LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LS4 Performance (https://ls1tech.com/forums/ls4-performance-108/)
-   -   Tire Size's? (https://ls1tech.com/forums/ls4-performance/862354-tire-sizes.html)
gpdscott Feb 11, 2008 08:16 PM
Tire Size's?
Has anyone put wider tires on their Monte Carlo SS or Impala SS ?, and if so , what size ?:confused::confused:
Corny40 Feb 12, 2008 12:11 AM
I've got 255/35/20's. Some have gone with 245/35/20's.
You could also go 255/45/18's or 245/45/18's.
Or 255/40/19's or 245/40/19's.
BuffaloSS Feb 12, 2008 07:53 AM
The 255's are a closer match, speedo-wise. They're within .8% of the stock size yet provide a 3/4" wider footprint...which results in the speedo being off .4mph @ 60. The 245's are off by 2% (still within acceptable limits), and result in a 2.1mph difference at that speed.
HOWever, it's not recommended to put the 255 on the stock wheels, as they're designed to install on an 8"-9.5" wide wheel. The 245's can mount on a 7.5-9" wheel. IIRC, ours are 7.5"? Or are they just 7"? If it's the latter, going with the 245s would be a stretch (both literally and figuratively), and may cause the sidewalls to bubble outward a bit and look funny.
I guess someone who has done the 245's needs to speak up about how they've held up, as what I posted is just technical information with no real-world results.
gpdscott Feb 12, 2008 09:27 PM
Thanks guy's, is there a problem with them rubbing on the rear with that size tire's? and stock wheels?
Corny40 Feb 17, 2008 05:46 PM
With the 255s, sometimes yes. I had to roll my fenders. Some have not had to.
© 2026 MH Sub I, LLC dba Internet Brands
