View Full Version : Conversions & Swaps
- 350Z LS7 F2 Procharger
- 4th gen LS1 dual fan assembly & stock style A-body radiator
- L99 LS3 tensioner pulley dimensions?
- 68 chevelle ls1 P/S whine
- Newb question about oil *rx7 LS6
- From a 5.3 to a 6.0 what is required
- Good source for universal swap mounts?
- thirdgen lsx help
- f body vs. truck ac compressor
- charcoal canister?
- 2nd gen pcm mounting/
- 2004 LQ4 and a 3 wire VSS, can I do it?
- Plug for stock oil sender?
- Truck vs Fbody belt system
- MIL - Check engine light issue
- Catalytic Converters, NJ inspection?
- motor question need help asap
- Street and Performance header collectors
- LS1 K-member on LT1 car
- ls3 injector pigtail?
- TKO-600 and DBW Cruise Control troubleshooting
- Which intake lq4 or LS1
- 79 camaro w newer vette wheels?
- 5.3L or 6.0L install into '57 Chevy Truck
- getting ready to put an ls1 in my 1968 camaro,need some advice!
- LS3 ---> 1982 Vette
- mounting DBW pedal
- PACE auto coil covers
- Pro Street 87' Mazda RX-7
- Truck engine into 65 Corvette ?????????
- Anyone have a problem putting ls6 intake on a LQ4
- one wire alternator with aftermarket harness?
- Tech Rods harness
- F Body Oil Pan measurement needed
- 6.0L Silverado engine fire questions
- Any 2nd gen lsx guys here?
- Need pinout for 2010 Camaro engine harness connectors
- ls2 in 79 camaro alternater hitting pitman
- Swap 6.0 from 2001 Silverado to an F-body
- STEERING WHEEL PEOPLE or any body with great info!!!!!!
- Parts you found out you didn't need for your swap afer you bought them?
- LSX Datsun Guys, COME ON IN!
- LS2 2005 GTO motor......DIPSTICK ISSUE
- LS1 Harness Connection Map
- fueling questions for a V6 camaro--->ls1
- new plan for jet boat build
- LS2 Nissan 350z Turbo Stage 3 =)
- cost of a conversion
- BMW 357i - Startup
- 5.3 T-5? How to?
- 65 nova wagon 5.3 questions
- school me real quick on swap
- wiring harness routing
- Y pipe for third gen LS1??
- kwik bracket
- 1987 Monte carlo Luxury Sport LS1 6spd (Camaro Dash and Features)
- Starting a 71 Chevelle LS3 swap
- Truck water pump, twisting the outlet?
- pcm???
- lockup switch wire
- Lsx 6sp in a 89 s10 2wd
- mustang coupe with ls1 questions
- adapter for four speed?
- 67 chevelle conversion ls2
- 05 5.3 LM7 charging module?
- spark plugs question
- Wiring Harness Question
- Completed LSX Monte Carlo Swap
- E-Rod Questions
- Gotta see this one...
- I made the cover of Hot Rod magazine!!!!
- Park/Neutral switch wiring
- Power steering to gear box question for 79 camaro
- 99 Camaro to 69 Camaro
- Full length Volvette Video
- Please help me decide...
- Congratulations Steve Verplank!
- No turning back now... 1969 Camaro convertible w/LS-2, 6spd from 2006 GTO
- SBC mount question
- ls7 swap in 2000 trans am
- LQ4 into a 1963 Plymouth Valiant
- Fox Mustang ls turbo question
- LS7 Question
- Making my Stock Ford tach work with an LS1...
- Trans Insight
- ls bell housing
- 4l60e shift cable question
- DBW cruise control
- f250 swap or not
- swap guys griffin 22x19x3 rad and fal 2500cfm low boy PUSHER 16" fan
- My 67 Camaro Build/Photos
- 67' GTO LSX Swap **4L65E Problems** *TCC Solenoid refuses to disengage*
- Trans compatibility questions...
- Foxbody LS swap longtubes/exhaust FS
- LS6 vs BBC 396 I need HELP making a Decision!!
- LQ4 which heads should I use
- 79-04 Mustang LSX/T-56 swaps just got a whole lot easier!
- ls1 engine connector pinouts
- Fbody- V6 to LSx
- C105 question pin H
- How do you tell if the engine harness is a 98?
- Anyone Looking for Shop Space in Sacramento area? Co-op Fabrication Shop?
- 99 Firebird L36/A4 to LS1/T56 Formula Firehawk
- clutch master cylinder location
- LS-1 crate motor
- '63 Short Fleet
- pcm codes
- 1981 Trans Am LS project
- T-5 speed + LS1 anyone done it
- LS2/TKO-600 1971 Chevelle
- My Turn...No Start!
- My 1967 dream machine
- ?s Windstar Electric fans
- Fuel pump wire question C101
- ls1 into 85 c10
- 4L80E controller or not
- Winter storage question...
- 1992 525iT LS1 Swapped Station Wagon For Sale
- LS! crate motor
- LS1 intake, EGR plug and PCV port
- New guy with lots of questions
- Great coolant fan switch adapter - lousy price
- LSX Ranger all info welcome
- Bitter Sweet Day
- LS1 into 95 mustang k-member decision help!!
