View Full Version : Parts Wanted
- WTB ls2/ls3 timing cover with sensor
- WTB: GEN-TTR Twin Turbo Kit F-Body
- 98 ac compressor
- WTB: LS6 Intake
- WTB LS1 or LS6 short-block
- AC Compressor and F-Body Alternator
- WTB: LS1 Motor mounts/TA/Camaro"Clamshells"
- LT1 Trans Am Power Antenna
- WTB tial 38mm wastegate/ 60-65# injectors!
- WTB: flexplate bolts, 4L60E bellhousing bolts, torque converter
- WTB lower airbox. Non-WS6.
- WTB: 98-02 firebird tail light
- wtb powers steering pump mounting bracket and bolts
- WTB: Trex
- Wtb!! Black c6 zo6 rims in any size would prefer with red pin stripe on lip
- 9" 3.00 gears
- 98-2002 drivers side spindle
- need a foward wiring harness
- WTB: 99-02 Trans am engine harness A4
- WTB: Good condition LS1 crankshaft
- Driveshaft
- WTB: LT1 style Z28 155 MPH Cluster
- wtb: air lid
- 4TH Gen camaro/firebird leather seats
- wtb LT1 pistons and rods crank
- a4 shift cable for 98-02 camaro
- WTB: Y3F / RS rear bumper valance
- WTB: Center console 2000+ camaro
- WTB Block
- WTB: LS1 parts asap!!!
- WTB ZR1's 17x9.5 17x11
- Need a headlight for my 95 Camaro Z28.
- WTB: 3000 to 3500 RPM Stall Converter for 98 Trans Am
- Wtb: Built t56
- LOOKING FOR LT1 58mm THROTTLE BODY
- Looking for 4l60e trans (lt1)
- WTB or trade: TNT 78mm Power ring
- nitrous kit
- WTB ls1 bare block
- WTB: 98/02 Firehawk Hood Screens
- wtb ac compressor low miles
- WTB E40 PCM for 05 GTO
- moser 12 bolt girdled axle cover
- wtb: stock 1994 lt1 timing cover?
- lookin for t56
- mac catted y
- Wtb 98-02 t/a sunvisors door panels
- wtb complete 5.3 pullout
- wiring harness and ECU
- WTB: Nitrous Controller or Window Switch with TPS
- WTB SLP Dual duals or GMMG Axle back system
- f body coolant lines all of them
- 21mm or 22mm Rear Swaybar
- WTB: 18" wheels/tires
- WTB: 98-02 1" Rear Lowering Springs
- WTB 99-02 M6 wiring harness
- WTB: LS2/LS3 Block... or complete motor
- wtb-98-02 camaro headlight lenses or headlights
- Wtb: Ls1 t56
- WTB: 1998 1999 Cruise/Throttle cables off of Non-TCS car
- WTB: Ls1 98-02 Engine Clamshell Mounts + T56 Rubber Shift Boot
- WTB forged Rotating assembly LS1-CASH-
- WTB: LS1 Camaro/ Firebird Accessory Brakets
- Wtb: sensors, timing chain, ls2 and ls3 stuff
- stock ls1 oil pan
- motor mount bolts
- WTB: 01-02 LS1 28LB Stock Injectors
- Do you have broken 98-02 Firebird/TA front fenders?
- wtb 65# injectors asap
- WTB Procharger D1SC 8 rib pulley
- WTT-WTS like new meaga death cam for another cam
- WTB forged motor for boost
- WTB: Turbo LQ4 cam
- WTB: Ls6 Valley Cover
- 98-02 Trans Am Crank Pulley
- wtb rear shocks and le2 heads. IT'S MY BIRTHDAY HELP ME OUT!!
- 98-02 Trans Am Power Steering Pump & Pulley
- Need a set of low mileage DeCarbon shocks (front)
- Wtb - LS6 cam
- WTB: TA LS1 AC Compressor
- WTB 2000-2002 Camaro ECU
- WTB Mono blade TB and other parts
- WTB FAST LS1 Fuel Rail Kit w/fittings
- LT1 oil pan bolts
- WTB o2 sensor extensions
- Wtb exhaust
- WTB 18in chrome tsw, ruff, rpm rims
- Wtb ls1 t56
- raptor hood
- Parts
- WTB Lots of LS1 and F Body Parts!
- wtb stock tensioner air and egr, rear lca
- W T B: Stock 4th Gen F-body REAR calipers (pair)
- Wtb afr 225 heads
- WTB-GMPP single plane intake with efi
- WTB: Stock Camaro hood in the New England area
- WTB: 98-02 front right RS Y3F GFX
- WTB: Engine stand
- WTB: 12 Bolt
- looking for a Zexel-Torsen Paddle
- WTB ASA cam
- i need some stock front strut parts asap
- LS1 alternator bracket
- Wtb complete 4l60e set up
- WTB: T76 or larger
- WTB: Autometer Cobalt
- WTB MonSoon Deck 00-02 preferred!
- WTB a set of sunvisors and ash tray cover
- Cash in hand need black passenger door and Driver side A piller
- WTB: 98-02 Trans Am Front Bumper Cover
- Need the 10308-16 Crane Spring kit quick!
- WTB lowering springs cash in hand
- wtb: AFR, Trick Flow, All Pro, aftermarket heads!!
- WTB: 78mm nitrous plate
- HI fellow ls1techers I need a set of pedestal mounts.
