help needed with a few temps.
Hey guys, I need a little help verifying all my temps are correct. I recently got a aeroforce interceptor, and after a hour drive in 86 degree weather, trans temp went up to about 185 Max which I'm fine with( stage 3 TEP trans and Hayden 679 cooler.) But my oil temp is reading 220* (oil t calc) and my coolant temp is right around 200* . Battery voltage is between 12.5 and 14.5 while driving or at idle. I know voltage is off but the new alternator didn't help that. Any ideas as to if the rest of the temps are OK?
Thanks for any and all help.
Moderator
Since there is no actual oil temp sensor there calculated from various sources on what it might be. That is right about normal though. Also coolant is right where it should be for a stockish car. Voltage will always fluctuate depending on load on the charging system it is not steady state like old school systems are.
We have variable rate alternators, i initially panicked too first time testing my alternator and seeing it charging at 12.7v, soon as you put a load on it though it should begin to ramp up to a higher voltage. With my smaller battery and my fans being consistently on, i have seen voltages as high as 15v in the dead of the winter in sub 20 degree weather. 185* is great for trans temps, even with my trans cooler i can see upwards of 210* from my high stall. Part of the reason im going with a dex3/racing atf mix this month.
The only real way to test is to put a high load on the vehicle and test the amp output on the alternator wire, and see if you are getting near its rated output.
The voltages sound fine to me, the voltage will vary from 12.5 to 15. Normally after a long sit ,"few days" mine will charge 14.5 for roughly 45 minutes or so, then after that voltages are all over the place. The computer controls the pulse width modulation to the alternator to control its output, based on draw and the pwm to the alternator you will see voltages all through that range. The computer is also able to read amp draw etc, anyways.
with hptuners you can readjust the way the fans operate, and generally speaking unless your in a climate that see's sub zero temps frequently during the winter, a 70 water 30 antifreeze mix with water wetter or purple ice will net you at least 10-20 degrees cooler on average.
