What's this in my plenum? Hey guys, I just finished changing plugs, wires, and valve cover gaskets on my 06 GXP. I noticed when I took the cover off the plenum there is a port in the middle of the plenum. I'm not sure if something goes here and if it's sucking air when the car is running because I have the battery out of it from doing several things. If something goes there I figure it can't be much since the cover sits on top pretty close. Not sure if this is the original plenum since I bought it used. Any info on this? I looked for pics of an LS4 plenum but had no luck. |
Originally Posted by pigsticker
(Post 18947806)
(Post 18947806)
Ok. I'll get a pic when I get home. Not really sure how to post it since I've never had to do it. |
thats the map sensor port, and the one to the right of that comes off the back valve cover with a vac hose |
1 Attachment(s) map sensor |
Since your a 06 you just need to move the map over to that location since it used to sit by the throttle body for all 05 06 ls4 vehicles |
So is he missing it ? |
91parkave is my map located somewhere else. I haven't noticed a wiring harness for it in that area in the picture. |
(Post 18948505)
Ok. I'll check it out. Thanks for the help. |
I've never seen a ls4 manifold with both locations for the map odd. |
Where do I need to look for my MAP sensor? Near my throttle body? |
Just leave it where it's at and plug the other port |
(Post 18948301)
https://cimg2.ibsrv.net/gimg/ls1tech...e533194eaa.jpg https://cimg3.ibsrv.net/gimg/ls1tech...3dfc2e1d54.jpg |
I took the vacuum line off when I was changing valve cover gaskets, plugs and wires. I got it in March and drove it home about 250 miles and did not have any codes to come up. |
I guess just look around and locate the map sensor, it has to be somewhere . Has to have a harness for it in that general area? |
Looks like the map is on the R/S of the pic. |
I just checked and it's right behind the throttle body. |
| All times are GMT -5. The time now is 03:53 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
