View Full Version : Parts Classifieds
- FS: 1 3/4" LS1 Style Header Flange- $50
- Ms3 fs
- Greg Weld Motorsports Dragstar 15x5 Rims
- 15 lb. Cold Fusion N2O Bottle & NX Shark Nozzle
- Ported Fast 90/90, Ported 5.3L Heads, Injectors, 100mm MAF
- Front set of factory stock shocks and springs +
- ls6 valve springs & RSI valve spring compressor
- 5.3 truck oil pan and pistons
- Circle D 4c Multi disc
- 17" 10 spoke SS wheels and 16" Z28 wheels
- ASP 948500 w/ belts, Ati 8 rib pulley & belt,New 98 steel tank,New Ron Davis Radiator
- 06 LS2 Gto Oil pan
- brand new FAST 90mm intake/fuel rails 1997-2002 LS1/LS6
- FS: stock LS1 long/short block 80K
- WTT EPP FMIC for Procharger 4.5" Twin IC
- FS DTE diff brace 275 Shipped
- TSP Stage 2.5 243 LS6 Heads
- ls1 coil packs with brackets
- SPEC stage 3 clutch and pressure plate $275
- DIY Turbo: Truck Exhaust Manifold flanges
- 6.0/L92 for sale
- HSW Dual nzl dry kit, New heater and purge.... cheap
- 317 heads FS
- need help with cam choice
- (2) Stock LT1 Iron Headed Long Blocks- $125.00 Each
- Camel Hump Heads
- Autometer Guage- Speed Pro Pistons LT1
- TRADE Fidanza Aluminum Flywheel, Spec 2+ clutch
- Yank Stall,JetHot Headers, True Duals
- FS: NX wet kit, WOT switch, Window switch
- Holley C950 EFI system, SBC
- 800 hp corvette sale ECS blower package
- LS1 Intake
- 6.0 shortblock, Coils, COMP CAM, Covers, Manifold, Piston, Rods, and Much More!
- GTECH PRO SS good shape $115 shipped
- Patriot golds New $200
- Rebuilt 454 BBC and THM400 complete.
- F/s: Fast toys ram air kit (ftra)
- 2 ls6 intakes for sale
- 799 heads and 222/228 Comp cam for sale
- LS6 block and crank FS
- T-56 needs 2nd gear syncros -$499
- 3.12" Vortech Supercharger Pully for LT-1
- Edelbrock Cross Ram Intake
- 68'-72' Chevelle/El camino SBC headers
- Nitrous switch** Oil Cap** SS Emblem** Header Wrap**
- F/S: LS1 longblock with ARP hardware, Mahle pistons and extra's!
- FS: LS2 Corvette Balancer
- G.I. ****RARE****slp h/o hood
- Compact Aeromotive Fuel Pressure Reg
- 275/40/17 Mickey Thompson ET Street Drag Radials BRAND NEW
- Trick Flow Specialties LS2 225 heads for sale
- ls1 parts for sale
- tires & remote n2o bottle opener f/s
- Like New Chrome 18" C5 Zo6 wheels/tires
- LT1 Meziere Electric Water Pump
- 10 Bolt Rear Diff cover/Girdle
- FORGE UNOS manual boost controller /APS waste gate 10 psi springs
- VFN 5in ram air hood WS6
- shaft mounted roller rockers comp cams fs
- wtt summit stars with tires
- 02+ z06 cam and poly motor mounts
- LS2 complete rebuildable
- BNIB monster stage 3 clutch w/ flywheel
- GI: 4 Chrome Firehawk Wheels
- FS: HKE 408ci Stroker
- SOLD - Stock LS1 28 lb/hr injectors....
- ls1 go fast parts and carb
- WTT: Z06 shifter/airbox for your???
- brand new TSP texas giant camshaft! in the plastic and box!
- WTS: NIB B&W shifter for CTS and CTS-V
- C5Z parts for sale
- NIB PRC Dual Springs and 7.4" Pushrod Kit
- 243īs
- Front Strange Race Brakes with modified OEM spindles
- SBC,BBC engine bolt kits
- Electric CUTOUT BadlanzHPE BRAND NEW
- LS6 valve springs, locks, and retainers NEED TO SELL ASAP!
