Charging System Failure
Old 12-26-2013, 06:53 AM
lVloses's Avatar
Default Charging System Failure
This has been plaguing me for about 2 weeks now and I cannot find a solution. My car won't turn over or anything the battery gets so low. I've replaced the alternator twice now and when that didn't work I got a new battery which all of them have remedied the problem for a few days at a time but come again today car won't start saying Charging System Failure. I'm so lost on what this could be. Anyone have suggestions on what to replace next? :/
Old 12-26-2013, 08:45 AM
blkchevyz's Avatar
https://ls1tech.com/forums/ls4-perfo...g-problem.html
check the end of that post.
i order that sensor on mine and havent gotten it put on yet. mine will vary some times my charging is fine, sometime its very high and very low.
Old 12-26-2013, 08:32 PM
08 pimpala ss's Avatar
Check the fuse box connections i had the same problem and where the plug on the bottom of fuse box lines up with alt fuse was all dirty cleaned and also replcaed alt fuse and no problems since
Old 12-26-2013, 09:05 PM
lVloses's Avatar
I think I've got it figured out. I did a test to see how much power was being pulled while the car was off. After the computers shut off I still had a .7-.8 amp drain on my car. Pulled the fuse going to my subs' amp and boom! Down to .02 amps which is perfect! Now I need to figure out why my amp is drawing so much power all of a sudden. I've had it for close to 2 years now and never had a problem with it. Wish me luck! And thanks for the tips.
Old 12-27-2013, 05:46 AM
fieroguru's Avatar
If the amp drain isn't your issue, there is a 200A fusible link in the power cable that runs to the alternator. If it blows, the alternator will not charge the battery and once it runs down you will be done.
Quick Reply: Charging System Failure
