View Full Version : Manual Transmission
- line locks which shifter knob?
- LS7 Clutch
- Should curb weight of vehicle have an effect on clutch decision?
- pro 5.0 install?
- Shifting into reverse shifter rubs console
- Whining noise coming from bell housing?
- adjustable master. Need some help
- Transmission lifting
- got a problem and need some help!
- what part is this...pics inside.
- Auto to manual write up
- Need Insight into problem:4th gear
- ES trans mount
- Can Anyone Diagnose This Problem????
- Should i buy a new clutch? Drifting \ Dragging 2 weekends apart.
- Clultch Recomendations for Drifting
- LS7 clutch?
- Pedal hanging up recenlty
- 02 hydraulics
- Tested for Slipping Clutch
- t-56 noise
- Any reason not to get textralia?
- what did I do?
- centerforce clutch
- How does my clutch look?
- tranny install, slave bleed????
- Is The Spec Stage 3 Clutch Kit Good For Daily Driving??
- LT1 T56 guys, question on clutch fork...
- Auto to manual swap ?'s
- pro 5.0
- Need advice - what clutch to get :)
- c5 t56 rating? specs. What can it handle?
- transmission is acting funny.. please help
- Recommended course of action
- just took apart my first t56...wow
- clutch issue
- POLL: Shifter Choice
- Bent clutch slave retainer for MC hose?? (Pictures)
- Hydrolic woes! New master/slave problems
- Symptoms of a broken spring? and also an odd noise under the car..
- Will GTO clutch master clyinder work in F body?
- Six Speeds Inc. in Joliet IL for Super Bowl Race
- Where to get t56 parts?
- BIG problem after getting on it.
- Balancing a fly wheel
- Slave Cylinder(s) Question
- Spray + Power Shift = Grinding
- Heavy or lightweight flywheel?
- Disaster!!!
- How Hard is it to convert from an Automatic to a 6 spd on a 2002 Trans Am?
- Bled the clutch and still hard to shift at high rpm's?
- T56 - noise / vibration only at light throttle?
- Clutch pedal sticks
- How much can a stock t56 from a 98-02 trans am handle?
- Clattering in 3rd and popping out (4th sometimes)
- T-56 tailshaft?
- flywheel question
- How much power can the LS6 clutch take?
- notchy hurst shifter...
- SPEC 4 or 5 for STS making over 500rwhp
- Soooo, do we really NEED the spring that returns the clutch pedal??
- parts list
- ram adj master problem..
- 3-4-2 shift question
- RAM adjustable master cylinder
- LT1 w/ Ram Al Flywheel and Mccleod Single REPORT
- need help with clutch issue!!!
- Clutch Fluid
- It's Official: GM Acknowledges Degraded Clutch Fluid Causes Pedal Woes
- Doing an M6 swap what flywheel?
- Found something while removing t-56
- Yellow smoke and burnt clutch smell after a trip to the strip...help
- can you still get into the gas when you are breaking in a new clutch ?
- '97 LT1 M6 - Trouble getting in gear, clutch seems partialy engaged.
- what i thinks seems to be a likage plz help
- spec 3 or tired tranny?
- [b]need Big Help On My Trans[/b]
- n00b shifter question
- hard time putting it in second
- Aluminum flywheel?
- Will consider trade
- having some trouble, need help fast please.
- Reinstalling the hydros.. quick question
- M6 Shifting:Where do you shift?
- can my clutch be done after a big mistake?
- Man am i Fkd
- Stock T-56 gear ratios?
- Throw out bearing reatainer
- Spec stage 2 plus
- Transmission Crossmember rear bolt holes?
- What am I doing wrong tex owners???
- what did I break??
- Tons of chatter after Spec stage one install?
- Need Help, Hard to shift into reverse after dropping engine/trans
- Need shifter removal help: sealant removal
- Ram Twin Disk Clutch System
- new t56 from D&D good idea?
- bleeding the clutch master cylinder?
- Installing the Master Clyinder
- No A/C HVAC after A4 to M6 swap
- whats the best M6 for a 3.73 rearend?
- real quick where is the bleeder valve
- Not shifting after slight load...
- Clutch installs Who is doing them
- Will an LS7 Clutch hold for me?
- Sudden soft clutch pedal?
- clutch release higher??
- Textralia Break In??
- clutch bleeding problem. (surprise) :/
- Clutch shopping, questions
- Clutch pedal to the floor, at an intersection
- M6 noise. Please help.
- NMCA 1 time only Race Special that is insane!!!!!!!
- Grinding Gears
- Wont go into reverse! need your hlep!
- could this be clutch slipping
- How much clutch is too much clutch?
- Can an LS style T56 be used behind another motor?
- Spec 3 slipping, weird
- shift boot clip
- High rpm shifts
- clutch problems--still have them after drill mod
- How much power will I be leaving on the table with my stock clutch?
