LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LS4 Performance (https://ls1tech.com/forums/ls4-performance-108/)
-   -   Lowered GXP's (https://ls1tech.com/forums/ls4-performance/1679442-lowered-gxps.html)
92builtbird Sep 30, 2013 09:03 PM
Lowered GXP's
I've been doing research for months now, and am still undecided on what lowering springs I want to go with.
I am not too anxious to get the SSC 1.7 springs, because it seems like everyone experiences some type of sag in the rear.
I want to go with the Canuck 2.5/1.5 drop, but I am afraid I'll have to roll the fenders with my new wheels..
Does anyone have any experience with either set-up or can add some information?
91parkave Sep 30, 2013 11:22 PM
i had the ssc combo it was pretty nice but just didnt seem right with the bilstein, after converting the bilsteins to coilovers it was the best thing i couldve done for the car handling wise. for around 175 per axle you can convert your factory bilstein's to a coilover setup which ride really nice even for a DD and when youre pushing it around curves the response/feel is infinatley better
92builtbird Oct 1, 2013 08:25 AM
Can you post where you got the coilovers from? Brand? Also, did you notice any sag from the ssc springs? Thanks!
91parkave Oct 1, 2013 08:30 AM
Just doing a simple writeup on converting the bilstein GXP struts to coilover.
Imo not going to go through the all the details of taking your strut apart etc..you can follow the writeup on CGP
here --->>http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
So a few notes while doing the bilsteins in particular. when you take everything apart youll want to reuse parts of the factory dustboot to keep your shocks relativley clean and have a good service life.
youll want the white collar from the inside of the blue dust boot as well as the black plastic cap. all pictured here
http://i173.photobucket.com/albums/w...psedac399c.jpg
so in order of things we start with the bare bilstein strut pictured here
http://i173.photobucket.com/albums/w...ps0f1692f7.jpg
we press the sleeve on, ( i happened to use a 2.048 i.d sleeve which was slightly to big so i hammered some (exhaust pipe adapter 2 1/4 ID x 2 1/8 OD available from autozone)
http://i173.photobucket.com/albums/w...psc8e8db77.jpg
for the dustboot just use scissors to slice the top of the collar off to get the white piece out.
http://i173.photobucket.com/albums/w...psdac7b661.jpg
so in order of assembly youll want to do this sleeve, nut, bearings, black plastic piece, coilover spring,white piece
(optional but not neccesary)washer, two polyurethane sway bar bushings,mount with isolator and nut.
(important side note---using the poly bushings youll want to use a 1/2' drill bit!! then use a 19mm socket and hammer it on the washer like so)
http://i173.photobucket.com/albums/w...psd8cc8c2d.jpg
http://i173.photobucket.com/albums/w...ps2535a2e2.jpg
http://i173.photobucket.com/albums/w...psa179ed11.jpg
Hope the visuals help. any questions or comments please ask.
92builtbird Oct 1, 2013 08:38 AM
Thanks! Did you notice any sag back when you ran the ssc's??
91parkave Oct 1, 2013 08:58 AM
I opted to go back to factory Gxp rear springs SSC springs made it a tad lower in the rear
92builtbird Oct 1, 2013 10:05 AM
Wow. Now my decision is even harder haha. Anyone else with experience in this??
GXP25 Oct 4, 2013 03:59 PM
I created the 2.5"/1.5" spring set.
I'm planning on raising the vehicle, but not back to stock.
I'm thinking maybe 1.5"/0.5", or maybe even 1.75"/0.5".
Red_Zone Nov 3, 2013 07:39 AM
I have 2.5 Front and 1.7 rear from CMS on brand new HD bilsteins... on 275 fronts.
I do not get rubbing.
I'm overall happy however to be honest I would prefer a little more drop in the front and a little less in the rear.
92builtbird Nov 3, 2013 08:11 AM
Originally Posted by Red_Zone (Post 17796283)
I have 2.5 Front and 1.7 rear from CMS on brand new HD bilsteins... on 275 fronts. I do not get rubbing. I'm overall happy however to be honest I would prefer a little more drop in the front and a little less in the rear.
Thanks for your response. I bit the bullet and went with the ssc 1.7 drop on new bilstein hd's. (As well as cv axles, hubs, tie rods, seals etc).
Overall I'm very happy.
turbo_Ls4 Nov 9, 2013 06:37 PM
i love the 1.7 ssc all around. i have no problems.. but running oversized tires i rolled the fenders.
92builtbird Nov 16, 2013 06:55 PM
To the guys that are lowered... how do you eliminate the camber in the rear wheels??
