View Full Version : LT1-LT4 Modifications
- B-Body Hits 200K
- Fuel pressure?
- Who ports stock lt1 heads?
- 94z timing chain question?
- For sale in the non lsx section
- will my car have 2 be tuned again?
- want to gut my cats
- Solid Roller/Again!
- Help with EFI Live 4
- cc306 cam expectations
- Dear Pacesetter...
- 385 LT1 AI H/C Idle Video
- A Few Pics of The Begining...
- old z/28 emblems
- Pulley question
- Are Ls1 shifters the same as Lt1 shifters (A4)??
- Foglight covers
- noob Lt1 project
- 1990-1994 240sx lt1
- Fuel regulator?
- high idle had these threads input
- Windage tray clearance
- Tire question..
- What else should I check?
- bad rocker arm stud
- Really Really Rich
- Replacing a cracked dash?
- Turn the crank to start my car?
- Qustion
- SES light on with fans?Anyone have a guess?
- opti test points?
- MY BABii
- Fuel Injectors
- 383,396,402,427 questions!
- Any idea??
- Chamber size - 10207643
- TB Coolant Bypass hose size.
- Air Pump Delete
- LT1 to LSx
- oil temp sensor
- missed 2nd on the onramp and it revved to 5500
- LT1 bolt ons. in what order?
- Comp 305 cam
- Best lt1 wires?
- 280XFI vs 292XFI
- blue spark under hood
- Any experience/opinions with SRP pistons?
- Our Z in Super Chevy!
- Just Traded My truck For A Fast 95 T/A
- zo6 wheels
- Best Sounding CatBack for LTs and ORY
- n20 ????
- maf screen
- Lt1 Fuel ???
- Need HELP,All Opinions Needed!!!
- Wtf
- WTF Balance sheet for 383
- I Know The Answer, But Ill Ask Anyway
- LT4 kit?
- What bolts do yall use for your engine stands?
- Front Gaskets
- car sputters then slowly dies need help please
- Rev limiter
- cam only dyno # inside
- Before I mess up something
- Slight miss
- Internally or externally balanced flexplate?
- post???
- shortys vs longtubes
- timing chain
- solid roller??
- stock rockers ticking??
- Does this sound like a good Idea
- How To Check A Icm??
- Help with Exhaust Band Clamps
- 3200 or 3600 stall converter
- Comp Bee Hive Springs
- want some fun.....with an lt1
- mallory 685 harness wires not same color (Need help please)
- What should i do!
- The Headers and the Hole: A book...
- Honest Opinions on Bosch O2s
- Header question!
- OTVC with MSD?
- Gas MPG 3.73 gears in A4 LT1 Camaro
- well the car goes under the knife this week.
- misshift + black smoke??
- FS: Nicely Modded 1995 LT4 Formula...9000
- Y-pipe?
- Best oil for 383?!!
- Cleaning engine parts, what to use?
- Street Tune vs Mail Order
- Hooker LT AIR problems
- P0300 Random/Multiple cylinder misfire WONT GO AWAY!
- Where to get drivers door window switches?
- Will lt4 hotcam kit work with 1.7 rr
- Anyone make a manual rack for LT1's
- bent k-member or frame?
- fog lights?
- Lt1 Vs 4.3l
- SLP or Lingenfelter cold air intake
- Accel Opti???
- running RIIICH
- 94 Z28 guage cluster help!
- Best Lt1 head gaskets
- so i have a hurst shor throw in my car...
- How long does it take oil to get to rocker?
- need 5' of taylor 8mm red wire
- 396 0r 383
- Underdrive question
- A/C Delete, Do i need a delete pulley or just reroute the belt?
- Anyone know anyone with a WS6 Hood and intake assembly?
- 383 or 400??
- My LT1 LIVES!!
- Serious oil problem. Need pro advice
- Pinion Angle and Bolts
- mileage question..
- Video. How do I get more traction ?!
- do i need retuned?
- Exhaust suggestions?
- ?that Guy?
- NEW SS Hood 93-97 Fit with 98+ Underside
- 94-95 Z28 underhood harness!
- Knock and some issues with rebuild
- Plz help
- Email Tune (OBDII)
- Collapsed lifter??
- Heater Box Removal
- building 383
- tune
- a/c relocation bracket
- 383 question
- Vortec Crab Cap, Timing Cover and more speculation...