- Delphi 50lb injectors
- 93-97 SS hood RK Sport Gauging interest
- M&H 325/45/17 drag radials $200
- NEW UMI adj torque arm
- need fuel pump
- wanna trade T2 cam for bigger
- QA1 F-body shocks for sale
- Black ZR1's- 17x9.5, 17x11
- WS6 Ram Air Box with K&N
- F.S. 18/19" Black C6Z motorsports with Hoosiers
- Hooker Headers shortys for LT1
- radiator & fans, stock wheels, madman travel limiters, stock front brakes, booster
- AFR 225 Heads 66cc Dyno Time Only
- Bogart D10 Bolted RR10
- FS: toyo r888s 335/30/18
- LT1 Zex Dry Nitrous & Pacesetter Longtubes
- New in box lsx block
- FS:BMR PHB & LCA's
- Suncoast Camaro ram air hood and airbox
- 2002 trans am ram air partout
- LSX Parts
- Flowmaster Y-merge dual 3" in with 4" out
- FS: Kooks Y pipe
- 1995 roller trans am BLUE Parts Car!!!
- texas speed 2.5 5.3l heads
- Comp 7.375 pushrods, 42# Bosch injectors
- Caddy Lifters, LS2 Pistons, Hawk Pads, SLP Knob, Gaskets, Etc. NEW LOWER PRICES !!!
- Got layed off. Stuff has to go,MTI LID, COIL RELOC.
- 39lb Cobra Injectors w/ EV1 adapters
- LS1 crank
- WTT: Ebony A4 Upper Center Console for M6
- 90mm harris speed works brute force plate kit
- FS: NOS/HSW wet plate kit WITH EXTRAS!
- complete LS1, TFS 215's, ported FAST90, 240/244 cam 480rwhp/430rwtq $5K
- lq4 exh manifolds, i/m, etc...
- new timing chain/gears, and oil pump
- New cam, springs, push rods from GM 365horse LS1 crate motor $50
- Brand New TSP Hardened Chromoly Pushrods 7.400
- F/S: 5" tach, and shifter knob.....
- F/S-F/T: 5" tach, and shifter knob.....
- Garage Sale...
- Mocal 1226-12an 180 degree Oil thermostat ( NEW)
- LT1 motor mounts and poly inserts
- ls truck exh. manifolds
- FEELER: Interest in Complete LS1 Longblock FS Soon
- Ls1 rear calipers (grinded down for welds) w/ rotors
- REDUCED PT-76GTS**$1,000 firm
- FS: set of 2 5 spoke 16" firebird rims
- LS6 Cam SOLD!!!
- Ford Racing 150 lb/hr 1600cc injectors
- OEM Chrome ZR1 wheels for sale
- FS:97 z28 stock parts
- Almost complete LS1 engine management system (all sensors) NIB $250, some other stuff
- Trailblazer LS2 Motor and Trans
- Slp air scoop&extension from ftra
- C5 halltech CAI FS $175 shipped
- Gaging interest in AFR small bore 225's and FAST/NW 90mm
- Delphi 585 Coils $110 Shipped
- 500 takes all 6 silver zr1s
- FS: 95lb/hrs (delphi) + acceleronics, N.I.B.
- 2001 LS1 Shortblock
- 95 z28 engine harness and pcm FS
- Parts Garage Sale!
- LS6 Valve Springs, Retainers, Locks
- fog lights 95Z
- FS:PTK A2W intercooler, pump, and hoses!
- FS: MS4 Cam & Solid Motor Mounts
- 3" Stainless Y-Pipe
- 5.3L shortblock, heads, misc...
- FS:LS1 Oil Pan,Cheap!!!
- fs 2008 zo6 comp gray wheels with tires and TMPS
- iron block 383
- ligenfelter 2 step launch and timing controller
- ls1 intake with fuel rail, injectors and tb
- LS1 parts and other stuff...cam, motor, pistons
- FS: Moser 12 Bolt + Spohn Suspension - package deal
- gmmg oval tips
- tr230 cam , harland sharp rocker arms sale cheap
- corvette manuel case & Husrt "H" shift knob
- Stage 8 header locking bolts
- OBD1 PCM $50+ship
- stock parts
- magnavolt under 1500 miles cheap!!!!