- WTB: stock 10 bolt 3 channel rearend
- Firebird / TA passenger side head light assembly
- need driver side ttop for 96 trans am
- Looking for hp tuners pro
- WTB: 98 or 97 LS1 PCM - $125
- WTB: 98+ ls1 a/c compressor
- wtb: pair of mufflers for dual setup
- SLP HO Hood
- WTB TA firebird front fiberglass bumper support pic inside
- Wtb horn
- Wiper Blade Arms
- hot side pipes for turbo setup wanted.
- Wtb
- fuel cell, 9 inch, and racing seats
- Need rear end parts donated, 00 WS6 (OE 10-bolt)
- WTB 7.350" hardened pushrods
- WTB: Front, lower and upper a-arms......
- WTB: Tranny cooler w/ elec. fan...ne brand
- WTB wheels with tires
- wtb; stock ls1 t56 shifter
- ls1 t56 bellhousing
- WTB: Backing plates
- 455 short block
- ls1 headlight switch
- wtb ls1 block
- Vette Wagon wheels
- wtb bilstein shocks
- WTB: LS2 or LS3 block
- WTB: 99 Camaro fuel pump assembly
- looking for a 3200-3400 stall
- WTB ls1 fbody t56 shift selector block and cup
- WTB Stall Converter 3000 + For LT1 !!!
- WTB MSD 8876 Wiring harness
- WTB Engine harness and ECM for LS3
- Need a Stock LS1 Crank- No Spun Bearings
- WTB: Stock RearEnd in Kansas
- trade my stalled for your six speed.
- ISO Fast Intake manifold
- Wtb Headlight motor and window motor.
- WTB: Windage tray nuts and pickup-tube bolt
- LT1 Cooling Fans/Radiator
- WTB tires that fit 18x10.5 rims
- WTB: LT1 A/C Parts...
- Wtb msd 6010
- WTB ashtray door
- WTB Air Lid and Base, Dash Pad, Fuse Door
- WTB fast 90 intake for use with 4 bolt tb
- wtb slicks
- WTB: LS1/4L60E Aluminum Driveshaft & Yoke
- lookig for nasty performance gas tank with sender
- WTB Clam shell bracket for the F-Body torqu arm
- wtb: 2800-3400 lock up stall converter
- WTB Trans Cooler new in box only
- WTB: LS1 Oil Pan
- WTB: LS6 Intake and Black TTM's
- wtb 700r4 setup for f-body
- <<WTB>> DBW pedal assembly with connector and pigtail
- Wtb: 5.3l
- WTB: Complete LS1 Intake
- wtb: d1sc headunit
- WTB. 92mm drive by cable TB
- Wtb tsp 228r
- pewter body parts
- WTB lq4 or lq9 short block or long block
- WTB TSP True Duals: Who's got some?
- WTB C5 Brake Conversion
- WTB D585 truck coils, brackets and harness
- Flex a lite fans
- WTB-Panchard Bar & SFC's
- Eboost2
- need 4l60e planetaries ASAP
- WTB: silverado cats
- WTB 99-02 Ls1/T56 Engine Harness
- Need a standalone fuel system for my nitrous
- looking for ls1 f-body passenger steering knuckle
- wtb: engine stand, forged pistons, harness, books
- 99-02 M6 LS1 engine harness
- wtb lt1 longtube headers
- WTB: Single or dual PUSHER fans
- WTB: forged pistons and rods
- WTB LS6 intake manifold
- WTB..Stall for LT1 4l60e.
- WTB: LS1 Starter, alternator, Coil Packs
- WTB SLP SS Grille
- WTB PCM tray
- WTB:Aeroforce scan gauge
- wtb injectors
- WTB 2002 TAC module and pedal
- Aftermarket K-member, A-arms
- WTB: Bullet muffler
- WTB truck manifold turbo hot-side piping
- WTB: Racetronix fuel pump and hotwire kit
- WTB 16" Rims
- Driver's side mirror bracket
- need air box for procharger 99 trans am
- WTB Rear Lowering springs and front coil-overs and springs Qa1 preferred
- WTB maf need asap
- 4L60E tail shaft housing
- WTB MSD coils
- WTB: 02 WS6 Driver Tail Light, seatbelt guide
- Rear Springs Only
- WTB: Front caliper bracket
- WTB LT1 Nitrous Plate
- wtb ls3/l76 intake
- headlight cover, a/c vent, hood grill inserts
- pistons 4.080
- WTB: 15x10 5x4.75" 7.5 BS PROSTARS
- wtb ls6 shortblock or bare block
- WTB: 4l60E output shaft
- WTB Stall Converter 3200 - 3600
- WTB LS1 T56 (cash ready to go)
- Need a MAF Sensor
- WTB cc305
- rear sway bar for my 9"
- Wanted: Stock exhaust
- WTB 90mm Power Ring
- WTB: Used Pro 5.0/MGW
- Ls1t56 tranny rubber mount
- WTB - 8 rib Procharger Head unit pulley - 4.00"
- Wanted: F-body Front Shock Mounts/Control Arms
- Front Harness for headlights fuse block etc.
- Wanted: LS2 Coils
- WTB WILSON INTAKE For LS1 cathedral port
- WTB L92 heads...bare or complete
- WTB ZEX wet nitrous kit
- NEED LS6 Heads
- WTB: Books
- I need a set of stock rear coil springs to fit 95 Trans Am
- Need 2 working key fobs for a 94
- WTB Random Parts
- WTB factory exhaust flange w/ flex
- Want to buy a short throw shifter AND/OR shifter knob!
- WTB: Flowmaster Y-merge
- Looking for a 4L60E