- got motivated.......
- 93-02 Rear End Differences
- 383 want to make faster w/tax returns
- lt1 oil pressure issues, why?
- Wife is letting me keep the Z28!! So...
- Lt1 edlebrock intake vs stock intake
- Intake porting
- Brake Help Please
- LT1 M6 Car, 3.90's or 4.10's? Top end question to.
- rear main seal question
- Best N/A sprakplugs
- 93 z28 install cam promblem
- What Is Open Loop
- Question Going From A 52mm Tb To A 58mm Tb
- how hard is it to convert to a vented opti?
- Stuck at high rpm idle
- Ypipe question
- LT1 motor difference
- Another random "what would this look like" appearance questions...
- Trans fluid and Rear end oil
- Heat Cycle the Coated LTs?
- Cranks but doesnt start
- wheel weight
- Crane Ignitions (Will it work with my OBDII Camaro LT1)
- Pacesetter LT, and Y pipe install
- why is oil being pushed out my valve cover breather?
- Roller Rocker ?
- 383 hp loss
- LT1 gas mileage
- Best Place to Buy Exhaust Clamps?
- Best Place To Buy O2 Extensions?
- Oil Pressure question
- help a newb build a motor plz
- for thoes thinking about thoes $7 ebay intakes
- Has anyone tuned their OBD1 with an LM-1 in here?
- Tune for Pacesetter LT's
- Backfire at high RPM, injectors?
- Heads/Cam combo ?
- 2nd to 3rd gear issue
- opti spark
- Its dead
- 302 Lt1
- looking for a stock Lt1edit tune 95 formula 6 speed
- quick idle vid...
- 383 Lt1 CAM god's look here.
- 1993 firehawk specs
- Does Opti rotor orientation matter on installation?
- ITS ALIVE THE LT1 IS ALIVE!!!!!!bwwwhahaha!!!
- rebuild motor
- I diddnt know headers F***** up Lt1's this much
- LT1 swap for B2000 Mazda truck
- Need some help
- Time to get headers.. but which ones???
- What To Use???
- Oil Pressure dropping??
- 13.7 stock m6
- Who makes good aftermarket body pannels for the 93-97 Camaros?
- LT1 Trans. mount?
- 1979 camaro...
- Where Are Your Rudy!!?? I Need Help
- what cam to use?
- which lca's??
- o2 extension length
- Mezeire Electric water pump...longetivity?
- Stock Rockers
- lt1 fuel pressure?
- non forged pistons and nitrous?
- Getting my suspension ready for the Shoot out>>
- sound clips of true duals??
- LS1 Driveshaft Swap Q's...
- pacesetter Lt and cat removal, now ses light?
- Need LT1 advice, 4L60E to TH400
- optispark installation question
- whats the differences between LT1 and LT4 heads?
- What does it take to convert an A4 to an M6
- Replacement Bolt
- what can i get out of this lt1?
- Vibration in 5th and 6th gear only
- LT1 and LS1 parts play nice???
- GM LT4 V8 Intake Manifold
- Modding my Corvette
- LTX Shootout N/A Question
- High Idle
- sub-frame connector question??
- LE H/c with spray..
- T-56 & high H.P. LT-1 combinations
- I need your advice for my 383 rebuild
- Anyone scrap there cat convertor
- looking for a couple of parts???
- Bought a LS1 TA for $200!
- LTX Extreme Street
- 97 30th Anniversary Maro Rebuild......PICS
- Advanced Induction 211-hr Cam Question???
- Any smog techs out there?
- Vacuum water out of block??
- C200 Pin-outs
- Heads for my LT1 truck - pixxxx
- need info on ground wire location, with pics
- Difference in lt1s
- What are some causes of fouled 02s
- All LT1's on nitrous in here!
- pushrods
- Does Joe O. Still Make Cams
- Russel brake line kit
- Dynatech headers 1 3/4" w/o collector
- med patriot red metallic...rare color?
- DTC 1371 / Cranks but No Start
- quick question about crane 10308-1 springs
- True Dual Question?
- Load of new parts in the mail :)
- powerdyne
- Guys Running Cc503 Are Ya'll Running A 255lph Fuel Pump??
- Radiator cap question
- LE1's or AI 185cc's
- Chime in guys what should I sell for? headscam block
