View Full Version : Generation III Internal Engine
- Anyone run Jardine exhaust?
- head stud question
- HOTT...My Ws6 reached the red area today
- Forged 347: Forged 6.098 vs 6.125 Rods : Discuss
- Can I hone a 346 out to a 347 or do i have to have it bored out?
- Ls6 Remanufactured Engine From Gm
- Cam for 02 Yukon
- Lunati/Morel lifters
- Mti Stealth cam?
- Need head and cam help
- anyone who has changed the altanator on there LS1
- H/C guys with F13/similar, step in....
- Should I worry about cleaning the carbon off my pistons?
- Poll: Which .040 Head Gasket to use?
- piston and block ????
- oil level in pan ? (picture) above or below level sender hole
- Stock Rod HP????
- L92 small bore heads
- what is the stock length of ls1 rods?
- Any ideas? Plewase?
- New Carbon Fiber Valve Covers @ SDPC!!
- 140000 on stock Ls1...rebuild?
- wierd squeeking noise from driver side head??
- Comp 918's
- Car running hot after cam
- heads options for my cam without flycutting?
- Will advancing my MS3 4 degrees decrease PTV clearance??
- 224- 112lsa with A4
- What cam to run?
- Aluminum or Tri-metal rod bearings?
- LS1 GT-2 Heads?
- Crank bolt torque specs
- Lifter help ASAP PLEASE
- Found this in my oil
- head cam combo?
- comp xe-r 281
- head install ?
- Cam help..
- A Little Partical in my Oil Should I be concerned?
- Texas speed Head/cam combo
- Having problems cleaning the cyl. bolt holes
- Heads leaking after installing .040 gaskets poll.
- Head bolts. Proper way to torque.
- Lifetime billet high flow oil filter for LS1/LS6/LS2 !!!
- TFS 215 head gaskets?
- Have to rebuild, best options?
- Is AFR or others going to make a 6bolt LS1 cathedral cylinder head?
- Bent push rod
- Get my car back today
- Engine Bearings
- What does everyone thing of this cam.
- Anyone have patriot stage 2 heads and F13 cam?
- opinions please
- worried about my engine
- what do you think re this cam?
- this is wierd
- Camed cars on stock alternators
- H/C options
- minimal needed amount of oil in oilpan ?
- Proper way to use a pushrod length checker?
- 224 228 113lsa
- Measuring pushrods?
- H/C and other stuff install in progress
- is Slps flow pac worth it the lid with cold air intake?b
- 402 help
- Head Questions??!!
- Fired the new engine up, ran it for 15 min, changed oil... now what?
- Texas speed magic stick 4
- what cam for 1/8
- How much power
- Stock crank/rods safe for a 200 shot?
- Help Explain My Dyno Numbers
- How do I remove my crank sprocket?
- rebuild LS1 vs switch to LS2
- Engine swap Question
- New engine - spun it over with the starter, no oil pressure
- trick flow bare castings
- wondering on turbo Heads/Cam/Pistons
- piston slap or spun bearing?help!
- How much , if any, should I advance this cam?
- Checking and cleaning oil pump.
- aftermarket rocker arms
- timing cover leak
- Cold Start Up Noise
- valve clearance question
- Oil sandwhitch adaptor thread size?
- Spun bearing, need budget small block setup...
- Update on tapping/clanking when engine warms up.
- 5.3L block... what year?
- New here! Looking for info/setup suggestions...
- Between
- questions about heads
- shim thickness for porting oil pump
- what compression with .010 milled heads
- lifter tool
- PRC dual springs question
- Tomorrow's the big day! Starting my new engine for the first time
- Valve spring seat pressure
- Oil pressure...can it get better?
- cam degreeing
- car won't idle ms4 cam texas speed tune? HELP
- PR length before wrong decision is made!!!
- ticking noise, help!!!!
- Lifter plunger travel stock vs. GM HP lifters
- Crane lifter preload?
- Help with 6.0L budget build
- Quick question about LS6 heads.
- Is There A Solution To The ''Sewing Machine" Sound
- Engine Oil Cooler
- MS3 Owners?
- Valve Spring Replacement question
- Cam guys give me your opinion.
- Diaginos my spark plugs guys.
- Front/rear cover and oil pan - do you use alignment tools?
- Ideal Cam for my Z28?
- motor knocking????
- Would this be a good cam?
- hyd lifter and lift...
- throwin together the bottem end
- turbo cam
- Smoke and fire out of exhaust :-X
- Cali guys please help...
- Oil pressure?
- What to use to block off egr valve
- Valvespring swap what's required?
- rebuilding 346 stock
- Victor Jr EFI vs Fast 90mm intake?????
- Yet another cam selection?
- Cammed: Nitrous or Heads next?
