View Full Version : Parts Classifieds
- Front lower control arm vertical bushings
- Front lower control arm vertical bolts
- PAC 1300 Series Solid Roller springs / Titanium retainers, 10° Locks and seats
- Low mileage Gen 4 rods and 5.3 Pistons 2008
- NIB Holley 105 Throttle Body
- LS2 4.120 bore darton dry sleeved
- CMB Motorsports CNC Procomp Cathedral Port Heads
- Sold
- Yella Terra YT6645 1.7:1 Non Adustable Rockers LS1/LS2/LS6
- T56 Transmission Clutch and Misc Parts
- Msd 6010
- LSA supercharger
- Induction Salutions Direct Port
- AEM wideband / boost failsafe 30-4900 gauge
- 4.11 gear for Moser 12 bolt
- 1998-2002 F-Body Headers and off road Y pipe for sale
- Huron Speed V1 Truck Manifold Turbo Kit (Many bundle packages inside!)
- Forged Chromoly Yoke 27 spline GTO
- Edge racing 3600 stall converter lt1
- s400 T6 1.10AR Housing (96mm turbine)
- FS: Mustang lsx Long Tubes 351s W/GM flanges
- Msd digital 6 plus 6520 SOLD !
- Sold
- Complete L92 with extras
- 1993-2002 camaro white door 5000 miles on them
- PCM and standalone harness
- Diablosport Intune
- LS1 T56 bellhousing
- Powerbond 10% underdrive pulley
- FS: Escort Passport Max Radar Detector
- 93-02 firebird/ trans am parts
- Set of stock LS6 valve springs
- Stock LS6 Pushrods
- Set of stock LS6 rockers
- LS Lifters 12499225
- Sale or Trade 58mm BBK throttle body
- Fs stock ls1 intake and injectors $175 + shipping
- Sold
- GZ Motorsports Vac pump kit
- CNC'd LS3 HEADS
- Parting out 01 Formula
- RST Clutch SOLD
- Ls1 AFR 205 heads
- On3 performance intercooler
- 3" Fleetpride driveshaft w new Spicer U-joints
- factory steel driveshaft
- pair of factory axle shafts both have relucter wheels
- T56 input shaft new
- B&M ripper shifter
- Procharger brackets to use with a GTO kit
- ATI Damper 918853 for GTO
- 2006 GTO wiring engine wiring harness
- 2006 GTO oil pan
- 2006 GTO oil pan assembly
- NW102mm DBW throttle body
- Oliver 6.125 billet I-Beam rods
- TSP MS4 cam
- FS: LS1 f-body SLP lid
- LSx Parts For Sale - 243's, FAST, 6.0, Oil Pan + More
- Yank PT 4400 billet converter low miles
- WORLD Warhawk Aluminum Block (AKA Bill Mitchell Products Block)
- 4l80e slip yoke
- Bullseye S480 Billet Turbo Polished Race Cover
- FS/FT - Like New Stage 2 LS3/L92 WCCH
- T56 adapter for SBC/BBC with old style bellhousing
- 01-02 WS6 wide spoke polished wheels with tires, UMI crossmember, other parts
- WANTED: LS1 MAF and at least one Coil
- Fog light and ASR switch
- F Body T56 Tail Housing
- FS: ported throttle body LS1
- 2001camaro race part out
- ECSB 08-13 Silverado/Sierra Extang Tonneau Cover
- 2001 ecu/modified harness
- Corbeau A4 seats
- LS6 valley cover $70 shipped
- HRE 547R rims for F-body
- GM 7.5 Zexel Torsen POSI plus extras FOR SALE
- BMR XTREME Torque arm molly with loop New in box
- PRICE DROP Zo6 corvette wheels 18*8.5 & 18*10
- FS: Escort Passport New Model
- Stock LS1 Flywheel
- Parting out wrecked 99 Trans Am
- 4L65e and Yank converter Forsale
- New in box FIC Flow Max 1000cc High Impedance Injectors
- Ligenfelter GT11 Cam *SOLD*
- 1970-1981 camaro ridetech level 2 coilover kit
- 6 Set of 5/16 .080" wall pushrods used only for rocker geometry testing
- Ls2 single pole timing gear
- 60 lb Siemmen Injectors, $200 shipped
- Huron Speed V2 TWIN Hotside Kit WEEKLY Bundle Sale! 10/5 - 10/11
- Half filled Iron 365" Longblock
- Volant intake, gears, killduff shifter
- 02-04 LS6 Cam For Sale
- C5 catback obx bolt on
- Ls9 camshaft and gm performance racing lifters
- LT1 performance parts- forged pistons, 40 lb injectors
- Used headlight motors Firebird
- Magnacharger mp112h for LS2 GTO
- Cleaning out Garage - Fbody parts !!!
