 injectors/rail, LQ9 heatsink coils
- 85mm BBK THROTTLE BODY nitrous outlet plate
- 04 5.3 engine harness complete uncut
- 2004 5.3L longblock Turbo style
- 10# NOS sell or trade for MAF
- Toyo R888 295x30x18 and 315x30x18
- ~LS6 Intake 290$~~
- Nitrous Express 10lb Bottle
- ls7 clutch low miles for sale
- nitrous works kit
- 2007 C6 Corvette wheels 18 / 19"
- WTT of Sell TH400 Set up For M6
- 1 5/8" to 3" header collectors
- FS: Futral F14 Cam (Like New) and Comp Hi-Tech 7.35 Pushrods
- M9 and GM c6z06 wheels
- K&N Camaro/Firebird FIPK Kit For Sale
- FS: 05-08 C6 Corvette Kooks Headers X-Pipe & elec cutouts
- FS: 05-08 C6 Corvette Corsa Sport Exhaust with pics!
- FS: QA1 adjustable dampers (shocks) fits all C5 and C6
- LS1 HOT Cam Kit
- Rollmaster double roller timing set
- ARP 134-3610 head bolt kit
- camaro dash
- 18in Hyper Black C6 Z06 rims cheap!!
- Infinity Kappa 5 amp for sale
- lt1 granatelli wires
- LQ4/LQ9 truck heatsink coils/harnesses/brackets
- Corsa Mufflers. True dual project
- FS,MSD5096 LS starter motor
- 4.8l complete
- Misc. parts torque convertor, MSD Boost a pump.......
- built 4l60 forsale
- camaro kyb agx adjustable front struts
- Wiseco 4.8/5.3 custom turbo pistons w/pins and rings
- Slp, arp, bmr, lakewood, hotchkis
- Innovate LM2 - used only once - $300 w/free shipping!
- T56 Pedals M6 console w/boot, 16" procharger Fan, 9:Spal fan
- Misc LT1 items
- USED Ross racing pistons for 4'' bore 4'' stroke (402ci) ls motor,PICS ADDED!!!
- T56 6 speed from 99 z28 with extras....brand new monster stage 3 clutch etc.....
- Ported LS2 Intake Manifold
- Comp Cams 850-16 lifters
- Ford Racing/SVO 30lb Injectors Red Tops EV1
- LS6 intake manifold
- Brp 1 7/8 coated LSX S10 long tubes
- FS: Misc OEM ZO6 Parts; Cam, Headers, Etc.
- 7.250 Crane Cams Hardened Ls1 Pushrods for sale (less than 6k miles on them)
- LS1 Parts- MAF Meter, Valley Cover, other misc...
- NEW HKE 408 Long Block For Sale
- NEW HSW 90mm LSX nitrous plate kit, $450 shipped
- Procharger kit
- Parting out 2000 trans am tons of goodies(more added)
- FS: *Brand New* PRO YANK 3400 EXTREME
- Brand New M/T ET Streets 28" 325/50/15
- AFR heads/Single Plane-LT1
- o2 extensions
- motor and parts clean out
- cam sensor, arp long wheel studs, lt1 backing plates
- z28 hood
- 2005-2006 L33 5.3L manifolds
- LS6 intake and polished throttle body
- Z06 wheels-- Hoosier drag raDIALS
- Brand New GM Sail Panel
- SLP Dual/Dual for sale
- SLP Ram Air Intake for ls1 or lt1 $85 shipped
- 5.3 and 6.0 stuff
- fuel Rail LS1 LS6 99-04
- Aluminum sumped fuel tank
- Innovate LM-1 Wideband and LM-2 RPM Converter
- Bosch premium oxygen sensor FOR SALE $35 SHIPPED
- F/S: Weld ProStar rims
- Camaro interior and Bird wheels + GFX + G5X3
- Mickey Thompson 26x11.5-16 ET Streets
- Weld Pro Stars and ET Radials 3.5"/10"
- walboro 255 and P/S pump F/S
- hardened 7.4 push rods 214 heads comp 918 springs
- Chris1313 ram air (non A/C)
- Meziere Remote Mount Electric WP
- BFG 275/40/17 drag radials (practically new)
- LT4 "Hotcam", Chandler Opti, NEW Roof Panel and more
- Hurst shifter, short stick, and slp H knob
- 97-02 Radio Bezel with SS plaque
- FS: 02 WS6 springs / strut mounts / brake pads / New sensors / lug nuts / interior
- 241 Stock Heads and Stock LS1 Cam
- New items. Headers. Oil pan. Adj. Torque arm.
- AEM Tru Boost, Turbosmart Raceport blow off valve
- WTB: Seat belt guides T/A seats
- ls7 valves, patriot springs, turbo manifold flanges
- Nitrous Outlet Plate Kit
- Gto t56
- everything's sold