- How much clutch throw is too much? Adj. master question...
- >>ALUMINUM FLYWHEEL OR BILLET STELL FLYWHEEL????????
- How to tell when clutch is failing?
- Transmission code
- Looking for a clutch
- After clutch install, I keep getting code 0704,Why?
- 4.10 Gears for my M6 Daily Driver
- A4 to M6
- Stick Question
- grinds goin into 2nd whats up
- LS7 Clutch/LS2 Flywheel Installed
- ***ATTN: SPEC*** Pics of my Stage 3
- Steel Shift Fork Question
- Who has actual experience with the spec 3+ clutch
- lt1 t56 to ls1 help now please
- Help With Whining Noise
- Slave and master suggestions
- need 01-02 slave cylinder...
- T-56 trans cooler interest?
- Installing 95 Chevy 5spd Help!!!
- spec....search is worthless today
- slave not disengaging clutch HELP!!!
- first gear grinding
- T56 Won't go into Reverse
- slave cylinder problem...
- quick stupid question be 4 i buy it!!!
- m6 problem help
- T56 Extension Housing gasket??
- m6 problem
- How do you bleed your clutch hydraulics?
- Flushing clutch hydraulics question
- Shifter bushings/spring?
- Pro 5.0 & Factory Hurst Short Stick
- Help me ID my left over T56 rebuild parts (PIC)
- less abrupt clutch???
- T56 locked me out of all gears???
- strongest T56 on market?
- >>quick question on clutch overheating!!!
- Textralia exoskel twin disk, a lilttle noisey?
- The Myth of the Street/Strip Clutch
- t-56 weight?
- Transmission Fluid
- McLeod slave cylinder with OZ700?
- Hurst Shifter question
- Sponsor that sells Hurst Shifter Emblem for rear of car
- problem with sticking 4th gear
- loud thump when i shift!!!
- banging in the trans tunnel??
- How long should this take?
- T56 Clutch and Flywheel question
- Just finished my 4l60e swap to a 6 speed!
- Sticking clutch pedal write-up
- is there a trick to hook up trans?
- Has anyone broken their LS7 clutch yet?
- Replacing clutch very VERY soon..few ?'s
- help me
- problems with t56 please any advise
- How to remove a 5 speed tranny? A friend in France is in trouble with his 96 V6
- Some T56 problems
- Textralia OZ700...first impressions...
- Help: Clutch hose popping out on T56?
- Aftermarket shifters bad for a Daily Driver ?
- Spec 3+ clutch questions. Should I use stock flywheel?
- Question about tranny
- MN12 in T/A, shifter problem HELP!
- clutch confusion
- hard to shift into 1st and reverse
- Remote Bleeder GP
- A built F-body t56 or a stock Gto t56?
- Parts list (ls7 clutch)
- help....
- clutch confusion
- hard shifting, and i have tried alot!!
- Trans is coming out again. #*^$!
- 3rd Gear Grinds
- Does the gto need thw drill mod???
- Strange situation with my hydro's. Not sure what to think
- is an ls7 clutch ok with stock '06 GTO T-out Bearing???
- Installed UMI tranny brace, now horrible vibration!
- clutch don't work need assistance
- Yet another clutch problem.
- New clutch, FW, Hydro's, rebuilt tranny, still not shifting right.
- rebuilt M6
- tranny question really weird
- bellhousing
- Any new shifting vids?
- Steeda Tri Ax handle. Which shift knob fits? Thread and pitch?
- problems
- can i rebuild my t56?
- Clutch shot?
- B & M Ripper install
- clutch install write up
- what 6 speed??
- Shifting
- Flushing Master Cyl.....check it out.
- How long?
- Update......
- T56 conversion question
- Six Speeds Inc. Closed July 4th
- master cylinder
- Ls7 Clutch Kit
- Tranny or Clutch??
- F'in LIVID @ McLeod Industries
- please help bleeder valve
- Need some input, just added longtubes and ory pipe, drivetrain slack?
- LT1 specific clutch questions...
- Seafoamed my car...added so much power, took out the clutch!
- TEX twin exoskel at nearly 400 miles review.
- stuck
- transmission mount tip
- skip shift
- Reverse issue
- Need help!! 96 T/A flex clutch line needed ASAP!!
- Ram powergrip Hd problem.
- T56 Rebuild Questions
- Cost of used t56
- VSS Trouble Code..Speedo not working
- FS: (1) New Spec Stage 3 Clutch Kit
- Problem with billet 3/4 keys/struts
- slave cylinder Q??
- stupid question
- Worn synchros?
- Correct Way to bleed Clutch???
- Hard to get it in Reverse...
- How should i adjust my ram adjustable master asap
- Where to get transmission rebuilt
- Anyone have experience with CF DFX clutch?
