View Full Version : Generation III Internal Engine
- why the hell am i down on power
- looking for advice on the next step
- How do you calculate how much weight an AFTER Market rocker adds at the valve?
- Need Your Guys Opinion Please!!!!!!!!
- lift the engine slightly on 2000 ss?
- issues..where to start, heads or oil pan?
- Is a Mirror image -55cc piston practical?
- 224/228 comp cam
- What is the best bang for the buck when building an engine from scratch ?
- Im Looking for some good books on building LS1's
- Jay Allen Cylinder Heads???????
- LS1 Stroker Parts
- 6.0 heads really any better than stock?
- Anyone use the Jesel SS series rocker?
- Any engine builders ever check this?
- LS1 with milled and ported 5.3 heads?
- Dyno results
- Burning Oil Smell...Something to be worried about?
- Will the Comp Magnum Rockers (1.75:1) clear the stock Valve covers?
- what is a good healthy dyno for stock a4?
- cam dyno 218/224 .552/.57 112
- Stock Rocker Question
- how much HP and 1/4 time
- cam/springs question
- Darton MID all-bore reborn from JD's
- APE 408 stroker
- Need Help Quick Please!
- have you experienced this?
- Block Work
- Titanium valves
- Need Help on 5.7 Vortec Engine
- terra 1.8 and stock 99 springs?
- Comp 921 Dual Valve Springs vs. Crane and Patroit Duals
- Cam Question
- Sad Day 265RWHP
- First Mis-step - I Didn't Ask Enough Questions!
- New Cam Sensor, New Crank Sensor, Fuel Pressure, but Car Still Won't Start
- Anyone ever LOST HP with aftermarket rockers?
- Healthy Cam Specs?
- Replacing stk head haskets on stk heads, any difference between the 97-01 and 02's?
- Removal of Intake Required to Replace Cam Sensor?
- SDPC LS6 Heads are on
- Looking to get new Comp cam cheap ?
- x1 vs. c2
- Need Help: Ses Light
- sound clips of a 231/237 cam
- Help me make sure I got right parts for Eagle stroker
- Which cam to go with for my ls1?
- Street Package Heads & Cam Recommendations?
- Ok here I go..wish me luck
- Is it possible for my 410 to make 550rwhp with 10.9.1 compression? What do I need?
- Is Ls6 Cam Any Good
- How many hp can stock head hold?
- 0031703614339864, This is stamped on the cylinder head, what does it mean ??
- Part # for 02/03 LS6 Springs
- FWIW - 2003 & 2004 blocks use different cam bearings (1 & 5, 2 & 4)
- before heads and cam...should i refresh the bottom end?
- Cams OK with 1.85 rockers and 918 springs
- Engine builder says, no way I will make 360 rwhp with a Z06 cam and boltons!
- LG can u overlay your 492 graph with the 503?
- Rhoads lifters
- Headers
- What size cam for a 427
- Camshafts and their specifications
- PLease help with Head choice!!!
- Can an older 350 block be converted to an LS1 or Lt1 ?
- Help, head gaskets
- Which head casting for 346 with poss future 383 buildup
- Valve springs?
- How long will a motor last with loose rod bolts??
- LS1 Hotcam vs TSP 231/237 idle? streetability? issues
- What parts are required to run 97-98 heads on an 01 LS1?
- Cam Swap
- cam degreeing
- LG and Cartek, I want 500rwhp how Much?
- Track Times With The Futral 228/230 Cam
- Ap-engineering Stage I Cnc Ported Ls1 Head Flow Numbers
- Recommended H/C combo
- Futral Motorsports Cams
- Intake duration for PTV clearance
- Push rod lenth with milled heads
- Paging Brian Tooley
- Cam going in tonight, double check my list..
- What cams are working the best with stock heads nowadays that aren't race-only?
- ALL S2 HEAD OWNERS!!! Question inside
- Oil Pump recommendations please (high volume - high pressure)
- durability of the LS1 engine...
- My block has been 0-ringed do I have to run copper gaskets and other questions
- Has anyone considered Nikasil?
- floating valves
- What to do with 6 L heads
- Absolute Stage 2.5 or 3 6.0 heads?
- AFR Update
- Are there any books that show...
- Need one last bit of info to calculate static compression ratio
- Stage 3X makes 501 RWHP and 432 RWTQ
- FMS 228/230 112 soundclips?
- TSP 228/228 ?s
- What are stock heads flowing?
- TSP 224/224 or 231/237 with 5.3 Head/Cam package?
- 379rwhp/362rwtw
- need to know cam specs on ls1 or zo6!!!
- how much can i port the ls1 heads
- Noob H/C question
- stock Cam
- What are the specs on the G5X3 cam?
- Any cam only + bolt on's ZO6's making 430+rwhp?
- Has anyone talked to Eagle this week?
- Can I use this cam in a stock motor?
- Heat cycle question
- Did GM start putting the new style valves in LS1 engines in 1999 ??
- AFR update from TonyM
- has anyone put the tr236 on stock heads?
- Got my TEA heads, flow #'s within
- What flywheel to go with?
- ARE Stage 2 heads ?
- Help judge my modification
- Oil sensor size
- Ape 6.0 Liter Cylinder Head Flow Numbers Inside
- Adjustable rockers
- 6L info needed
- My Combustion chamber on my Heads?
