After Cleaning MAF, whats proper way to reset.
Oh the joy of the internet. YOu search for one topic for example this one on google and you got probably hundreds of way to make sure your new car sees your new clean MAF.
I looking for an honest answer from a tech or someone who has very good knowledge of this. After you clean you MAF, what do you do to your car so that it reads correctly after you clean it. Some say drive car. Some say turn car on and off about 10 times. Some say disconnect your battery. Whats the proper way please?
After cleaning the MAF only... Drive normally!
If you disconnected the battery... YOU MUST:
Start engine and allow it to idle (no load) 1 min. Then turn on all power acc, and apply brake, put in gear and sit for 2 min., return to park and return loads to normal. Then drive as you wish.
Same porceedure applies to if you remove and clean the throttle body, which you should do at regular intervals on your LS engine.
And if you disconnect the battery for that... you should also follow a driving cycle:
General Motors Driving Cycle
A complete driving cycle should perform diagnostics on all systems. A complete driving cycle can be done in under fifteen minutes.
To perform an OBDII Driving cycle do the following:
1. Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3. Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
Reprinted on OBDII web site courtesy of General Motors Corporation
© General Motors Corporation
