View Full Version : Generation III Internal Engine
- T-REX Question
- ls2 chain vs double roller
- Flycutting help
- motor damage pics
- 5.3 piston???
- H/C Dilema!!! Which Combo???
- Will 6.0L heads bolt on LS1?
- picking a set of heads
- what balancer are most of u running??
- arp rods on stock rods
- Look whats going in my x-mass stocking
- Piston & rod trouble
- Reinstalling rockers?
- what Cam is this?
- Another cam thread
- Are The 98 Ls1 Camaro Heads Worth Me Porting And How Big Of Cam Can I Put On It.
- what pushrods?
- what about a voodoo cam?
- 2 Step Rev Limiter Help
- Which of these would make more power?
- Which head gasket is safe for my heads/cam??
- Important rods question
- What size injectors... E85
- H/C is this Normal? Trouble staying started!
- Coolant system an "auto-bleeder"?
- Torque 2 Yield bolts / fasteners
- help ground off casting #
- Need help with springs?
- Need more power...TFS setup...
- Need rev limiter setting help
- Cams in California
- CP Vs Octane
- Are the cam bolts torque to yield?
- Oil On #2 Spark Plug
- WHERE CAN I GET Specifications OF LS1-LS6-LS2-LS3 ECT
- Head & Cam Swap Parts List for Comment
- CAM recommendations for stock heads, stock injectors? 360 RWHP+
- Anyone install the LS3 motor in a LS1 bay
- LQ4 build questions
- Cam trouble!
- cam swap
- cheapest way to cut piston's check it out!!!
- Mild Cam for '04 GTO LS1 w/Z06 heads
- Best cam with stock headers and Magnaflow
- where to get the best cam head package for the ls1
- *Need Help Fast!! Cam Swap In Progress!*
- 241's worth porting?
- LS1 Stroked???
- Explain This For Me
- What do you think of my results for this set up 5.7 ls1 stock bottom end?
- Eagle Crank Oil Gallery Plug Leak???
- 59cc or 64cc?
- CAM Swap
- Power Band for G5x2?
- stock cam dcr?
- weird oil pressure problem
- MTI x1/2e
- High mileage LS1s
- 06-07 LS7 cam in a LS1
- Those of you that have pulled an LSx out the top of an F-body.....
- patriot performance heads?
- Valve springs or lifters?!
- just realized my oil pressure ranges from 50-70?
- Some cam input please
- how does your heads exhaust flow affect power?
- TSP Ls6 2.5 Pics ARHeaders cats
- Good shop in cleveland
- Help remove a bad lifter
- what kind of power to expect?
- question about this cam
- Replacing timing chain (help)
- Do These Cam Lobes Look Ok? Gurus Come In
- cold start up tap
- are these the right head gakets pics inside
- Random miss fire need HELP
- Summit underdrive pully?
- Another Heads/Cam ?
- Free set of American racing headers. FREE FREE FREE for the holidays.
- Cam Install: JPR tool clone ?
- How much do heads affect smog??
- which cam and gasket for PP 243's ??
- Gasket Advice (Head and Cam install)
- 62cc AFR 225 finally available (and in stock)
- Just installed cam, throwing security code!!
- 5.3 heads
- Need valve cover spacers or not??
- Intake Runner size & low end torque?
- valvespring question
- TFS 215 or TEA stage 2 LS6?
- Crank Gear will not slide on????
- good cam?
- 799's or 243's?
- Opinions On The Following Cams
- HP diff between Corsa or true duals
- Ticking coming from Engine bay?
- Is this a good deal?
- PRC Head/Cam Combo advice needed (long)
- New Cam
- TSP 408 Long Block for Xmas...411 Needed
- Preparing for cam
- crank length
- Problems with Patriot heads???????
- tfs 215 heads and pushrods??
- High CR 5.3L Pistons
- Comp Cams Lifters
- file fitting rings
- wanting to build 383! what parts? where from?
- Few Question about this Cam
- can some one tell me why this firebird wont start**vid inside**
- So finalllllyyy Im doing my head/cam swap
- Getting the lift back
- Who wants to build me a 499 shortblock?
- Which Package to produce most power
- Need help on torque specs!!
- Ms4 GUYs come in!
- Which one of these cams will better suit my combo??
- Rebuilding an LS1 (DIY). What do I need to know?
- 59cc afr 205 valve drop
- Power Steering Fitting
- Patriot stage II/III brand new or used Lingenfelter heads?
- Just got cam installed, quick question.
- cam?
- My experience/opinion about my cam install
- MS4 install, mill heads and flycut or not?
- Several questions
- who has a set of ls1 truck coil packs
- ls1 heads casting# JO49
- Is this a pretty good cam Cam Guru's
- Bolt Torque Specs
- Piston Slap? How about a little help here.
