View Full Version : Parts Classifieds
- 1.85 Rockers, 11/32 PR's, BTR dual spring kit with TI retainers. ALL NEW IN BOX
- Trade Complete LS1 fbody swap for needed parts
- GM Performance Racing Lifters 88958689
- nitrous kits and catbacks and other items
- Aeromotive A1000 fuel pump
- LS6 Valley Cover 12568002
- Yank 3600
- 42lbs injectors
- Nitrous Outlet 90mm plate
- LS9 Heads Titanium Valves New
- Induction Solutions Sledgehammer Nitrous Plate
- UMI stuff, LT1 stuff!! CHEAP!
- LS6 Intake / BMR k-member
- BNIB: reverse split turbo cam
- Adams Products detail spray VRT Sealants polishes and buffers
- Garage clean out misc parts. Comp cam,trunion upgrade,ls2 rods
- Cam kit for ls1 ls2 5.7 6.0 6.2
- Alum DS w/1350 u-joints
- McNord Wide Body for 1998-2002 Camaro
- WTT built 4l60e for th400/350 w/brake
- GI: Built 4L80E
- wheels and tires
- 99 Ws6 Part Out
- wideband,muffler,merge pipe,rocker stands,fuel pump
- FL: 2007 cts-v e67 ecm + gas pedal assembly, ls2 silver blade throttle body
- Ns Nitrous Kit ***SOLD****
- 1997-2000 Corvette C5 TPMS sensors 2
- pro star rear wheels and tires SOLD
- TONS OF LS PARTS FOR SALE!! shipping available!! LS1/2/6/7 AND T56.POSSIBLE TRADES!!!
- OEM Black SS Camaro Hood
- Ls1 harness, console, cam and more
- LT1 UMI k-member
- yank pas 3400 for 4l60/65/70e
- Holley MidRam 92mm TB Powdercoated and Ported* GT55-94* 1650cc Injectors* Wastegates*
- Lower Center Console & Driver Knee Panel
- Dressed Holley high ram
- FS: Lunati Forged Crank
- LS2 camshaft
- ls1 ls2 f body and vette parts
- OEM polished C6 Z06 wheels
- UMI Drag Sway Bar
- 6 Speed Part Out
- FS: Leather, plastic & Vinyl care products
- Ls1 camaro taillights & hid headlights w ballasts
- Wolfe Race Craft: 4th gen F-body Torque arm
- Huron Speed turbo kit (sold)
- Complete ls6 intake (sold)
- T56 For Sale
- 97-04 corvette factory exhaust cheap
- SLP H.O hood
- Holley Low Impedance 160 lb Injectors & FLT STage 3 4L80 Trans
- LT1 parts - Opti,MSD Wires,Cloyes Dbl roller, coil/icm, eng harness
- Aeromotive ls1 rails, regulator , billet filters
- Asanti 20"/22" wheels off of c6 corvette
- Turbosmart Race-Port 50mm Blow Off
- Turbosmart Hyper-Gate 45mm Wastegate
- Power steering pump
- Waterman Mechanical fuel pump drive
- LS3 Vic Jr carb intake, Holley Pro Systems 950, MSD 6LS kit
- Dorman window motors
- 4 gen PCM cover
- Fbody Alum. Driveshaft,t56 crossmember, waterpump, c5 DBW TB, jp timing chain
- on3 78/75 turbo for sale
- Predator diablo u7193
- ARP 134-3610 LS Head Bolts
- (4) 20" Breyton Race GTS wheels Black
- *badass custom c5 headers...
- Wilwood SRP Rotors for Ford 9-inch, BRAND NEW
- SOLD!!NOS super powershot solenoids and Leash relay board.
- Sold
- Comp Hydraulic LS Lifters
- Brand New DISCOUNTED! Nitrous Outlet 102mm Hardline Plate System and accessories
- DMH dual 3" electric cutouts (round)
- Hp tuner for sale
- 42lbs ls3 injectors
- Brand new magnaflow 15684 cat back. NJ
- Super Vic LS3, Quickfuel 850, Stinger Kit
- 5.3/6.0 parts
- Flaming River Billet-Joint
- TCI th400 full manual reverse pattern valve body
- partial hotside/coldside
- GTO 3.90 Diff, Driveshaft, ATI Damper, Lonnies GTO Fuel Kit, LS3 Intake, MSD Light
- Truck 6.2 Oil Pan/Windage Tray/Pickup
- 2006 6.0 lq4
- LS6, LS3 Knock sensors, PS cooler
- Siemens 60lb injectors EV1 (73 lbs)
- ls1 lq4 lq9 oem flex plate 12563136
- Ctsv blower with solid isolator installed
- Stock K-Member, Trans X-member, truck intake,tb, and rails, f-body fans, etc
- Edlebrock 90mm cable tb, lingenfelter trg-002
- Manton 11/32" Chromoly Pushrods 7.400"
- Swap T56 Wiring Harness for A4 ill add some cash
- Fast 102mm intake Ls1
- 35th Anniversary Wheels Flawless! 600 shipped!
