View Full Version : Generation III Internal Engine
- Help Me With a Build
- What size pushrods for heads milled 30 thousandths?
- How bad is this?
- Least expensive tall valve covers
- Good heads for me ?
- Differences running 5/16 versus 3/8 Pushrods
- MS3 with thinner HG
- Need Help after cam swap!
- Which Head Porters Are Planning CNC World Heads
- prc heads and ms3 or order
- head bolt TQ question...
- need some compression figuring help
- mild hp rebuild kit
- how to make a rear main seal installation tool for free
- Another torque spec..
- Jesel's finally, ET solid roller pushrod length ect...
- F14 installed..have a few Questions??????
- engine ?
- connecting rod weights
- Mixing Bearings... Safe?
- rocker arms??
- 233/276@.050 Why GM?
- chugging after cam install!
- 10 sec car...cam only?
- Katech New Years hours
- Katech rod bolts back in stock
- Anybody running a 408 w/ MTI Stage III LS6 Heads?
- How good is this Port Job? (TB)
- what cam?
- Cam??
- SDPC N228 cam??
- what's wrong with my car? Please help
- TSP 228R and Comp918 springs ??
- cam break-in
- Worth the time and money?
- Dart 205 data
- Stud Problem
- Car seems to want to die at idle somtimes ????
- another cam decision thread
- who sells ls2 chain
- What else do I need?
- truck ls1's: post info and suggestions here!
- Where to put ring gaps in cylinder?
- Burning Coolant After H/C
- 5.3 lingenfelter cam
- Update on Heads&Cam R&R....
- Did search, found nothing.
- Upgrading Rod Bolts... What else??
- Can Felpro 1041's be copper coated?
- couldn`t find an answer !
- New head ??'s
- Katech Rod Bolt Install. Did I Screw Up?
- resleeve 1 cylinder?
- Lifter surprise????
- I have an idea. but I need help making it work :)
- Cracked block = junk???
- MoDs
- Engine Noise
- Question Installing Rollmaster Timing Set +2 Cam Adv.
- Stock rockers?
- Are 1.8 rockers too much with this cam?
- Anyone tried T-rex cam with Ported Heads?
- 383 or 402 stroker w/turbo
- Piston Identification
- How reliable are Cometic Gaskets for a Street Application
- harmonic balancer mounting bolt re-usable?
- heads and cam packages
- 99-02 ls1 heads fit a 98 ls1
- Compression Test results?
- do i have valve float???
- TSP 231/237 in A4 car??
- cam questions
- Canton Oil Pan: Two Thumbs Down
- Head Swap, Motor In or Out?
- It Started!!!!
- Why not 1.8 Rockers?
- School me regarding spring wear with example inside using two Lunati grinds
- bent pushrod question
- 402 stroker?
- What head company???
- can I reuse my Cometic gaskets?
- Oil Pump installation Question
- 3.905 Gaskets?
- Just got my cam specs. Whats your opinion?
- head cc/ compression
- 228/232 .588/.595 114lsa XER in 408?
- 6.0 block, 5.7 heads, what head gasket?
- ARP Head studs
- LS1 sleeves
- Oil Pump spring shim
- MLS headgaskets reusable?
- anyone in phoenix have a good valve spring compressor?
- LSA and loping
- is there a how to section?
- Will a stock LS1 TB work with LS6 Heads?
- Comp. Ratio effective..static???
- LS6 Oil pump
- head help pp vs prc
- Car shuddering
- Ferrera Valves?? worth it??
- LSK lobes...
- when measuring how far the piston sticks out past the deck...
- Need help choosing lifters
- What kind of powere are you making with your AFR 205's????
- GMPP ASA vs. Lunati 230/237 :Roadrace setup...To be used with TEA Stage 1 5.7's
- PRC 5.3L (S) 2.5's or Patriot Ls6 Heads
- Rollmaster DOUBLE ROLLER
- adverage cost of cam install??
- Any testing done on the vic jr vs gm per?
- Bad Luck With Futral Cam
- need help verfiying an ls6 cam
- Dart Head Issues
- Dart Heads???
- So I was taking the rings off my hurt #7 piston...
- Are LS6 springs direct replacement for LS1 springs?
- Replace head gaskets....whats a fair price...........
- Anyone have any info on the GT1-1 Cam?
- 383 stroker help
- New Cam
- JPR tool
- Lingenfelter GT-11 or GT1-1
- Do I Have Enough P/v Clearence And What Compression Will This Be
- Which heads are better?
- Low Lift Cams & More
- Actual Hp
- X-Mas Camshaft :)
- Soduim filled valves worth it??
