LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LS4 Performance (https://ls1tech.com/forums/ls4-performance-108/)
-   -   problem with the SS's radios (https://ls1tech.com/forums/ls4-performance/483939-problem-sss-radios.html)
kissmyss03 Apr 6, 2006 05:47 PM
hey impalas and monte owners:
if you have the amplified 8 speaker system, do u notice the fuzz noise from speakers. go in your car, close windows and turn radio all the way down then up one or two notches. there is a reprogram on SI for it but it didnt work for my bosses impala so we didnt try it on my car yet.
ecl1pz Apr 25, 2006 01:24 AM
Hey
I made a lot of comments about this on gminsider forums. If you put the volume at 0, you hear no hiss from the tweaters, and if you go 1 + you can hear it. Thats the reason I didn't get the sound system. There shouldn't be a fix via software for this problem because I believe its an amplifer issue. Did you notice the weird sounds when you have the volume down when playing a cd, which you don't hear when playing the radio :P....
As for the bose system, I emailed and sent requests to GM since July last year and they said they woud look into it (Laugh)... but maybe a software fix would fix it, but from all the reprograms I saw from tisweb, none directly make any refrence to that problem.
BuffaloSS May 1, 2006 02:19 PM
I didn't get the BOSE, and i need to have the radio at 1/2 volume to listen to it normally...and no, i don't think i have bad hearing. Anything less than 1/2 generally will not overcome the ambient noise (with windows closed).
© 2026 MH Sub I, LLC dba Internet Brands
