View Full Version : Parts Classifieds
- Eibach Lowering Springs Fbody
- 2013 camaro ss cats and o2 sensors.
- Texas speed longtubes and x-pipe c5 corvette
- Fbody LS1 Brake cyliner
- GMS 255 LPH Fuel pump (rebranded Walbro 255) SOLD
- 90mm Holley Throttle body
- Holley 120 Injectors
- K&N cold air intake tube.
- Magnaflow 59956 2.50" metallic spun catalytic converter
- SOLD fbody Magnaflow Quad exhaust
- Ls mustang turbo kit
- 04-06 GTO OIL PAN, LS9 Headgaskets(NIB)
- LS7 440ci stroker w/ WCCH LS7 Heads - ARP Main Studs - ATI - Katech Dry Sump
- Some parts for sale
- 98-02 Camaro headlights, brackets, 3rd gen grid tail lights
- Walbro 450 new in box
- ATI Super Damper w/ Dry Sump Drive 918855
- Ls1 Pushrod length checker tool
- L92 valves, springs, etc
- FS: LS1/LS6 ARP Head Studs 234-4110
- FS: GM LS Swap Oil Pan kit 19212593
- LS1 LS6 valvetrain - rockers pushrods oil pump lifters
- WS6 Wheels (all 4) - 2002 Trans Am
- Stock parts: LS7 heads, cam, c6z full exhaust
- lingenfelter LNC 2000 launch control
- PAC 1218 beehive springs
- Nasty 4th Gen Fuel Tank
- 72mm turbo and ls1 engine
- Manley LS-1 H-Lite 6.125 Rods ARP 2000 SOLD
- Export Tails
- New Nitrous Express purge kit, special price for a kit buyer
- used NX/NOS dry kit
- 1996 trans am/ fbody parts
- Oem ls2 injectors
- kooks 3'' true duals w/cats & dual tips
- Fast 102 Intake
- LS7 clutch and flywheel
- B&M SHifter for 2008-2016 Corvettes
- LS2/LS6 rocker arms with trunnion upgrade
- PST 3-1/2 Inch Aluminum Driveshaft w/Forged Yolk
- Slp loudmouth 1, 2 and dynamouth
- big red procharger bov and flange kit like new
- .650 lift dual springs
- Yank SS3600 for 4L60E
- D1SC Procharger head unit and Innovator's West 8 rib pulley kit
- 2010-2014 Camaro xpipe
- L76 shortblock
- Lt1 accessories, maf, msd box
- Comp Cams Trunion upgrade kit.
- Garage sale
- 11qts of Valvoline VR1 oil
- Tci super Street fighter. 3500
- GTO Shocks, Springs, Gauges, Mav Man, Gauges, Accessories, LOOK!
- GTO FRCs - MINT!!!!
- 98-02 Camaro MWC Bumper Support - NEW!!
- Id2000
- Ls1 intake and other parts
- LS2 tb, PCM, X-link, pedal
- SOLD! 2 brand new simulated stainless 3" catalytic converters.
- AFR 230cc cathedral port Mongoose heads
- 3rd\4th gen fbody parts
- New comp 941-16 valve springs
- LT1 HPE Stage 3 Heads and LE Ported Intake
- LS1/LS6 Stock Fuel Rail and Injectors
- Comp 222/224 cam
- 98-02 pre cat O2 sensors
- FAST 102 fuel rails
- Injector Dynamics ID1000 set of 8 brand new
- WTB LSA Valve covers and rockers
- Tony Mamo 235 cathederal port heads
- Shift knob, shift stick, window regulator, gauge cluster, and T/A center filler panel
- Lots of LS Parts/Shortblock/LS3 Heads and MORE
- textralia z clutch,67 Camaro parts,autometer gauge,98-02 Camaro brakes
- C5 Corvette Pop up headlights
- OEM C5 Wagon Wheels
- Goodridge Stainless Brake Lines, Phantom Series - BNIB 97-04 Corvette
- Prothane "Total" Suspension Kit - BNIB 97-04 Corvette
- Billet specialties
- LS3 65lb Injectors, 300lb Viking Front Springs
- 87-93 Mustang cluster housing Holley 5.7" LCD
- Sold
- CW-33 MORE wheels (WORK Equip look-a-like)~3 piece forged~18X9.5 +46 offset~5X120.65
- 18/19 Gunmetal Powdercoated C6 Wheels With Tires
- monster stage 3 clutch bnib
- Performabuilt lvl 2 and fti 3800 stall
- On3 88mm turbo
- SOLD: Spacers (4) - 12mm 5x4.75 70.5 Hub-Centric NEW
- SOLD: Spacers (4) - 5x4.75 5mm (3/16") 70.5 Hub-Centric Used
- black t-top shades, 2001 service manuals
- Fbody Shifter Cup & Pro 5.0 for GTO Shifter cup & Short shifter
- 4l80e trans,billit converter and controller
- 2001 trans am POWER LEATHER seats
- Pacesetter f body 1 7/8" headers NEW,ls2, Mcleod rst twin disk and flywheel
- 2000 gtp - buyers beware - stay away!
