View Full Version : Parts Classifieds
- F-body LS1 FLP LT bolt in converter's
- GMMG CatBack
- LS6 Intake, Spohn Strut Tower Brace, Steering wheel w/radio controls & airbag
- FS: L33 Truck parts
- JE Pistons, MS4 Cam, Ported Heads, Suspension, Nitrous, Interior, LT1
- Parts & Pics added 2/15/10 Brand New Ls2 Intake Ls2 and Injectors, cam and some misc.
- Boost a pump - MSD Fuel Pump Booster Control - works with boosted cars
- FS ForcedInductions ST80 Turbo
- Sold: 98 Camaro 16x8 Inch Wheels $150 OBO Chicago
- FOR SALE:ls1 return style fuel rail
- 4 Wheels & Tires
- 1997 firebird part out & weiand intake ls1
- 2007 6.2 L92 Complete take out Motor
- 112 lsa for sale
- D&D built t56
- LS1 trick flow cam
- '98 4L60E Transmission/Converter and Flexplate
- FS- 90mm FAST Throttle body! *SOLD*
- Drag Parts Blowout
- WTT for Skinnies and Wides.
- Painless wiring harness & ecm
- LS9/ZR1 Injectors Set of 8
- Comp Cams - 224/230 .581"/.588" on 114 LSA
- F/S Siemens Deka 60lb injectors
- SBC Performance Parts
- LT1 4 bolt Splayed 383 Shortblock, PREMIUM
- WTT chassis mounted spohn torque arm for trans mounted
- L92 ls3 compl. Heads, stainless/inconel valves, prc .660 springs, gm rockers, $999 !!
- new yellow z06 springs
- 6l80e 2800 Vig Stall F/S
- stock 1999 maf for sale 40 bux
- !!SOLD!! Double Adjustable Lower Control Arms (LCA) !!SOLD!!
- Harlan 2-step
- 317s with afr .650s, arp 12pt head studs, lca relo brackets
- Upgrade to LS2 Maf!!
- 275/30-19 Cooper Zeon tire like new $100
- LS1 & SBC parts for sale.
- 317 Heads
- Lots of parts 2 motors!!!
- 98-02 Z28 Camaro Billet Grille
- WTB: FAST 78mm Manifold
- Service Manuals 4Sale
- Feeler: black zr1 rims and fuel rail covers
- Dynotune Air/Fuel Ratio Lean Shut-Down Switch
- 2 slp loudmouth resonators
- Complete LS1/T56 Swap
- 98-02 ta hood
- lsx 427 shortblock
- A few Ls1 and Truck/Escalade Parts
- Black 08 Corvette wheels for sale
- SRP pistons and 97 timing cover modded for double roller
- 93-02 rear camaro panel
- OEM LS1 SS spoiler
- Lunati stroker shortblock 383 shortblock
- Used Upper and lower FTRA and new Center console switch plate
- Garage sale - LS swap stuff and truck stuff
- 2002 6.0 block & 317 heads
- ** BRAND NEW Patriot Stage III LS6 Ported Heads!! **
- 860 Performance Bottle Heater/Bracket
- Corsa Clones/C6 Tips
- qa1 275lb springs
- LS1 coils, with mount and harness
- ls6/t56 combo!
- Ported Fast 92 and Nick williams 92mm TB
- YANK ss 4000 4l60e torque converter
- Loudmouth I/II resonators
- NEW LS1/LS6 Engine Block
- Hoosier drag slicks
- trickflow 220cc "as cast" heads
- FS:short 60lb inj.85mm maff,NW 90mm TB
- 99z28 part out
- compstar 6.125 rods
- LT fidanza alum. flywheel
- T56 Hurst shifter
- 02' Z28 Camaro part out
- C5 Corvette LS-1 Goodyear Gatorback A/C Belt
- OEM C5 FRC/Z06 Corvette Antenna
- LT4 hotcam for sale
- OEM LS-1 Oil Pump (Under 20k Miles)
- Corvette Fog Light Housings/Side Markers/Intake/Throttle Body/Thermostat/Tail Lights
- OEM Black C5 Corvette E-Brake and Shift Boots
- Arctic White C5 Corvette Door Handles
- FS: MT 29.5 x 10 Slicks, like new
- Kooks 3" y-pipe
- WANTED- Valve Cover for 97-98 LS1
- LS1 Engine Wiring Harness
- Ls2 Intake Manifold, Spintech mufflers
- Stock air intake assembly for LT1 Firebird
- 2000 nbm z28 part out
- F/S 99 Camaro Door Panels & T-Top Headliner & Shades
- Le heads,nitrous kit,aluminum valve covers,etc
- Billet Specialties 17in Street Lites
- Viair 450C compressors.
