View Full Version : Parts Classifieds
- Keisler Engineering Hydraulic Throwout kit
- ls2 truck intake 60k includes fuel rails and injectors
- 30k ls2 rotating assembly with arp rod bolts
- LS1 rocker arms
- Borg Warner Turbo
- Brembo Camaro 1LE front calipers/pads/rotors
- Holley 553-103 digital dash - USED
- chrome staggered zr1 wheels never been salt
- 95 z28 part out
- Cx racing 3in intercooler
- GTO instrument cluster & trim
- ***FAST ls2 length 57# injectors!***
- AFR 205 Mamofied Heads
- ls1 harness, gm msd 6012
- 5.3 oil pan/truck coils/manifold with fuel rail and injectors
- Stainlessworks up and forward headers brand new
- New Manley 4.070 / -18cc pistons with rings
- Zex Dry Kit & Accesories, REV Valve Springs... *SOLD*
- Mt et street radials
- NIB Kooks LT headers 1 3/4" to 3"
- Brand new ls9 head gaskets part number 12622033
- Various Stuff for Sale
- UMI tubular lower A arms.
- Racetronix, ABS, Calipers, Lights, M6 console/xmembr, Interior
- FS: TSP 7.4 pushrods
- Lt1 rear disc
- B body hooker 2063 lt1 shorties
- Fresh 6.0 with forged rods and pistons ( SOLD LOCALLY )
- Motovative Alternator relocation bracket, T4 Turbo hot side with Tial waste gate
- UMI Non-Adj. Torque Arm, A4 and T56 Torque Arm Relocation Kit
- Turbo Hot side for camaro + Truck Coils
- Complete LS1 w/LS6 extras ..LS Swap
- Aeromotive 11142 Fuel Pump/Pumps ****SOLD***
- Feeler: Parting Out 2010 Camaro SS
- Ls6 intake manifold
- L92 Water Pump
- Parting out 2000 camaro ss
- Looking for White TA body parts
- FTI 4000 Hard Hit Converter
- 2 454 HO motors 425hp 500tq 500 hours on them
- Delphi single and double crimping tools
- Holley ntk wideband 554-100
- LS1/T56 harness
- 37# fast injectors
- Nos mini 2-stage progressive nitrous controller
- Strange Adjustable Shocks
- RPM Level 5 4L60E w/ Precision 3600
- Rear Hatch and other parts for sale off a 2001 Formula
- nitrous express two stage plate 90mm
- 5.3 Iron Block
- 853 heads and other
- New Polluter Cam V2
- ls6 intake, rails, injecotrsm tb
- complete turbo KIT without turbo
- Sail Panel
- SSRA Jaws/SSRA/cold air intake kit
- Dyno Tune Nitrous kit, programmer, & SLP lid
- L92 823 heads & bare 5364 heads
- 65# deka injector and BAP
- Zex 75-175 kit
- Hypertech Power Programmer III Camaro Firebird Corvette ***SOLD***
- ls1/ls6 fuel rails fuel rails
- 2009 throttle body from suburban
- F/S: First Gen A&A Intercooler
- Aeromotive GM LS2 Billet Fuel Rails///sold
- TCI th350/400 to LS convertor
- Garage Cleanout: LS2, ZR1 Clutch Kit, LS7 Clutch, Slaves, Tick Master, etc
- *PRICE DROP* Factory Refurbished Spec SC09ST Twin (1300ft lbs) for sale
- Ls1 ignition coils with brackets
- LSA heads & LS7 parts
- WTB: Any Driveshaft for TH400 to 10 bolt (temporary DS)
- Used Brute Speed Blower Cam
- SOLD: EPS/Comp 226/230 cam, PAC 1518 valve springs, Yella Terra rockers
- LS1 PARTS-heads, lifters, rockers, & PERFORMANCE PARTS
- 53 lbs Fuel Injectors
- BNIB GM LS7 clutch and flywheel
- dynatech 1 7/8" long tube headers for foxbody
- Vrx5 cam slightly used
- FS: ls3/l92 rocker and rocker stands
- Trans Am Wheels, Polyurethane Motor Mounts, and Stock LS1 Parts
- Innovative LC2 wideband, Odyssey PC925 battery
- 1/4" Water Pump Spacers NIB
- 2 Camaro SS 10-14 O2 sensor 12609457 /4sale
- Batch Of 1/4" Push-To-Connect Fittings
- FS:Reactor LS flexplate
- N/A Cam for Turbo Cam TRADE...
