View Full Version : Parts Classifieds
- turbo, injectors, fuel pump, surge tank, valve springs, and more FOR SALE
- TVS 2300 magnacharger
- BNIB SRP PRO LS Piston set, -5cc Flat- 4.030 bore w/4.000 stroke
- FS: Set of Chrome Firehawk wheels with tires
- 5.3 computer2002
- Dart BILLET LS block, all pro 12-4 heads intake rockers NEW
- complete fast 102 intake setup and ls3 heads
- bumper Support
- MAST/LSX LS7 4150 EFI Intake only used for dyno testing
- REDUCED Vortech V1 T-Trim RACE RMCR 98-02 Fbody
- Holley LS7 Hi Ram intake (300-125)
- Upcoming used LS parts sale
- ls1 stock cylinder heads and valve stems
- fs: Fast 92mm bare intake
- New adjustable starter and double roller timing set
- LS1/LS6 28lb (stock) injectors
- NON EGR Truck manifolds w/heat shields PRICE DROP
- bare ls6 and ls3 intakes
- Rocker Arms, Pushrods, Manifold, ECMs, LS7 Oil Pan, Derale, more...
- LSA superchargers
- 01 Tahoe 5.3 engine harness
- Vortech V3 t-trim
- LC2 wideband and GTO trunk wing
- Complete a4 GTO swap
- LSA FIC 1000 INJECTORS fit ls3 also
- C5 QA1 Coilovers *FRONT SET ONLY*
- 5.3 LM7 partout
- 4 Gallon RCI Fuel Cell and Mt Brackets
- Finish Line Transmission level 4 700r4 4l60
- New Weld Pro Star Wheels - New Drag Radials
- LS6 intake, fuel rails, and throttle body, injectors
- Ls3 intake cover injectors &throttlebody
- [SOLD] Solid roller lifters
- Less than 3k miles 500whp cam
- FIC / Bosch 127lbs inj.
- Manley ls7 severe duty valves
- Snap on tool box trade
- camaro l99 engine and 6 speed auto complete
- FS TX 317 heads complete
- Hood latch assembly with bumper cover support
- One 3” turn down with cone made by Dynatech Headers
- SLP Smooth Bellow & Delphi MAF sensor
- Cams, N2O gauges, pushrods, gears, maf, ARP, FAST, raptor, etc.
- Air Cleaner lid, Factory, Used, 98-2002 LS1
- Fast Toys Black 98mm LS1 High Flow Air Lid
- Fast Toys Air Lid, Ram Air Box Base and Induction Kit
- KRC Power Steering Pulley
- TIAL MVR Wastegate 44mm
- 4l60e Stock Torque Converter
- 42lb injectors for ls1 and 6
- 88mm turbo brand new
- REDUCED! LQ4 370. Long block
- Forced Inductions Borg Warner S484 Turbo
- WTT: Moser 3.89s For Moser 4.29s
- 3.6, 6l50e, Rear Cradle, 2010-2011 Camaro
- Ls7 intake & fuel rails
- **FRESH 4L80e NEEDS A HOME**
- Garage Sale
- UPDATED! Price Drop! OEM 2002 Camaro SS Wheels 5k miles w/ tires
- Complete LS1, Rebuilt, 475hp
- LSx Single Turbo Kit
- 16" CCW Classic drag pack w/ tires
- FS: Blue Demon LS1/LS6 Injectors Super CHEAP! - SOLD
- LTx Parts (some universal too)
- Stretch Satin- Indoor Coverking Car cover Trans Am
- Isky LS1 Single Valve Spring kit
- AJE T56/TH400 Swap Cross-Member for LS Swap SN95
- 07 LM7 5.3 long block
- nitrous outlet direct port fogger with intake
- siemens deka 80lb injectors and 100mm MAF
- 42# injectors, 36# injectors, L92/L99 coils
- MAST BLACK LABEL 305 LSX LS7 heads PRICE DROP!!!
- Fast 102 intake,fast tb 92mm, 42 lb injj, ls2 rail complete
- f body oil pan with pickup and windage tray
- For Sale 241 Casting Heads
- Aluminum 5.3L w/LS6 intake/rails/42# injectors/F-body TB, water pump & balancer
- G8 GXP a/c compressor SOLD!
