going to be installing my scc springs this weekend if my 275/40/18 tires will work.
Old 10-21-2010, 10:50 AM
DavidGXP's Avatar
Default going to be installing my scc springs this weekend if my 275/40/18 tires will work.
Title explains my intentions. I've got the scc Gxp spring kit. 2.5" front/2.0"rear. What do you guys think? Might be a little low but its not my daily driver anymore. Can anybody confirm that my tires will fit without issues? 275/40/18 with stock rears. From the looks of things I've have tons of room. Massive of wheel well gap
Old 10-21-2010, 11:21 AM
2005gxp's Avatar
should fit well, where did you get that much drop in ssc's? mine are only 2" all around
Old 10-21-2010, 11:34 AM
DavidGXP's Avatar
Scc its its what they list for the Gxp now.
Old 10-21-2010, 12:18 PM
DieselPump's Avatar
I'm lowered on ssc's with 275's but I only have a 1.8" drop in the front. It could fit with the 2.5" springs though.
Let us know how it works out.
Old 10-21-2010, 01:22 PM
DavidGXP's Avatar
So i should be ok?
Old 10-21-2010, 01:33 PM
DieselPump's Avatar
I'd say it's gonna be pretty close. With my 1.8" it looks sweet and there isn't a whole lot of space left. I think you'll be right at the tire when lowered. And who knows if you'll hit when you turn.
Old 10-21-2010, 01:40 PM
DavidGXP's Avatar
Man... now Im scared. I don't wanna have to take it all back apart again.
Old 10-21-2010, 03:03 PM
DieselPump's Avatar
I hear that. But I guess that's the only way to find out as I don't think anyone else is lowered with ssc with 275's in the front but me. And only one person lowered 2.5 up front with stock tires.
Old 10-21-2010, 05:26 PM
monte_with_a_LS4's Avatar
just think. if the tire stays clear its going to look sick as hell! I say go for it
Old 10-21-2010, 05:38 PM
DavidGXP's Avatar
It should clear now that I've had time to think about it. Im running a 40 series tire vs a 45. My tire height is 26.5 vs 27. Only concern is rubbing. But i don't rub now when going over big bumps.
Old 10-22-2010, 12:40 AM
GXP25's Avatar
They're still selling those 2.0"s for the rear?
I told him to switch to 1.5" as 2.0" in the rear might be pushing it when it comes to a full back seat and full trunk.
Also, the 0.5" difference isn't enough. The car still looks like it's sagging. My 1" difference is on point.
Might have to give them a call about this tomorrow.
Old 10-22-2010, 12:47 AM
GXP25's Avatar
It's a long process. You'll need four (4) camber kits as well. Use A LOT of anti-seize and remember to torque your bolts!
I didn't torque mine the first time (back in April) and after a few months I had clicks and noises like you wouldn't believe.
Replaced my 2.0"s in the rear with 1.5"s, put in camber bolts (all wheels), anti-seize (all 8 bolts and nuts), and then torque'd everything (did this all two weeks ago) and now I'm good. Just need to get an alignment sometime soon.
Old 10-22-2010, 08:54 AM
DavidGXP's Avatar
Thanks fir all of the in put Gxp25.
Old 10-23-2010, 11:36 AM
DavidGXP's Avatar
Are Anti pogo washers needed? And who do I get the camber kit from?
Old 10-23-2010, 12:02 PM
GXP25's Avatar
No washers needed.
ACDelcos: http://www.rockauto.com/catalog/x,ca...,parttype,7542. Make sure to put in your vehicle.
MOOGs: http://www.moog-suspension-parts.com...name&Sec=12430
ACDelco:
MOOG K5330:
ACDelcos allow a +/- 1-3/4 degree camber adjustment while the MOOGs allow a +/- 1-1/4 degree adjustment. So a higher degree of adjustment with the ACDelcos.
5% RockAuto coupon code may still work: 40076333300853
Old 10-23-2010, 01:15 PM
DavidGXP's Avatar
Can I use the MOOG kit in the front too? Or do I use the AC Delcos in the front and the MOOGS in the rear?
Old 10-23-2010, 01:19 PM
DavidGXP's Avatar
Got it. Napa has my kit in stock. 1 3/4 kits NCP 2643642
Old 10-23-2010, 01:37 PM
DieselPump's Avatar
Looking forward to seeing pics
Old 10-23-2010, 02:24 PM
GXP25's Avatar
Yeah there are different kit manufacturers, but you only need one kit type for the entire vehicle.
I just went with the ACDelcos because I liked the simplicity, design, and higher degree of adjustment due to my 2.5" drop in the front.
Old 10-23-2010, 03:41 PM
2005gxp's Avatar
i simply slotted my struts like my alignment machine at work told me to do. worked mint for me got all my wheels lined up perfect and i mean perrrrrfect lol
Quick Reply: going to be installing my scc springs this weekend if my 275/40/18 tires will work.
