View Full Version : Parts Wanted
- WTB t56
- WTB: 1994 Pontiac Trans Am optispark
- WTB driver side taillight and middle filler 02 TA
- looking for a ls cam
- WTB: 32#-36# injectors
- How to tune GM EFI engines
- ***wtb stainless ls1 headers***
- WTB: Engine wire harness auto, headlight brackets
- I need some parts for my 2000 camaro
- WTB: 98-02 F-Body LS1 FIPK intake
- WTB: Stock lugnuts with outside threads
- Trans am Interior Parts needed
- WTB: Uncut LS1 6spd Engine Harness
- wtb ls6 intake
- WTB: Humount Faceplate
- Battery tray for 98 ss
- wtb: weld pro star front runner wheels
- WTB Torq Thrust 2's ASAP!
- Ford 8.8 diff girdle
- WTB: HEADS AFTER MARKET CASTINGS for 383 LS1
- adjustable panhard bar and adjustable lower control arms
- WTB: LS2 timming cover w/sensor
- wtb ls6 heads
- Slp ram air lid
- WTB-18" Simmons FR series or CCW, Fikse, Kinesis
- Wtb ebony 6 speed shift plate
- WTB: Black 98-02 SS hood
- WTB: PCM bracket for LS1
- WTB: LS1 Throttle position Sensor
- Wtb line lock
- WTB: The Tuning school DVD/workbooks
- wtb ls1/2 gto power steer pump
- WTB black oem spoiler and hood.
- WTB T56 Shifter
- Stock leather manual shift knob
- rear end
- WTB 98-02 rear calipers and brackets.
- ws6 ebony seat belt buckle
- lookin for ls1 coil harness
- WTB VIC Jr or Sr.
- Need 30 lb injectors
- WTB: Firebird TA seat belt holder on headrest
- \|/ WTB: GTO 04-06 Gauge Pod , Grille , Magnaflow Exhaust \|/
- T56
- LS1 Coils and coil harness and coil mount
- WTB: Bare LS1 oilpan
- I want to buy EFI LIVE v2 or HP TUNERS
- WTB: One 317 Casting Cylinder Head
- WTB-LS1 o2 sensor extensions! ASAP paypal ready
- WTB Fast 90/92 intake
- WTB th350
- LT1 parts! please!
- WTB 2010 Truck stock Throttle body and MAF
- short throw shifter,slp grill,injectors,gauge pod
- catback wanted slp lm1 for trade and cash or just buy
- WTB: yank ss4000 ls1 fbody 4l60e
- LS1 Oil pan.
- LS6 intake/Rails/Injectors
- Coil Harness for use with MSD Coils...
- WTB Weld Prostars
- Sbc 350 tbi heads!!!!!
- fuel pressure regulator for boost
- Intake manifold Bolt
- Carpet
- cobraeater81...any1 got PM's from this guy??
- WTB Flex-Hone Brush 4"
- Stock LS2 intake and factory Fuel rail
- WTB/WTT for LS1 Alternator Bracket
- Wtb: Lt1 single plane/Vic jr intake set up
- WTB: 98-02 Trans Am Front Clip for LT1 conversion
- WTB: oil pan and carb intake
- wtb a pair tt2 17x9.5
- 900$ plus 4 98-02 Camaro true SLP ULTRA Z HOOD
- WTB Stock 10 Bolt w/3.42 gear
- 00-02 stock, unported throttle body
- Wtb: Slp lanyard
- looking for 98-02 center console plastic piece
- Need 98-02 Trans Am front bumper
- WTB: Vert Windstop
- WTB: Pewter Trans Am/Firebird front license plate filler panel
- wtb stall converter 3200-4000
- Autometer shiftlight pills
- WTB: 26lb LS1 injectors
- Fast 90 or 92 intake manifold
- WTT: SubThump boxes for MTX Thunderform Pre-Amplified
- wtb LS6 intake in Houston/TX2K11
- WTB: 1 Trans Am rim
- WTB Ls6 cam
- WTB Intake Manifold bolts
- WTB Idle Air Control Valve
- WTB: Stock Rear Coil Springs for 98-02 F-Body.
- wtb afr heads or trick flow
- WTB 1 silver snowflake wheel 16"
- WTB- RPM R 505's
- wtb 4" intercooler or thicker
- WTB Ls1/Ls block parts
- WTB B&M Ripper or Pro 5.0 for 98 WS6
- hvac box
- Need a ls1 pcm, 315/35/17, and a stall
- WTB ls9 cam
- WTB: WS6 lower air box
- WTB: Set of 42LB injectors for 02 SS
- T56 shifter and boot ring
- Need 93-96 a4 console for my 72 :)
- wtb: auto pedals, 2step, m6 shifter boot
- wtb ls1 alt bracket and power steering pump
- Need Complete AC System
- WTB: ls1 coil packs
- SVO 36# injectors
- looking for a rear end for my 2002 z28
- wtb: rear strano springs
- Looking for some wheels .....aftermarkets/replicas 17-18"
- WTB L92 truck intake complete
- Clamshell motor mounts
- Wtb
- Ls1, Vette Engine Covers?
- WTB front runners
- WTB 95 T/A Fog Light, and facory/aftermarket Wheels & Tires
- need these brackets
- WTB: Nitrous Accessories, Lid, Gauges...
- (1) 243 head
- Wanted: Rear Bilstein Shocks
- wanted: shaft rockers!!
- wtb: tubular k member for lt1
- Need wheels!
