Wheel Hub Bearings...again....
Old 07-18-2011, 03:02 PM
2002ScottOnyxSS's Avatar
Default Wheel Hub Bearings...again....
Does anyone know the size of the axle nut for a 2007 Impala SS
I need to purchase a socket to get to my hub bearings...
These things go once a year, so I figured I would try it myself this time
http://www.paulstravelpictures.com/G...ent/index.html
Procedure states 36mm..sounds about right?
Can anyone verify 100 ft-lbs
Thank you
Scott
Old 07-18-2011, 06:34 PM
ghetto joe's Avatar
100ft lbs is wheel lug nut torque i think wheel bearing are around 180 thats what alot are but i could only find spec on that vehicle showing 118ftLB so im not sure either?
Old 07-18-2011, 06:39 PM
TheJPGXP's Avatar
Sounds about right, I forget if it's 34mm or 36mm... I've replaced my hub twice.
And, seconded on 100 ft-lb being lugs. I think we went 120 or so on the axle nut.
Old 07-19-2011, 08:16 AM
Damn these hubs...my brake pads last long than these things..
cool! Thanks everybody for the feedback. 100 ft-lbs on the axle nut seemed a bit light!
Old 07-19-2011, 09:40 AM
TheJPGXP's Avatar
My problem was the bolts backing out, loc-tited and all, snapped the sensor's wires and it was done.
Old 07-19-2011, 10:55 AM
oh sh**! The hub bolts?
That could have been horrendous...
Old 07-19-2011, 11:30 AM
TheJPGXP's Avatar
Yep, I check 'em regularly.
Old 07-20-2011, 08:16 AM
Definitely a good idea...I'll do the same
OK..just picked up a set of BCA/Nationals yesterday
Got a year (almost to the date) from the last set, which were OEM...
Installing them this weekend
Quick Reply: Wheel Hub Bearings...again....
