View Full Version : Parts Wanted
- WTB: Moser 12 Bolt Axle Shaft
- wanted: forged shortblock for boost
- need a 02 z06 cam
- WTB: covette fuel rail covers
- Nitrous feed line
- WTB 99+ knock sensors (2)
- WTB: Chrome Zr1 wheels
- Need 3" electric cutout asap!!!!
- Looking for Fast intake
- Ls1 backing plates
- W/B: Old style BMR rear lowering springs only! New or Used
- WTB Complete A/C unit
- WTB: LS1 motor mounts from Fbody
- Need lines for LS1 Fbody power steering pump
- WTB: 4.10 gears for 10 bolt
- WTB: 98-02 Trans Am front bumper cover
- Wtb set of 60# injectors
- ls1 intake breather wanted
- WTB: LS1 T56 Input Shaft and Front Plate
- WTB injectors and fuel pump
- th350 crossmember and 96# injectors
- WTB DMS Springs
- LOOKING FOR STOCK OR WORKED 243's
- WTB: 3:42 Posi Disk brake rear/ 91 Z28
- WTB electric cutout with switch
- wtb smoked corners and rear reflectors
- suspension/chassis upgrade
- WTB 17" 4th gen wheels and stock rear springs
- WTB CCW CLASSICS to fit 98 Camaro Z28 with moser 9
- WTB PS Headlight Motor/PS rear tail light
- WTB: Stock LS2/LS7 clutch and flywheel combo
- WTB/WTT: TH400 Cross Member
- WTB: Rear O2 sensors
- WTB 93-99 Dash Vent Housing
- wtb: mint pewter front bumper, berger panel
- need tight steering column for 95 t/a
- WTB Corvette alt/PS bracket
- Black halos
- WTB Turbo/Super Kit, Built Auto, For 02 SS
- ZR-1 Rims Wanted
- Wtb, t/a rear spoiler/ram air hood.. In nbm
- Wtb:th350 rmvb
- WTB Stock 317 heads
- WTB/WTT: Hurst Short Shifter
- WTB: E40 ECM and all 3 ECM connectors
- WANTED: LT1 Clutch Fluid Cap
- Wanted: Ls6 valley pan!
- LF Wilwood Brake Upgrade from Sponsor
- looking for ls1 parts
- someone sell me a good turbo cam
- wtb '98+ TA front bumper cover in Ohio
- wtb wolfe 6 point bolt in roll cage for 98 trans am
- wtb-fuel rail's and injectors ls1
- WTB: Parts for D1SC Setup
- 4th Gen Camaro Passenger Front Seat
- Harlan sharp 1.7 rockers,non adjustable.
- wtt my storker kit for yours
- Procharger cooiling fan
- Snow Tires / Wheels near chicago for 98 Camaro
- WTT: My t-56 for your th400
- victor intake, 750 carb, msd box, cam
- coil harness
- WTB: 2000-2002 TA Ebony Leather Seats
- WTB: FM10's/FM5's
- Lq4/lq9
- Th400
- WTB: T56 for LS1 in Texas
- 10-15lb Nitrous bottle wanted. Beat up scratched whatever I will buy it!
- WTB LS T56 Slip Yoke
- WTB : G5x2 camshaft
- need a 98-02 ss wing
- WTB rear shocks for 2002 WS6
- WTB: OEM driverside tail light 98-02 firebird
- WTB Drivers Side T-Top with key
- wtb electric cutouts
- WTB used Drag Radials for 17's or if someone is selling a pair of 16's with DR's.
- WTB damaged LS6 intake & F-body oil pan
- WTB 3 channel Rear end with 3.23-3.42 gears (98-02)
- WTB Tan rear seats, seat belts and door panels
- WTB 2002 F-body ECM/PCM Computer
- Factory Hurst Shifter
- AEM wideband and WS6 lower air box
- WTB: AC Lines & Sensor, PCV Hose, DBW Harness.
- need a stock 2001 exhaust with cats
- Wiper linkage needed!
- WTB Electric Vacuum pump for power brakes.
- WTB D1 or F1 Procharger kit
- WTB Meziere WP319 water pump
- WTB: Altenator for LS1
- WTB T/A 4 Side Markers, Third Brake Light, Center Filler Panel, A4 Console
- WTB ls1 p1sc head unit
- I need 1 lifter
- WTT: C5 z06 Motorsports for draglites
- WTB: 98pcm harness for f-body
- wtb.. tubular k member and shocks
- wanted 4.2L trailblazer or envoy torque converter
- LS1 Fuel rail (With Return)
- WTB: 93-96 Camaro Window Switch Bezels
- WTB Passengers side T-Tops
- WTB: Drivers Side Caliper and Bracket
- WTB: Stock T56 shifter
- WTB - SLP dual dual catback exhaust
- WTB: Charcoal sun visors / Whistler mod headlights
- wtb some Ls1 parts
- ls1 fbody acessory bracket
- lt1 engine accesory bracket
- WTB: Full Ls1/Ls2 pullout w/t56
- Trailblazer Oil Pan and Front Differential
- wtb: Rear Brake line 99-02 camaro
- Wtb tires!!!!
- If u need ls1 parts please look
- WTB T56 parts
- Wtb: 315-35-17
- Wtb: 315-35-17
- WTB ls1 motor mounts
- wtb: gto oil pan setup
- WTB: 3.73 gears/ ud pulley
- stock 5.3 rod and piston
- Wanted: 2 Drag Radial Tires
- shifter needed
- WTB: Short block.