- AFCO Scirocco Radiator (dual pass)
- 06-10 Z06 or 08-10 LS3/GS C6 Vavaram intake
- Fast LS1 Fuel Rails
- Ms3 gold box with harness 58x
- S484 borg warner - Forced Inductions Turbo / Trade for smaller turbo
- quick fuel technologies carburetor
- Turbo Kit FS
- Ls9 2300 supercharger
- FS: Innovative SCG-1, New in box, wideband/boost controller
- 4.8L Rotating assembly for sale
- PARTING OUT 2005 GTO - 6.0L LS2 - NICE INTERIOR and HOOD
- 2 pair 98-02 headlights (Camaro)
- Magnacharger TVS Overdrive Rear Pulleys and Belt
- Th400 to ls converter
- Texas Speed 233/239 cam/ dual valve springs/.080 pushrods
- LS1 LS6 Corvette Steel Manifolds
- Gear timing set, comp cam pushrods, air cleaners and acessory bracket
- Sold please delete
- Forged 396 LT1, 24x, trickflow, 12.0:1 for sale plus other stuff
- Bmr crossmember part number Tcc005h
- 18x9.5 18x8 Staggered M-Parallel Wheels with Goodyear GSD3's - CA
- FS: LS7 12569011 Intake manifold
- MOMO Race Steering Wheel with 4th gen adapter
- Comp Cams - 247/255 .624/.624 113+3
- Lsx fox mustang swap headers
- 4l80e trans and stock converter
- Nitrous Outlet 98-02 Hardline kit
- 98-02 Camaro LS1 Parts/ See list and pictures:
- LS3 Intake, LS3 Injectors,Fuel regulator
- LS2 block
- LS2 block
- fs ls2
- NEW TR 219/230 cam
- nos nitrous seloniods and plate, Tsp true duals, lid, complete fbody ac system
- For Sale 98-02 F Body Radiator
- For Sale LS1 Valve Covers
- LS6 Intake Manifold
- ported ls3 heads
- Sold
- 99 z28 rear end.
- FS: Stock GM 3.42 gears
- Racetronix 255 in tank
- 98-02 Camaro Rear Bumper Cover
- 98-02 Camaro Front Bumper Cover
- For Sale - Superchips Cortex 2950 tuner
- 10 bolt axles
- Complete 4L60E auto swap
- Ws6 lower ram air box /slp lid/k@n filter $250 b/o may trade???
- Russell Stainless Steel Brake Line Kit
- LS Rear Cover
- LS2 Injectors
- 6pt bolt in, nx gemini plate, e85 carb, opener
- McLeod rxt clutch
- FS: ID1000 injectors dyno time only
- 4th gen Borla cat back non-adjustable
- LS1/LS2 Fuel rail and Heat sink coils
- 99 ws6 speedine rim 17x9 mint condition
- Ebony Speaker Cover, B&M Trans Cooler
- 02 CamaroSS stock fuel rail, coolant crossover,flywheel,pressureplate,Alu valve cover
- GI: Solid Roller 427 LSx built for lots of nitrous!!
- Parting out 98 z28 ROLLER
- S480 T6 Basically new
- Fuel system components.
- LS2 (D510) Coilpacks & Electronic Boost Controller
- UMI SBC/BBC tubular k member
- BNIB comp 224/228 112lsa
- LS7 factory 3/8 7.800 push rods
- FAST 92 intake and TB
- set of 8 RC 750 fuel injecters
- Complete t56 swap
- 2006 GTO Torrid Red front bumper with SAP Grilles
- Th350 trans brake, rmvb & shifter
- Autometer Sport-Comp Gauge Set
- monster stage 3 clutch and flywheel
- Nitrous Xpress Nitrous Solenoid
- LS6 intake, fuel rail and TB
- Load Boss 200 Amp H.O. Alternator
- 28# Injectors, Stock Fuel Pump
- Smoothed and ceramic coated v banded truck manifolds
- 19x12 rear only Grand sport wheels
- Cnc' GM ls7 heads
- 98-02 parts and garage cleanout
- 4 BW alum dp flange, for t4. $20.00 shipped
- Ls6 cam, damaged 50.00 shipped
- FS: Gto drive shaft
- NA 383 LT1 w/EFI Connection 24x setup, McLeod Street Twin clutch
- Comp Cams 918 Valve Springs barely used
- Bosch 160lb injectors
- Nitrous parts, Ford 8.8 gears and diff, zex bottle warmer
- 99 Z28 and 98 T/A partout (rollers)
- 317 heads w/rockers and stands
- NEW t56 Magnum TUET10009 with extras
- 2008 L92 6.2 Longblock 35k miles.
