View Full Version : Parts Wanted
- Searching for fbody accessories
- WTB oil pan 1998 LS1
- 240sx ls1 swap kit
- Wtb car 4l60e tail housing
- ISO Holley Hi-Ram---Used
- Wtb: Pie gm9-aux
- WTB LS1/LS6 Pistons/Rods
- Wanted: FAST 92 intake and 92 throttle body
- WTB : LS6 Intake Manifold
- wtb battery relocation kit and box for 02 firebird
- Wtb mgw for 02 Trans Am
- WTB ls1 accessory drive
- WTB HSW micro edge
- LSX EGR block off plate
- In Search Of A Torque Arm Mount for 98-02 4L60E w/ hardware
- WTB ls1 engine harness
- WTB 99-02 EBCM with trac
- WTB clean pair of 317 heads and LS6 or LS9 cam
- Need a 90mm or larger dbc throttle body 4 bolt
- Need a stock 97-00 ls1, ls6 or lq9 cam
- WTB C5/C6 power steering pump/reservior
- lookin for cam
- ws6 front end
- L92/L99/LS3 pistons
- WTB: LS1 T56 F-body Bellhousing
- Wtb c5 power steering reservoir and brackets
- WTB FAST 90 or 102
- Nice, clean LS1 Power steering pump
- Wanted: FAST 92 intake, FAST OR NW 92 throttle body
- WTB auto tranny Dip stick tube 98-02 trans am
- WTB plastic ls1 fuel tank located IL.
- Wtb: Cam
- WTB: Good black upper backseat for 2004 GTO
- WTB: Valley Cover Plate for LS2
- WTB: Trick Flow heads
- 243 ls6 heads
- Vette C5 crank pulleys
- WTB LS6 Pistons
- WTB LT1 to LS1 t56 conversion parts
- WTB: 93-02 TA stock parts
- wtb returnless truck fuel rail
- WTB supercharger or turbo kit
- WTB T56 Skip Shift Solenoid
- wtb 98-02 front bumper support
- Crank pin kit
- wtb 58to24 lingenfelter module
- ls1 throttle cable bracket
- Th350
- Z06 or a turbo cam
- WTB: Body wiring harness, passenger side section
- WTB LS2 manifold
- Wtb: 98-20 Fbody 4l60e
- LT1 Crankshaft
- wtb fast 102mm intake
- WTB : Intake Manifold (LS6/FAST etc)
- WTb aeromotive 13110 fpr and holley ls3 fuel rail kit
- WTB- Suspension (BMR, UMI, SPOHN)
- S484
- Need trans cooler lines
- Wtb: ls1 camaro front accessory kit
- Shaved/smoothed ls valve covers/GMPP LSX covers
- WTB: exhaust hanger bolts
- WTB Callies 4" Dragon Slayer Crank
- WTB 3.42 gear and posi
- WTB TH400 93-97 crossmember
- WTB Racelogic Traction Control Unit
- WTB: LS1 accessories minus AC stuff
- Rag joint eliminator wanted
- Ls1 4 corner steam vent / coolant crossover
- Wtb:truck alt. Bracket
- WTB Complette Nitrous kit
- WTB 98-02 4 channel backing plates
- Wtb springs, fuel pump and nitrous accessories
- WTB: Thirdgen LS1 SWAP MOTOR MOUNTS
- Exhaust tips wanted Z/28
- WTB/WTT holley 558-105 for ls1 style harness
- Wtb 2 17x11 tt2s. Or another set of rims. With 17x11 or 18x12 rears
- wtb the following items
- WTB single bolt cam sprocket (condition doesnt matter)
- Morel 5315 lifters
- WTB LT1 D1SC Procharger
- WTB stock cam (damage is fine)
- wtb truck manifolds w/vband
- SLP or SS car cover 4th gen....
- 98-02 ac knobs and high rise 3rd brake light
- WTB: MALLORY 685 ignition box
- WTB: Holley EFI Dominator ECU with or without harness
- Looking for factory LQ9 Cam and LS1 / 6 Injectors
- WTB PAC 1518 Valve Spring-Single
- WTB: Kooks 3.5"X4" Y-Pipe
- Rear drag bar
- Wtb jgs 40mm wastegates x2 or precision 46mm wastegate x2
- WTB nitrous outlet plate
- WTB Tick Master, Viking Coilovers, FR "Big Switch"
- Ls6 243 heads stock
- 35th Anniversary car cover
- Stock 2001-2002 fbody cats and O2 sensors
- Gto passenger exhaust manifold
- Wanted FAST 102
- 823 LS Heads Complete
- Ls1 underdive pulley
- Help axle needed
- WTB: 6.0/6.2 pistons and rods
- Trans am third brake light
- ls1 intake bolts and steam tube
- Need a stock LS based camshaft.
- wtb. 6.0 bare block
- WTB RK sport ground effects/body kit 4gen
- WTB Used Drag Radials/Wheels
- Dragon slayer stock stroke crank
- Wtb tfs 255 or Frankenstein ported ls3 heads stage 2
- Need parts trade drone
- Wanted stock 02-04 ls6 cam
- WTB: Damaged 6L Transmission
- Wanted: 05-06 GTO hood
- Wanted: SLP Smooth Bellow...