- ls1 slp cold air intake
- WTB: OEM Catalytic Converters
- WTB: 78mm Nitrous Outlet plate
- WTB Stock v6 front fbody springs
- Deleted
- Fl WTB BAD-LEAKING LS2 WATERPUMP C6 CORVETTE
- Looking for one LS3 head
- Camaro Front Bumper Cover/Pass Pass Fender
- WTB: 30lb injectors for my LT1
- WTB STS kit
- WTB: Underdrive Pulley
- Building a LS1 383 and need forged pistons, rods, crank
- WTB ls2 timing cover
- WTB: 98-02 F-body PaceSetter longtubes
- WTB: Angled Short Stick!!!
- WTB: LS1 exhaust parts
- WTB: LS1 Victor Jr & front accessory brackets
- need oem ws6 badge
- Wtb monster clutch
- WTB: 3in Electric cutout
- front draglites
- Autometer gauges
- T-56 wanted
- WTD: 98-02 Trans Am fog lamps housings
- WTB: Stock Exhaust Hanger
- WTB Silver WS6 Wheels Rims
- WTB: 02 simulators
- WTB: NSA 1.6 RR. Guideplates and Rocker studs
- WTB:93-97 Trans Am Hood, Fenders, Headlights, (front clip)
- WTB cheap headers, 1.6rr/hot cam kit, bottom rotating kit, Full LT4 engine
- WTB: 1 C6 corvette wheel
- WTB fast 92 intake
- WTB: 4L60E Tailshaft housing
- ISO Ls1 02 simulators for my Ta
- WTB LS1 ARP bolt thread cleaner PN 9120011
- WTB rear axle jounce bumpers
- wtb perfect ready to use 5.3 crank 24T
- headlight covers
- WTB: 42lb or 60lb Injectors (42# 60#)
- WTB ASP 25% UD pulley
- Wtb new corner and fog lights
- WTB: few LS parts for my swap
- Fab 9in, oem ss spoiler
- LS7 Injectors
- wtb f-body ls1 oil pan set up
- WTB: Procharger Kit
- WTB ls2 coil harness and oil pan
- WTB LT1 Heads
- WTB stock C6 exhaust flanges w/ a few inches of pipe - no cats
- CCW's 19" 505as or sp500s for camaro
- WTB: Forged Pistons and or rods!!!!
- WTB M6 shift plate and pedals
- SS hood in SE US
- wtb ls crank spacer and bolts
- wtb: wirng harness pcm,fbody accessories,fbody complete intake
- 02+ LS6 Cam
- Wanted: SLP LANYARD
- WTB: LS1 GTO OEM Intake (pretty please!)
- Looking for 15x3 or 15x4 rims
- WTB 1 7/8" Headers!!!!!!
- Wanted:ws6 emblem a.s.a.p
- wtb- hsw microedge
- Drivers door hinges
- WTB Bilstein rear shocks
- Need asap
- Power sterring assembly needed
- WTB: Drag springs, Chris1313 ram air and more
- WTB: Any LS6 intake!
- WTB: any 05+ C6 Corvette oil pan! Can pay NOW NOW NOW
- Wtb ebony top part of six speed console
- WTB: Katech Connecting Rod Bolts
- NEED: 92mm Fast intake manifold
- wtb: chris1313 non ac ram air
- WTB: Intake manifold bolts for LS1/LS6
- Need 99+ LS1 valve covers (center bolt style)
- rotating assembly/ FI short block
- WTB Front Seat Belts
- WTB: Coil Pack Brackets
- pacesetter headers and ory pipe...
- WTB: Pacesetter LT Headers and Cam
- WTB: Stock LS1 Motor & 4L60E Trans
- 92mm Throttle Body
- WTB: Weldon 2345-A fuel pump, or better
- WTB Camaro/TA LS1-T56 harness.
- WTB: 7.2 hardened pushrods
- Lt1 parts wanted
- 4.065 or 4.070 dished pistons
- Wtb: pre 04' headbolts
- WTB: 4L60 slip yoke & pcm
- WTB: slp lanyard
- WTB: SLP Air Lid for 2001 WS6
- WTB- LT1 Performance parts..
- WTB: EPP Blower cam
- Wtb 5.3 block
- roll bar
- WTB Top Dash Cover San Antonio
- lt1 long tube headers 1.6 rr's 36lb injectors
- Drivers side Sun Visor
- parts needed please
- procharger air pump relocation bracket
- 9inch or 12 bolt nearby KY or Tn
- Wtb fast 90,92 or 102
- Wtb piping for procharger and bov!
- WTB TSP MS4 cam, also possibly springs and rods
- Wtb victor jr efi intake
- WTB Ebony Center Console Lid
- Wtb fast 92
- stock rods and pistons
- Backing plates WITH emergency brake hardware
- WTB: LS2 Throttle Body; DBW
- Black and white slp lanyard!
- Intake Wanted.
- WTB: SLP 2 on the left exhaust or muffler, SS Grill
- Wtb ebony console lid
- WTB stock ls1 crank pulley
- Returning T/A to Stock, Need Several Parts
- wtb stock A4 shifter/cable/bracket
- 4" crank
- Wanted GTO Shift Knob
- Need some 15x10 inch rims for 98 T/A!
- WTB lt1 ram air box bottom piece
- WTB Factory WS6 Wheels
- Clutch fluid resevoir with cap
- wtb 4th gen t56 aftermarket shifter, stock length rod and knob