- yella terra pushrod question
- GMHTP Patriot Install
- Whats the max octane i can use?
- Vaccum leaks! Where-to and how-to.
- crank and piston problem help!!
- Stage 2.5 5.3 L Heads With Ms3 Cam For Nitrous Set Up Are This Good Heads And Cam
- Just did camsprings/pushrods/shortys install, and now have blinking SES
- What LSA for the 228R cam
- Harland Sharp SLS17 Roller Rockers
- cam install near Lafayette , Louisiana
- ls6 heads??
- cam bearings
- Best LSX shop on the west coast?
- synthetic vs conventional oil
- Katech Timing Chain - Adjustable Sprocket
- Help Picking Best Heads And Cam Set Up For Nitrous W Stock Internals Full Bolt Ons
- Makeing a stall and cam work great!!!!
- Rpm drops, no idea of the cause
- Patrick G custom cam arrived today!
- MS4 clearance issues...
- Heads only w/ stock cam
- Should I align hone the mains with ARP studs?
- Rev limit?
- Cam package noob questions
- patriot heads stage 3
- what to build?
- serpentine belt help plz
- TSP 231/237 sound clip with magnamouth carback
- Tune Needed?
- Help on a cam change
- Can I use the 918 springs?
- stronger internals?
- No spark after motor rebuild????
- If my Pistons & rds are all the same weight do I have to balance the crank?
- Looking to do cam, what to expect?
- Stock short ls6 shortblock, stock head gaskets, 66cc afr 205 heads, compression?
- A little PTV problem. Pulled motor with pics.
- Motor damage...pics!
- What else?
- H/C fly cutting question
- What heads with Trex?
- off idle rev hesitate?
- Cheap heads vs. AFR225
- opinion on doing heads cam on stock ls1 without lt's
- G5x3,243 heads,4.10 gears,
- Intake
- What your Advice for LS6 Cam
- Is this normal
- wanting 500 plus hp ls1
- AFR 205's too much for 231/237 cam?
- What heads/cam package for 408?
- SLP Underdrive pulley removal
- Few questions...(freshen up engine)
- RPMs go up when I push the clutch in on my H/C TA...
- If the valves have hit the pistons..
- Flycutting....should I be scared of it?
- CR vs Oct
- Thanks guys (Head and cam complete)
- Oil pump?
- LS1 pushrod size
- Stock radiator for TT's
- Oil Psi Question.
- Having some issues need help
- Rockers rubbing retainers
- Best heads to get for under 1k?
- is a cam motion regrind worth it?
- when dropping the motor from bottom should i take the harness down with it or just?
- TR6 Plug Gap on big cube motor??
- Anyone use Dart heads?
- need a scr check (seems high)
- Rocker arm options??
- Problem hainging rods
- Let me be the 100th person to ask this. What Cam??
- what cams?
- Valvefloat Questions..... CamSwap ?'s
- 2004 GTO Bellhousing/Starter different than others.
- Torquer 3 Cam Install Question
- change out stock lifters??
- At what point to add Rod Bolts
- Safe redine for stock internals, but upgraded rockers and lifters?
- How often should you change spark plugs?
- MS4 cam owners; how much power are you making, and what other mods do you have?
- Quick cam help so I can order for X-mas!!!
- ported vs. non ported power gain #'s
- rounded rocker bolt, need help ASAP!!!
- car wont start
- Are these plugs fouled?
- Head, Cam and PCM swap, idle problem (3,000RPM)
- What is a normal oil consumption for LS1?
- Were the heads different for the 98 LS1's than say the 02 LS1's?
- TSP Toquer V.3 ?'s
- "Smaller" TR Reverse Split; Good or No?
- Daily Driver Cam
- Should i do it myself or leave it to the Pros??
- Head choices????
- I think my head gaskets are shot
- Honing cylinders
- Need advice for valve train upgrade on stock cam
- ls2 in an f-body?
- NMotion timing advance...where should I have it?
- Swapped INjectors... No start?
- is this normal pics inside
- Can someone identify this cam?
- Heads...
- Piston slap? bent pushrods? Help Please...
- hemo me pick the right pushrod. 7.260 at ZERO preload. LS7 lifters.
- patriot 243's and t rex?????
- Need help: 408 top end
- Comp Cam in from Rapid!
- Tsp?
- anyone have real proof that 98 heads flow so much worse than 99 up heads....??
- Looking to Increase Compression ????
- one turn on stock rockers ='s how much preload?
- shiming up the rockers, why?????????
- What cam for a 383 road racing (HPDE) setup?
- oil in the exhaust port
- i need advice on a package.
- spiked to lean on one side at idle ??
- 402 on a budget Is my DCR to high?
- need tuning