I went to get an alignment and they can't adjust the 2.5 degrees out.
Ill_Born_ss Nov 17, 2013 06:16 AM
MOOG camber bolt kits! You can install 1 on each strut but it is recommended to install 2 on each. Other brands are available but they are not heat treated. Simple install you can do it, then go for your alignment.
Note for alignment park car on platform and setup for alignment, then do not lift the car at all during the adjustment and use an air bag between the tire and strut (top portion) to hold the wheel assembly at spec, while you/they tighten the camber bolts then release the bag and do the other side the same way.
Product ID: MOOG-K5330-Rear/Front
Manufacturer: MOOG
GXP25 Nov 17, 2013 06:54 AM
Manufacturer: MOOG
I would have to disagree. I would suggest the ACDelco camber bolts instead since they offer +/- 1.75° of adjustment versus the +/- 1.25° of adjustment on the MOOGs.
I also think heat treatment for this application is unnecessary; I've had my bolts in since November 2010 with no issues. My front and rear camber are to spec.
ACDelco P/N 45K18036. You will need four (one per strut) if you're lowered front and rear.
Ill_Born_ss Nov 17, 2013 07:34 AM
[QUOTE=GXP25;17829205]I would have to disagree. I would suggest the ACDelco camber bolts instead since they offer +/- 1.75° of adjustment versus the +/- 1.25° of adjustment on the MOOGs.
ACDelco P/N 45K18036. You will need four (one per strut) if you're lowered front and rear.[/QUOTE
This is good (options) but you are not subject to the salt and corrosion as most north of you. Also the MOOG using as I specified gives over 2* adjustment and as for the heat treating it does not cost any more and the first time you hit a pothole or curb it does not change its shape, just a little more security!
92builtbird Nov 17, 2013 07:36 AM
Originally Posted by GXP25 (Post 17829205)
I would have to disagree. I would suggest the ACDelco camber bolts instead since they offer +/- 1.75° of adjustment versus the +/- 1.25° of adjustment on the MOOGs. I also think heat treatment for this application is unnecessary; I've had my bolts in since November 2010 with no issues. My front and rear camber are to spec. ACDelco P/N 45K18036. You will need four (one per strut) if you're lowered front and rear.
Thanks for the response guys. I'll post up my report later today. My camber is not showing out in the front, do I still need the bolts?? Or just the rears?
GXP25 Nov 17, 2013 04:24 PM
I'm pretty sure the ACDelco part is engineered for all weather conditions in the US. They don't make certain parts for certain regions of the country. It's more likely than not that the parts are overengineered for the worst case scenario.
Also, I've hit plenty curbs and potholes and I'm still able to be put back to spec. I also took a trip to D.C. and dealt with those ridiculous roads.
And could you please provide a source to the claim that those MOOGs provide over 2° of adjustment?
MOOG's own website begs to differ and backs up my original claim: http://www.moog-suspension-parts.com...rod=MOOG-K5330
Ill_Born_ss Nov 17, 2013 05:55 PM
"Problem Solver Magna cam / bolt kit. Allows (neg) 1-1/4 to (pos) 1-1/4 degree camber adjustment" That equals 2.5* of adjustment. Quoted from the exact web page you linked.
As I stated earlier just an option.
GXP25 Nov 18, 2013 01:02 PM
Your 2° of adjustment statement earlier came across as if they were superior to the ACDelcos that I brought up. As if to state it was a +/-2° adjustments. If that's the case, and you're adding both ranges totaling 2.5° of total adjustment, then I can also play with numbers.
The ACDelcos provide 3.5° of adjustment. And that's not my opinion.
Don't get me wrong, I've used plenty of MOOG parts which tend to be overengineered to fix OEM parts. But it just so happens that in this case, ACDelco prevails.
92builtbird Mar 16, 2014 08:29 PM
Sorry for the bump on this, but I am about ready to order but have a couple questions. (I don't drive it during the winter so I am ready to dig her out and get this going)
1) Do I still need these bolts on the front? The camber in the front is fine, its the rears that are bad
2) ACDelco P/N 45K18036 Would I need qty 4 of these?
3) Which bolt does the camber caster bolt replace in the picture below. Top or Bottom?
http://i57.tinypic.com/1ywupy.jpg
4) Do I just throw this camber bolt in, and will the alignment shop be able to do their magic, or does the washer need to be in a certain orientation. OR should I just give the shop the 4 bolts and have them install them?
Thanks guys!!
© 2026 MH Sub I, LLC dba Internet Brands