- After MS3 now what Dynotune or Gears..help me decide
- Please Help w/Melling oil pump....
- Heads made for 4.125 bore on a 402 LS2?
- Dial Indicator head mount (pics)
- Stock 862 head castings
- LS6 springs + cam....worth it?
- Bottom End Rev...
- How many Cam only guys have trapped 120?
- what plugs?
- which cam is better for these heads?
- ASA and Nitrous
- Why all the Vindicator talk?
- How hard is it to rebuild your own lsx?
- What is the Oil Capacity in a 6.0 408?
- Front to Rear Steam Tube Connection???
- question about cam sound and idle
- PTV clearance question
- SDPC2000 forged block? PPL who stuck with stock cubes inside...
- How many have had Flycut their pistons?
- need a Hp est plz! come on in!!!
- 2000 Trans Am problems.
- is there a way to find out the specs of a cam without a cam card??
- Strange stalling issue...please help
- What to seal rocker bolt threads with?
- Do you need to degree the cam and shim the springs on a small cam?
- I need advice on 382 Stroker & parts selection. Please Advise
- Considering 382 Stroker - Solid Roller? FAST Intake? Spray? - Need Guidance
- l92 heads on an ls1?
- stock LQ9 pistons
- cam specs
- head gasket install?
- Cam swap shopping list! am i missing anything?
- lq4 6.0 install
- Heads/Cam/Header install now guages not working
- Vindicator and nitrous?
- weight?
- Starter locks up when hot.
- Quick Pushrod Question
- Valve job questions? Is this true?
- Updating 98 Knock Sensors?
- UPDATE: original LS4 oil pump after putting it on track finally, awesome results.
- MS3 question?
- new cam for my tsp 2.5 5.3l heads
- How much can it handle
- Best cam to fit my application???
- Head question???
- Is anyone running the PRC 200cc Terminator Series Cylinder Heads???
- Vette motor for Camaro
- questions on vette motor swap
- MS4 w/ 5.3 STG 2.5 Heads???
- 6.0L pistons
- Milling Dart heads with a F14 cam and -2 cc pistons.
- Need help with H/C setup!!!
- tr 224 112lsa
- **Ultra small metallic color stuff in my oil**
- Crane Cams 1.7 Gold Rockers question...
- lunati and sdpc valve springs
- bout to order valves, but which ones?
- Exhaust to Intake flow ratios??????
- Anyone with a TTP Cam only car?
- Louder valvetrain after Duals installed from 918's?
- where to find #'s on ls 1 heads
- Stripped headbolt, help
- ls6 swap...
- Heads and cam dilemna
- what method/tool do people use to keep valves up when swapping springs?
- Any carb 6.0L guys out there?
- Problem w/ ARP head stud
- Post up your popular H/C combo numbers with cam! Lets see what gets good gas milage
- Instructions for checking Piston Valve Clearance with heads on????
- M6 guys with cams...where do you set your idle at?
- has anyone ever port matched or ported an LS6 intake?
- Is 2000 Stock oil pump good enough?
- Car Acting Strange
- WTF Got P0343 code on friends ZO6 (2003), cam sprocket bolts loose & NO dowel-pin???
- 400HP Daily Driver on Stock Heads?
- Cam is in, quick question
- ac cond bolt
- Help find the missing RWHP : 408ci, M6, 9"
- cam question
- Dropping oil pan #$@#$
- cheatr package 1/4 mile time????
- LS1 or LS6 Heads?
- Rear oil pan bolt length?
- change oil light??
- Help! Stock rocker bolts won't fit my HS modified rockers!
- LS6 Intake and HVAC
- how in the F(!@#*(&!@ do you get the damn oil pickup tube bolt back in.
- ls6 questions
- what can I do to get more out of my H/C combo??
- LS1 and LQ9 crank pulleys the same?
- 918 shim under or on top of valve seat?
- 243 Sodium Filled Valve ID (5 pics included)
- stock rods
- DO i need to change the gear of cam???
- Life of a valve spring
- How safe is it too...
- afr spring question
- head selection for MS4?
- 6.0 build
- Car falls on it's face (HELP PLEASE)
- Nitrous Bearing Clearances
- Can I Reuse My 6L MLS Gaskets???
- Bearings..
- Finally got the cash, Cam time
- Intermitent lifter noise question
- AFR 205 heads
- seafoam question
- what pulley do i need?? my asp wont fit.
- Better than pr0n. PICS INSIDE!
- tr244 question
- question about patriot performance
- need alot of help thanks
- Ported TB new MAF?
- What is the expected RWHP??
- shaft mount rockers
- Timing Chain question
- making a higher rpm motor
- Necessary Machine Work?
- Specs on TSP 233/239 cam???