- ls6 intake for your intake
- moser 12 bolt in PA
- Stock Aluminum Driveshaft
- OEM Ws6 hood GMMG Corsa Tips WS6 Speed line wheels fs or trade rear end
- TWO 9" rears CHEAP (CLICK THE LINK!!)
- 799 Heads
- Holley A/C bracket and adapter
- mcleod mastercylinder
- LS6 Cam 5308 springs, Ls2 ls3 coils, ls6 valley cover
- Like New M6 Shift Boot
- Mint Ebony M6 Center Console
- F-body LS1 pil pan with pick up tube
- Fresh fully machined 6.0 block
- 1998-2002 Camaro 6k HID Projector Headlights
- Fs/ft. (( procharger d1sc kit//cometics//blowercam//60#injectors))
- BRAND NEW Holley HP ECU
- Mcleod Adjustable Clutch Master Cylinder
- Dragonslayer/Magnum lx & rods,Lt1 6.2 hollow stem valves and ls1 2.02
- lt1 t56 parts
- powerdyne bd11-a and other stuff
- Turbonetics 42mm Race Gate & Raptor BOV
- Rare ls6 hollow valve heads 9000 mile 04 vette
- stock 18 inch gto rims
- Complete turbo hot side kit and turbo!!!
- Clutch master Part#DB07HF601 A
- 1 3/4 stainless headers
- custom nitrous cam for sale break in time only cut by martin smallwood
- PRC 237cc 6 bolt heads
- MWC Short Tunnel Mount TA Torque Arm
- LS6 Intake
- Founders performance adj LCA's
- Ls6 intake with rails and injectors and ported stock throttle body
- Huron Speed V2 T6 Turbo Kit Complete w/ S475, WG's, BOV, Oil lines, etc
- Lonnie's Twin 255 Fuel Pump Set Up,
- 243 cylinder heads
- NEW LS2 block
- 4l60e, PTC converter, Pushrods
- stock corvette throttle body dbw
- 93 Z28 part out
- SOLD Heatsink truck coils and brackets
- 4" trans am hi rise fiberglass hood
- HSW 90mm plate (new)
- F-Body LS1 Oil Pan *** SOLD ****
- 2-EPS cams, LS6 cam
- Holley 650 DP
- turbo cam!
- NIB Chevrolet Performance Musclecar Oil Pan 19212593 S10
- Z28 rims and nittos for sale
- 2010-2015 Camaro Brake Caliper sets --SOLD--
- Comp cam, spring price drop
- Heads cam headers exhaust a/c cruise
- Small garage clean out
- Complete LS Supercharger System
- FS: 2 Brand New Catch Cans
- FS: Brand New ID850
- fast multi port ez efi fuel injection
- callies compstar 6.125 rods
- FS: Chrome BBK headers
- GM Muscle Car Pan/ASP Underdrive Pulley
- C6 LS2 LS3 Oil pan Pickup Dipstick Windage tray
- F body radiator and fan setup
- LS 383 Rotating Assembly. Sold!
- Precision 120lb injectors
- comp 7950 7.350 push rods
- holley mid rise with extras
- Bunch of stuff...Race & stock parts. Darkstars, SS4000, PAC .650's, Man Brake Conv.
- SOLD 2002 Stock rearend
- Wiseco piston K451X3 0.030 $280 shiped
- 5.3l pistons, fixed pin style
- 4.8l flattop pistons -SOLD
- Ported Throttle Body and MAF
- F-body 10 bolt
- ported and milled 243s
- 38mm Turbosmart wastegate, spohn safety loop
- Nitrous outlet f-body ashtray switch panel
- ls6 intake for trade, 853 heads ls1 engine
- Bullet Custom Turbo Cam - NEW!!!
- GMPP LSX LS7 Intake Manifold #19244033 - BRAND NEW!!!
