View Full Version : Parts Classifieds
- Comp Cams XR269 cam and New Yellow springs
- SOLD!!!: takeoff L92 heads
- wtt L76 intake for carb style intake
- Cors Premium tips for sale!
- For sale ported throttle body SOLD
- Used MS4 Cam
- Aarons Alum Intake Elbow
- NEW Custom Radiator setup
- Thinking of selling my used C5 corvette wheels.
- Accufab 105mm throttle body
- LS1 New Crate motor parts & Used engine parts
- Forged 346 LS1
- 243 Heads with Afr springs Also F/S Center Bolt Valve Covers
- gto pan , ls1 camaro mtr mounts
- F/S Ls2 Gto Starter
- UMI lower-A Arms and UMI K member - Chicago
- LS1 and 5.3L engine parts and MAF
- nitrous express
- aluminum driveshaft
- LS1 EV1 injector pigtails
- Charcoal TA interior pieces, convertible pump, weather stripping, etc. CHEAP
- SOLD!!!! Vortech Aftercooler (Upgraded parts)
- TPS/Lean Shutoff Nitrous switch and bottle heater
- Edelbrock Victor intake, rails, elbow, TB and 42.5 injectors
- YANK Turbo400 LS1 Converter
- MSD Starter
- FS: Forged LS 370 Short block, w/cam, chain, and pump
- WTS:Stock exhaust...
- Textralia OZ700 clutch forsale
- Built 4l60e for ls1 camaro/ta
- Moates RoadRunner PCM 97-98 LS1
- Strut tower brace,Coils,Ati Pin kit, Ls1 valvecovers Bunch of other ls1 F-body parts
- clean 1999 camaro ss
- Black Tial Q Blowoff Valve
- LT1 engine front clip
- Exhaust
- Stock Exhaust Manifolds
- TCI SSF3500 Stall 0k since cut and clean
- 10-Bolt Richmond Gear 3.73
- Stock parts tensioners, belts, power steering hose and more
- 10 Bolt Rear End: FS
- Corvette Z06 Front Brakes, and Leaf Springs
- Stainless header flanges
- GT5533R Turbo 91mm Brand New !!!!!!!!!!!!!
- LG G5X3 Cam
- LT1 Longtubes and dual exhaust
- Power Acoustick BAMF-800/2 Amplifier 2-channel
- FS: SLP Blackwing Air Lid, SLP SS Grille, C5 rims
- 1999-2006 Superchips Programmer LS1, LS2, LS7
- Procharger Big Red Bypass Valve
- 5.3 truck oil pan
- FS: 18" SSR Integral-A2 Rims $150 OBO
- stock 2001 ls1 injectors SOLD!!!!
- Weldon 600-a Fuel pump
- Lt1 four bolt .40 over block
- Camaro/Firebird Steel Fuel Tank Sumped + Pump
- PI vig 2800-3000 stall 6k on it (sold)
- Lingenfelter Polished Intake Manifold
- LPE 100mm MAF w/ Harness NEW~!
- Eibach pro spring kit with Bilstein Front/Rear Shocks Camaro/Firebird 93-02
- Delphi 42# Fuel Injectors
- 243 heads w/ sodium valves & dual springs, LS6 intake, MAF
- 5.3 truck parts
- Bogart center caps
- PRC LS7x 265cc 7.0L CNC Heads
- Comp Endurex Solid Roller Lifters
- WELDSTAR R/T'S. rears with tires
- Gauging interest in a used MS3 cam.
- Ls1 Intake..etc
- FS: LS6 243 Heads with Dual Springs
- Katech billet belt tensioner take-offs for sale $75
- LOTS OF Parts for sale in ny
- 5.3 Intake , Throttle Body , and Accesorie Mounts
- MS4 cam
- gm truck underdrive pulley
- FS: Dynotune Digital Nitrous Pressure Gauge
- few stock parts
- Billet fuel rails and braided lines, March 25% UD pulley, lots of stock LSX parts
- CNC'd Allpro heads*SOLD*
- FS: Poly Motor Mounts in clam shells
- built ls1 for sale
- 317 heads
- 42 lb injectors
- lingenfelter LNC-002 Launch and timing controller
- Ls1 intake/throttlebody/injectors
- BW s475 Turbo For Sale!