- custom turbo cam from LJMS
- NEW 58x Callies Compstar 4.000" crank. $850 shipped
- AFR 205 heads
- SuperChips Vivid Linq Paq
- MOREL Lifters
- Wiseco forged +5cc pistons 4.005" bore
- Sold
- Ls6 intake
- Meziere Electric Water Pump.. WP319R
- 1995 trans am shell
- Random parts
- Stock Car Products dry sump pump
- dry sump LS pan
- Interior parts
- LT1 flywheel (almost brand new)
- Autometer 5" tach w/shift light
- Bbk throttle body
- ls3 intake and fuel rail
- Billet specilaties biller serpentine setup
- LS swap oil pan
- 98-2002 Camaro Sunoco Extended
- 98 gauge clusters, Civic Exedy clutch disc and pressure plate, K&N smooth bellows
- 60lb Siemens Deka Injectors - $250
- LS6 Bare Block
- LQ4 Oil Pan
- LQ4 Pistons and rods
- LQ4 Cam
- FAST 102 fits LS7
- SOLD - LS Oil pump
- Ls6 pistons and rods
- Hp tuner pro w/ 6gm credits available
- LS2 Block dual valve springs ls3 heads arp bolts and more local pick up
- Callies Compstar 4" LS crank and rods...Houston area
- FBody turbo hotisde
- <<SOLD>>Comp ls camashaft, spring kit, pushrods NEW PRICE!! 550.00 SHIPPED!!!
- 243 heads - freshly rebuilt
- OEM WS6 Hood
- *SOLD* Brand New Monster lightweight level 3 Race twin disk clutch for LS1 Fbody
- nitrous outlet 78mm f-body ls1 plate kit and snow performance meth kit
- AEM 30-4110 A/F Digital Wideband UEGO Controller Gauge Air Fuel Ratio 4.9LSU
- 2010 ly6 6.0
- LS3 BTR STG4 polluter cam
- 97 Hardtop Shell, fits 93-02, OEM
- Built Turbo 350 and cheetah turbo action shifter
- 98-02 Camaro headlights single halo red ring
- RX Catch Can
- T56 with spec stage 5 clutch
- Turbo, intercooler, 4150 throttle body, fuel rails, timing set
- Complete L92 heads, pistons, LS2/L76 block, ect
- Ls1 lt1 t56 parts
- Summit racing coupon code needed
- 98-02 fbody d1sc
- Brand New AEM 320 E85 Fuel Pump
- Ls1 maf
- 98-01 ls1 pcv line
- Big Block COMP Cams 883-16 - Endure-X Mechanical Roller Lifters
- SOLD: brand new Accufab 4150 for 4500
- pat g spec'd eps cam 234/242 and FIC 42lb injectors
- PLX M-300 TE Wide Band
- Precision 76mm, oil feed line, air filter
- 799 heads- great shape
- QA1 coilovers and CC plates
- Double DMods Double Din for headunit
- [sold] Ported Victor jr w/ direct port & tb
- FS Derale 16925 fan
- Trg-002 lingenfelter
- [SOLD] Kooks stainless stepped fbody/gbody
- F2 PROCHARGER COG RACE KIT LSX transplant
- Trick Flow 235 Cathedral port heads SOLD
- Kooks Headers and Exhaust 98-02 LS1
- SOLD! LS1/T56 complete dropout 1998 F Body
- LT1/4L60E Complete Dropout F body
- LT1 WS6 hood for sale
- Brand New UMI K member and subframe connectors
- AEM Gauges FS
- New patriot heads
- T56 with spec stage 3 clutch
- magnacharger mp112H
- Powerlglide transbrake valvebody*SOLD*
- BRAND NEW, 80/89mm BILLET COMP TURBO CT5X T6 TURBO FS! ***LOWERED PRICE***
- Fti th400 w/rmvb, trans brake and removable housing
- 30lb & 40lb injectors
- Improved racing fbody baffle
- LS3 FAST 102 LSXR Intake (ported by Tony Mamo), FAST Rails & NW102 DBW TB
- LS3 block.. 4.065 bore.. GM takeout w/ 1 cracked sleeve
- FS: Wiseco 4.070" pistons w/ ring set and pins.... BRAND NEW!
