View Full Version : Conversions & Swaps
- 1st gen camaro aftermarket subframes
- Turbo LSX Fox Body Mustang with Power Steering?
- 3.8 a4 to 5.7 t56 help
- Stock uncut Fbody pan & manifolds in a 1st gen camaro, they both fit.
- 600Z build
- Motor Mounts Help
- Need help deciding what color Speedhut Gauges!!
- Ls1 in a 99 mustang GT build
- turbo project
- LS1/T56 in 67 Camaro TRANS HITTING TUNNEL
- 82 c10 with 5.3
- Super vic question
- New at this site need help with engine build
- Foxbody Swap Crossmember Information (LSx) The CHEAP and Easy way
- carb'd ls1 ignition problem
- Got LQ9 6.0 for 1968 Camaro – Best low cost setup for fuel injection ? Help !!!
- Brz Ls swap thread?
- can some one please post a drawing for cooling fan wiring
- Ls? Swap mustang cobra 1997 vnmous !pics
- Fuel delivery help please!
- Oil galley plug thread size???
- Engine starts but dies after 5-7 seconds
- 98-02 Fuel Pump Pinouts!!! Using a Vetteworks Kit
- What ECU / Wiring harness to use?
- 00 v6 formula to lq4 turbo swap
- 1935 Buick LS1 swap questions
- Sachs NFW1050
- 61 belair, LS3/4L60 swap
- AC Delco part-number for C100,101,105,220,230 connectors with pigtails
- ls? s10
- L92 oil pressure spikes.
- need some direction lt1-lsx swap
- Looking for Mustang swap results with EFI
- driveshaft? ???
- need part number for correct oil pickup tube please
- Oil pickup tube hits pan - HELP!
- 86 Notch Project Halfbreed gettin close!
- 4,000 ppm vss for 5.3 th350 swap what's everyone useing??
- 57 Chevy with LQ$
- 96 s10 cheap 4.3 to ls swap?
- 67-69 1st gen camaro guys, how close is ur engine to the firewall?
- 86 Monte SS. 5.3, Single turbo, Megasquirt II. Lots of pics
- what can i remove
- LS swap into 71 Nova. Mount issues
- Emissions and Registration engine swap questions?
- Not the norm for a ls1
- GEN III or IV: Which engine?
- new in town
- 6.0/5.3 conversions w/o power steer and a/c
- 98 SS swapping everything into 95 v6 shell
- Need LS motor advice for 69 Camaro swap
- Anyone know where you can get covers for these fuse holders??
- Using a 2006 GTO front drive
- 64 Chevelle LS swap questions
- oil sending unit
- Building a LS1 M122 Blower Intake. Need some help.
- Twin Turbo LS powered AC COBRA Kit Car Build
- Question for LS/t56 foxbody guys
- LS1/M6 to A4 into 3.8/A4 Firebird
- Who should i send my harness/computer to for mods?
- 71 camaro+lm7+dbw=headaches!
- Autometer guage (TACH) inop
- New use for truck mounts
- some ls foxbody swap questions
- foxbody questions
- 1978 opel
- Stick guys, I'm ignorant and need help.
- need a shop that can finish a LSx swap
- What cam for a ls1?
- What motor mounts for 80 malibu?
- Champion ls3 miata dyno
- '88 Supra Turbo LR4 swap BW S472
- power steering issues-98 Vette LS1 & pump feeding into 89 S10 box
- Best mechanical speedo kit for 6 speed ?
- LQ4/T56 g-body swap ecu ?'s
- Please Help! Jeep Grand Cherokee steering box swap on a-body
- LS2 Miata @ PBIR - Drag Video
- 1967 Ford Mustang LQ9 swap - Lil' Heathen
- Cooling - Help - lsx fox swaps
- E38 ECM Harness extension?
- T43 OS swap (6L80E TCM)
- Power Steering Rack - something other than Mustang II
- Car warriors ls3 nova
- 1968 Camaro question (brake)
- Remember Cash for Clunkers when you vote tomorrow
- Starting a 86 conquest ls2 swap
- 5.3 swap issues..
- LM7 5.3 verses 5.3L LC9
- Cooling fans and A/C compressor wiring
- Problem starting engine that hasn't run for 3 years
- 5.3/4L60e first start
- LT1 T56 to a LS1 engine
- Help with crazy (and/or stupid) idea
- Need help with a A/C & Alt Relication
- Strange O2 Sensor Problem
- using motor plates?
- Another 5.3.......Well 6.0 Mustang Build
- 2002 pinout instrument panel
- ls into 82 Caddy
- c220 and c230 harness to insturment panel $$
- Msd atomic ls efi system
- air condition swap
- fuel line question
- LS2 Alternator wiring help
- Mustang AJE K member questions
- 64 Nova wagon with heidts
- Chevrolet Performance 19155067 Serpentine System
- 2009 GMC 1500 nemb question
- Just received my convesion harness.
- L33 stand alone harness
- what to use for a pedal/slave cylinder setup in an ls/t56 swap into a g-body
- Angry and eternally burned by carburetors and gasohol vapor lock
- Will ls1 fit 3.8l 5 speed?
- 89 Formula getting 5.3
- 07 LS2 into a 70 Chevelle
- 1998 Vette DBW question
- Clutch setup in fox body with ls1 t56.
- Spark Plug Wires
- 87LSX Monte SS nightime burnout vid.
- ls1 t56 swap questions?
- 2" exhaust too restrictive?
- Where to start.....
