View Full Version : Parts Classifieds
- EPS cam and Manley springs with very low miles....
- BULK of Chevy 350 parts!! LS oil pump, forged rods
- Fs: Cnc ported ls3 heads and intake manifold - bolt on 140hp
- 99 T/A exhaust, 4L60E Chrome Trans Pan "NEW"
- PRC .675 springs,TSP Torquer v3 cam, LS6 cam etc.
- SLP Blackwing lid
- 98-02 Camaro Full Interior and SUNCO HOOD!
- Garage sale!
- FS: Autometer Wideband Gauge Nexus Series
- Texas Speed 7.4" pushrods chromely
- Moser 9", Spohn torque arm, sway bar, LCA's, panhard bar, Adj. shocks
- Procharger 6-rib balancer pulley
- brand new TFS cam
- Hurst Line Lock
- For Sale: HP Tuners - Serial Version
- guaging intrest:built 347
- oem ram air hood
- LS1 motor and Pacesetter Long Tubes
- z06 wheels & adj panhard bar
- Rockers with Comp Cams Trunion Upgrade
- FS ported TB 70 bucks shipped
- Stock and Performance Engine parts (LT1) *Updated 7-18-10*
- Ported Heads For Sale!
- 4th gen T/A power mirrors
- ltcc ign system
- F Body Oil Pan & Corvette Batwing Oil Pan
- Brand new never opened EFI 24x conversion kit with lsx pcm
- sphon solid motor mounts
- Carillo H-beam rods 6"
- VIGILANTE 3600 single disc lock up converter
- -MSD Wires-NGK TR55s-oil filters-
- SOLD SOLD REV Titanium Retainers and dual springs
- 317 heads, truck oil pan, crank, 4l80e trans, rockers
- LS6 Manifold pn 12573572 with 17KMiles off of cts-v SOLD!
- z06 oem gray rims and goodyear eagle f1 tires 9k miles
- Complete NOS / NX Nitruos Kit w/ Timing Tuner bottle heater purge brackets
- Instrument Cluster 99-02
- NIB Comp engineering rear drag shocks
- 4Ch Backing Plates
- new brakes front cross drilled rotors
- Wheels, exhaust, and more for sell.
- WTB T56 swap
- C5 Brakes complete front/rear Hawk HPS
- Coil packs w/ brackets..
- FS: NEW ARP LSX Block 12pt Head Studs
- lots of parts borla,billet mains,and more
- Hoosier Slicks For Sale (FL)
- UMI Strut Tower Brace, Red, New
- NEW Walbro GSS340 and T4 Turbo Blanket
- 02 extensions
- PART OUT!! 2002 camaro ss
- Stock virgin LS-1 MAF for sale.
- Granatelli MAF
- Custom Camaro Black/Grey Seats w/harness
- FS: Pro Stars with MT ET Streets (not radials)
- stock parts need gone/ taylor battery box
- Rebuilt ls1
- ***17x9.5 BLACK C5 Deep Dish Rims***
- Grey stock GM lugnuts and stock wheel locks
- L92 intake assembly &w/wp
- Brand New Ls6 Intake SOLD!
- 5.3L's, NBS truck parts
- Boyd Coddington Smoothie Wheels and Tires
- C6Z Radiator hoses, brake pins, Fog lite bulbs, O2 extensions
- B&M Magnum Carbon Fiber Shifer & 5 Gal alum Fuel Cell
- Want to Buy Chrome 17 inch WS6 Wheels with tires!
- FS: '00 WS6 Rims & Tires
- EFI live
- 80mm BBK TB
- MBA WS.6 Shift Knob - Black
- 99 z28 parts.
- 2greg weld wheels
- Complete aftermarket FBODY Speaker System--NEW
- 2greg weld wheels
- ls1 water pump
- bosch 42# white giant injectors
- 98-02 TSP TD's, VFN WS6 pin on hood
- LT1 383 Mahle Light Weight Forged Piston With Rings CHEAP
- ss hood, interior trim, ls1 garage sale many parts
- CTS-V Oil Pan LS1/LS6! New
- LS2 Intake Manifold & DBW Throttle Body
- E67 ECM for sale
- WTT WTB 6.200" eagle rods
- TFS CNC 235cc Heads w/shaft mount rockers pick up in Michigan ONLY, no shipping
- 93-02 Black Leather Camaro/Trans complete rear seats
- Roxanne's scrap pile! Used stock and abused aftermarket parts for cheap
- Pontiac Grand Prix GTP 36# Injectors, Cheap upgrade for you LS1 guys!