- F13 112+4
- Ls1 Double Roller timing chain (New)
- TrickFlow Heads
- Headunit for sale
- N20 soleniods/Cheetah shifter/Cobra seats
- 5.3 long block
- Weiand Intake for ls1
- 317 Heads For Sale or Trade for 243s
- COMP 7.400 PRs, K&N filter, 241 heads/dual valvesprings, stock LS1 TB/plug wires
- Comp Beehives 26918-16
- Low mile LS2 cam F.S.
- L92 parts
- Ls2 engine trans sold
- LS2 LS3 LS7 MSD Coils, NEW GM GTO 05-06 Hood, Comp 918's, NEW LS2/LS7 Throttle Body
- NEW Stainless Corsa Clones
- ls1 intake manifold
- Ls1 moser 9in rear end housing and comp cam!
- LS6 Sodium Exhaust valves, Firehawk Floormats, sphon Drive Shaft, AC parts 241 heads
- Nitrous, exhaust, micparts
- LS1 Powerdyne kit with PCM BD11-A 8 lbs
- Black GTO Wheels & Tires
- 99+ TransAm White Gauge Face
- Mahle 4.005" Forged Pistons -12cc reliefs
- Eibach PROKIT LS1 Camaro Firebird, less than 300 miles. $150
- Mint Condition Aluminum 10 Spokes off of 2000 SS
- 96 lt1 maf
- Sold
- FS: FBody LS1 & Full C5 Drivetrain & Suspension
- NEW LS6 cam, springs, retainers
- FS:93-97 12" Baer Two Piece Eradispeed Front Rotors
- SOLD-Strange S60 & Driveshaft
- 347 ETP Head Long Block $3900
- carb vic jr, T-rex cam and more.
- slp rear lowering springs
- turbo headers stainless!
- fast toys air lid
- Last of my 98 TA extras
- 2001 Camaro steering wheel
- LS1 throttle body for sale...
- Lq9 parts, 317 heads, truck intake, truck manifolds
- New 60# Injectors F/S
- Miscellaneous Fbody Parts
- Cleaning out my garage, stock and aftermarket parts!
- HSW Wet kit sale Cheap!!
- Brodix LT! track1 heads
- HUGE Parts List
- lots of sbc high performance parts
- F Body Susp. for sell
- TNT 90mm Power ring
- slp loud mouth II
- FS: Hp tuners vcm suite MPVI Pro
- Brand new Hooker Super Comp LS1 Headers, 98-99 Camaro, Firebird
- 2007 LQ-9 6.0 liter
- Whisper Lid
- TCI Super Streetighter 3600 torque converter - LT1
- 05 GTO Valve covers and exhaust manifolds
- Billet Specialties Comp Series
- 98-03 Chevy Camaro Billet Grille with SS
- ls1 shaft mounted roller rockers
- Hurst billet plus with UMI short stick in MD
- Camaro/Firebird Power Antenna
- HP Tuners Serial w/licenses for 98 F-body and 03 Malibu
- LS1 Parts
- 93-98 Camaro Airbag
- Stock LS3 Pushrods
- trans am ebony front seats
- Dual gauge POD with Autometer Narrowband
- FS: Many different wheel/tire combinations. MUST GO!!
