- Tach Output Signal
- 68 firebird with a ls2 396 could it fit??
- lq9 swap
- Auto to Manual swap
- Oil pan
- Using LS1's HVAC...BCM?
- Acc Bracket space difference
- 2000 pcm pins
- will 6.0 ls1 bolt to 200-4r trans
- ls2 cam in a 6.0?
- LQ9 in 95 v6 a4 Questions
- LS1 Engine Conversion!
- 2nd gen auto shifter
- Few more Turbo pics of 59 Impala
- i've got a 65 vette...
- T5?
- O2 sensor actually different?
- 1994 Camaro V6 To Ls1 Any Info.
- PRC heads/Stainless Headers
- Cheapest place to remove VATS?
- ATTN: Mustang Guys, Suggestions for hydraulic clutch (fox mustang)
- ls1 or lq9 into a 98 c1500
- 4.2 ltr swap questions.
- 62ChevyII project need advice
- Master and Slave Cylinder Question
- Chevelle radiator hoses
- VSS signal different A4/T56?
- Using complete 4th gen body harness in a different car
- finally driving the Mustang
- 90* reducing elbow.
- Tremec 6 speed shifter.
- 59 TT LS1 Impala custom gauge pics
- LS1 plate problem with 3rd gen
- Need LS1 emissions info...
- About to buy a motor, need answers
- LSX drop questions
- 95/98 ls1 video finally runs
- LS1 into a Vauxhall Astra Coupe
- Datsun LS280Z Update!
- LS1 Ford Capri starts!!
- 68 C10 LS1 conversion headers
- LS1 in my '60 Pontiac
- LS-1 headers
- 6.0 into 86 monte.
- Pics: 92 TA vert swap, 99% finished
- PCM circuit/wiring questions
- Do you think camaro lt will fit in a fox body?
- Brake Woes... People with brake knowledge please help.
- Question: Hacking stock 98-02 manifold
- LS2 into 57 Chevy
- ls1 to th350, parts needed?
- steel braided line
- Advice and Guidance
- Finally she lives 1995 to 98 ta a4
- Water Pump
- LS1 fan swap
- Difference between a 98 or up LS1 and regular 5.7
- cable clutch set up tko ls1
- Mechanical speedo on T56
- LS1 engine weight?
- Pics of Pacesetter LT, need lil work
- autometer tach hook up
- speedway header kits
- Tremec TKO 500/600 swap for Fox LS1 swap?
- 5.3
- supra sleeper????
- motor for sale
- LS1 in a Porsche 912
- Reverse drivetrain direction
- Pictures of LSx
- Feeling out responses
- I need LS1 S10 help
- I have a question for yall.
- Dual line fuel rail to one line?
- LT1 to LS2 Questions?
- looking for Steel fuel line with GM male EFI connections
- Radiator cap pressure for LS1?
- ls1 and my 68
- Camaro Dash swap??
- advantages of LS1 over Turbo Buick motor?
- ls1 conversion help....
- T56 Shifter Relocation
- LQ4 swap into a C4 corvette in progress
- custom long tubes
- hey steve Your car is a bargin haha!
- 4l80e?
- Gas Pedal Options?
- Bolts?!
- what do i need to install a ls1 into a 69 camaro?
- GENIII in 69 C20 4x4
- Ls1 runs finally
- Stoopid mount question
- My '69 Camaro is done and hit the road
- Mallet Canyon/Colorado LS7 conversion.
- Colorado Canyon LSX swap? How tough?
- Pics of Trans-Dapt MM brackets/notched oil pan/Turbo Headers
- ultimate sleeper
- Silverado, Sierra 2WD 6.0L swap?
- Any LS1 Vega swaps?
- Cheap place to buy an LS1 in the UK ?
- Ls1 Cj7
- AC for my 69 Camaro - LS1???
- my new project
- 69 twin turbo project....
- Third gen LSx motor mounts-help guys!
- Extended LSx wiring harness?
- Swap into Porsche 930?
- Pics of my LS1, what needs to be done?
- Anyone using Painless LS1 EFI harness ?
- Headers finally fit
- Corvette accessory brackets
- what headers will work?
- Engine codes ?
- 5.3 oil pan gasket
- accessory drives
- LS1 Studebaker - Crossmember finished!
- 63nova with a LS1
- Using Donor Cars gauge Cluster
- what else?
- Hinson??????!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
- Header question
- Motor Mounts - LSx to SBC
- distributorless ignition
- LS1 Fox Body rear end choice?
- Where did it go??
- which coil packs for thirdgen ls1 swap?
- 1984 2 seat Z28
- My Conversion
- T-5 instead of T-56 with LS1 Swap
- speartech is awsome
- who uses this gauge cluster?