- 98-02 LS1 4L60E automatic pedals
- 42lb Green Top Injectors SVO
- 93-97 LT1 T56 6-spd pedal assembly
- BMR Front/Rear Sway Bars
- 2002 Camaro SS LS1 Motor Complete and T56 Transmission Computer Included!
- 2000 Lq4 6.0L
- monster lvl 4
- ATS LSX Road Race oil pan (for 1st Gen)
- LS1 rear brake calipers
- LS1 rear backing plates SOLD!!!!!!
- 5 Gallon Fuel Cell
- For Sale: 3rd and 4th gen F-Body, and LS parts
- LT1 52mm throttle body
- 2 Tail Light filler panels AC vent & Plate frame
- GM SS emblem and wheel caps
- LS9 Piston Squirter Oiler
- 241 heads complete SOLD
- Autometer ProComp Gauges
- LS1 LS2 Parts, Heads, Valves, Pistons
- AFR heads, Procharger, sts turbo kit, Fast 90/90, window switches, VC's, etc....
- Stock catalytic converters
- Ccw drag pack for sale :)
- Stock 4L60e w/torque converter
- OEM rear ground fx camaro 93-02
- GI: WTT/WTS Draglites w/ ET Streets
- Eagle alloy 16x8 polished alum rims with tires
- WTT dart block 406 built for boost for LS motor
- FS: NIB New style BMR lowering springs
- Part out of 96 T/A
- 243's W/Rockers $450 low mileage! L92's with rockers $535 shipped
- FS: NEW Innovate LC-1 Wideband & Gauge
- Racetronix and other fuel system goodies
- Autometer D-PIC D pic Ultra-Lite
- TA bumber FS make offer
- Bmr tubular k member lower a arms and manual rack
- 241 heads with patriot dual valve gold springs max lift .650
- BMR X-treme TA (red)
- FS: Polished Magnuson MP112
- HSW Nitrous Kit, Tunnel Mount and some other nitrous acess. Brand new.
- 10" 150lb & 12" 175lb springs
- Vortech G-trim w/ aftercooler - PRICE DROP - WITH PICS!!
- Brand NEW 355 SBC shortblock for sale. plus more. new price 1000obo
- 2 stage Nitrous kit with 90mm TB ring 10lb bottle w/heater +extras
- Race parts, moser 9" rearend, bmr, lca, etc...
- Strano Springs, Koni Yellow Shocks, LS1 Brake Setup
- 7.4 tsp pushrods
- 2001 Trans am hatch for sale in Orlando Florida
- Brand new 2002 camaro ss seats ebony with gray suede inserts for sale
- Vigilante 3000 torque converter
- Brand new rims, tires, and stock parts!!!
- Pirelli PZero's 275/305 30/19 used
- New Hp tuners, low profile cutouts, ported ls7 intake
- 76mm Master Power turbo BRAND NEW IN BOX
- F13 Cam, coil packs, LS6 cam/ springs etc.
- TH400 Vigilante 3600 Stall Converter
- 853 heads and valve springs and retainers
- LS2 Intake w/Injectors & Fuel Rail + Jet Mass Air
- Dr.X Throttle Body Adapter - X-link
- Built 355 proven 11.70's@119mph
- procharger polished twin 3.5 intercooler setup!!!!
- 243 castings,Kent Moore balancer installer,Chevrolet area rugs
- 799 heads same as 243's CHEAP! COILS W/BRACKETS
- Ls2 timing chain with sprockets
- Used BLACK Tial 50mm BOV 185shipped
- Yank Converter, 918s, 30# SVO, LT1 shortblock
- Used Aeromotive 13109 FRP with 2 fittings 100$
- New gmpp single plane intake
- Used Silver Tial 38mm WG-150$
- N/X progressive nitrous kit 10lb bottle, electric bottle opnr
- FS: DPE R05 Variant S Wheels (18x9 & 19x10)
- GZ motorsports C5 Vacuum pump kit.
- Yank 4400 Stall converter LS1
- Dry NOS System
- Wilson Intake Elbow
- Stealth Box & Amp Rack
- WTS two GTO front spare wheels NEW
- Computech EGT Plus.
