View Full Version : Parts Classifieds
- Large room of ls stuff in Monterey ca moving new place no garage!
- Cnc'd complete l92 heads
- Turbo Guard - 5.5" inlet
- Hooker Super Comp ceramic LSX headers
- 82-02 UMI Bolt On LCA Brackets
- pro series water pump short
- LS2 Motor with MP112 Blower...
- Looking for LINGENFELTER LNC 2000
- Non-Sponsor Soliciting Policy
- NOS remote bottle control (solenoid style)
- '99 Trans Am Tan Interior Part Out
- FIC Bosch 160lb High Z fuel injectors
- (4) SLP Chrome ZR1 17x9 New goodyear F1's
- trickflow 7.450 pushrods
- SD 83# injectors, 25k miles - $225
- C5 corvette engine covers, fbody wp spacer kit
- lsx parts
- Various OEM LS1 Parts
- Doug Thorley Shorty Headers
- Borg Warner Turbo
- arp head studs brand new in box
- 2006 GTO Nitrous Kit with Extras
- 2014 ZL1 Blower w/snout for sale, only 10K miles
- 2008 ly6 823 heads...no oil pressure
- bnib red bmr crossmember p/n km003
- Garrett GTX3071R turbo GTX3071R CHRA GT3071R CHRAs BNIB!!!
- SOLD! Midwest Chassis Fab 9" rear end -With torque arm setup and Strange driveshaft
- 2006 LS2 Shortblock with Bad Bearings
- Driveshaft, 4l60 Trans mount, coolant level sensor
- END OF SEASON SALE!! Rims & Suspension Parts
- FS: Aster Procharger Bracket, F1 Pulley, CBR Crank Pulley, 3 Belts
- Nitto 555R Drag Radials (sold)
- PST: Carbon fiber Drive shaft
- GM Goodwrench 4L80E - 0 miles on it ** SOLD **
- wideband airfuel gauge Led 125.00
- ARP Head Bolts. NEW 134-3610 $110 shipped
- Nitrous outlet system 78mm plate kit complete bnib
- 4l60e tail shaft for torque arm
- Custom btr cam, short travel link bars, siemens 60's
- Infinity 96lb injectors
- 20x8.5 Helo Wheels with Goodyear tires
- Yank 4l80 converter
- F/S: used 2010-2013 Camaro SS LS3 Magnaflow Stainless Cat-Back Exhaust System
- Fs Camaro leather shift knob for auto cars cheap
- Founder's Adjustable Torque Arm Red
- Airaid Cold Air Intake kit for 1999-2006 GM truck or SUV
- BNIB ATI Super Damper F-Body Harmonic Balancer 917264
- Comp Cam 1.8 Crane Rocker Arms Trickflow Pushrods Kit
- F/S: Procharger P-1SC-1 Supercharger
- LS1 rocker arms - comp cam upgrade
- FAST 36lb injectors
- ls1 intake and throttle body
- nitrous outlet 78mm plate
- Holley Mid Rise Intake Manifold Cathedral Port
- 8.8 rear setup for fbodies
- ls7 lifters
- MSD Coil wires
- Injectors 79@3BAR LS3 LS9 Flowmatch
- 60. headgaskets
- ls7 timing chain
- LS7 Factory oil pan
- LS7 harmonic balancer
- F/S ls6 long block from my 02 c5z
- F/S : NEW ported ls3 throttle body
- Built 10 bolt f body rear
- Racetronic 17104487 50 pound injectors
- Need nitrous stand alone fuel system
- Full EGR system off my 02 TA
- Show quality coil relocation with valve covers. Complete kit
- OEM Truck (2005 LQ4) Manifolds,Intake, Accessories, and LS6 injectors
- Stock 10 bolt Axle Shafts, Differential & Cover, Ring/Pinion (3.42) (4CH ABS)
- Holley black fuel rails and crossover
- Parking Brake Shoes
- Ls3 intake
- Ls1 fbody accessories
- FS: Oem zr1 carbon fiber side skirt + flaps
- C5 accessories bracket
- Narrowed strange 12 bolt
- LS6 Intake and Ported TB
- 68-74 nova t4 hot side SOLD!!!