- AC Compressor, lines and accumulator, Power steering Cooler, MAF
- 2002 WS6 Rims W/ET Streets
- Turbonetics evolution wastegate
- Trade: Brand new LS3 - L92 Holley modular mid-rise intake manifold for high rise
- FTI 4l80e billet lockup 4k sall converter
- Borla NON adj. catback
- 102mm TB
- ATI Serpentine Balancer and Drill Fixture
- FULLY ported LT1 intake
- 247/255 .600/.606 110 LT1 cam
- Comp 26918 springs and 795 retainers
- Turbosmart eBoost Street Boost Controller
- 16" and 9" Spal electric fans
- Powdercoated centerbolt valve covers
- rear eibach springs
- 18,19 inch TSW wheels,Firehawk tires
- 99-02 Fbody A4 Engine Harness / LS6 Intake
- Holley fuel pressure regulator
- C5 corvette exhaust manifolds
- new callies magnum
- Deka 85 lbs injectors forsale BMR rear control arms Alky injection system fast rails
- Bmr alternator kit
- NEW 383 iron LS1, Wegner CNC 799 heads w/Ti valves, BTR Stg IV, Vicr Jr carb, Complet
- 1995 Cluster Guage
- 2000 Trans Am Dash
- Suspension parts galore
- Pro Comp 1.8 Rockers NEW!!!! SOLD!!!!!!!!!!!!!!!
- FS: FIC1000 95lbs/hr Injector Set for LS3/7/9/A
- 17in black staggered ZR1s
- Fs: Fully Built 10 bolt
- 2010+ Camaro Vortech V-3 Si Procharger Kit Complete
- Fbody 93-02 (Camaro/Firebird/Trans Am) J&M Subframe Connectors (NEW)
- ls7 intake, comp xr277, push rods, ls7 dry sump tank, etc..
- New water pump, power steering bracket, C5 rear brakes, maf, and front cover
- Huge turbo camaro part out!!
- 4150 zex perimeter plate
- L92/ls3/l76 parts
- LS6 intake manifold
- 416 Wiseco Ceramic Coated LS3 LSA 4.070 pistons Sold
- Borla xr-1 muffler
- Ragin Racin Late C5 and C6 Twin pump fuel system
- SOLD FAST 90mm LS1/LS6 Intake Manifold
- C5 Corvette Drive Shaft Shop 1000HP Prop Shaft
- C5 Corvette Quicktime SFI Bellhousing Manual Trans
- 10 Bolt Detroit Locker
- UMI K-member and Boxed a-arms, used $650.00
- FS Misc Fbody Camaro / C6 Z06 / LS Parts
- Garage clean out
- Fs/ft new ms3 cam will trade for boost cam
- Fbody Honeycomb taillights Great shape!
- LS6 Intake and ported stock throttle body
- Ls1 intake, knock sensors, misc stuff
- LS6 Intake & Vengeance ported/polished StockTB
- LSXRT 102mm, X-link, 90mm ls3 TB, rails/30# injectors, adapter plate
- T56 6 speed manual transmission
- FS: NIB ID1700's
- BBK 85mm LS1 TB Throttle Body
- SBC 383 (Well built) long block price
- 2006 Pontiac GTO t56 Complete swap 6 speed
- Rick Crawford Custom grind and pushrods
- LT1 parts-vented opti. PCM etc.
- A1000 aeromotive fuel pump with filter and AN fittings
- Fast 102 rails and 80lb deka injectors
- OE LS1 injectors
- 98 Camaro taillight,truck intake,gauges,nitrous bottle Warmer &more
- Forged long blocks, LSA longblocks, heads, twin turbos set up, and more!
- Wiseco 9cc dome 4" pistons with scat h beam rods, 6.0 block, new Jp timing set
- L92 victor jr accufab 4150 Wilson fuel rails
