View Full Version : Generation III Internal Engine
- Help me pick a cam.
- need help about a cam code
- ETP stepping up!!
- T-rex and other manufacturers?
- What do you think of this combo for a dd
- Smog Legal Camshaft
- Dex-cool bad?
- 03 vette oil pump??
- valves
- ARP part # for head studs for a LS6 block?
- What is acceptable oil pressure?
- HELP: Modifying timing cover
- Steering rack removal??
- holy shit... dodged a BIG bullet...
- Max Duration/Lift?: 243's and Cometic .040
- oil pressure
- What pushrod length with .040 cometic gaskets for a H/C swap?
- Need to decide between Patriot LS6 and PRC 5.3 Stage 2.5's
- '00 LS1 to '05 LQ9 what works??
- 408ci DYNO results-how can I improve?
- cylinder head selection
- Video of tick, Pushrod?
- would 5.3 heads work with this cam?
- How strong is slp's zl402 iron short block
- will a this work?
- Quench.... Do i dare go with .030's?
- cam package
- smokin bad, help!
- TSP torquer V2, Cometic .040" gaskets-SAFE?
- Absolute cylender heads flow numbers
- Patriot Heads
- Cam for LQ9 in 78 TA
- Stroker kit
- ls1 valvetrain
- What size tap ?
- In line with some recent threads discussing smaller cams and "milder" combinations...
- streetability
- nw main studs and bolts?
- Anyone running 220 @ .050"?
- Winter 402 Build Just fired it Feedback or Suggestions Appreciated
- MTI Heads & Cam
- Looky, Looky.. UPS Man was Good To Me
- Knocking on startup
- Texas Speed 224/224 XE Camshaft help wanted
- 383 or 408?
- Idle problems after upgrades....
- Any meth benefit on n/a engines?
- 396 Cam Choice, Please Help
- Oil Pressure Issue
- What is the vapor vent pipe seal?
- Cam/Milling heads combo question...
- "Notch" in cylinder wall... Thoughts?
- Compression problem
- GM Performance Parts LS1 to LS6 Conversion Package
- Catch Can Oil: What Color is Yours ???
- Anyone running Manley pistons?
- Chime in if you're actually running an LS4 pump.
- Cheatr cam vs. GT2-3 (Help PatrickG/Predator)
- Mobil 15w 50 Oil???
- TB bypass to cool the TB????? anyone tried it?
- Is synthetic oil required on these engines?
- ported heads !!!help!!!
- can we get a sticky on interchangeable parts for LSx
- GM hot cam tuning???
- LQ9 shortblock @ 7K RPM
- Head gasket confusion
- Noise at front of valve cover?
- Need advice on purchasing an LS1 with 100K+ miles
- Valves hit pistons,help me figure out why.
- Stock rocker arm wipe?
- Lost trying to figure dcr, help please
- tsp stg1 ls6 vs stg 2.5 ls6?
- oiling system
- Cylinder Wall Thickness/ Valve Spacing
- Head/cam combo. Is this a good one?
- LS2 heads?
- Help Help Help
- ms4, prc ls6 stage 2.5, fast 90/90 ?
- PRC vs. Patriot vs. Manley?
- Potentially bad question
- please help
- LS1 oil pan questions, drag racing... launch = less oil press..
- How much does an ls1 shortblock weigh
- rebuilding questions..
- Oil Pick up tube o-Ring
- Quick question on arp head studs,please help.
- ls1rx7...good mod combo?!
- What cam comes with this painless kit?
- which cam for cam only car?
- LS1 stock lifters and Timing Chain ?s
- p/n for oil pump pickup tube rubber sleve
- What Do Y'all Think Of This Dd Cam?
- Heads to big???
- SCR & DCR on a TR224? w/AFR heads?
- What size push rods for my application
- another "what about this cam" thread,sorry.
- Why Buy Rockers
- Quench
- cam swap starting issue
- 806's vs. 243's
- LS1 Cam only setups
- Anywhere to buy an engine rebuild kit?
- cam experts, is this ok to install?
- Is this a burned valve, opinions needed ASAP please....
- Rocker arm question
- Who specs out the best Custom Camshafts?
- Permatex on new Cometics MLS??
- Oil drain bolt pics. Input/Feedback welcome.
- TEA stage 1.5 5.3 heads vs TSP PRC stage 2.5 5.3 heads
- LT1 and LS1 roller lifters?
- Neeh Help!!
- Head bolts Vs. Studs
- Static Compression Calculation
- how much power can you get from a custom cam?
- O2 Sensor and Spark plugs.
- Which Is Better
- TSP stg. 2.5 5.3L heads!
- help needed on ls1 cooling system
- cam gurus: thought on this
- Best combo to produce about 415rwhp out of an 00' A4???
- Whats my motor worth?
- new ls1 girdle kits! who's heard?
- cam question
- New engine... questions on tune???