- Gen 4 6.0 turn key engine for sale
- TruFiber WS6 hood NIB!! $400 in Alabama
- Holley LS Injector Harness - Brand New!
- ARP Head Studs Brand New
- 93-02 Firebird Rear Quarter Panel
- Turbo 5.3 partout: Holley, Yank, Edelbrock, 76mm
- 853 Heads with PAC Springs
- 408 Stroker
- 2000 LS1/auto dropout
- Electronics
- WTT: M6 pedals for auto pedals
- 411 ecu with 6.0 truck harness, 6.0 MAF
- L33 5.3L timing/main/valley/valve covers Coils, Crank, main caps
- Gen IV cathedral port truck intake
- T56 transmission for LS1 F-body, rebuilt with Tick Level 2 kit
- Innovate Wideband and gauge
- Corvette front accessories
- 3 Bar MAP Sensor with Harness Plug
- Z06 ls6/t56 harness with TAC module and PCM
- Moser chromemoly double adjustable panhard bar ~very good condition!~
- 00 f body ls1 engine harness ecu and bracket
- LSA Longblock
- LSA Heads - Hand Ported - Great Parts
- Selling odds & ends stuff from my build
- BMR torque arm and crossmember
- New 823s
- 90mm TNT nitrous ring
- Garage cleanout
- LJMS T6/Borg Downpipe flange with clamp 5-4"
- 15x10 7.5 bs Champion Beadlock wheels NEW and 325/50/15
- Fabbed Aluminum Valve Covers (Racer Performance) SOLD
- FAST 102MM Intake and rails
- LS1 Bullet cam & PAC 1215 springs
- Manley 7.325 pushrods
- Ez tcu, Daytona smart spark and carb setup for sale
- WTS/WTT Ace Slick Z07 18x11 18x9.5 wheels with almost new tires - SoCal
- GM cylinder head bolts - stretch to yeld
- numerous parts and gauges
- Th400, crossmember, flexplate, drive shaft for fbody
- Fays Watts Link/UMI LCA's/SS Grill/Founders LCA's
- Brand New Nitrous Outlet 52mm Throttle Body Plate conversion
- 853 heads
- PCM, Wiring Harness, DBW Throttle Body
- Bunch of leftover parts
- 799 heads, injectors, rocker pedestals, valve covers
- Ccw wheels
- FS: LS6 cam, low miles
- SS Slp floor mats: set of 3
- F/s: Hp tuners pro and Daytona WEGO IV wideband
- L92 & LM7 manifolds and bunch of turbo parts
- MSD Std length LS Spark Plug wires
- LT1 stuff
- PA FS: 241 heads, spohn subframe connectors ls1, rocker arms
- Weld draglites
- Fbody Oil Pan, Pick Up, & Windage tray
- GEN 4 4.8 long block 180k miles
- Siemen deka 80lb injectors with ev1 plug
- 98-02 Fbody Twin Turbo Kit
- vsracing gt45 69mm turbo
- Holley BBC MPFI Manifold, Rails, TB
- TrickFlow 220 As cast and Yella Terra rockers NIB
- cts-v intercooler brick & HX,
- LS2 clutch, pressure plate, and LS2 flywheel
- Fti converter
- Nitrous parts
- Nitrous Outlet stinger 1 plate 4150 flange
- 80 lb siemens deka
- 7.250" 3/8 Chromoly Pushrods
- 25 gallons of c16 near akron ohio. 10.00 a gallon
- 2005 truck harness
- Window Stabilizier w/ felt pad - OEM 10257988
- Kooks longtubes**new price **
- Custom Comp Cam out of a ls3 418ci
- ptm 92mm throttle body
- AC DELCO spark plugs
- FS: SP 1 7/8" headers w/ Hi-Flo cats and Vollant CAI
- SOLD. 2004 Z06 stock Injectors 28#ers 38k miles 70 shipped
- Ls2 intake with factory fuel rail.