- What head gasket for 99 LS1?
- Cylinder Wall Scratches
- 408 high rpm woes
- real quick question
- ls1 making noise
- Trak Cam Question?
- Lifter Preload Help!!!!
- ls2 heads and MS3
- Engine & Tranny Out...Ready For Cam/Heads
- 408 cam ?
- Can anyone ID this valve spring?
- dropping the hammer from a roll...............
- cam question?
- What FMS cam for 3.23 gears and 3500 stall?
- Stock pistons...
- TSP Torquer 2 too big for a Daily Driver?
- when to change lifters
- HELP! Crank pulley inner tab broke off.....
- heli-coil failed, now what?
- LS2 heads
- CAM for a 2005 Sierra 5.3
- Is this safe to drive?
- OPINIONS: Best A4 cam for 10's/Highway
- Idle sticking !
- Head problem (good one)
- Will this setup get me anywhere near 750 hp on pump gas?
- cam/valve spring install ?????
- Another Cam question
- Will I have to flycut?
- Need advice LS1 w/LS2 heads and cam
- part i need help finding
- PRC 5.3L Stage 2.5 'R' Ported Heads?
- 5.3 cam and engine opinions- suggestions needed
- LS1 main girdle... Any Believers?
- No Lock up after Cam install
- Heads And Cam
- Need opinions/advice on setup (H/C + N20)
- low compresion heads
- high rpm smell (like a skunk, lol)
- How do I set lifter preload??
- Do you need to have stock heads machined for the PRC dual springs?
- best cam for p/p stock heads
- ARP headbolts...
- Cam, lifer, rocker opinions needed
- Engine rebuild costs
- Futral FM 6 cam
- spring selection
- problems
- rocker arm problem help!!
- valve spring help
- Max stroke on LS1?
- 2nd set of ET heads, 225 with comparison pics, (56k night night)
- Here are some pics of my blown up LS1
- 1.7 vs 1.8 Rockers
- ? on changing my set up
- cam install suggestions
- 806 LS1 heads for 6.0 LQ9 good or bad?
- Doing cam swap need suggestions for parts
- Lifter orientation
- what I need
- What causes this
- Biggest cam?
- Rate my LS6 Stage-II Heads...
- T-Rex Cam - what else do I need?
- Starter install
- Valvetrain Noise!! Help
- South's planned setup:5.7 TEA 1,ASA,LS6 TPIS OVAL,QTP HVMC,etc. Object:Usable Power
- URGENT: Cam HELP ASAP
- Under the curve
- Mill heads vs. welding chambers
- Fms 13 112 / Afr 205 / Ls6
- Some lifter, stud,cam and assembly questions.
- Cam for Ls1 Intake, 3.42's, heads,and no surges at idle.
- Head Gasket Opinion Please
- Cam differences
- Combustion Chambers and Ignition Timing
- Pull Timing At What CR
- Whats the thickness of GM head gaskets?
- stock roller rocker
- T-Rex Question
- MS3 On Order :)
- parts on order
- Stock heads/LTs/X/3000Stall/3.23... CAM?!?!?
- Need help! H/C install
- TSP 232/234- PRC 5.3 results
- cam bearing hole orientation question
- Hot cam vs milage
- Motor noise?
- Go with stock lenght pushrods?
- 59cc or 64cc
- ARP's or stock bolts
- stock pushrods w/big cam
- Patoit valvesprings?
- cam swap rod to hold up lifters need help
- biggest cam for D.D. and 3.42 gears
- Another PTVC ?
- Katech Christmas schedule
- tr224/227 114 vs lpe gt2-3 with procharger
- Merry Christmas from Patriot Performance !!
- Were absolute speed Stg II heads milled?
- New Sponsor! World Products
- How to store the stock cam?
- rebuild kits?
- Im having problems with the Mass Airflow Meter.
- ET Performance heads, anyone using em?
- Pushrod length with new heads/cam
- how hard will a trex be on a stock 4l60e?
- Started Heads&Cam today..Holy Crap!!
- g5x3 ptv clearance
- Cam shredded my lifter............
- Oil Comparisons
- Rotery cam??
- stock ls1 cam in a 00 5.3
- Bent pushrod making a knocking noise?
- Vacuum Pump lines and connection
- Motor Break In Process? (my search is f'ed)
- LS6/LS1 owners noticing more than normal oil consumption? I can help!
- Lower timing chain gear
- Swapping One Head
- just ordered a new SB 408
- how common is piston slap in 01-02 trans am's
- TReX cam + FAST intake or suspension, ls6 & tb?
- much differance between these 2 cams -
