View Full Version : Generation III Internal Engine
- CR Formula
- Anyone know the oiling order of an ls1?
- Piston / Valve Clearance ?
- LS6 Heads Chamber size?
- WOW-----READY FOR CAM AND I KNOW U ARE THE GUYS TO TALK TO PLEASE HELP ME CHOOSE
- what cam is best???
- S1 cam sound clips?
- light weight valve train for quick response? 2?'s
- Tired of debating....which cam
- Who upgraded from B1 to something bigger on S2 heads
- Need the GM part # for LS6 intake?
- Does anyone have a.....?????
- Stock Heads and Manifolds with a CAM who has the most power
- GM part numbers
- Low oil pressure
- What size are oil pan bolts?
- What fuel system to support the superstrokers?
- 6.0 Crank same as 5.7??
- X1 cam users inside please...
- spring pads
- Head/cam swap complete...got a question.
- 02 LS6 CNC Heads and 02 LS6 Cam buildup...thoughts wanted
- What head gaskets
- Oil
- Aftermarket cam with GMMG exh?
- Who sells Rev or Ferrea valves?
- How small of a cam is to small
- What side is your oil pick-up tube bolt on?
- Intake valves and cam for heads and cam set up?
- TR230/224 + bolt-ons = 422rwhp!!!
- Weird explosion type problem....
- Cam choices
- What is the advantage of a D-shaped exhaust port?
- Almost Christmas. Are the COME stroker cranks coming out?
- How much will .005 difference make on cam lift ?!?
- 500-600 hp......
- 500-600 hp......
- Where can I get 2.02 valves?
- Urgent head install question
- Help me with my final cam choice
- Jesel or T&D shaft rockers??
- Dealer F'ed up my car
- Roller Rocker Alternatives..
- intake closing point...
- Need Some Help
- We know 4* advance works, but what about...
- TR 224 and base circle question
- Nicked cam bearing
- Swapping motors
- Any Experience with Reverse Split Cams?
- 393 All-bore Solid Roller cam
- At 471rwhp now, how to hit 500rwhp?.......
- TR 230 people.. Inside please!!!
- Comp Cam 224 XE-R
- What's my misfire from?
- What is the difference between single, split, and reverse split camshafts?
- What do you guys think about Absolute Speed's Stage 2 heads?
- 6.0L Stroker Questions
- Thoughts on this shortblock
- 4.00" Bore sleeves??? Builders please respond.
- New push rods with a cam in a A4?
- cam choices, speedtek? thunder racing? other choice? please help
- LS6 PCV questions
- Help with Pushrod replacement!
- LS6 heads or 5.3L heads?
- Can anyone help me out with my compression ratio?
- Where's the best deal on LS1 stage2 heads?
- pictures
- I need your 220 and 224 sound clips on a 114 LSA
- Thinking of going to the dark side - solid roller
- stroker cranks who's to use?
- ls1 stage 2 heads
- What to Do Next - Big Duration on a 115??
- 382 small bore or big bore?
- Bonus rod sticking out the side!!!
- Dyno# MTI S2/X1 100 wet shot!
- 224/228 XE-R cam
- ADVANCING CAM/ TETARDING WHAT HAPPENS TO POWER CURVE
- LT4
- what to do for valve covers?
- BROKEN VALVE SPRING QUESTION!!!!!!!!!!!!!!!!
- Lingenfelter H/C packages
- how much lifter preload when adjusting valves???
- Is Colonel's Engine Just a Myth?
- Hotcam????????Which heads?
- 2002 stock Z06 springs - max lift?
- Need a set of stock valves
- Cam Grind # question
- Anyone know the specs on the GTP #4 cam?
- And auto tap says....
- What do i need to run with this cam?
- Yellow stuff under oil cap?
- Help me help a friend, cam? for a 422
- Is there an easier way to measure....
- Roller Rocker Noise
- what would happen( if anything ) if you deleted the egr and did not add a breather-
- connecting rods
- help with simple pushrod question thank you
- Is a cam with stock manifolds and heads a bad idea?
- Please explain "boring/resleeving an LS1
- Engine experts, take a look at my setup for 68 Camaro Twin turbo
- Not a pick my cam post but......
- engine block
- valve question
- head work info
- the great cam question
- Spitting water on warm up?
- looking for good info on main bolts, bearings, and piston rings
- C5R heads
- Any body running a 220/220
- OIL PRESSURE
- gota problem - need some guidance please!
- Not another LSA discussion, My take on the situation. Tell me what you think.
- Question about the main bolts that go through the outside of block...
- Pushrods: Thunder's VS. Comp Cams...
- LS1, what is the pushrod length?
- play pick a camshaft (i really appreciate any help)
- 99 SS knocking and won't stop after warm-up
- LS6 Heads
- Cam Advise
- Head/cam package help...
- "Project Wife's Car" get a CAM!!! results;
- changing pushrods? Got a couple ?'s...