- 17x9 & 17x 10.5 TTM's FS
- Bogart for sale
- LT1 Canton valve covers, Strange master cylinder
- LT4 Rockers/ LT1 Pushrods. Good Deal!!!
- Complete LSX Long Block
- ls hotside turbo kit retains ac
- Ls1 throttle body
- FS: GM master cylinder #12568371
- FS: GM Ls1 clutch kit #12581650
- Ls1 Trans am Front Plate Red with Black Bird Polished
- Turbo truck part out
- Comp 7955 chrome moly 7.4 push rods
- 1 Special Offer Available - Huron Speed V2 Twin Hot-side Turbo Kit!
- WTT/WTS: 60k mile 4.8 lsx .
- All sold
- Fs stock ls1 injectors $55
- LS1 stock 28# injectors 15K miles & F-body LS1 fuel rail
- LS7 Crank and dry sump tank
- Ls1,5.3,6.0,c5, parts
- Zex LSx Blackout Nitrous Kit w/ Accessories
- Full 99 Z28 Part out (Moser, Tick, Umi)
- Mahle flat tops with eagle h beam. Dyno time only, like new.
- c6 oem factory car cover
- Hughes 4l80e 2500 stall
- 402 LS2 / LS3 Engine
- Revmax 4L80E Converter (New/Unused)
- DBW Standalone Harness, TAC module, Pedal, and Flashed ECU
- LS6 Intake #12561184
- stock 317 heads
- Kooks 1 3/4 to 1 7/8 stepped 04-06 GTO headers
- 345 35 18 et streets
- Treadstone center top outlet intercooler
- Fikse FM5 FOR SALE
- super vic, elbo, fast 92 and edelbrock rails complete
- T-56, Standalone wire harness & PCM's, Corvette Front Accessory Drive Kit
- D1SC Head Unit
- Fast 92mm Intake, Cathedral Port
- SOLD - Spohn non adjustable panhard bar
- ID 1300 injectors Trick flow 6 bolt 245cc 70cc chamber heads
- Mickey Thompson ET Streets
- LSX engraved gen 3 black anodized valley cover
- Ls9 cam new
- Wts/wtt have a bmr torque arm and th400 crossmember
- FAST 102 Rail Adapters and O-rings
- NGK Powerdex AFX - Air Fuel Ratio Monitor Kit and Aeroforce PT201
- 02 SS OEM CAM, Starter, 01 TA MAF, Silicone intake tubing
- WOT BOX - 2 step/rev limiter
- LS1 F-body fans 15K miles
- Ported LSA blower and snout
- 2007 LQ4 80k miles + LS3 heads + LT headers trades
- HPTuners Suite MPVI Pro
- SOLD - 417 Motorsports Twin Turbo Kit, retains A/C
- turbo stuff
- SOLD stage 3 T-56 6 spd trans fresh build & BN stage 3 clutch
- FAST Injector Spacer 146025-KIT
- WTT TRADE (Possibly + Cash) Borg Warner S475 T6 for Smaller Turbo
- diablo trinity t1000
- LS3 intake manifold
- Nitrous Supply Solenoids+accessories
- OEM 2002 T/A WS6 Rims - REDUCED TO $1,200
- New F-Body Double Adustable Rear Lower Control Amrs
- '93-'02 F-Body shock/spring cushions
- EGR tube and gasket
- Yella terra platinum roller rockers and valve cover spacers
- 4150 Tb super victor intake
- 823 heads 20k miles $700
- short block 6.0 /243 heads /ls6 intake
- HCI swap parts, 853 heads,cam, lifters, oil pump, etc..
- MSD 6010 6LS ignition box and harness
- Fikse Profil 5S - Fbody application 18/19 w Michelin Pilot Sport tires
- 4150 tb,fuel rails,harness,pcm
- Stock LS1 maf
- Core T56 out of an LS1 with bell housing and slave cylinder and ACT 6 puck clutch
- MGW shifter for c5 c6 or c7 SOLD
- Isky Redzone LSx Solid Roller Badass Lifters Tie-bar Low Miles 1377-LSH
- lt1 complete motor, 28x10.5s, lt1 parts
- FS used coil packs
- CME valance
- 10 bolt LPW untimate girdle with braces
- FS/FT PT6376, MISC LS Parts *REDUCED*
