2005 Gxp with 2007 motor I bought not running 2005 gxp with a 2007 motor not cranking thought it was vats issue read ecm with hp tuners says it a 2007 saturn vue v6 so the ecm i not the one that came with the motor.Is it possible to still use that ecm if i get i flashed or do i need to find one out of a 07 gxp. Thanks:bang: |
Were any of the sensors changed form the 05 to the 07? The 05/06 uses a different computer than the 07+ The earlier engine has a 24x reluctor wheel and the 07+has a 58x wheel (there is a kit available to convert this, thus allowing you to use the 05 comp)(Lingenfelter TRG-002 58X to 24X Trigger Conversion Module) uncertain if they have/use the same connectors on the computers but if they do you will need to get one for the 07 and have it VIN # programed for your car or nothing will work. Also possibly a crank re-learn too! |
Originally Posted by Ill_Born_ss
(Post 18644551)
Were any of the sensors changed form the 05 to the 07? The 05/06 uses a different computer than the 07+ The earlier engine has a 24x reluctor wheel and the 07+has a 58x wheel (there is a kit available to convert this, thus allowing you to use the 05 comp)(Lingenfelter TRG-002 58X to 24X Trigger Conversion Module) uncertain if they have/use the same connectors on the computers but if they do you will need to get one for the 07 and have it VIN # programed for your car or nothing will work. Also possibly a crank re-learn too! Thanks for the info |
can you confirm what type of ecm is currently installed in the car |
Without knowing what exactly has been done here (05 harness, sensors and such verses 07 harness and sensors) I have not verified pin for pin on the 2 different ECU`s (E40/E67 for both years and there communication with other modules. If you can use the 05 original E40 with (http://shop.proservsolutions.com/LIN...L460065397.htm) It may be your best option. Also remember the oil filters are different for both engines... do not use an 05/06 filter on the 07 engine |
Sounds like a nightmare to me sir. Best bet is going with 05 pcm as it is original to car and repinning any sensors or swapping them as appropriate. I would be concerned about the very issues Ill has mentioned...and then some... |
no you can not use that ecm.. you have to get the proper 2007 ecm for that car/engine... you can not use a 2005 or 2006 ecm, because they were different for the 2007 engines.. the controlling parameters/settings in the 2007/E67 ecm are different... so you have to get the correct 2007 E67 ecm for it... |
I am going to have to correct 06montess on this one because: - the 05/06 uses a body control module p/n 19300151 - the 07 uses body control module p/n 15942206 by using the 07 computer on the 05/06 it/they will not communicate with each other. the engine difference is the crankshaft position sensor on both engines the -05/06 uses a 24 tooth reluctor ring and its matching sensor -07 uses a 58 tooth reluctor ring and its matching sensor the camshaft sensors are the same on both but the cam gear on the 05/06 only has 1 pickup/phase, the 07 cam gear has 4 pickups/phase So using the unit I recommended directly plugs into those sensors and translates the 07 outputs to the required 05/06 parameters. the transmission control units are the same though the 07 uses an extra pin that the 05/06 does not (it is an extra ground) there is/ are some other small differences but to get you going in the right direction go with the 05/06 ECM and the unit recommended above. this is providing that the 05/06 engine harness was used with the 07 engine, in this case the crank sensor connector would not plug into the 07 crank sensor as it has a different connector. the camshaft sensor connector are the same. |
© 2024 MH Sub I, LLC dba Internet Brands
