GXP Problems...:/ Well 1st issue is as I turn into my driveway I get a weird sound like a bent wheel on a bike spinning(hopes that makes sense) only happens wen I'm turning left?I got 225/55/18 all round 2nd issue is a weird cricket like sound coming from the vents only when the heat/air is on.. 3rd issue rattling from the dash and sunroof annoys the Sh*t outa me. On a good note I'm gettin my car tuned this saturday woooo!!!!!can't wait:D |
Originally Posted by christopher.lazaris
(Post 14336728)
Well 1st issue is as I turn into my driveway I get a weird sound like a bent wheel on a bike spinning(hopes that makes sense) only happens wen I'm turning left?I got 225/55/18 all round 2nd issue is a weird cricket like sound coming from the vents only when the heat/air is on.. 3rd issue rattling from the dash and sunroof annoys the Sh*t outa me. On a good note I'm gettin my car tuned this saturday woooo!!!!!can't wait:D 2nd might be caused by a leaf or something in the blower motor of the ac. 3rd I sometimes get a rattle as well, turn the radio up louder lol. |
check your frontend, could have a loose wheelbearing and it could be causing the brake rotor to rub on the dust shield. 2nd take your cowel off so you can get access to your cabin filter, remove it and you can see down to the blower fan, check for leafs ect. in there and spray the center(theres a bearing in there) with some lube that dosent smell. 3rd do you have a sunroof? check the trim around the sunroof/headliner and make sure its still attatched all the way around. i dunno bout the dash rattle tho, check the glove box for anything that could make the noise. |
Ah, welcome to this car. The sunroof noise is probably the most prevalent. I have a slight squeak under the steering wheel behind the knee panel. |
© 2024 MH Sub I, LLC dba Internet Brands