- BTR camshaft
- FS: 2 New 17x9.5 Black C6Z Wheels
- t56
- tonneau cover for sale
- 5.3 stock crankshaft
- REDUCED! turbonetics midframe 78 w/ progate50 and blanket.
- CTS-V Injectors
- C5R Engine Block
- Race Stars
- 0411 ecm
- Complete T56 swap package for LT1 or SBC with one piece rear seal
- Built LT1 T56 - Tick Level 2 kit + other upgrades
- Lq9 408 long block 823 heads
- Stock G8 exhaust manifolds
- 78 mm N20 Outlet plate kit.
- 243 heads
- GM t56 master and slave cylinder 20k miles
- 2000 2001 2002 Firebird Black Dash Pad
- *NEW* LS6 Coolant Crossover Tube (SOLD)
- Big Comp Custom Solid Roller Cam
- LS Parts Sale!
- New Autometer oil pressure gauge
- 12582605 from '03 GMC envoy 5.3l
- WTS: F-Body Oil Pan, Pick-up Tube, & Windage Tray
- Misc LQ9 Parts
- King XP main bearings SOLD!!!!
- Fast 65lb ls3/7 inj and fast ls2 85lb injectors. Fbody spacers
- Weld Alumastar wheels 15x10,15x4 mickey thompson 28x10.5
- Torsen diff unit with block
- FS: Procharger 5.25 pulley
- FS: Transam rear Filler Panel w/ hole for cutoff
- FS: Spohn Pro Series Anti Roll Seay bar setup
- FS SPOHN Proseries Adjustable Torque Arm / DS loop
- FS: SPOHN Pro Series DA Rear LCA w/del sphere
- FS: Koni Sport Yellows 8241-1140 sport
- Koni adjustable rear shocks
- SOLD!! VA Speed turbo cam. VTC2
- LS6 intake manifold, ported and powder coated tb, fuel rails and injectors
- Turbos for sale
- Strange shocks, SLP springs
- Driveshaft shop conversion flange
- Pro 5.0 shifter
- New Wiseco Turbo Pistons K445X05
- Mototron 60lb injectors
- UMI Fully adjustable front upper and lower QA1 coil overs
- Camaro window switches
- SLP double roller timing chain
- Engine parts garage clean out.
- Wegner TVS 2300 with complete 10 rib Front Runner
- ls1 fbody oil pan for sale
- VS Racing "Sloppy Mechanics" Turbo kit NEW
- SOLD -Greg Banish Calibrated Success DVD - Data disc
- New GM LS7 CNC Heads
- Simens/Deka 60lb injectors ev1
- Lq9 Injectors
- LS6 Intake #12573572
- Greddy Profec B boost controller and autometer boost gauge
- LS6 coolant steam pipes and plugs
- Parting out 2000 firebird
- FS: Ford 9" Moser Wavetrac 35 spline diff New
- TSP headers/y-pipe, SD 60lb injectors, K&N FIPK
- Seeking f body exhaust manifolds
- badass twin setup... LSX based.
- Steel brake lines for 1998-02
- Stock 1999 camaro z28 hood
- Mustang ls swap full exhaust
- T56 Stage.3. 32 spline output for sale
- Comp Turbo CT5X 80/82
- Turbo Header materials
- dod delete valley cover
- Auto trans crossmember
- Like New 09+ CTS-V Wheels + Tires + TPMs
- LS6 Intake Manifold Powdercoated SOM, TB, Fuel Rails
- Complete 05 DBW harness W/sensors TB & gas pedal
- Spohn Driveshaft Loop (93-02 cars) (SOLD)
- Dedicated fuel cell system for nitrous
- SLP Loudmouth II Exhaust - 1998-2002 Camaro and Firebird
- 823 l92 / ls3 heads
- Ysi Head Unit, Brand New!
- CNC PORTED 317 Heads
- LS1 K-member
- Victor Jr, 60lb injectors, BTR cam, carb hat, wheels/tires
- 2003 express van pcm 6.0 4l80e
- 97 98 99 C5 corvette throttle body 25179793
- jerico 5 speed road race Transmission
- ctsv front calipers
- NIB American-Powertrain-Manual-Transmission-Bellhousing
- Stock ls1 intake, injectors, springs, sway
- 98 ls1 pcm 2bar os
- Truck heat sink coils
- Truck intake with DBW TB, rails, injectors
- Deka 80# injectors. NEW!!! $250!!!