- Brand New Nitrous Outlet Dual Channel digital window switch
- (2) 5.3 pcm's
- PBM/SCAT 6.125 H-beam rods(new), and Lq9 truck stock parts
- F/S: Comp Cam XR273HR 220/224 -112 $225
- LS1, 4.8L, 4L60E, TH400, 10 bolt, Interior, V6 Firebird & Trans Am Parts
- Nos fuel cell, bmr th350 crossmember,nos bottle heater
- SOLD...SOLD...SOLD...Forged 6.0 lsx/complete shortblock/low miles
- LS6 Manifold and a Ported Throttle Body
- 4.165 Mahle Dished pistons new in the box will trade for 6.0L parts
- 02 TA Parts
- WTT/ WTS 17x11 black ZR1 w/tires
- Ignition coils complete w/ wire harness and brackets
- holley 90mm tb
- Textralia OZ 700 z- grip
- LS1 Intake and Throttle Body
- Stock valvetrain parts! Anyone?
- stock ls1 heads
- (6) camaro zr1 chrome wheels
- Nitrous and Fuel Solenoid FS SOLD!!
- 5.3 parts---LS4 shortblock-intake/injectors/fuel rail...MAKE AN OFFER-MUST GO
- Hp tuners pro cable ready to tune!
- C6 Mufflers
- 98 Z28 Exhaust Manifolds
- Ls6 intake
- 243 heads
- Whole 109 block buick GN built motor for sale
- '97 LS1 Bare Block
- WTT: GTO pan and windage tray/pickup for same F-body parts
- LT4 parts, heads intake 90k
- Kirkley Seats, S91 Turbo, 85mm Turbo
- Door Panels & Center Console
- TCI Powerglide and Neal Chance Converter
- Meziere Electric Water Pump
- L92 Long Block
- EFILIVE v1 scan/tune
- PRC 5.3L Stage 2.5 CNC Ported Heads (never been run)
- 2004 LS6 cam, low miles, $130shipped obo
- Mcleod Street Twin RST
- Harland Sharp aluminum shaft Rockers- Adjustable
- 4 nx proshot carbonfiber selonids cheap
- Lucas Delphi 42# injectors
- Barely used UMI poly/rod lca's,phb, bolt-in relo brackets
- Wilwood 6 piston fronts and 4 piston rears calipers
- Wtb asap stock 2000 valve covers
- L92 waterpump
- Garage Cleanout - make offers
- nx carbonfiber noids
- GI: LS6 intake, and ported TB.
- ThirdGen F-Body SLP 1"3/4 Shorty Headers and Y-Pipe
- Handful of LS1 & SBC parts for sale.
- dash top for sale
- Demodding a 07 TBSS
- 2005 GTO Stock Parts and 2 Drag Rims
- Wtt my t56 set up for a complete 350/400 turbo set up for my 00 t/a
- stage 2.5 5.3 heads
- Misc engine parts FS and WTB
- Brand new in box thunder racing complete cam package! 228/228 114lsa
- 36lb injectors, 2 torque converters, NOS kit, LT1 LT headers Super charger 17 in rims
- !!!LS6 Intake!!!
- Vig Stall Needs Cut and Clean 175.00 Shipped.
- 2006 5.3 H.O. in VA.
- FS: Harland Sharp Modified GM Rockers
- 2000 LS1 6spd complete dropout partout
- F Body manual steering rack
- lt1 engine
- FS - SLP Logic Module (TCS Off on start-up)
- LT1 part out
- Zex 10 pound bottle, bottle brackets & feed line
- lt1 corvette fuel rail covers
- Clevite MS-2199H Main Bearings
- Ls2 timing chain with sprockets
- FS/FT Ruff Racing 279s...Brand New In Box
- 383 rotating kit NOS kit LT1 LT HEADERS 17 Rims 36lb injectors m112 S/C
- Custom WS6-CAMARO Trunk sub box with 15" sub & Amp
- ARP head studs 12 points brand new!!
- Edelbrock RPM Carb Plate Nitrous Kit
- Various Chevy Parts
- sold
- CHEAP Muffler, tailpipes, tips (FLOWMASTER, MAGNAFLOW)
- Valvesprings, LS2 intake/rails/inj, Eagle rods, 42# inj
- 825 cfm Mighty Demon Carb
- Forced Inductions 85mm Turbo- Brand New!
- Wheels and Tires 700 obo
- Ls-1 Ls-6 D1SC-1 SC Complete
- 26x11.5x16 Mickey Thompsons
- 10lb nitrous bottle
- Nitto 335/30/18s
- billet hi mount alternator bracket