- FS: PAC valve springs, FTI titanium retainers, FTI valve locks
- Turbonetics GTK1000
- new exhaust tips for sale and stock ws6 exhaust
- TONS of parts, ls6 pumps, stock cam, injectors
- Pair of Gto spares
- FS: 224 cam
- Hooker Catback w/ Corsa Clones
- ls1 sts rearmount kit REDUCED! $2,200!!! OBO
- Complete Dry Nitrous Kit! Purge, Window Switch, Heater, Electric Gauge, Switch Plate!
- 2 - GM Fbody Clutch Master Cylinders
- 255x50-16 MT Drag Radials. Two 16x8 rims
- New T56 throw out bearing
- 94 Z28 Parts, LT1 minus heads, stock/aftermarket
- FS: Futral F14 Cam (PICS ADDED)
- Stock TBSS take off parts...
- BNIB Spohn non adjustable PHB
- PICS ADDED*** Dynatech 1-7/8 LS1 swap headers for 67-69 Camaro
- RPM Level 5 transmission and 4k Triple disk Vigilante Converter
- Procharger D1SC twin intercoolers LS1
- 7.450 pushrods
- RS spoiler, Stealth sub box, stock suspension stuff
- 25% underdrive ls1 pully
- GI: Black Basecoat/Clearcoat Fiberglass'd Dash to be let go
- LS1 BBK intake, 241 heads, magnaflow, etc..
- luvlady th350 w/brake and ls stall
- 347 forged assembly
- Siemens Deka LS2 EV6 Direct Fit 54lb Injectors
- Precision PT106mm for sale
- Corvette Fuel Rail Covers
- FLP LT hi-flo cats
- Trick Flow 7.700 x 5/16 Pushrods
- taylor battery box
- ASP alternator overdrive pulley
- Monsoon Factory Radio from 2002 Trans Am
- F/S 76mm TURBO Turbonetics Refreashed like new. T4
- FS: Monsoon speaker (sail panel)
- ls2 cam for sale
- Hypercoil springs f.s
- ls1 headers, y pipes, o2 extensions, header gaskets brand new $550
- ls1 fast intake 90mm throttle body $700
- borla cat back
- LT1 motor pull out/ T56 / some ls1 parts
- Brand new NX MAF kit F/S
- Chicagoland area : P255/50R16 MICKEY THOMPSONs NEW $275
- TPS sensor
- LSX-383 for sale
- Cleaning out the shop going to the scraper on friday july 30
- 2007 Z06 Wheels
- parting out a 00 formula, 94 camaro Z28, and a 95 trans am
- FS: 5.3 Vortec Parts and 98 LS1 Intake Manifold
- Drysump and ls1 BS3
- F/S: Ls1 crankshaft
- Yank PT4000
- LE1 Heads
- 396 solid roller lt1
- textralia oz700 z grip clutch!!!
- Ram air duct
- Th350C lock-up - $300
- FS: HSW 78mm Plate WET Nitrous Kit
- NX nitrous kit with NOS purge...cheap!!!
- Stock 5.3 heads,706 casting#
- FS: JET CAGS 61619 2004-2006 GTO Skip Shift...NEW!!! Price is Shipped
- LPP Stainless Longtube Headers and y for LS1
- rear spring isolators
- Stock LS1 driveshaft
- FS: Pas. T-Top, K&N CAI, MSD Opti Cap/Rotor
- Brand New M/T 295-45-17
- Oil Pressure & Water Temp Gauges
- delete
- Shift knobs, FTRA,
- 2 Bridgestone RE-11s for Sale 305/30/19s
- Custom 85mm Nitrous Plate F/S!
- Comp Cams Hi-Tech Pushrods - 7.375"
- WS6 Ram Air Box- Granatelli MAFS-LT1 wiring harness w/PCM
- SOLD! Black Steering/Radio Control Buttons
- C6 Wheels 18x8 19x10
- 3.42 Gears
- S76 Turbo + RevXtreme Fuel Rails
- Custom Spec VA Speed Cam for sale!