- 4L80e/Swap/LSX
- tire valve stem logo caps (firebird / camaro)
- Street/Race Car Part Out!!! Selling All Performace Parts!
- Fast toys 104mm airlid brand new $190.00 shipped
- 2-15x10 Racestar Darkstars
- D585 coils, harness, mounting brackets
- Wilwood Aero 6 Calipers - Nickel planted, ThermLock pistons
- FS - ARE 1005M Dry Sump Pan
- Ported LS3 heads, trunion'd rockers, cam
- Tsp 4" maf
- Brand new Pro 5.0 shifter
- siemans deka 60lb fuel injectors (SOLD)
- QA1 and Eibach springs
- D1SC procharger kit, meth kit
- Complete t56 swap 4th gen f body
- Fbody rear needed
- 98-02 fbody Oil Pan, pickup, dipstick
- HTV-2300 (TVS) Supercharger
- LS3 turbo cam for sale
- F body 8.8 driveshaft u joint, yoke, adapter
- E boost street 40 psi
- FS LS3 Fuel Rails
- Edelbrock Victor Jr. Manifold, sheet metal elbow, fuel rails
- 2006 GTO AC Compressor
- GTO engine covers, RED ,NICE
- Stock 2000 trans am pcm holder
- 2000 trans am Driveshaft with 4l80e yoke and 8.8 flange
- New BFG KDWs - 255/40/18 and 285/40/18 ** SOLD**
- Sold
- ls1 intake with throttle body and fuel rails
- ls6 intake
- **NEW** Forged Speed Inc-built 408 Stroker
- Tick Master, 799 heads, NW 95mm , coil packs, NX
- 347 Forged Short Block
- LS6 complete intake brand new
- Nitrous bottles
- Parting out 2000 Firebird Formula, and other 93-02 F bodies
- L33 Intake Manifold/TB w/ Rails/Injectors
- LS AFR 215's hand finished by Tony Mamo
- Fbody Complete Radiator and Fans
- FAST 102mm (Black)
- 383 LS1 long/short block AFR
- Sold
- Custom Ls3 comp camshaft
- Valvetrain Parts (ROckers/Cam/Pusrods....)
- 4" aluminum exhaust merge
- Dry N.O.S. system, LS7 Ti Valves, LS3 Hollow Stem
- Super Vic efi cathedral port
- Stock 4l60 flex plate
- Stock 4l60 crossmember
- Ls1 rocker arms
- WCCH LSA stg 2 heads
- 2007 4.8 turbo project for sale
- Ls3 intake with fuel rails and injectors
- Ms3 cam
- PRC LS3 heads and comp pushrods
- **Nearly new TMS 408 shortblock**
- parts
- Precision A2W intercooler w/ water system TURBO cam/GLIDE driveshaft
- LS6 Valley Covers & Front and Rear Engine Covers
- forged ls2 with afr 230 heads.. built for boost
- Texas Speed Built 383 shortblock - nearly new, SEE BUILD SHEET!
- FS: Bunch of LS Parts, LSX DR Heads and intake, Nitrous kit, FAST, Wiseco and More!!
- Wiseco 383 SBC/LT1 pistons, UMI on car adjustable LCA's, Ram-Air Hood
- LS Garage clean out
- NEW still in crate ls3 block
- LS GTO Coil Covers - $110 obo Shipped
- 2005 5.3 L33 Harness, Coil Packs, Accessories
- Hooker exhaust manifolds
- WTB centerline auto drag 5X4.5 pattern
- CTS-V - Garage SALE
- OE wheels c6 center caps set
- Vortec 6.0L Complete Intake Manifold,WaterPump,HM Balancer
- LSX to glide/ th350 5500 stall
- WTB 3.7 to 3.9" stroke crank and rods and block
- NX Direct Port shark kit!!!
- NEW Holley 58mm LT1 throttle body