- Wanted: Front license plate cover for Trans Am
- WTB: trans am gauge bezel
- WTB: 243 single head
- WTB: S475 Turbo
- Wtb g5x3
- WTB: used drag tire 26x11.5 or 28x11.5 for 16" rim drag radial et street
- WTB: LS2 Throttle Body and DBW Gas Pedal
- Wanted 243/799 Heads
- wanted : 15x10 5" b.s wheels
- wtb holley hp ecu 554-113
- WTB: Moser/ Strange S60
- WTB SS Hood Grille
- WTB: Trickflow 245s 6 Bolt
- Wtb 285/30/18 tires
- WTB 4L60 Yank 3600 Converter
- Looking for Rear 15x10 Weld RTS71 Black Wheels
- DRL Module (Daytime Running Lights)
- WTB hp tuners pro
- WTB LSA/ZL1 pistons
- ctsv 2 leather shift knob wanted
- Misc 4th gen parts needed
- WTB c6 stock shifter and knob
- Web joe van ws6 hood
- iso lsa heads
- WTB: Pewter Front Bumper 2000 Camaro
- WTB LM7 power steering bracket bolts
- wanted 58x 24x conversion box
- wtb lpw girdle
- WTB: fbody tensioner and starter
- Pro Charger D1SC
- WTB 98-02 four channel axle shaft
- WTB 04 LS1 GTO and 05-06 LS2 GTO FUEL RAIL COVERS
- WTB LS3 Rocker Arms
- Wtb ws6 hood front bumper
- WTB: drag pack
- 98-02 Fbody Power steering
- WTB: Chris 1313 ac version
- T56. For 5.3
- WTB:Calibrated Success DVDs- Beginners or Advanced
- $$$ WTB 243 heads!!! $$$
- WTB tan floormats
- WTB Valve Cover Bolts, AC Comp Bolts
- WTB 98-02 Full Passenger Headlight
- Yank 3600ss 4l60e
- Looking for tunnel mount torque arm
- WTB LSx engine or Block
- WTB crank pulley install tool, can be homemade
- Iso some kooks exhaust
- 98-02 F-Body Exhaust hangers + misc bolts
- WTB rear bumper cover for pewter camaro
- WTB: 1998 F Body Fuel Sending Unit
- WTB: Callies Compstar 6.125 rods (new)
- wtb a d1sc head unit
- WTB: one 243 head, and TSP 228R camshaft
- WANTED: FAST LS1 intake manifold, tb, injectors and fuel rails
- ISO Carb intake/MSD 6LS
- Automatic ebony shift plate
- LSA Supercharger
- WTB Shifter Lever/handle for tremec
- Wtb: 3rd gen camaro parts
- WTB some more LS parts
- ISO F1 Procharger
- WTB Pistons and rods
- Wtb- t56 reverse lockout solenoid or parts for it
- WTB ls6 throttle bracket
- WTB: Holley 302-1
- wtb ls1 fbody/gto alternator bracket
- ls1 backing plate
- Wtb c5 z06 chrome replicas
- WTB gen III sensors and parts.
- looking to make trade for a stock LS2
- WTB: ls1 t56 bellhousing
- WTB LS7 block
- WTB LS2 rotating assembly
- WTB Coil covers
- WTB: TR230/224 Camshaft
- Coils
- WTB Fbody Hotside/Crossover
- exhaust wanted
- WTB some super nice ebony seats for 1998 firebird
- WTB-LS1 complete rear brake setup
- Chrome moly ft suspension 4th gen
- Wtb: Mgw shifter c6 zo6 corvette
- Torque converter
- WTB LS 3 bolt Cam - 224/224 112LSA or similar
- Ls1 throttle cable bracket
- WTB LS1 T56 & Maybe LS1 Rebuild Kit
- Wtb 02-04 z06 cam
- Wtb: 2 pc rms t56 conversion flywheel
- Looking for rear hatch interior panels 00-02 ebony
- TURBO CAM ls1
- WTB stock fbody oil pan, accessory brackets
- ISO: 243 or 799 heads
- looking for super vic or vic jr
- gen IV rotating assemblie
- WTB: stock ls1 coolant steam lines
- Lingenfelter LNC 2000
- WTB 18x9.5 +40mm Wheels (Spyder or c6 z06)
- Wtb
- WTB ls2 crank 24x
- WTB: GTO Spare Wheel & Tire So-Cal
- Wanted: FAST intake and tb combo
- WTB 243 Casting heads
- WTB: Hurst Billet/Plus Shifter or SIMILAR Shifter
- WTB: 92mm TB for '02 LS1 WS6
- WTB: 1 3/4 Headers for '02 LS1 WS6
- WTB: Trans Am Lumbar Seat Harness
- Ls1/6 rear plug for brake booster/map
- WTB: LS1 style T56 front plate and input shaft with bearings
- 102 tb cable driven and 100 mm maf
- want to buy catback
- WTB 4 channel rear abs sensor
- LS1 intake and injectors
- WTB: Stock exhaust 02 Z28
- WTB LS6 exhaust valves.
- WTB: Ls1 flexplate
- Wtb 1 truck coil
- ISO 12 bolt 3 series 30 spline spool
- LT1 Tb lower IAC housing
- Air Conditioning Compressor Bracket, Corvette
- wtb: 98-02 sailpanel sub (good quality)
- Racing seat wanted!!
- Wtb lnc-2000
- Stock f-body LS1 maf
- WTB ls6 intake asap
- WTB 19" HP Design R5 Wheels
- WTB:Trick flow GenX LS3 255 heads
- dash assembly
- Wtb: Tbss intake
- WTB: 4L60E shift cable
- WTB LS1 and T56 drop out from F body