- elbow and tb
- WTB GTO shift knob
- WTB - Chrome 10 spokes
- 3rd Brake light 02 SS
- 01 up LS1, manual trans, computer, etc
- WTB: Firebird center caps
- Wtb fuel pressure gauge
- WTB 9" Moser/ 12 bolt Parts or whole
- WTB - 02 Sensors & Extensions and Firebird Clear Corners
- 98-02 Dash Pad
- wtb PRO STARS
- WTB: 99+ PCM, Fbody Pan, WS6 hood, etc..
- I need a power steering pump, air dam, and throttle body
- WTB: Stock shifter linakge bracket
- wtb rims
- WTB Gauges (WB,Boost,Fuel PSI)
- Wtb SBC.......Roller Cam
- Wtb upper dash pad/filler plastic
- LS1 POLY Motor Mount
- Wtb 2 front 98 trans am leather charcoal grey seats or corbeau racing seats
- WTB: White T-56 shifter Ball
- oil dipstick
- wtb: lt1 longtubes, big cam, heads, bearings, stall for 700r4
- WTB Trans Am Seat Belt loop
- stock elbow for lt1
- need misc 95 Firebird interior/stereo parts
- looking for cam kit
- WTB: 3.70 or 3.73 gears for a ford 9"
- PS fender/ Seats
- wtb any year ls1 or truck harness, cable throttle pref, and PCM
- WTB: 26" slicks, cam, heads, 15x8-15x10 wheels
- Rims
- NEEDED ASAP!!! ls6 243 heads unmilled
- Need a carcover
- Caliper mounts and backing plates - LS1
- Wtb:15x10 weld drag lites 7.5 bs only
- WTT NX wet kit for rear drag wheels/tires
- WTB: LS1 Tails
- 275/40/17
- LS6 Heads 243/799 castings
- 3.42 gears
- WTB passenger side fender vents for firebird/ TA
- Need a T- Top asap
- Bolts for backseat
- LS1 Poly Motor Mount
- Need an ECT connector.
- Y-pipe and catback wanted
- wtb LS7 lifters (high Rev)
- Rear end
- WTB Lower WS6 Air box....
- WTB: Manley Valves
- WTB GM 4L60e dipstick + tube
- Wanted -LS1- V-Plus Volt Booster
- WTB LS7-style "SHORTY" injectors #46-#65 High Impedence
- WTB LS1 ABS Block
- Converter
- WTB - Tri-State Area Camaro SS 10 Spokes
- HELP! F-Body Windage Tray needed near Charlotte NC
- 93-96 Camaro 6spd console trim plate!
- Wanted: Triple Gauge Pod & Raptor Shift Light
- 98 LS1 CTS sensor and connector
- Early C5 Exhaust Manifolds Heat shields
- LS1 Motor Mounts
- LS7 Flywheel???
- WTB 2 '02 WS6 Wheels
- LS1 K-member
- LT1 Radiator Cover
- Wanted plz, will pay anything for it
- F Body LS1 Oil Pan, 1 Ls1 coil. WTB ASAP!!!
- WTB: harlan 2 step/ 99-02 engine harness for a4
- WTB 99 LS1 pistons
- LT1 LT y-pipe
- 98-02 Parts
- Wanted 335/30/18's for the street.
- WTB brake pads and seat belts
- WTB-Stock LS1 Rocker Arm
- LS1 Car Emergency Brake Setup, all factory cables, handle, and bracket
- Looking for elbow+CAI
- WTB-Random engine/trans parts Ls1 fbod
- som license plate cover
- 99-02 fbody valve covers & coils and brackets
- Third Brake Light
- 4.00 bore 4.00 stroke 10-15cc dished pistons
- WT LM1 powerflo for gmmg catback
- Need 3ft 4an nitrous line in line gauge adaptor
- WTB torque arm mount
- WTB Bump Stop
- F-body or Corvette Accessory Brackets
- wtb mufflex 4 inch exhaust
- WTB couple part
- T=Tops...looking
- WTB or WTT VFN hood or cowl hood for 2000 TA
- Looking for black berger panel
- WTB camaro stealth sub box
- Clutch Fluid Cap
- stock headlights
- WTB LTx heads or intake
- WTB-Ported Throttle Body and Lid
- WTT Z06 18/17 C5 Wheels for TTII or ZR1
- WTB Hurst H knob
- Center Console Cover
- 6.0 parts needed.
- WTB: Black Z06 Wheels/tires
- 6.0 parts needed.
- Wtt!
- need ASAP: oil pick up tube screws/bolts
- WTB: 98-02 Firebird/Formula Hatch in Tampa, FL area
- Need one good LS1 connecting rod!!
- WTB: 18x9.5 Black C6 Motorsports
- WTB:heads,intake,valave covers
- WTB: 3" E-Cutout
- WTB Aluminum Block 4" or Larger Bore
- 01' Trans Am borla cat back exhaust wanted
- WTT: Tail light covers
- Internal rubber shift insulator wanted 4th gen fbody
- wanted: truck plug wires
- WTB 2 utla lite 17x9 1/2 -10 wheels
- WTB -15CC DISHED 3.903 BORE pistons
- Wtb: Bmr phb
- WTB Chrome 16x8 5 star wheels
- gauges and car cover
- WTB 5.7 or 6.0 block
- LS1 brake abutment brackets
- WTB- Black Visors
- Want to buy SLP LM 1 or 2, Borla or other Catback
- bmr lca's
- WTB-93/97 Firebird ws6 hood
- Differental posi for 6spd
