dumb thing i did
and that code is for "Powertrain control module fault" or just "Driver 5 Line 2" - depending on which DTC list you look at, heh...
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
EDIT: It erased my tune, as well.
may have zapped your module then... may be lookin at having to buy a new one $$$
ECM is about $435 MSRP...
if you DID have a custom tune in it, then it should still be there... your ecm/tcm messing up on your car wouldn't affect the predator or erase anything from it...
if not, then it will always have Performance Tune in the menu...
to restore the original backup, you have to go to Options - Troubleshooting - Restore Original Backup
#1 - you didn't have your key turned on...
or
#2 - your key was on, but your ECM is toast cuz it can't read/access it -- which is most likely the case, since the predator couldn't read/access it to tell if there was a tune already on it or not - hence why it went into performance tune when you connected it...
Are all your mileage infos broke?
http://s380.photobucket.com/albums/o...rent=001-2.flv
yeah, there's no tcm/tranny support for these cars, so the only thing the predator can communicate with, is the ECM for the engine tune...
and because he's getting that error, that tells me it can't read the ECM at all... so my money is on the ECM being bad...
or, like you said, could be both...
but definitely the ecm...
my car went into limp mode on me once - I didn't put the battery cable back on the post fast enough, so there was some arcing, hehe....
started the car up, and went to move it outta the garage, and no matter how far down I pushed the gas pedal, the car barely crawled, had the tranny CEL on the dash, etc etc..
disconnecting the battery cable again for about a half hour, then putting it back on (quick this time!), solved the issue...
did you buy the predator new or used?? and when??