- So many head choices, but I am lost on what to get!
- mobil 1
- Parts are in and build up is about to begain!
- Mahle Piston Rings?
- I Need Your Help Spending Some Dough!!!!
- Which H/C package for stock geared + spray car?
- Crankshaft?
- Cam card
- ls1 engine problem
- Ok I am confused 918 springs or 921 springs
- anyone try theses rockers?
- Did I receive the right lifters?
- Valve Overlap and CA Emissions
- Is this oil pressure normal? Pics inside.
- cam/valvetrain upgrade or STS turbo??
- Biggest cam that will still pass emissions..
- rebuild help
- Is their any PTV clearance with this combo!
- another tapping noise question
- Here's my SCR/DCR,best way to lower it???
- Oil Change Light Quiestion
- Heads and cam
- ? on Heads install
- Who is making close to 400hp on 224 & bolt-ons only?
- Just wondering about ls1 and lt1 vehicles.
- What did the LQ9 come in?
- Wanted a stealthy setup,what do u think?
- Fork in the Road: 347 vs 383
- MS4 is in!!!!!!!
- vacc pump
- ls6 spring question
- Biggest cam for more power AND MILEAGE than stock?
- Rollmaster Double Roller Timing Chains instructins
- torquer 2 shiftpoints, A4
- Can I just "drop" in these valves?
- LS1 timing gear-on-gear sets
- 2002 ss heads?
- Clayed my engine, then CC'd my heads
- LS1 cam & spring swap tools
- WTF... LOW COMPRESSION? Ugh....
- factory rockers???
- EGR Block off
- engine vacuum
- What cam would work best on a stock 99C5? 01-04 ZO6 cam? LS1 hot cam?
- Head Gasket blown? Coolant low...Help!
- Ls1 to Ls2 Swap?
- Change oil pump or tear engine down?
- dry sump system (i need a pro to clear things up)
- Fresh rebuild problems...
- will LS6 springs work for this?
- 2-piece timing cover
- Flycutting Pistons How to?
- Is this a good price to dissemble/assemble a block???
- Lucky No. 7!!! (spun bearings)
- cutting pistons
- What do you think of this cam only setup???
- 383 stroker
- MS3 vs. MS4 question
- 241 heads to big????
- cam + heads
- TSP224R with stage 2.5 5.3l heads
- Cam Selection
- what cam to run with TSP PRC 5.3 2.5R heads?
- Where do i buy brand new stock gm pistons???!!!!
- Those running the Castrol Euro Blend 0-W30.
- torquer v3 camshaft?
- Is this too much compression for 93 octane?
- DCR for the GM Hot Cam
- Which Cam?
- How much power from raised SCR?
- what do you guys think about this cam FMS-F13-114 FMS Custom Grind Camshaft - 230"/23
- What synthetic oil for DD 383 LS1?
- TSP H/C going in soon. What RWHP to expect?
- lifters
- Which sponsor has the least expensive Comp Cam price?
- Does the LS1 flywheel balance the motor?
- going bigger valves on 243's
- LS6 crate motor exchange to 99 SS
- New 241 Heads: Milled to 30-thousands? Thinner head gaskets?
- Can I put an LS7 crank in my LS1?
- Help!
- Cam Gurus...Not a "help me pick" thread
- Cammed, now for engine safety?
- where to get a cam doctor report
- Too much Cam??
- cam/converter matchup helppp
- cam install help!!!!!
- Callies Billet Main Caps
- Just Picked Up my cam...suggestions welcome
- diveability be damned-cam help
- How to tell Injector Size
- Daily Driver Cam
- how much is too much for a h/c swap
- Will this be OK LS6 396 - GT2-3.
- Oil Pressure?
- Which cam?
- ASP Pulley?? YES or NO
- Cam gas mileage and driveability TSP 231/237
- shaved ls1 heads or stock 5.3 heads
- Anyone using this Futural Cam
- Ls1 Carb Guys Come On In!
- Here's a decent video of the Z06 post G5-X2 install.
- Injector question
- How much horsepower from this combo?
- G5X4 / MS4 guys
- What is needed to install PRC 2.5r heads on a 1998 LS1?
- need a cam, help me out guys.
- Any HP/TQ gains from just raising the lift on this cam??
- LS1 Rear Cover / Gasket Differences
- head question from 241-->806
- Which timing chain?
- crane spring tool
- rev kit questions
- 317 6.0 heads
- 228/224 Reverse Split, heads selection
- Guys with Ls2 throttle bodies.....
- Which bolts to replace?
- possible upgrades?
- LS1 heads...
- 3/4 race cam...what the heck?
- LQ9 Rod Bolts
- 408 and alot of horse..
- LS6 or 5.3 Heads
- Those with the Patriot 226/226 cam....
- What kind of rwhp from stage II LS6 heads and stock LS6 cam?
- Few questions about different cams
