First passes on Turbo GXP
Ran my GXP to for the first time today. Cartuning turbo kit,stock trans,full weight,junk tires. Ran 13.54 at 114 mph with 60 foot of 2.58. NEED TIRES!!!!
Thank you,
Barry
Thank you,
Barry
Of course, the trans will die soon after!
Had 8 pounds of boost with dump open. Didn't open the dump until the car shifts to second, transmission thanks me.
Car was never tuned just run. The times aren't ground braking but really not that bad. The DA was over 1800 air temp was 79 degrees.
Thank you,
Barry
Thank you,
Barry
I was just comparing that 13.5 to what the car will run on full bolt ons and a tune which is 13.5 so there's no real pickup there. But now I see your untuned so that could explain it.
He got a 2.58 60ft! With stickies and spring blocks, I'm sure he could get a 2.0 or better.
If he did get a 2.0, then his ET would have been 12.38. Once tuned, I'm sure the car will do much better.
114 mph is about 390 fwhp in our cars. I trapped 111mph and put down 360 fwhp last fall.