- Dyno numbers for 5.3 Malibu
- Low Alternator for Low Cost
- steam vent tube
- Lt1/LS1 T56 Swap.... Why?
- 87 notch
- Question on AC lines for LS1 into 95 Camaro swap.
- Kit cars
- Air filter suggestions/ideas....
- lq4 swap in Pro touring 67 Chevelle
- Looking for some custom LS1 harness parts
- Best wishes to all in the path of Sandy.
- 1977-1978 Trans Am LS Swap
- Transmission issues
- How do I check oil pressure without starting the motor,
- older vortecs vs 03+ question
- What starter do I use?
- wiring harness question
- 5.3 Mustang Build
- Computer issues
- LS engine in a new Cadillac ATS?
- Jeep Grand Cherokee steering box swap on a-body
- the right cam
- 1969 Pro Street Camaro, 5.3 twin turbo
- HELP, guys I think I forgot to check
- LS turbo GN.
- waterpump leak
- Converting fox to 5x4.75 bolt pattern
- 1970 GTO LSX Conversion ?'s
- HELP! Can someone read my engine serial #
- database for junkyard parts?
- 91/88 mustang reswap 6.0/T76
- Now thay I think I have top dead center
- LS or LM swap
- QA1 with 6,000 miles blows a seal. CRAP
- Wow, I can kick myself :(
- New "LT" engine series announced to replace the LS series
- Range (PRNDL) switch on 4l60e for conversion
- Ford headers on LS1
- LY6 Newb Need Some Help
- cheap ls fox headers
- Plug and play harness for ls g body swap available anywhere ?
- 71 Firebird Formula LM7 turbo swap - build thread
- weight difference between a stock 92 z28 and a stock 2000 z28
- 99 camaro 3.8 to LS1 swap
- advance adapters with th3500?
- 4th gen camaro fuel tank in third gen camaro
- lt1 to ls1 fuel system
- 1988 Monte Carlo SS LS7 stock short block H/C/I belts out 660 RWHP N/A on 92 Octane!
- E36 swap with a 4L60E
- New to the forum with a Cobalt LS2 drivetrain swap
- Who has used the trans-go kit on a 4l80e?
- mid engine ls2 corvair no spark advance
- Tall Deck Fox Questions
- Stainless Works to expand LS swap header and exhaust line up. SUGGESTIONS!
- what is the torgue for the stock rockers
- Fuel return line question
- 68 camaro 5.3 swap questions
- LS1 t56 s13/240sx reverse lockout wiring
- Is AN -4 too small
- going rate to wire up a LS1 combo
- Power Distribution
- LS7 into 2004 C5 Auto?
- Quick question about the wiring for my swap......
- optimal exhaust design for my LS3 RX7
- Electric fan on/off setpoints
- Which ly6 accessories with vvt delete?
- Budget 1st gen camaro swap info 1969
- Which pan and brackets for a 68 chevelle.
- Physical size...truck 5.3 and a truck 6.0...same?
- Fiero LSX 427 IMSA hits mid 10s at Byron, IL
- Holy Crap! I need help! Battery/Alternator
- Team Z Fox K member
- ls1 swap into 94 k1500
- LS1 Fuel Pump Fuse
- Need some help with 62 impala build
- ECU location for Fox/LS swaps?
- Ly5 oil pan swap to gen4 camaro pan ?'s
- Making my own LS1 Standalone harness and How to wire the Bussmann Fuse/Relay Box
- HUMMER H3 Alpha LS1 Swap
- fc + 4l80
- Local Tampa guys that weld
- Any Success with LT1 to LQ4 AM motor mounts
- 67 chevelle 5.3 swap edelbrock intake questions
- Need help to identify connector
- LS376 525 crate swapped bmw m3 with no tach
- how cheap could you swap a ls into a foxbody?
- a/c quetion for ls swap into a 94 t/a
- 5.0 mustang ls1 swap
- Will this 4.6 ls setup work ???
- Fuel Line, Over intake or driver side?
- Thinking about a Turbo 5.3 build
- Post your 75-79 Nova LS swaps.
- 6l80e Slip Yoke
- Mercedes 280 Four Door W114 with 4.8
- ? For Fox Guys
- What starter???
- Where can you buy this exhaust flange?
- 5.3 vortec swap
- LS in a Chevelle motor mount and header combo?
- "Nadine" and the Fireball...
- Dipstick problems
- Ls in foxbody ???
- Long Crank/Short Crank Questions
- Connector ID
- Fox Body LsX Turbo dilemma...
- good price for LS1 dropout??
- 5.3l into 1962 impala
- Idiot light sensor
- Headers
- 81 cutlass factory wiring needed to run standalone 5.3 harness
- 74' Laguna S-3, LQ4 6.0L, GT4294 turbo Build
- 1999-2002 V-6 Firebird - LS3 Swap ?
- LS3 Swap Into a 1999-2002 V-6 Firebird ?
- No spark #7, coil and plug wire are good.
- 2000 corvette tranny
- Range Rover conversion to LS
- Fan Wiring Question
- Quick steam pipe question -LM7/S10
- 2000 truck harness injector connector seal
- Anyone use a ctsv tranny in ur LSX swap?
- Won't stay running
- 4.8/5.3 width?
- Shops handling L92 / GM truck conversions?
- Lt1 to ls2 harness
- lq4 and t56 prices?
- 2nd Gen F-body LSx header suggestions needed
- Mustang or Camaro
- LS1 PCM and Cruise Control Installation in 1933 Willys