- Plastic Replica Engines/transmissions
- it is alive!! Aside from a pesky ruel rail leak all went perfect
- A little different...
- 4L60 Trans info
- exhaust on 68 c-10 ls1
- Welding Oil Pan
- 4l80e shifting
- cheap temp sensor adapters
- exhaust pipes
- Finishing up 87 Z28/LS1/4l60 Project, last of the setbacks.
- Longtube headers in Stingray corvette
- evap canister removal?
- anyone need a cheap ls1`/mustang swap header?
- exhaust manifold help
- Overall LS1 Swap impressions?
- Crankshaft Position Sensor Help
- 3rd and 4th gen torque arms question
- To A/C or not to A/C, that is the question ...
- fox body AJE k-member mystery part
- Photos from the weekend's work (LS1 into 3rd gen)
- The Datsun 600Z Lots of pics
- ls1 into 84 avanti II
- What gets changed to install ls2 or ls7?
- Finally...the S10 gets the motor it needed all along!!
- LSx in a '94 Supra?
- Lq9 in a camaro?
- Bending header tubes: Need opinions
- LS1/ LS6 TB comparison
- is this a ok deal or should I keep looking?
- Wiring diagrams for LS1 and/or LS6?
- Are all motor mount adapters just about the same
- Swap LS7 Into SBC- Sort Of
- 2nd Gen Front Clip for Sale
- exhaust manif. interference??
- It's Alive - 3rd Gen w/ LS1
- LS1 and 4L60E in 39' cpe (tranny question)
- ???? for the ls1 mustang guy's
- CORBRETTA is born!
- Info on Quiet Exhaust
- -Ls1 in a e30 BMW
- Do I need to keep both PCMs?
- Starting engine after 2 years
- Any one use a Canton pan for conversions?
- Ls1 Swap In A Chevette Anybody?
- LS1 and tranny exterior measurements for Volvo 240 Wagon swap
- Eclipse GSX w/ AWD and LS1?
- Can I mate a 98 6speed to a big block Chevy
- 2002 5.3L Conversion into a 1986 Pickup
- ls1 third gen camaro header question
- Entire car available for swap...
- Just got LS1
- And so it begins ....
- Help with conversion
- Fly by Wire on Conversion?
- Looking for PCM and harness
- Who makes that fuel injector adaptor harness?
- Kicking around the idea of a LS2 in my 69 Camaro
- M6 reverse lock out selonoid
- price of used ls1
- LS1 Custom Pulley setup
- LS1 in a 3rd gen question
- Header clearance with QA1 K-member
- FBW harness questions
- Alternator location
- Videos of 240sx conversion?
- Dash Cluster with conversion
- turn key nothing happens WTF
- year of pcm to use for conversion
- The Jimmy is 90% Complete
- SBC Fox Body
- Push-button gearshift for powerglide?
- Anyone running a carb'd LSX?
- LS1 in a LT1
- Slave Cylinder Connector
- custom dash ideas
- crate motors
- Who makes headers for 3rd gen ls1 swap?
- 4" aluminum tubing
- turbo chevelle gettin there!
- carbed Crate Motors?
- Stock parts for conversion
- LS1 into 37 Ford "What is needed!"
- Rack won't reach collum
- Ran my LS1 Blazer at LACR on Friday...
- LS1 headers for third gen camaro?
- need info /2002 5.3 into a 1997 silverado 4.3
- rack and pinion quesiton
- Need some help with f-body acc. brackets
- Cooling problems
- Can I convert 4wd 4l80e to 2wd?
- Carbon Fiber block off plates?
- Cruise Control?
- power adder fuel line size?
- Alternator fusible link?
- Which motor mounts?
- LS1/T56 into 95 Camaro
- Stainless Works Headers
- 59 Impala Turbo Systems pics
- How do I make my 8.5 10 bolt strong?
- Gas guage question
- Can I lengthen mass air wires?
- LS1 S14 240sx Swap
- 9 inch housing in a 68 camaro rear brake ????'s
- 5.3 Swap into S10
- 69 rs camaro T56 conversion
- cold air inlet size ( 3.5" - 4 ") ??
- Help - Just Bought LS1 For My Rx7 - Any Good Books Out?
- Street & Performance Headers- how much power?
- ls2 intake swap
- 8.8 F&%D rear end swap
- LSX in 64 chevelle?
- My LS1 240sx Swap
- Banging My Head - No Start
- Complete LS1 w/ Supercharger for sale with Swap parts
- water pump pulley removel?
- Planning on swapping LT1 for Ls1
- '98 Vette LS1 Swap
- dynomax x-pipe muffler
- 68 Camaro Conversion what kind of gauges?