- Carbon fiber cowl hood and SS Spoiler
- LS3 Heads
- Performance shop clean out- duramax intake, c6 lower radiator support
- ID 1000's & 2000's
- Precision GT4067 Turbo .75/.96 2 Tial 44mm V-Band Wastegates
- Performance shop parts-price drop!! 2010 Camaro 2" primary headers!!
- Brand new T56 Magnum kit
- Holley Dominator EFI System Chevy LS3 – Complete Package!
- MSD 2950 LS3 Master kit
- New Procharger F1C 10.5
- original 28# injectors from 2000 corvette all in great shape
- Clutch Pivot Ball Bracket for GM Cars and Trucks
- F-body Radiator & Dual Fans
- LS1 Camaro Passenger Ebony Leather Seat
- Ly6 parts
- Hsw dry interface, pushrods
- Magnafuel 4303 Protuner 750 and MP-9950-B regulator
- 98-02 F-body oil pan pick up tube windage tray and bolts *complete*
- New 4l80e
- FS: FAST classic system
- 2002 camaro ss headlights and taillights 27k miles oem
- DiabloSport I1000 inTune
- Texas Speed TSP LS3 235/239 112 cam low miles. SOLD
- Fs: LS1 Camaro Billet Aluminum Power Steering Bracket
- NIB Kooks Long Tubes 98-02 F body 1 3/4
- 243 Heads
- 6L90E Transmission w/ converter 8k miles
- 4l80 PTC 4400 convertor sold
- Ls2/ls3/l92 parts
- b&m shifter
- LS1 Complete pull out
- Complete T56 Swap
- Fs stock ls1 intake and belstein shocks
- Wilson LS1 Fuel Rails
- RevXtreme Catch Can (new)
- LS Crank Pin Kit
- CBM CNC LS6 Heads 2.055 & 1.60 valves SOLD
- LS3 fully ported heads. sold!!!
- UD Powerbond Balancer
- CTSV Front & Rear calipers 2004-2007
- 1998 Lonnies Dual Fuel Pumps supports 1000+HP
- RPM Trans
- 9" + ls parts clean out
- Motive Gear 3.73 Ring an Pinion 7.5"
- LS6 Intake
- NEW 454 Warhawk tall deck N20 short block - complete
- Relay kits, 200A circuit breaker, ANL fuse holder, Alternator pigtail
- Hurst Billet/Plus Competiton Shifter
- Trans Am 16" wheels (2) Great for track tires)
- 1999 Corvette Cam, 853 LS1 Heads
- Forged, Boost Ready LS1 w/LS3 Heads, 6766 BB Turbos, Oil Cooler, Anvil Auto Parts
- Ls1 mahle powerpak piston set 3.898"
- 2002 LS1/T56 Complete Swap - 45k miles
- CBR Alt relocation bracket
- Strange front race Brakes 4th gen fbody
- Built LS1/ Tick Built T56 complete pullout for sale
- Kooks Headers
- LS7 LS3 gold blade Throttle body for sale
- 15X10 Racestar wheels with 275/60/15 MT Slicks
- wanted 8956 comp cams mechanical lifters need two
- LS3 shortblock 427 CID
- 7= L92/Ls3 pistons and rods
- Forged 347" LS1- Complete from Fuel Rails to Pan! Available to see running in car!