- turbo gbody
- my bird needs an engine
- Need help with wiring harness install
- Testing the LSX Willys MB
- LSX swap, cannot decide on 6speed or Auto?
- wont't go into closed loop
- New to LS swaps
- LS-1 crate motor
- LSX - 1967Firebird
- Electric water pump
- 94 camaro ls1 swap( NEED SOMEONE TO DO MY LS1 HARNESS WILL PAY)
- Which One?
- $312 Spectre FI fuel tank
- on the fence old school or new school
- Camaro/Nova 1/2" forward with Autokraft pan + Dougs headers
- drive by wire to cable ecu changes
- ls1 water pump
- Ls intake manifold
- Quick wiring help
- 1969 LS1 chevelle gearbox?
- Lq4 powered 1977 cadillac coupe de ville
- LS1 Powered 98 Toyota Tacoma (will update with pics)
- Need a quick measurement
- 5.3 vs. 6.0 on a budget
- DBW help
- SPEARTECH- quote
- ls2 engine and harness and gauges in 68 camaro help issue!!
- LS1 foxbodies come in here.....exhaust questions
- Stock Balancer to go with 19155066 kit?
- Needs the best links for 1998 V6 Camaro ls1 swap ASAP!!
- reprogramming ecm same as tuning?
- Range Rover LS Swap
- LT1/LS1 T-56 6speed question.....
- which lsx swap kit into a fox is best?
- Drive Shaft / Crossmember Question... LS1 / 4l60e in 70 Camaro
- Turbo parts for A-body
- ls1 swap into fox body. need help
- Street rod conversions-advice
- 2008 5.3 Vortec installed with T5 WC/66 Chevelle
- Trans Selection Help
- Looking to sell my complete LS1/4l60E or part it out
- electric fan wiring testing
- Few Noob LY6 questions that i cant answer with the search
- Anyone running C6/Vette style Engine Mounts?
- Porsche Conversion Flipped PCV Question
- My 1987 Jaguar XJ6 swap thread
- brake pedal switch purpose
- LS1 to LS3 swap in a 98 T/A?
- Mustang diff ??
- 1969 GTO Judge Clone LQ4 turbo 4L60e
- LY6 mated to a T56
- 2005 5.3 pinout/diagram?
- o2 sensors not working
- Clutch bleeding frustations
- Need Pinouts/wiring diag for 2003 Express Van
- Is this engine swap worth it?
- UMI Performance A-Body rear control arm brace design
- Pics request, ls swap in a fourth gen monte carlo ss
- HELP! sbc swap in v6 fourth gen firebird HELP!
- Question about LQ9 Accessories
- help on brake light switch!
- 4l60e questions
- Something a lil different.
- ls1 in 68 camaro coversion questions? (basic newbe)
- fuel line sizes???
- Need some help with A-Body clearances
- Edelbrock mounts/headers on a 67 Camaro w/F-body pan
- fuel pump wiring
- Pcm controlled electric fan (2) wiring schematic
- "Chirping" Lq9 - Need advice
- virtual dashboard, oil pressure, hp tuner questions
- Looking for another Monza for an LS2 swap...
- g-bodys keep your digital dash speedo
- Experienced tig welders please chime in!
- fuel pump relay lq4 swap
- 1990 notch swap throttle question
- Distant Future LQ9 or LQ4 Swap in '82 C-20?
- found a mustang roller, looking for a vin check
- e-bay grand national fuel tank and sender????
- ls2 in 68 camaro swap kits and options?
- Turbo 5.3 Ford Focus
- Hummer pan dipstick
- ls1/th350 mustang help
- 96 v6 to either a ls1 or a lt1
- Chevelle good deal?
- LSX 454 swap
- 1986 cutlass 5.3 build topic .
- E-Rod Program
- gas tank question?
- Motor mount relocation advice.
- LSx conversion with Cruise Control, want a cruise control "ON" light.
- Have 2 harmonic balancers - which one?
- High current fan relay with PCM ground.
- mustang 408 stroker ls1 swap with kooks headers
- 996 w/ls1 swap - kaput thanks to California
- trans crossmember 79 camaro?
- Another 240SX with ElEsJuan
- gas tank question
- Ls1 swap into an a body
- LQ9 swap into 1956 nomad
- Edelbrock pro flow intake height?
- question
- anyone do an ls swap into a 92-96 f150
- 1961 Parkwood Wagon starts and runs
- LS6 1991 Camaro speedometer hook up
- brp standup guys
- AC, mixing old and new?
- Your thoughts
- 350z LQ9 Swap
- Aluminum 5.3 block engines
- ls1 powered ford five hundred?
- Does it matter where I put the oil pressure sending unit?
- 69 camaro procharged ls7
- Fox Body K-Member Questions
- Good Source for Jeep Mail Order Tune
- What would be better?
- Autokraft Mount Adapter Thickness
- Mustang Guys
- Ls1 Brunton Super Stalker
- Can I use the F-Body cluster with my swap?
- Fast Ez Efi Multi-Port with MSD 6010?
- Turbo-LQ9-T56 96 Blazer
- anybody done a 5.3 jeep swap?
- cheap CH-R or CH-R replicas for a 74 chevelle
- Lq9 z28
