impala ss tire pressure sensor question
im tring to figure out how the tire pressure sensor system works (mine keeps breaking) do you all have any infor on where all the parts are located and how it all works together?
thanks!
-john
thanks!
-john
they're not that accurate (false readings/warnings) mine went off a couple of times when it was new (less than 500mi) none since, my bro's Explorer (04) always says something is low, all over 35psi!, there's bands around the rim with a pressure sensor attached and a remote signal is sent to a module/comp. also my mother's Century 02'(thank god she got rid of that POS) used to do it and my father's TL a couple false alarms as well. Like getting aDVD player when they first came out, yeah it works but a year later they can do 10X what they did before (MP3's, Pic Disks, CDR's)
The tire pressure monitor system on the W-bodies doesn't use actual pressure sensors. The computer monitors the signals from the wheel sensors that the ABS, Traction control and Stabilitrak systems use, and if it detects that one wheel is rotating faster than the rest consistently, it will activate the tire pressure warning. A low tire means a smaller rolling diameter, which means a slightly faster rotation. If it keeps setting after you reset it, you should contact the dealer.
I'd say the dealer is part of the problem then. If the tires are all at the same pressure, it's been reset, and still goes off, then there's definitely a problem. If the dealer can't figure it out, find a dealer who can.
the new cars do use the sensors, they're reset by entering the relearn mode(holding the lock and unlock buttons on the key fob)and then learning the sensors, u can do this two ways. first is to use the gm hand held tim tool, which u wont have or u can decrease the pressures in the tires starting at the lf and working clockwise, lowinging the pressure in each tire until you hear the car honk. do this on all 4 tires. oh yeah when u hold the key fob buttons down veh must be in run and you will hear it honk