- 315/35/17 MT drag radials - Chicago
- On3 performance alternator relocation kit for ls powered fbody turbo
- Nitrous outlet Fbody kit
- BRAND NEW TSP 100mm MAF w/FREE air filter
- NIB Kooks 1 7/8 headers w/o2 extensions bolts gaskets 98-02 LS1 $800shipped
- F1C Procharger race kit with upgrades GTO/ LsSwap
- V banded manis, heat wrap, fuel rails, injectors
- LS1 Trans Am Hood Black Stock Excellent Condition
- 98-02 Camaro/Firebird Dash Pad OEM GM# 10269102
- COMP Turbo Billet 76mm triple ball bearing
- 4th Gen f-body suspension, appearance and audio
- NEW LS3 BTR Platinum(Ti) Spring Kit and NEW set of valves(hollow intake!)
- WS6 air lid and Z28 STOCK AIR BOX
- 4L80e with Jake's Performance Stage III Build
- Bunch of Random LS Stuff
- NEW passenger side headlight motor for 98-02 Firebird/Trans Am
- T56 parts and LT1 M6 engine harness for sale
- LT1 Bell housing, input shaft and mid plate
- 94 Camaro Z28 M6 engine harness
- LSX376 Block
- LS7 parts and C6Z06 air intake
- 24x LS2 AFR 205 heads nightfury cam
- Zex nitrous kit wet 150 shot FS 500.00
- Garage clean out Kooks T56 Corsa
- Nitrous Express Proton Kit *NO BOTTLE*
- LS6 Intake and TB
- BNIB Bosch 044 fuel pump for sale
- A&A 3.8 pulley for sale
- Ruff 944 wheels for sale
- Ls2 rods
- Ligenfelter ported 823's ***SOLD***
- Sold
- tr6060 with clutch
- LS1/LS6 coil brackets
- LSX Build Partout
- Fbody accessory drive and misc. S10 Rack
- Lingenfelter oil cooler adapter SOLD
- L92 Short Block / Vic Jr Efi / 6061 Elbow / Lsa Heads
- For Sale DiabloSport InTune Programmer
- Textured black LS4 valve covers
- Richmand 4.10 gears, Autometer nitrous gauge
- Ported stage 3 317 heads and port matched victor jr
- lt1 parts
- F14 CamSlp lid, 85mm GM maf, slp smooth bellow, Complete ac bracket
- fast 92 intake with rails/injectors
- Nitrous Solenoids
- 4.30 gears for 9 inch/ locker
- LQ9 long block, l99 water pump, 9" gears
- c6 Tails / Nitrous Outlet Digi Gauge
- [sold] Solid roller camshaft with springs
- Comp/ms3 cam,slp under drive , ls6 pump and dual chain kit.
- 3" Stainless Steel Resonator 12" Overall Lenght "NEW"
- 17x9 OEM Chrome WS6 Wheels (With Drag Radials)
- Delrin Shift Knob
- Ls parts, c6 parts and other stuff
- ls7 injectors GM#12576341
- 243 heads
- LS1 F-BODY Lower Alternator Bracket w/ Pulley
- 04 5.3 truck harness and computer 175$
- new msd 6ls box harness and efi adapter plugs 250$
- Kooks Ls swap headers
- Pfadt Inverted Adjustable Shocks
- Brand new magnaflow exhaust. New umi sfc adjustable panhard
- LS1 Coils, Injectors, Throttle Body, T56 Shifter
- AutoMeter Sport Comp Boost gauge NEW
- Weld rts sale!!
- 2002 ls1 4l60 dropout 115k complete
- wtt weld rts 15x4 front runners with tires
- LS turbo headers
- F.S. Edelbrock Pro Flo intake !
- Like new Siemens 60# Injectors
- 2006 CTS V engine cover
- Slp cold air intake kit
- Huron Speed V2 AC Kit WEEKLY Bundle Sale! 9/28 - 10/4
- F/S : Vortech V1 S Trim for C5/C6. Low Miles. Pulleys. Possible trade for Turbo.
- 2 DiabloSport Predators U7198 and SLP
- Ls6 shortblock
- 226/232 cam bnib
- Complete ls6 intake
- Truck Coils
- 4 nos bottles, 1 heater, 1 blanket
- ls6 intake manifold and ported TB
- MAST 305CC Black Label LS7 Heads w/T&D shaft mount Rockers FS or TRADE
- LS3 821 heads
- Ls2 Parts-243 heads, timing sprocket, valley cover, pushrods, oil pump
- Fluidampr corvette crank pulley
- 4l80e
- 1998 lonnies dual fuel pump with hobbs