- CAM opinion- 2000 SS
- Power difference from 346ci to 6.0L????
- Need help about overheating problem!!
- Anyone running a 382 all bore?
- ENGINE INSTALL
- help appreciated what is a good cam for a 98 z
- What's the biggest lift on a cam you can go w/ stock pistons?
- 6.0 bored .030 or .060-stock rods & Crank
- 6.0 Qs
- Any one ever had their car worked on by LPE?
- Wanting to mod my car
- would u please discuss this cam with me
- Stock rods vs aftermarket rods
- 02 LS6 cam + 1.8 rockers okay?
- What is involved in a cam install?
- head stud clearence
- Installing head studs with shortblock in F-car??
- ASA hotcam and piston to valve clearance?
- Budget calls for a ARE 393 all bore, help me select a cam:
- Help me pick a cam!
- LS1 - 5.3L parts compatability
- ls6 port measurements
- cam install question?
- Lifting a Head: what is it???????
- LS1 hotcam in A4
- 5.3 liter heads and cometic gaskets
- Pagin 770 Boy, Cam Question
- H/C or Turbo?
- Jesel rocker torque?
- crankshaft question
- Stock cam
- Help pick a suitable cam for my hybrid swap!!
- TR 224-112 OWNERS
- Thoughts on forged pistons and knock sensors...
- Where are the splash guards
- got cam, want bigger
- what are the specs on the ASA camshaft
- asa cam-cnc stage 2 heads what do u think
- Can our stock camshaft be reground?
- F1 CAM INFO
- Torque specs on Lunati rod bolts?
- Any LS1 dry sumpers out there??????
- 10w30 or 10w40 for High rpm's?
- CAM QUESTION
- Oil pump went out
- WTF is this condensation??
- TEA= Total Engine Airflow
- Car choking?
- Car keeps dying?????
- hot cam sound clips any one
- cam question
- Is the HOT CAM a good choice for me?
- absolute speed heads.
- Pistons - Please Help !??
- Different Dyno's - Same car - Same set up - Biggest difference in RWHP you've seen?
- Does windage tray need to be shimmed with stroker crank?
- Please Help!!! Need GM Part # for vspring retainer key asap!!!!
- Anyone gained low end torque from cam change
- Help, want a stock sounding idle cam? Z06?
- ARP main and rod bolts
- engine building question
- LS1 Part Numbers
- Weird Problem with ARP studs
- Any install/tech info Websites ???
- Put LS6 cam in, Lost 15hp?
- Connecting Rods and FI
- Coolant/Oil Sludge on the underside of the Oil Fill cap....HELP!
- GM LS6 CNC ported heads
- NEED HELP CHOOSING A CAM
- dealers on crack?
- 6.0L Buildup ???
- What dyno numbers do you predict for my MTI ironblock 427?
- stroke bore question?
- Oil.......
- dumb question..but of major importance
- Cam questions about degrees +/- advanced/retarded
- non LS1.... Tips for restarting an engine thats been sitting
- Storing my car. need help please
- A couple of Engine Building Questions
- A Couple of Engine building Questions.
- Gettin my heads ported and polished
- PCV system removal?
- head and cam with out pulling motor?
- Lunati camshaft
- ARE
- What should I be running after cam install?
- opinions on 228 224 588 581 on a 111.
- Hotcam with stock headers worth it?
- Holy FREAKING POPCORN BATMAN!!!
- Attaining Sound of 302 Camaro
- casting numbers
- C5R Block
- How much compression you running with your big cubed motor?
- Inside of the Intake is shiney....could it be?
- Using Patrick G's 44-46 ABDC theory.....
- Anyone running a ARE 442 big bore?
- TEA heads?
- What numbers if a 6speed?
- What is the largest dish you can order pistons....
- BEnt Pushrods??
- benefit of milling heads??
- Any difference in N/A performance between TR-55 and TR-6 plugs?
- radiused inlet flowing heads....
- Alright, I am convinced. Time to get an adjustable timing chain.
- good head question please respond
- 425 hp with 01 LS6 cam
- Synthetic Oil Life Study
- another compcam 212/218 question
- do u need a spacer or tall valve covers for Jesel ShftMntd Rockers ?
- new Stage II setup: is 360 rwhp in the ballpark?
- Best cam for stock heads
- Whats a good throttle body cleaner that won't damage plastic intake?
- H.P. Limit on stock crank and rods???
- optimal oil temp? Ifound condensation under my oil cap..
- 02 Z06 Valve size?
- GM stock rings pistons.....gap
- Main and rod bearing clearances??
- Hello Everyone
- The best rings ??
- What kinda cam does it take to get 550 HP out if a 422-436 CI?
- Speed-Pro/Sealed Power rings
- Solid Roller ?'s
- ls6 heads
- what is the best way to install new lifters
- TR224 112 & GTP S3 heads dyno