- Ok..It's my turn now. Which heads for my tr224
- Who has best $ on kooks LT headers like on the Cartek 501HP vette?
- Reluctor ring
- head gaskets
- blue smoke on start-up
- Q about oil bolts for oil pump.......
- LS2 valve spring part#- 12586484 will replace the LS6 valve spring 12565313....
- New Dyno Numbers for TSP 383 Stroker
- need help
- EWP and or other high $$$ parts???
- what valvetrain for z06 cam?
- Block prep for solid roller lifters
- Maybe purchasing this Cam.. Opinions
- What will this Package get me?
- G5X2 on a 250-300 shot?
- G5X2 Cam with stock converter?
- Ring problem or Valve seals?
- 383 Stroker Kit?!?!?
- Flowed some Patriot LS6 STYLE heads on an independent bench today...
- ***cartek Stage 3 X Pkg*** 501 Rwhp And Over 430 Rwtq Stock Bottom End 346 !!!!
- Can someone give me p/v clearance on a stock Ls1
- Question on building a new engine.
- How does DOHC make more power than pushrod?
- Any pros/cons of a 112 vs 114 lsa with M6
- PLease post your 224 clips
- How much did it cost you to have heads installed
- Wrong CAM! ?
- 7.40 or 7.35 pushrods?
- Erratic Oil Pressure
- Clearence
- what is the safest the piston can come out of the block?
- Ls1 heads on a 5.3 truck
- Iron vs. Aluminum Block ?
- how will a 234/232 590/590 114 cam run in a stock 6.0?
- Crank Position Re-Learn??
- HELP! what gasketts, head bolt or stud with stage 2 heads?
- Just ordered my FM11 (228/230 581/591 112+4), got a question
- Valve spring / Cam question
- GM Warranty Engine Replacement
- What gains have you guys seen with your h/c packages?
- Help choose my cam...choices have been narrowed
- How much can the stock short block handle?
- How will my Absolute Speed Stage II's work with this 427?
- What should I run with this combo PP 5.3 and more
- Rebuild
- asa in 408
- Push rod length
- Does anybody know anything about these?
- why is my car missing 30rwhp?(compression #'s inside)
- What gains did you see with...
- Engine crackling?
- Those with YTs and COMP R's
- Dry Sump???
- Piston Slap
- PP heads and oil consumption
- Do I need to mill my heads?
- Help me start my 382 Project
- Which rockers with comp "R" lifters
- 4.8 heads?
- cam for an A4
- bore size
- 383 Stroker LS1 experience needed...
- with 60 thousand mile do i need to replace timing chain and oil pump
- flashing on new pistons
- HELP...where to get VITON valve seals for 5/16 valves / .500 guides???
- CALLIN' ALL HEAD/CAM GUYS & GALS????
- Slight scratches on bottom or head = re-milling?
- I need a cam
- After cam install
- oil pressure
- new hotcam #s
- Rear Main Seal
- Anybody been running the comp 26921 springs for awhile?
- Question for Dynojet operators
- Patriot 5.3's, 224/581/112, Macs Track Results
- At what spring pressure do stock lifters collaspe?
- oil pressure
- oil pump and timing chain ideas?
- oil pump and timing chain recommendations?
- Bottom End Question
- Help with compression on Corvette LS1 heads on a 5.3
- Started my cam swap today.....
- Info on how Plastigauge is used...
- Is my piston to valve clearance measurement correct
- 226/226, 228/228, or 228/230 Futral Cam users Come In
- 6.0 budget build
- Car Won't Start, No Spark, No Power to Coilpacks
- TEA hand finished heads, need help picking cam
- Cam Recommendations for inside set up
- G5X3 fit with stock heads, other big cams only stock heads
- Adj Rocker Arm recommendations
- F1 Cam info please......
- Piston Slap
- Stock replacement FORGED rod?
- Convert Static Compression Psi to...
- Dyno questions with 224 cam
- BAD Low RPM bog/miss, any guesses?
- RM Timing Chain Q. Need Response ASAP!
- restrictor pushrods?
- Is it tough to assemble a motor...
- Need advice on build up
- lowest CR w/5.3 heads
- In-Car Valvespring Change - Need Help NOW!!
- Help IDing Cam Manufacturer
- Ls1 to LS6 conversion?
- pin size on Eagle rods
- Will a stroker pass smog in cali if...
- valvetrain noise question
- Finally Dyno'd my 10 second cam only setup
- Balancing a rotating assembly....
- Moderator Announcement: Big Mike is in the house!
- What do 317 Castings Flow ?
- How much P to V clearance is minimum?
- Installing new lifters
- biggest cam for A4?
- A4 Guys with TR231/237 Stage II LS6 Heads
- PtoV on FMS 228/230 112 +4
- If crosshatches can still be seen does the block need a hone?
- Newbie - H/C parts check list
- Any one have the thread on Head CC & volumes
- Looking for a Stealth Cam...
- K-member hitting header problem.
- Rwhp?
- When pulling motor can I leave the tranny in the car ?
- Looking for some advice
- anyone used 6L heads w/ pop up pistons?
- PtoV with G5X-2 and .010 milled 5.7 heads?
- Dual Springs... Patriot or Crane??
