LS4 Thrown Rod - Options/Routes to take
I threw a rod in my LS4 somehow and I want to fix it but I'm new to the LS/V8 world and never dealt with anything like this. I plan on removing DOD, Upgrading the cam, Upgrading my transmission and Tuning it. What are my options? Bearings? Machine shop? What route would I have?
I would seriously consider the condition and value of that car before you spend anything, to do what you want correctly will be costly if you are paying to have all the work done. Bare minimum would be turn the crank with new bearings and upgrade the oiling system as something probably failed if this happened at 124k. You make no mention of budget, but everything will add up quickly.
You need to figure out why it threw the rod and what other damage it caused. A friend had a stuck open injector hydro lock cyl 4, snapped a rod and windowed the block. He was hoping to just replace the piston and rod before he found the hole in the block, now he is looking at an engine replacement.
Your issue could be deeper than just a broken rod. I would figure out what you have before putting together any plans to repair.
Well the value of the car needing a motor is much less than 8k, that's my point. It would be very easy to add 5 grand plus to fix this, and the value would still be around 8k. If you are someone who keeps a car for a long time , it will even out. Consider and spend wisely.
Nice well do you have an engine lift and stand? I'm gonna assume you've got all the other stuff to do the job.
Might as well get out there and get to work. Just bag and tag everything. See what's going on in the engine at least. Pull the valve covers first and see if you can find a clue.
What makes you say purge canister?
I thought it was purge solenoid and charcoal canister..