- Stock ls1 parts - 40k miles
- 853 heads, stock pushrods-40k miles
- headers and ypipe
- WTS or WTT my cc503 for a 93/94 lt1 for a cc503 for a 95+ lt1
- 2005 gto center section $100 13k miles
- 1999 WS6 Motor and rebuilt 4L60 complete pull out
- Full Strano Koni 4/4 Set//Strano Springs// Textralia OZ700// Tick Master Cycinder
- 95 TA part out, MISC LT1 performance and OE,17" Mustang AR Rebels
- FS 417 rwhp ls1 good price.
- FS: Red LED Harlan Shift Light $30 shipped
- HP Tuners $395 shipped
- Transmission Specialties Converter
- 241 heads 55k miles cpmplete
- FS. TNT Nitrous kit
- FS-HP TUNERS VCM SUITE PRO interface
- New Cam, NOS Progressive, LS2 w/spray bar
- 5.3 part out and ls1 heads
- Pro 5.0 shifter
- COMP CAM 239,254 .605,.612 lift on a 114+4
- Ram Billet Steel Flywheel 11" $150
- 97 camaro ss complete part-out
- 17 x 9.5 ZR1s
- LSX Th350 converter, MSD 6010 & Intake
- FS: K&N Fipk, oil cap, LS1 cam, stock catback
- Camaro Bumper, Fender, 3.73 Gears and more for sale!
- Mickey Thompson 295/45/17 ET Street Radial
- LT1 52mm BBK Throttle Body 180shipped or trade for 58mm
- FS: GMMG Tips
- FS: LS2 Timing Chain,Valve Cover Gaskets, Timing Cover gasket
- FS: Spearco Air to Water Intercooler 2-230
- Weld draglites with tires
- FS:NX remote bottle opener
- SubThump Stealth Box and amp
- LS1 Lid
- SLP 2otl CHEAP (pics)
- SLP 2olt CHEAP (pics)
- Nitto INVOs (2) 345/25/20 Like NEW!
- Draglites & hooiser drag slicks
- Jesel Sportsmans Series SS Shaft Mount Rocker Arms.
- Aeroforce Interceptor gauge
- FS: T56 conversion parts (Philadelphia)
- FS: 98-02 Camaro SS Hood
- FS: NEW LS7 clutch and Flywheel
- FS: BMR K-member, A-arms, Strange brakes...+ Extras
- anybody need a complete 350?
- stock driveshaft, springs, cam, and more. $Cheap$
- Mustang 302 Victor Jr. Carb Intake Manifold + other stuff
- SLP Factory Dual Dual Cat Back
- FS:T56 drag setup freshened 5 passes!!!
- ****sts turbo kit ls1 f-body****
- FS: new LS2 injectors !!! $50
- 6.0 Factory Crank Spacer $40 shipped
- LT1 Parts for Sale
- Chrome GM 16 x 8 rims/tires
- WTT: 35th seats
- MPT76 turbo, Racetronix fuel pump upgrade kit, Racetronix #42s, Tial 38mm wastegate
- 232/238 580/590 112 comp cam
- FS: LS1 intake, rails, injectors $110 shipped
- F/S 3.70 8 Rib Procharger Pulley
- Precision GT42-76
- FJO Progessive Nitrous Controller, Window Switch, etc.
- S472 Turbo, 317 heads, 6.0 Truck manifolds
- 93-02 BMR Strut Tower Brace For Sale In Indy
- Autometer Tach Adapter for sale...
- FS Comp Cam 238/242 112 $250 shipped
- Vortec Intake FS
- ls1 parts for sale just ask i may have
- harland sharp 1.7 non adjustable rocker arms
- FS: 02' Fbody Accesories, Complete
- 2002 Trans Am Speedline 17x9" wheels
- LS6 intake w/ fuel rails
- leather seats, prostars, ls1 block
- 7.5 BS Weld Prostars Front & Rear w/new tires & 20" and 19" Cray Mantas
- Lou's short stick
- Fast 90mm Ported by Tony Mamo $950 shipped
- wanted used ls6 zo6 valves sodiem & hollow int. ex all 16
- FS: 2 Sets of Gears
- 2 JGS 50mm wastegates, C6 manifolds, Ebay intercooler for twins
- FS: 93-97 Trans Am, Firebird, Formula Hood
- ARP LS1 6-point head studs
- 396 LT1 (complete)
- FS: Stock GM Clutch Master & RAM Adj. C/M LOW MILEAGE
