Thermostat replacement
After reading many threads about replacing the thermostat I would appreciate some input from someone who has done it. I read the back bolt can be accessed using long extensions running behind the front manifold. Some say the heat shield needs to be removed to do this, some posts do not mention this at all. I will be flushing the system for the first time so I would like to do the thermostat at the same time as preventive maintenance. Also anyone still use the GM sealing tabs or some other product when doing this? I hear the job isn't fun so any input or tricks to make it any easier would be appreciated. Thanks in advance, its appreciated.
Thank you. That manifold is staying right where it is until this car is done with its daily driving duties and the motor and tranny come out(hopefully winter 2017 for a full rebuild/refresh) . If its that much of a pain the thermostat will have to wait until then. I had a hell of a time trying to get that black plastic cover off for the transmission cooler install so that isn't really an option either. Even the drain plug looks terrible to access so I'm hoping to flush removing the lower hose. Thoughts on that?
Ive always used the upper hose and a garden hose to flush.the refill with appropriate mix.If you dilute your own, use distilled water.the gm seal capsule are not needed.this was like a north star thing maybe few others.
Update on this. Did the thermostat and flush and fill, WAS NOT FUN! While getting the rear bolt out using extensions running behind the exhaust manifold works, its a complete mf getting the bolt back in. The bolt would just keep falling off the socket while trying as careful as could possibly be to snake it back in. I ended up using spray tack glue on the bolt and socket which held it on long enough to get it back on and threaded. Another fun piece of the puzzle is the spring clamps. There is just no room to get at them with anything, I ended up buying a set of spring clamp pliers and then it was easy to slid back on. One more fun fact is MR Gasket 180 degree thermostat part number 6368 does not fit, its too tall. It says it fit all 04 and newer ls/lq/and lm sb chevy motors(with separate water neck?), I thought that's what we have .So many posts say they are all the same, I guess they are not. I read a post here somewhere the guy said it took him 5 minutes to change his out, took me over 6 hours. These cars are no fun to work on. Some pics of the different height tsats and my makeshift extension. I had a longer extension, but it was too hard to work going under the manifold and I found having different lengths a tad easier. Glad its done
Well the pen magnet may have got the bolt there if it was over 2 feet long , but there is no room to get your hand in there so you really need a socket to start the threading. A post on a gto forum talked about this tsat , not sure why it didnt fit but it bottomed out. Maybe ours is somehow different. Wanted to do 180, threw in a Stant 187. Small difference I know but could have lowered cruising temps some . Any idea if a tech 2 scanner can program the fans on sooner? I have to get my car in for a recall and was thinking about asking about that if it does infact do that. Thanks
I wouldn't want it to run any cooler then what it already runs, kills efficiency that way. Honestly these cars run alot cooler then what my cobalt used to run, fans were programmed to turn on at 226 from the factory. lol I think in the amount of time it took you to do that thermostat i had most of the front end of the car disassembled. lol
LMAO ,Yea, I guess I should stop reading all the posts. Most of them them say to have the fans programmed thru a tune along with the trans. Post some of your progress, it seems slow here lately. How are you telling what the temp is actually, the gauge is useless for that?
laptop and the hptuners adapter cable, i use an inspiron 11 with a touch screen. Datalog the information I need and then make adjustments and upload a new tune. diablo standalone is crap, had one, didnt allow the kind of adjustment that you can have with hptuners and had numerous issues with it failing during writes and bricking the ECM.
Moderator
Nothing cuts the fans down from the 192 turn on fan temp. Unless you use a custom operating system which enables you to go from 163 and up. What you can adjust though is your fan percantage power at whatever tEmp after 192 you want.
I use a tablet mounted in the car with hp tuners. So much better than the laptop