- Aeromotive EFI Regulator #13113
- Complete 2008 LY6 LS3 Intake manifold
- 160 # Injectors
- Zeitronix ZT-2 Wideband with LCD Display, Precision T3 Exhaust Housings
- nitrpus outlet coolant crossover, valve covers, 5pin maf
- 02-04 Zo6 cam and springs
- Parting out nitrous wet kit with purge
- 60lb SIEMENS DEKA Injectors
- FS: Fti 3200 stall converter
- Miscellaneous Turbo and Piping Stuff
- 317 heads with Patriot Gold .650" dual spring kit
- Delphi 96lb. injectors
- Couple parts for sale that will not be used
- Turbo Kit with Precision Billet 76GTS Turbo
- Patriot cnc heads
- BNIB Nitrous Express Bottle Heater
- Turbo set up for 98 S-10
- Stock parts
- Texas Speed 7.400 push rods
- ETP 255 CNC cathedral port heads and rockers
- ss camaro rims. Great shape!
- Headers,blow off valve,and more
- FS: Spec Aluminum Flywheel, Spec Stage 1 Clutch
- F-body and ls1 parts
- ls1/ls7
- FAST dual wideband
- on3 7096 turbos
- Truck Motor Mounts
- Complete Intake, 2005 Truck
- Flexplate, 2013 5.3
- Stock 10-Bolt Axles, 4th Gen F-Body
- S91mm OFI Tubular Header COMPLETE turbo kit. KEEPS A/C
- nitrous stuff
- GZ Motorsports Super Pro Series Vacuum Pump setup
- Holley HP with Harness BNIB 1500!!
- Ported Victor Jr. 6061 sheetmetal elbow, fuel rails, and NW 90mm TB
- 93-02 Camaro Leather seats Graphite grey like new
- 98 z28 part out
- Ati Harmonic balancer PN# 917246
- 17" Enkei wins PRICE DROP!
- ls9 injectors with adapters
- meziere 35gph wp
- Sold
- Ls1 intake with throttle body
- NOS Nitrous System
- Tick Master Fbody
- 4 post coolant crossover
- New Tick cam and 2 New .040 Cometic HG's
- LS1 F-body oil pan
- (4)OEM ZR1 17x11 wheels
- garage clean up.
- 8.1 Supercharger Kit, 8.1 Built Engine (Raylar Parts), 8.1 Parts
- Wings West Grille. Camaro 98-02
- lq4 Pistons and Rods
- LS6 intake manifold w/throttle body and rails
- 35th Anniversary style SS 10 spokes w good tires
- c5 6 SPEED SWAP FOR C5 AUTO SWAP
- alky control , psi wiring harness, injectors
- 2009 5.3 Cammed 4l60e conv 40k miles
- 243 heads. fresh from machine shop
- LS2 fuel rail
- 2004 ZO6 LS6 243 heads w/hollow/sodium valves
- UMI FBody Shock Relocation Brackets
- Innovate Motorsports 3806 LM-2 Digital Air/Fuel Ratio Meter
- 5.3 and 4.8 genIV short blocks, bare block
- Spohn torque arm mount with driveshaft loop
- brand new scat 6.125" h beam, factory ss hood
- 799 heads sold
- New Powerbond Underdrive Pulley
- MSD opti and LT4 composite valve covers
- Used LSA cam and sprocket, valve springs
- 06 LS2 pullout 17k miles
- Nick Williams 92mm TB SOLD!!!!
- ((garage cleanout))
- LS6 Intake 12561184
- Clean out stock 5.3 and LS1 some new some used
- SOLD Diablo Sport tuner for 99-03 GM cars/trucks
- Nitrous Outlet 90mm plate Lsx
- Two Fuel pumps...PROCHARGER and internal give away for $50
- Strange 12 bolt spool and gear set
- 4.10s 3 carrier
- Comp Ultra Gold 1.72 Roller Rockers
- Brian Tooley Stage 2 Truck Cam 212/218 **New**
- brand new PROCHARGER BIG RED OPEN RACE VALVE
- **SOLD** Taylor Universal 10.4mm Wires With HEI/Socket/LS/LT1 Coil Ends, Separators
- New LS6 Hollow stem and sodium exhaust