- Edlebrock Super Victor EFI for LS1 w/fuel rails.
- JL 10W3 sub
- stock maf
- SOLD: Stock Camaro wheels:SOLD
- Brand new MSD Coils
- Factory Monsoon Amp and Changer
- 2 6.0s for sale ....
- summit 25% ud pulley and belt
- slp lm1
- FS: LT-1 Comp Cam CC503 Camshaft
- My 3 guages for triple pillar pod=65$!!!!!!!!!!!!!!!!!!!!!!!! (Priced for quick sale)
- Ebay / PTK turbo kit BRAND NEW
- valve springs/retainers,sway bars,door panels,d/s,ect.**obo***
- 2004 GTO Corsa Sport Exhaust
- Greg Banish Calibrated Success DVD
- 2004 GTO SLP Headers
- th400/350 converter for sale
- Ls1 4l60e Torque Converter
- Full k&n lt1 cai
- Fikse 18 x 12.5" Full Polish rear wheels - new
- LS7 exhaust gaskets W/bolts
- Moroso Ultra40 plug wires
- G5x3 (114)
- GTK 650 Turbonetics Turbos 4 sale Cheap!
- stock 01 maf ls1 sensor
- Harland Sharp Rocker Arms(non adjustable)1.7
- Spec super twin clutch (PT trim)
- 315-35-18 toyo dragradials
- F/S Head Gaskets
- FS: Two Nitrous Lines w/ Quick Disconnects
- LS1 Coils/Bracket/Harness $125 Shipped
- msd programmable digital shift light
- 468 (454) Race engine and Powerglide w/ brake and 5500 ATI stall
- BMR Trak Pac Tq Arm
- K&n cai
- t-56 6 speed LT1 transmission and Spec Stage 3+, make an offer.
- 243 LS6 Heads Assembled W/Double-springs
- 2 brand new 99-02 camaro/firebird v6 fuel pumps - $65
- 347 forged ...... new pistons and rods
- 53lb injectors $275
- Patriot Performance LQ9 Stage II Heads
- ls1 coils with bracket
- 98 transam part out, stock - couple aftermarket
- Nitrous Noids, 50/each
- Complete LS1 Intake TB injectors fuel rail
- Patriot Xtreme Dual Spring Kit
- LS1 FBody Stock Aluminum Driveshaft Auto
- New JGS 50mm WG, 60mm BOV, GT-88 turbo
- 2002 z28 ls1 Altenator
- Msd 6010
- Slightly Used Spec 3+ clutch and PP
- G5X2 Cam $300 shipped.
- Air Lift air spring
- Red Firebird Fuel Rail Covers
- Truck oil pan and rocker arms w/ stands
- Camaro (LT1) Black Leather Interior
- NEW GM LS1 F body oil pan gasket, comp 918 springs
- ls1 for sale
- chevelle ls conversion parts
- last of my ls parts
- McGard Lugs for Prostars/Draglites
- GTA Wheel
- 17x9 17x11 ZR1's
- 5.3L truck parts and other misc LS1 parts
- LT1 stock parts for sale - FIRESALE!
- 275/17 MT drag radials and wheels
- F body M6 pedal set with pads and switches
- comp camps XER281HR ls1/ls6
- procharger inlet hat, tube and huge filter...........heat shields for truck manifolds
- PARTS,autometer,comp cam,bogart caps,susp. parts,ds with 1350 conv. and more
- 3500 stall
- Various LS1 Camaro Parts for sale !
- Autometer Digital Tach W/shiftlight
- F/S - Lots of C5 performance and audio parts...
- Upgraded HSW nitrous wet kit
- LS1 Heads w/Comp 921 Dual Springs
- 42# @ 43.5psi Lucas/Delphi Injectors $125
- 28.8# Stock Injectors from 01 TA $80
- lingenfelter conversion module 58x to 24x
- painted LS6 intake and ported stock TB
- nitrous plate,bottle,HSWmicroedge etc.
- Center Mount Exhaust (CME) Valance for sale
- Jesel Belt Drive
- Pa Racing K-member
- 26x10-15'' MT ET Drags Stiff
- LT 396 and ZZ4 F.S.
- TR224 custom ground cam new, SOLD SOLD SOLD