- T56 Torque Arm Relocation Cross Member
- B&M Ripper Short Shifter
- Spec 3 clutch kit with flywheel sc663
- 317 heads and lq4 rods/pistons for sale
- McLeod 30lb SFI 1.1 billet steel flywheel for LS - Brand new
- LS-Chevy Slant-Edge Valve Covers
- Tick master cylinder and slave for LT1 F body
- Lunati LS1 Pistion Set
- ls3 maf
- Strano springs and Koni yellows
- LS1 28lb injectors, LS1/ LS6 aftermarket fuel rails, and C5 windage tray
- Shaved truck intake
- 98-02 ls turbo kit
- Shark Nozzle, solenoids, gauge.
- 5.3 Gen 4 pistons and rods
- T56 Tailhousing
- Parker hose
- LS6 Valve covers
- Oem replacement sail panel
- FS: LS2 out of 2007 TBSS
- Ls3 intake, racetronix 340 sender for g body 4l80e
- YELLA TERRA Ultra Lite 1.7 Rocker arms Adjustable
- UMI Performance Valve Cover Spacers PN 2111 For Sale NEW IN SEALED BAG
- Yank 3400 stall pas
- Fast 102mm intake, LS6 heads. Price dropp
- Eibach lowering springs & SLP Bilstein shocks
- Spec 3+ with aluminum flywheel
- Turbo part out Huron speed, Turbonetics, eboost, BMR k-member
- Dirty dingo mounts.
- Speedline Mistral 6's 17x9.5 ET48
- Snow PERFORMANCE Stage 2 kit with 7 gals of juice
- Intake manifold spacers
- Stock 2000 camaro wheels with bfg drag radials
- Single ZR1 Rim and Falken Tire.
- 862 heads and truck intake manifold
- C6 wheels and tire for sale or trade
- Corsa H-Pipe unused (2.5")
- OEM 06 CTS-V Sway bars
- Complete ls6 intake
- 2009 aluminum 6.0 short block
- 2005 ls6 with less than 12,000 miles
- 2001 C5 corvette ABS unit and pigtail
- Speartech 4l80E Upgrade Harness
- Comp Dual Valve Springs and Retainers
- Heatshield Products 36x56 cobra cloth
- LS1 ***SOLD*** tunnel ram intake/daytona sensor ign./MSD coils/ never bolted up
- LS1 LS6 edelbrock super victor 28097 carb. intake "SOLD"
- 0411 ECM's
- LNC-2000 RPM-300 Lingenfelter Controllers
- Zo6 wheels and tires.
- Nitrous Outlet Dedicated Fuel System
- fbody oil pan**SOLD**
- Spohn torque arm and ds loop
- Btr Stage 3 Blower cam / Ati 8 inch balancer
- Eagle 4340 LS1 crankshaft
- FS: various universal intake and injector spacers
- F-body pan, covers, cams, etc.
- ls7 manifolds
- fbody race stars front and rear
- Gen 3 LQ4 pistons/rods
- OEM C6 Z06 Wheels and tires (black)
- Billet GT5588 w/ 1.0 Garrett Turbine Housing
- ported 799 heads
- 304SS Bends
- Rear brakes / Pads - low miles
- K&N filter
- Sold
- cams, intake, Centerline autodrags, etc.PARTS ADDED
- ~~Huron Speed V2 T4 & AC T4 Kit BLOWOUT~~ Base & Complete Kits!
- True trac with 4.11s 19k miles must go!
- MS3 cam, injectors, lifters, pushrods
- 2004 - 2005 - 2006 pontiac gto parts * rear bumper insert/fuel rail covers/etc
- Quarter master t56 clutch tool brand new
- new 4.8/5.3 .020 over block and pistons
- Left over project parts
- Tsp rumbler tru dual setup. New, f body balancer
- Magnesium N73 Corvette Wheels (17x8.5/18x9.5) off C5 FRC
- GMPP Pontiac Valve Covers