- Trans Am honeycomb tail lights
- STS Turbo Truck Kit
- 96 firebird roller for sale or part out
- ATI ls1 crank pin kit f/s
- LE2 heads for sale $1000
- Forged 347 and Comp Trunion Kit
- F/S All Pro Heads
- FS : l92 heads New in Box
- Comp R roller lifters (New)
- Clutch and brake pedal assembly - 4th gen
- misc Ls1 camaro / firebird parts fs
- B & M Ripper Shifter 93-02 F-Body
- Kenwood Excelon headunit, and Kenwood Amp
- FS: LS1, LQ9 heads/cam, turbo...
- 2005 gm 5.3L complete engine Aluminum
- *****FS Complete Wet NX Nitrous kit, Comp R lifters, and a couple gauges*****
- Crower 8mm valve locks
- DynoJet 224x
- LS1 Intake and Throttle body
- 2x 4500psi Universal NANO kits
- 2002 Firehawk Rims
- Set of 4 OEM C6 Wheels 3k miles
- Wheels and PHB
- thunder racing 7.400 pushrods
- Stock ported/descreened maf
- Custom LT1 Comp Cam
- stock heads, TB, lid and Stall
- Badlanz 3" electirc cutout new motor, Gasket, extra cap.
- Parts for sale
- brand new ls1 mahle power pack and melling high pressure oil pump.
- LS3 intake manifold,rails and injectors complete
- Complete remote fob and C5 fuel rail covers
- rims hres 18x9.5 and 19 x11 rears
- FS Trans Am Exhaust tips
- FS: WHEELS/TIRES $900 SHIPPED! Alipine HU, MTX sub/box/amp...
- Wtt Deep dish C5 chrome
- turbo hotside/coldside for chevelle, nova
- new bumper and right front fender for sale
- Misc. Parts (rad, fans, TA fog lights)
- Venom nos bottle for sale
- FS: ARP Head Bolt Kit for 2004-up (PIC ADDED)
- Summer Sale!
- 98 Camaro SS Instrument Speedometer cluster
- 96 camaro interior parts
- rossler TH-350 w/ long tailshaft for ls1
- Lingenfelter/B&B TRI FLO cat back quad tip
- Ls1 driveshaft
- NX Nitrous Kit Complete DRY WET, Polished bottle, warmer, purge, window switch, gauge
- Extremely Ultra Rare Daytona Prototype Ported LS6 Intake*
- LS6 intake. ported throttle body, nitrous accessories
- 04-06 GTO procharger main bracket and tensioner assembly (NIB)
- FS/FT: UPD 92 mm air lid
- Weiand Polished Aluminum Intake
- 2001 VHT tail lights (Both)
- BBK SSI Manifold & T.B.
- CCW Drag Pack 16" (black)
- wtt f-1 procgarger for turbo setup
- Lt1 performance parts- t56, K&N, intake elbow etc.
- Harland Sharp Rockers, BBK Throttle body
- M29 T56 42k miles 2.97 1ST GEAR
- MSD Ignition
- 3" Magnaflow High flow Cats New Sealed boxes
- Stock 10 Bolt, 3 Channel- Manhattan KS
- Borla Adjustable Catback, Electric cutout instead of plates
- 2 255/50R16 Mickey Thompson Drag radials (BRAND NEW)
- Cyclone Cold Air Intake for C5's - never used
- MAP Sensors LS1 - LS2 Part # 16212460
- fs: new autometer gauges/ pillar pod
- FS/FT: Black with polished lip 17x9.5 ZO6 Motorsport rims with tires.
- c5 corvette calipers front added more pics
- Silver painted 1996 ws6 wheels......
- SLP SS Mats, Leather shift knob, Crosa tips, Backouts
- 18" bullet mufflers with turndowns
- 94-95 MAC Headers and Y-Pipe
- T56 Bellhousing
- QA1 rear shocks
- Gauge Cluster
- Used 3.73 gears
- New Comp Endurex Solid roller lifters 818-16
- NIB Greg Weld Dragstar Polished 15x10" 6.5" Backspacing
- New Comp 254/262 108 .622 5/7 swap solid roller cam
- For Sale LS2 MAF Sensor
- FS: LS7 Exhaust Manifolds(Jet Hot Coated) & Cats
